path: root/drivers/gpio/pl061.c
2010-07-27ARM: Fix section build warnings for AMBA driversRussell King
Found in the Versatile build: WARNING: drivers/built-in.o(.data+0x14c): Section mismatch in reference from the variable pl061_gpio_driver to the (unknown reference) .init.data:(unknown) The variable pl061_gpio_driver references the (unknown reference) __initdata (unknown) WARNING: drivers/built-in.o(.data+0x40f8): Section mismatch in reference from the variable pl011_driver to the (unknown reference) .init.data:(unknown) The variable pl011_driver references the (unknown reference) __initdata (unknown) WARNING: drivers/built-in.o(.data+0x5ab4): Section mismatch in reference from the variable pl031_driver to the (unknown reference) .init.data:(unknown) The variable pl031_driver references the (unknown reference) __initdata (unknown) Basically, amba_id structures must not be __initdata. Also fix: WARNING: drivers/built-in.o(.data+0x138): Section mismatch in reference from the variable pl061_gpio_driver to the function .init.text:pl061_probe() The variable pl061_gpio_driver references the function __init pl061_probe() which is an incorrectly annotated probe function. Fix it to reflect the other AMBA bus probe functions by removing the __init attributation. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-27pl061: fix offset value range checkingAxel Lin
The valid offset value is 0..PL061_GPIO_NR-1, this patch corrects the offset value range checking. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-29ARM: 6061/1: PL061 GPIO: Bug fix - setting gpio for HIGH_LEVEL interrupt is ↵viresh kumar
not working. In current implementation of PL061, setting type of irq to HIGH_LEVEL is not working. This patch fixes this bug. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-04-22ARM: 6060/1: PL061 GPIO: Setting gpio val after changing direction to OUT.viresh kumar
pl061_direction_output doesn't set value of gpio to value passed to it. This patch sets value of GPIO pin to requested value after changing direction to OUT. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-04-22ARM: 6059/1: PL061 GPIO: Changing *_irq_chip_data with *_irq_data for real irqs.viresh kumar
PL061 driver is using set_irq_chip_data and get_irq_chip_data for real irq lines. It must be using *_irq_data functions instead. As chip_data is used by interrupt controllers also, which makes vic write at incorrect addresses. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-06bitops: rename for_each_bit() to for_each_set_bit()Akinobu Mita
Rename for_each_bit to for_each_set_bit in the kernel source tree. To permit for_each_clear_bit(), should that ever be added. The patch includes a macro to map the old for_each_bit() onto the new for_each_set_bit(). This is a (very) temporary thing to ease the migration. [akpm@linux-foundation.org: add temporary for_each_bit()] Suggested-by: Alexey Dobriyan <adobriyan@gmail.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Artem Bityutskiy <dedekind@infradead.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30gpio: pl061: fix IRQ handling for GPIOs >= PL061_GPIO_NRBaruch Siach
IRQ handling is wrong for any GPIO >= PL061_GPIO_NR. Fix this by implementing and using a proper .to_irq method. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30gpio: pl061: fix probe error handling codeBaruch Siach
Note that IRQ has not been initialized when kmalloc() fails. Also, use DECLARE_BITMAP() to make the code clearer. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-19gpio: driver for PrimeCell PL061 GPIO controllerBaruch Siach
This is a driver for the ARM PrimeCell PL061 GPIO AMBA peripheral. The driver is implemented using the gpiolib framework. This driver also includes support for the use of the PL061 as an interrupt controller (secondary). Signed-off-by: Baruch Siach <baruch@tkos.co.il> Cc: David Brownell <david-b@pacbell.net> Acked-by: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
