path: root/drivers/gpio/gpio-wm8350.c
2013-08-16gpio: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-11-28gpio: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Peter Tyser <ptyser@xes-inc.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28gpio: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Kevin Hilman <khilman@ti.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28gpio: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Peter Tyser <ptyser@xes-inc.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-04gpio: wm8350: Convert to use devm_kzalloc APIAxel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-06-06gpio: reorganize driversGrant Likely
Sort the gpio makefile and enforce the naming convention gpio-*.c for gpio drivers. v2: cleaned up filenames in Kconfig and comment blocks v3: fixup use of BASIC_MMIO to GENERIC_GPIO for mxc Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
