path: root/drivers/gpio/langwell_gpio.c
2011-01-13gpio: langwell_gpio: irq_data conversionLennert Buytenhek
Converts irq_chips and flow handlers over to the new struct irq_data based irq_chip functions. Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Cc: Alan Cox <alan@linux.intel.com> Cc: Yin Kangkai <kangkai.yin@intel.com> Cc: Alek Du <alek.du@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27langwell_gpio: add support for whitney pointAlan Cox
In this case the logic is very similar but the IRQs are not exposed and the device is not picked up via PCI Based on a separate internal whitney point driver by Yin Kangkai. Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: Yin Kangkai <kangkai.yin@intel.com> Cc: Alek Du <alek.du@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27drivers/gpio/langwell_gpio.c: remove semicolons after function definitionsAndrew Morton
Deweird this driver. Cc: Alek Du <alek.du@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27gpio: add Penwell gpio supportAlek Du
Intel Penwell chip has two 96 pins GPIO blocks, which are very similiar as Intel Langwell chip GPIO block, except for pin number difference. This patch expends the original Langwell GPIO driver to support Penwell's. Signed-off-by: Alek Du <alek.du@intel.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-16gpio: fix test on unsigned in lnw_irq_type()Roel Kluin
The wrong test was used, gpio is unsigned and it had an off-by-one. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Alek Du <alek.du@intel.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-01gpio: Langwell GPIO driver bugfixesAlek Du
- Remove wrong and unnecessary unmask operation - Remove extra GEDR reading This fixes the loss of interrupts which occurs when two or more pins are triggered in close succession. Signed-off-by: Alek Du <alek.du@intel.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23gpio: add Intel Moorestown Platform Langwell chip gpio driverAlek Du
The Langwell chip is the IO hub for Intel Moorestown platform which has a 64-pin gpio block device inside. It is exposed as a dedicated PCI device. We use it to control outside peripheral as well as to do IRQ demuxing. The gpio block uses MSI to send level type interrupt to IOAPIC. Signed-off-by: Alek Du <alek.du@intel.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
