path: root/drivers/gpio
2010-10-29gpio: Add VIA VX855 GPIO driverDaniel Drake
This is needed for supporting the upcoming VX855 camera and OLPC DCON drivers, as well as the advanced viafb features on non-OLPC hardware based on this chip. Based on earlier work by Harald Welte. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29gpio: Fix stmpe error pathVasiliy Kulikov
Free allocated memory. Call stmpe_disable() if it was enabled. Signed-off-by: Vasiliy Kulikov <segooon@gmail.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29gpio: Handle stmpe-gpio platform data with no gpio baseVirupax Sadashivpetimath
This patch removes the requirement that gpio base be supplied in platform data. Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29gpio: Add bitmask to block requests to unavailable stmpe GPIOsWolfram Sang
GPIOs on these controller are multi-functional. If you decided to use some of them e.g. as input channels for the ADC, you surely don't want those pins to be reassigned as simple GPIOs (which may be triggered even from userspace via 'export'). Same for the touchscreen controller pins. Since knowledge about the hardware is needed to decide which GPIOs to reserve, let this bitmask be inside platform_data and provide some defines to assist potential users. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Rabin Vincent <rabin.vincent@stericsson.com> Cc: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29gpiolib: Hook up WM8994 gpio_to_irq()Mark Brown
Not sure where this went. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-27langwell_gpio: add support for whitney pointAlan Cox
In this case the logic is very similar but the IRQs are not exposed and the device is not picked up via PCI Based on a separate internal whitney point driver by Yin Kangkai. Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: Yin Kangkai <kangkai.yin@intel.com> Cc: Alek Du <alek.du@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27drivers/gpio/langwell_gpio.c: remove semicolons after function definitionsAndrew Morton
Deweird this driver. Cc: Alek Du <alek.du@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27gpio: add Topcliff PCH GPIO driverTomoya MORINAGA
Topcliff PCH is the platform controller hub that is going to be used in Intel's upcoming general embedded platform. All IO peripherals in Topcliff PCH are actually devices sitting on AMBA bus. Topcliff PCH has GPIO I/F. Using this I/F, it is able to access system devices connected to GPIO. [akpm@linux-foundation.org: ese DEFINE_PCI_DEVICE_TABLE (per Joe Perches)] Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Rabin Vincent <rabin.vincent@stericsson.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Linus Walleij <linus.walleij@stericsson.com> Cc: Tomoya MORINAGA <morinaga526@dsn.okisemi.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27gpio: adp5588-gpio: support interrupt controllerMichael Hennerich
Implement irq_chip functionality on ADP5588/5587 GPIO expanders. Only level sensitive interrupts are supported. Interrupts provided by this irq_chip must be requested using request_threaded_irq(). Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27gpio: add support for 74x164 serial-in/parallel-out 8-bit shift registerMiguel Gaio
Add support for generic 74x164 serial-in/parallel-out 8-bits shift register. This driver can be used as a GPIO output expander. [akpm@linux-foundation.org: remove unused local `refresh'] Signed-off-by: Miguel Gaio <miguel.gaio@efixo.com> Signed-off-by: Juhos Gabor <juhosg@openwrt.org> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27gpio: timbgpio: use a copy of the IER register to avoid it being trashedTomas Hallenberg
Some versions of the hardware can trash the IER register if simultaneous interrupts occur. This patch works around it by using a local copy of the register and restoring it after every interrupt. Signed-off-by: Tomas Hallenberg <tomas.hallenberg@pelagicore.com> Acked-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27gpio: add driver for basic memory-mapped GPIO controllersAnton Vorontsov
The basic GPIO controllers may be found in various on-board FPGA and ASIC solutions that are used to control board's switches, LEDs, chip-selects, Ethernet/USB PHY power, etc. These controllers may not provide any means of pin setup (in/out/open drain). The driver supports: - 8/16/32/64 bits registers; - GPIO controllers with clear/set registers; - GPIO controllers with a single "data" register; - Big endian bits/GPIOs ordering (mostly used on PowerPC). Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: David Brownell <david-b@pacbell.net> Cc: Samuel Ortiz <sameo@linux.intel.com>, Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26pca953x: pca953x driver fixes for x86 mrstAlek Du
Our Moorestown platform has two max7315 chips which is covered by pca953x i2c gpio driver. A while ago this driver got updated with nested irq thread support, and it broke the compatibity with "request_irq". For example, the gpio_keys.c driver can not work with this driver now. This patch fixes the issue by switching to generic_handle_irq. Also fix the irq_base issue: irq_base == 0 is valid, and a "-1" value should mean invalid. IRQ 0 is not a valid IRQ, irq_base of 0 is valid. Signed-off-by: Alek Du <alek.du@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: mtd/m25p80: add support to parse the partitions by OF node of/irq: of_irq.c needs to include linux/irq.h of/mips: Cleanup some include directives/files. of/mips: Add device tree support to MIPS of/flattree: Eliminate need to provide early_init_dt_scan_chosen_arch of/device: Rework to use common platform_device_alloc() for allocating devices of/xsysace: Fix OF probing on little-endian systems of: use __be32 types for big-endian device tree data of/irq: remove references to NO_IRQ in drivers/of/platform.c of/promtree: add package-to-path support to pdt of/promtree: add of_pdt namespace to pdt code of/promtree: no longer call prom_ functions directly; use an ops structure of/promtree: make drivers/of/pdt.c no longer sparc-only sparc: break out some PROM device-tree building code out into drivers/of of/sparc: convert various prom_* functions to use phandle sparc: stop exporting openprom.h header powerpc, of_serial: Endianness issues setting up the serial ports of: MTD: Fix OF probing on little-endian systems of: GPIO: Fix OF probing on little-endian systems
2010-10-18Merge branches 'at91', 'dcache', 'ftrace', 'hwbpt', 'misc', 'mmci', 's3c', ↵Russell King
'st-ux' and 'unwind' into devel
2010-09-29of: GPIO: Fix OF probing on little-endian systemsMichal Simek
DTB is always big-endian that's why is necessary to convert it. Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-09-19ARM: 6373/1: tc35892-gpio: add setup/remove callbacksRabin Vincent
For board-specific initialization. Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: linux-kernel@vger.kernel.org Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-09gpio: sx150x: correct and refine reset-on-probe behaviorGregory Bean
Replace the arbitrary software-reset call from the device-probe method, because: - It is defective. To work correctly, it should be two byte writes, not a single word write. As it stands, it does nothing. - Some devices with sx150x expanders installed have their NRESET pins ganged on the same line, so resetting one causes the others to reset - not a nice thing to do arbitrarily! - The probe, usually taking place at boot, implies a recent hard-reset, so a software reset at this point is just a waste of energy anyway. Therefore, make it optional, defaulting to off, as this will match the common case of probing at powerup and also matches the current broken no-op behavior. Signed-off-by: Gregory Bean <gbean@codeaurora.org> Reviewed-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12gpiolib: Implement set_debounce for WM831x GPIOsMark Brown
The debounce times are approximate, they can be selected using the two input functions. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-08-12gpio: Add STMPE GPIO driverRabin Vincent
Add support for the GPIOs on STMPE I/O Expanders. [l.fu@pengutronix.de: fix set direction input] [l.fu@pengutronix.de: set GPIO alternate function while requesting] Acked-by: Luotao Fu <l.fu@pengutronix.de> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-08-11gpio: sx150x: add Semtech I2C sx150x gpio expander driverGregory Bean
Add support for Semtech SX150-series I2C GPIO expanders. Compatible models include: 8 bits: sx1508q 16 bits: sx1509q Signed-off-by: Gregory Bean <gbean@codeaurora.org> Cc: David Brownell <david-b@pacbell.net> Cc: Jean Delvare <khali@linux-fr.org> Cc: Trilok Soni <tsoni@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11gpiolib: allow nested threaded irqs for poll(2)Daniel Gl?ckner
The pca953x driver requires the use of threaded irqs as its irq demultiplexer can sleep. Our irq handler can be called from any context, so use request_any_context_irq to allow threaded irqs as well. Signed-off-by: Daniel Gl?ckner <dg@emlix.com> Reported-by: Ian Jeffray <ian@jeffray.co.uk> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11gpiolib: get rid of struct poll_desc and workletDaniel Gl?ckner
As sysfs_notify_dirent has been made irq safe, there is no reason to not call it directly from irq. With the work_struct removed, the remaining element in poll_desc is a sysfs_dirent pointer which may not be NULL. We can therefore store it directly in the idr and pass it as context to the irq handler. Most part of the patch deals with renaming defines and variables to reflect their new use without functional change. I also took the opportunity to initialize the idr statically. Signed-off-by: Daniel Gl?ckner <dg@emlix.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11gpiolib: decouple might_sleep_if() from DEBUGDavid Brownell
Be more consistent about runtime programming interface abuse warnings, which can reduce some confusion and trigger bugfixes. Based on an observation and patch from Jani Nikula. Also update doc to highlight some sleeping-call issues and to match some recent changes. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Jani Nikula <ext-jani.1.nikula@nokia.com> Cc: "Ryan Mallon" <ryan@bluewatersys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11pcf857x: support working w/o platform dataDmitry Eremin-Solenikov
Provide sane defaults for pcf857x, so the driver can be used w/o providing platform data (and thus can be simply bound via OF tree). Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <david-b@pacbell.net> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11gpio: max730x: make pullups configurable via platformdataMarc Kleine-Budde
The gpios on the max730x chips have support for internal pullups while in input mode. This patch adds support for configuring these pullups via platform data. A new member ("input_pullup_active") to the platform data struct is introduced. A set bit in this variable activates the pullups while the respective port is in input mode. This is a compatible enhancement since unset bits lead to disables pullups which was the default in the original driver. _Note_: the 4 lowest bits in "input_pullup_active" are unused because the first 4 ports of the controller are not used, too. Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-05Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: (63 commits) of/platform: Register of_platform_drivers with an "of:" prefix of/address: Clean up function declarations of/spi: call of_register_spi_devices() from spi core code of: Provide default of_node_to_nid() implementation. of/device: Make of_device_make_bus_id() usable by other code. of/irq: Fix endian issues in parsing interrupt specifiers of: Fix phandle endian issues of/flattree: fix of_flat_dt_is_compatible() to match the full compatible string of: remove of_default_bus_ids of: make of_find_device_by_node generic microblaze: remove references to of_device and to_of_device sparc: remove references to of_device and to_of_device powerpc: remove references to of_device and to_of_device of/device: Replace of_device with platform_device in includes and core code of/device: Protect against binding of_platform_drivers to non-OF devices of: remove asm/of_device.h of: remove asm/of_platform.h of/platform: remove all of_bus_type and of_platform_bus_type references of: Merge of_platform_bus_type with platform_bus_type drivercore/of: Add OF style matching to platform bus ... Fix up trivial conflicts in arch/microblaze/kernel/Makefile due to just some obj-y removals by the devicetree branch, while the microblaze updates added a new file.
2010-07-31Merge branch 'misc' into develRussell King
Conflicts: arch/arm/mm/init.c
2010-07-27gpio: fix spurious printk when freeing a gpioJon Povey
When freeing a gpio that has not been exported, gpio_unexport() prints a debug message when it should just fall through silently. Example spurious message: gpio_unexport: gpio0 status -22 Signed-off-by: Jon Povey <jon.povey@racelogic.co.uk> Cc: David Brownell <david-b@pacbell.net> Acked-by: Uwe Kleine-K?nig <u.kleine-koenig@pengutronix.de> Cc: Gregory Bean <gbean@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-27ARM: Fix section build warnings for AMBA driversRussell King
Found in the Versatile build: WARNING: drivers/built-in.o(.data+0x14c): Section mismatch in reference from the variable pl061_gpio_driver to the (unknown reference) .init.data:(unknown) The variable pl061_gpio_driver references the (unknown reference) __initdata (unknown) WARNING: drivers/built-in.o(.data+0x40f8): Section mismatch in reference from the variable pl011_driver to the (unknown reference) .init.data:(unknown) The variable pl011_driver references the (unknown reference) __initdata (unknown) WARNING: drivers/built-in.o(.data+0x5ab4): Section mismatch in reference from the variable pl031_driver to the (unknown reference) .init.data:(unknown) The variable pl031_driver references the (unknown reference) __initdata (unknown) Basically, amba_id structures must not be __initdata. Also fix: WARNING: drivers/built-in.o(.data+0x138): Section mismatch in reference from the variable pl061_gpio_driver to the function .init.text:pl061_probe() The variable pl061_gpio_driver references the function __init pl061_probe() which is an incorrectly annotated probe function. Fix it to reflect the other AMBA bus probe functions by removing the __init attributation. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-24Merge commit 'v2.6.35-rc6' into devicetree/nextGrant Likely
Conflicts: arch/sparc/kernel/prom_64.c
2010-07-20Andres has movedAndres Salomon
My Collabora address is no longer enabled - update the MODULE_AUTHOR fields of drivers to my current email address. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-05of/gpio: add default of_xlate function if device has a node pointerAnton Vorontsov
Implement generic OF gpio hooks and thus make device-enabled GPIO chips (i.e. the ones that have gpio_chip->dev specified) automatically attach to the OpenFirmware subsystem. Which means that now we can handle I2C and SPI GPIO chips almost* transparently. * "Almost" because some chips still require platform data, and for these chips OF-glue is still needed, though with this change the glue will be much smaller. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Bill Gatliff <bgat@billgatliff.com> Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jean Delvare <khali@linux-fr.org> Cc: Andrew Morton <akpm@linux-foundation.org> CC: linux-kernel@vger.kernel.org CC: devicetree-discuss@lists.ozlabs.org
2010-07-05of/gpio: stop using device_node data pointer to find gpio_chipGrant Likely
Currently the kernel uses the struct device_node.data pointer to resolve a struct gpio_chip pointer from a device tree node. However, the .data member doesn't provide any type checking and there aren't any rules enforced on what it should be used for. There's no guarantee that the data stored in it actually points to an gpio_chip pointer. Instead of relying on the .data pointer, this patch modifies the code to add a lookup function which scans through the registered gpio_chips and returns the gpio_chip that has a pointer to the specified device_node. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> CC: Andrew Morton <akpm@linux-foundation.org> CC: Anton Vorontsov <avorontsov@ru.mvista.com> CC: Grant Likely <grant.likely@secretlab.ca> CC: David Brownell <dbrownell@users.sourceforge.net> CC: Bill Gatliff <bgat@billgatliff.com> CC: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: Jean Delvare <khali@linux-fr.org> CC: linux-kernel@vger.kernel.org CC: devicetree-discuss@lists.ozlabs.org
2010-07-05of/gpio: Kill of_gpio_chip and add members directly to gpio_chipAnton Vorontsov
The OF gpio infrastructure is great for describing GPIO connections within the device tree. However, using a GPIO binding still requires changes to the gpio controller just to add an of_gpio structure. In most cases, the gpio controller doesn't actually need any special support and the simple OF gpio mapping function is more than sufficient. Additional, the current scheme of using of_gpio_chip requires a convoluted scheme to maintain 1:1 mappings between of_gpio_chip and gpio_chip instances. If the struct of_gpio_chip data members were moved into struct gpio_chip, then it would simplify the processing of OF gpio bindings, and it would make it trivial to use device tree OF connections on existing gpiolib controller drivers. This patch eliminates the of_gpio_chip structure and moves the relevant fields into struct gpio_chip (conditional on CONFIG_OF_GPIO). This move simplifies the existing code and prepares for adding automatic device tree support to existing drivers. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Bill Gatliff <bgat@billgatliff.com> Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jean Delvare <khali@linux-fr.org>
2010-07-05gpiolib: cosmetic improvements for error handling in gpiochip_add()Anton Vorontsov
Hopefully it makes the code look nicer and makes it easier to extend this function. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> CC: devicetree-discuss@lists.ozlabs.org CC: linux-kernel@vger.kernel.org
2010-06-29drivers/gpio is platform-neutralDavid Brownell
Update Kconfig and Makefile in drivers/gpio to discourage inappropriate addition of platform-specific code. [akpm@linux-foundation.org: fix tpyo] Signed-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-28gpio: Fix inverted rdc321x gpio data out registersFlorian Fainelli
rdc_gpio_set_value_impl has the gpio data registers 1 and 2 inverted, fix this. Signed-off-by: Bernhard Loos <bernhardloos@gmail.com> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Change rdc321x resources flags to IORESOURCE_IOFlorian Fainelli
The rdc321x southbridge PCI device has no MEM PCI resources that we could pass to mfd_add_devices. Since 33254dd5, mfd_add_device checks for the mem_base argument that we set to NULL. Changing the resources passed to our MFD cells from IORESOURCE_MEM to IORESOURCE_IO fixes that. Since we use those resources as offsets to the PCI configuration space base address of the southbridge device this is also more adequate. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28gpio: rdc321x needs to select MFD_CORERandy Dunlap
Fix rdc321x-southbridge build: GPIO_RDC321X needs to select MFD_CORE so that the core is built at the same (or higher) tristate level. rdc321x-southbridge.c:(.devinit.text+0x6103): undefined reference to `mfd_add_devices' rdc321x-southbridge.c:(.devexit.text+0xe5f): undefined reference to `mfd_remove_devices' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Florian Fainelli <florian@openwrt.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28gpio: Add TC35892 GPIO driverRabin Vincent
Add a GPIO driver to support the GPIOs on the TC35892 I/O Expander. Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28gpio: Update gfp/slab.h includes for rdc321xTejun Heo
Implicit slab.h inclusion via percpu.h is about to go away. Make sure gfp.h or slab.h is included as necessary. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-05-28gpio: Add support for Janz VMOD-TTL Digital IO moduleIra W. Snyder
The Janz VMOD-TTL is a MODULbus daughterboard which fits onto any MODULbus carrier board. It essentially consists of some various logic and a Zilog Z8536 CIO Counter/Timer and Parallel IO Unit. The board must be physically configured with jumpers to enable a user to drive output signals. I am only interested in outputs, so I have made this driver as simple as possible. It only supports a very minimal subset of the features provided by the Z8536 chip. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28gpio: Add support for RDC321x GPIO controllerFlorian Fainelli
This patch adds a new GPIO driver for the RDC321x SoC GPIO controller. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-27drivers/gpio/it8761e_gpio: check return value of gpiochip_remove()Daniel Mack
This eliminates the following build warning: drivers/gpio/it8761e_gpio.c: In function `it8761e_gpio_exit': drivers/gpio/it8761e_gpio.c:220: warning: ignoring return value of `gpiochip_remove', declared with attribute warn_unused_result Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Denis Turischev <denis@compulab.co.il> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27gpio: add Penwell gpio supportAlek Du
Intel Penwell chip has two 96 pins GPIO blocks, which are very similiar as Intel Langwell chip GPIO block, except for pin number difference. This patch expends the original Langwell GPIO driver to support Penwell's. Signed-off-by: Alek Du <alek.du@intel.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27gpiolib: introduce set_debounce methodFelipe Balbi
A few architectures, like OMAP, allow you to set a debouncing time for the gpio before generating the IRQ. Teach gpiolib about that. Mark said: : This would be generally useful for embedded systems, especially where : the interrupt concerned is a wake source. It allows drivers to avoid : spurious interrupts from noisy sources so if the hardware supports it : the driver can avoid having to explicitly wait for the signal to become : stable and software has to cope with fewer events. We've lived without : it for quite some time, though. David said: : I looked at adding debounce support to the generic GPIO calls (and thus : gpiolib) some time back, but decided against it. I forget why at this : time (check list archives) but it wasn't because of lack of utility in : certain contexts. : : One thing to watch out for is just how variable the hardware capabilities : are. Atmel GPIOs have something like a fixed number of 32K clock cycles : for debounce, twl4030 had something odd, OMAPs were more like the Atmel : chips but with a different clock. In some cases debouncing had to be : ganged, not per-GPIO. And so forth. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Cc: Tony Lindgren <tony@atomide.com> Cc: David Brownell <david-b@pacbell.net> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27gpiolib: make gpiochip_add() show a better error messageBen Dooks
The current message, 'not registered' is confusing as it implies it was not registered with something, whereas printing 'failed to register' implies it was the gpiochip_add() call that did not work correctly. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27gpio: max732x: fix input configuration for open-drain pinsMarc Zyngier
Fix a bug I noticed while hacking on the max732x driver for interrupt support. According to the datasheets, open-drain pins have to be configured as output-high (which in that case is actually high impedance) to be used as input. Signed-off-by: Marc Zyngier <maz@misterjones.org> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27max732x: correct nr_port checking off by one errorAxel Lin
Setup both client_group_a and client_group_b if nr_port > 8 (not including nr_port==8). Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Eric Miao <eric.miao@marvell.com> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
