path: root/drivers/gpio/pca953x.c
2008-05-24gpio: pca953x driver handles pca9554 tooDavid Brownell
Teach drivers/gpio/pca953x.c about PCA9554, another compatible chip. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01gpio: pca953x: add support for pca9555 I2C I/O expanderWill Newton
Add support for pca9555 I2C I/O expander. As the comment suggests this part is software compatible with the pca9539. Signed-off-by: Will Newton <will.newton@imgtec.com> Cc: "eric miao" <eric.miao@marvell.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29i2c: Convert most new-style drivers to use module aliasingJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. Update most new-style i2c drivers to use standard module aliasing instead of the old driver_name/type driver matching scheme. I've left the video drivers apart (except for SoC camera drivers) as they're a bit more diffcult to deal with, they'll have their own patch later. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Jochen Friedrich <jochen@scram.de>
2008-04-29i2c: Add support for device alias namesJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. This patch allows new-style i2c chip drivers to have alias names using the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this point, the old i2c driver binding scheme (driver_name/type) is still supported. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jochen Friedrich <jochen@scram.de> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org>
2008-04-28gpiolib: i2c/spi drivers: handle rmmod betterGuennadi Liakhovetski
Use the newly introduced owner field in struct gpio_chip to protect the current (small) set of non-SOC GPIO drivers from being unloaded while any of their GPIOs are in use. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> [ add mcp23s08 and pcf857x ] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10gpio/pca953x bugfix: mark as can_sleepArnaud Patard
The pca953x driver is an I2C driver so gpio_chip->can_sleep should be set. This lets upper layers know they should use the gpio_*_cansleep() calls to access values, and may not access them from nonsleeping contexts. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: "eric miao" <eric.y.miao@gmail.com> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06gpio: handle pca953{4,5,6,7,8} tooGuennadi Liakhovetski
This third part of an extension to support more pca953x chips updates the logic to handle the smaller register widths used by the 4-bit and 8-bit parts, and to use the chip type to determine how many GPIOs it provides. As long as we don't support interrupt and reset capabilities, those size issues are the only software-visible differences between these parts. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06gpio: rename pca953x symbolsGuennadi Liakhovetski
This second part of an extension to support more pca953x chips renames the C and Kconfig symbols. All affected files were updated by sed, except for a couple of obvious exceptions. It also updates the Kconfig helptext. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06gpio: rename pca9539 driverGuennadi Liakhovetski
First part of an extension to let the pca9539 driver support more chips, starting with pca9534, pca9535, pca9536, pca9537, and pca9538. This renames the files and modifies the Makefile. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
