[ Upstream commit a51b2fb94b04ab71e53a71b9fad03fa826941254 ]
Return value of "pm_runtime_get_sync" API was neither captured nor checked.
Fixed it by capturing the return value and then checking for any warning.
Addresses-Coverity: "check_return"
Signed-off-by: Srinivas Neeli <srinivas.neeli@xilinx.com>
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
The state container of the Zynq GPIO driver is sometimes
extracted from the gpio_chip exploiting the fact that offsetof()
the struct gpio_chip inside the struct zynq_gpio is 0, so
the container_of() is in practice a noop. However if a member
is added to struct zynq_gpio in front of struct gpio_chip,
things will break. Using proper container_of() avoids this
problem.
Semantically this is a noop, the compiler will optimize it away,
but syntactically it makes me happier.
Also replace some explicit container_of() calls with the helper
function.
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Ezra Savard <ezra.savard@xilinx.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Acked-by: Harini Katakam <harinik@xilinx.com>
Most interrupt flow handlers do not use the irq argument. Those few
which use it can retrieve the irq number from the irq descriptor.
Remove the argument.
Search and replace was done with coccinelle and some extra helper
scripts around it. Thanks to Julia for her help!
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
Linux 4.2-rc4
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into devel
Add missing pm_runtime_disabled to remove().
Error log:
root@zynqmp:~# modprobe gpio_zynq
root@zynqmp:~# lsmod
Not tainted
gpio_zynq 7086 0 - Live 0xffffffbffc00a000
root@zynqmp:~# rmmod gpio_zynq
Not tainted
[ 246.924438] zynq-gpio ff0a0000.gpio: Unbalanced pm_runtime_enable!
Not tainted
Reviewed-by: Alexandre Courbot <acourbot@nvidia.com>
This driver is tristate, so it should be cleanable.
Tested-by: Michal Simek <michal.simek@xilinx.com>
Use irq_desc_get_xxx() to avoid redundant lookup of irq_desc while we
already have a pointer to corresponding irq_desc.
Preparatory patch for the removal of the 'irq' argument from irq flow
handlers.
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Alexandre Courbot <gnurou@gmail.com>
Hand in irq_data and avoid the redundant lookup of irq_desc.
Originally-from: Jiang Liu <jiang.liu@linux.intel.com>
Added support to Zynq Ultrascale+ MPSoC on the existing zynq
gpio driver.
Signed-off-by: Anurag Kumar Vulisha <anuragku@xilinx.com>
Acked-by: Michal Simek <michal.simek@xilinx.com>
Fixed several spelling errors in gpio-lynxpoint, gpio-pca953x,
gpio-tegra, gpio-zynq, gpiolib-of, gpiolib.
Signed-off-by: Colin Cronin <colinpatrickcronin@gmail.com>
The SET_PM_RUNTIME_PM_OPS() and SET_RUNTIME_PM_OPS() macros are
identical except that one of them is not empty for CONFIG_PM set,
while the other one is not empty for CONFIG_PM_RUNTIME set,
respectively.
However, after commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if
PM_SLEEP is selected) PM_RUNTIME is always set if PM is set, so one
of these macros is now redundant.
For this reason, replace SET_PM_RUNTIME_PM_OPS() with
SET_RUNTIME_PM_OPS() everywhere and redefine the SET_PM_RUNTIME_PM_OPS
symbol as SET_RUNTIME_PM_OPS in case new code is starting to use the
macro being removed here.
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Acked-by: Kevin Hilman <khilman@linaro.org>
Some drivers accidentally still use the return value from
gpiochip_remove(). Get rid of them so we can simplify this function
and get rid of the return value.
Cc: Abdoulaye Berthe <berthe.ab@gmail.com>
Acked-by: Alexandre Courbot <acourbot@nvidia.com>
Acked-by: Javier Martinez Canillas <javier@dowhile0.org>
this remove all reference to gpio_remove retval in all driver
except pinctrl and gpio. the same thing is done for gpio and
pinctrl in two different patches.
Signed-off-by: Abdoulaye Berthe <berthe.ab@gmail.com>
Acked-by: Michael Büsch <m@bues.ch>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Use of unmask/mask in set_wake was an incorrect implementation. The new
implementation correctly sets wakeup for the gpio chip's IRQ so the gpio chip
will not sleep while wakeup-enabled gpio are in use.
Signed-off-by: Ezra Savard <ezra.savard@xilinx.com>
Reviewed-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
Added flag to the GPIO chip so that IRQ from non-wakeup GPIO will
not wake the system.
When looking up the IRQ the bank offset needs to be taken into account.
Otherwise interrupts for banks other than bank 0 get incorrectly reported as
interrupts for bank 0.
zynq_gpio_irqhandler() uses up to 7 tabs of indention in some parts. Refactor
things to use a helper function for the inner loop to reduce the indention to a
sane level.
There is no need to init .owner field.
Based on the patch from Peter Griffin <peter.griffin@linaro.org>
"mmc: remove .owner field for drivers using module_platform_driver"
This patch removes the superflous .owner field for drivers which
use the module_platform_driver API, as this is overriden in
platform_driver_register anyway."
The Zynq GPIO interrupt handling code as two main issues:
1) It does not support IRQF_ONESHOT interrupt since it uses handle_simple_irq()
for the interrupt handler. handle_simple_irq() does not do masking and unmasking
of the IRQ that is required for this chip to be able to support IRQF_ONESHOT
IRQs, causing the CPU to lock up in a interrupt storm if such a interrupt is
requested.
2) Interrupts are acked after the primary interrupt handlers for all asserted
interrupts in a bank have been called. For edge triggered interrupt this is to
late and may cause a interrupt to be missed. For level triggered oneshot
interrupts this is to early and causes the interrupt handler to run twice per
interrupt.
This patch addresses the issue by updating the driver to use the correct IRQ
chip handler functions that are appropriate for this kind of IRQ controller.
The following diagram gives an overview of how the interrupt detection circuit
works, it is not necessarily a accurate depiction of the real hardware though.
INT_POL/INT_ON_ANY
| +---+ INT_STATUS
| E |-. |
| +---+ `----| | ,-------|S | ,*--| |
GPIO_IN -* | |- | Q|- | & |-- IRQ_OUT
| +---+ ,-----| | ,-|R | ,o| |
,-| | INT_TYPE ACK INT_MASK
INT_POL
GPIO_IN is the raw signal level connected to the hardware pin. This signal is
routed to a edge detector and to a level detector. The edge detector can be
configured to either detect a rising or falling edge or both edges. The level
detector can detect either a level high or level low event. Depending on the
setting of the INT_TYPE register either the edge or level event will be
propagated to the INT_STATUS register. As long as a interrupt condition is
detected the INT_STATUS register will be set to 1. It can be cleared to 0 if
(and only if) the interrupt condition is no longer detected and software
acknowledges the interrupt by writing a 1 to the address of the INT_STATUS
register. There is also the INT_MASK register which can be used to disable the
propagation of the INT_STATUS signal to the upstream IRQ controller. What is
important to note is that the interrupt detection logic itself can not be
disabled, only the propagation of the INT_STATUS register can be delayed. This
means that for level type interrupts the interrupt must only be acknowledged
after the interrupt source has been cleared otherwise it will stay asserted and
the interrupt handler will be run a second time. For IRQF_ONESHOT interrupts
this means that the IRQ must only be acknowledged after the threaded interrupt
has finished running. If a second interrupt comes in between handling the first
interrupt and acknowledging it the external interrupt will be asserted, which
means trying to acknowledge the first interrupt will not clear the INT_STATUS
register and the interrupt handler will be run a second time when the IRQ is
unmasked, so no interrupts will be lost. The handle_fasteoi_irq() handler in
combination with the IRQCHIP_EOI_THREADED | IRQCHIP_EOI_IF_HANDLED flags will
have the desired behavior. For edge triggered interrupts a slightly different
strategy is necessary. For edge triggered interrupts the interrupt condition is
only true when the edge itself is detected, this means this is the only time the
INT_STATUS register is set, acknowledging the interrupt any time after that will
clear the INT_STATUS register until the next interrupt happens. This means in
order to not loose any interrupts the interrupt needs to be acknowledged before
running the interrupt handler. If a second interrupt occurs after the first
interrupt handler has finished but before the interrupt is unmasked the
INT_STATUS register will be re-asserted and the interrupt handler runs a second
time once the interrupt is unmasked. This means with this flow handling strategy
no interrupts are lost for edge triggered interrupts. The handle_level_irq()
handler will have the desired behavior. (Note: The handle_edge_irq() only needs
to be used for edge triggered interrupts where the controller stops detecting
the interrupt event when the interrupt is masked, for this controller the
detection logic still works, while only the propagation is delayed when the
interrupt is masked.)
Acked-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
The Zynq GPIO controller does not disable the interrupt detection when the
interrupt is masked and only disables the propagation of the interrupt. This
means when the controller detects an interrupt condition while the interrupt is
logically disabled (and masked) it will propagate the recorded interrupt event
once the interrupt is enabled. This will cause the interrupt consumer to see
spurious interrupts to prevent this first make sure that the interrupt is not
asserted and then enable it.
E.g. when a interrupt is requested with request_irq() it will be configured
according to the requested type (edge/level triggered, etc.) after that it will
be enabled. But the detection circuit might have already registered a false
interrupt before the interrupt type was correctly configured and once the
interrupt is unmasked this false interrupt will be propagated and the interrupt
handler for the just request interrupt will called.
Add support for GPIO controller used by Xilinx Zynq.
v3 changes:
- Use linux/gpio/driver.h instead of linux/gpio.h
- Make irq a local variable in probe
v2 changes:
- convert to pm_runtime_force_(suspend|resume)
- add pm_runtime_set_active in probe()
- also (un)prepare clocks when they are dis-/enabled
- add some missing calls to pm_runtime_get()
- use pm_runtime_put() instead of sync variant
- remove gpio chip in driver remove()
- remove redundant type casts
- directly use IO helpers
- use BIT macro to set/clear bits
- migrate to GPIOLIB_IRQCHIP
Signed-off-by: Harini Katakam <harinik@xilinx.com>
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
