path: root/drivers/gpio
2011-10-13gpio-pca953x: fix gpio_baseHartmut Knaack
gpio_base was set to 0 if no system platform data or open firmware platform data was provided. This led to conflicts, if any other gpiochip with a gpiobase of 0 was instantiated already. Setting it to -1 will automatically use the first one available. Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-10-13gpio/omap: fix build error with certain OMAP1 configsJanusz Krzysztofik
With commit f64ad1a0e21a, "gpio/omap: cleanup _set_gpio_wakeup(), remove ifdefs", access to build time conditionally omitted 'suspend_wakeup' member of the 'gpio_bank' structure has been placed unconditionally in function _set_gpio_wakeup(), which is always built. This resulted in the driver compilation broken for certain OMAP1, i.e., non-OMAP16xx, configurations. Really required or not in previously excluded cases, define this structure member unconditionally as a fix. Tested with a custom OMAP1510 only configuration. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Acked-by: Kevin Hilman <khilman@ti.com> Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-09-14drivers/gpio/gpio-generic.c: fix build errorsRussell King
Building a kernel with hotplug disabled results in a link failure: `bgpio_remove' referenced in section `___ksymtab_gpl+bgpio_remove' of drivers/built-in.o: defined in discarded section `.devexit.text' of drivers/built-in.o This is because of bgpio_remove() is exported. It is illegal to export symbols which are discarded either at link time or as part of an init/exit section. Fix this by dropping the __devexit attributation from bgpio_remove(). Also drop the __devinit attributation from bgpio_init(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-01Merge branch 'gpio/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'gpio/next' of git://git.secretlab.ca/git/linux-2.6: gpio_msm: Move Qualcomm MSM v2 gpio driver into drivers gpio_msm: Move Qualcomm v6 MSM driver into drivers msm: gpio: Fold register defs into C file msm: gpiomux: Move public API to public header msm: gpio: Remove ifdefs on gpio chip registers msm: gpio: Remove chip-specific register definitions msm: Remove chip-ifdefs for GPIO io mappings msm: gpio: Remove unsupported devices gpio: ab8500: fix MODULE_ALIAS for ab8500 of/gpio: export of_gpio_simple_xlate
2011-08-01Merge branch 'msm-move-gpio' of ↵Grant Likely
git://codeaurora.org/quic/kernel/davidb/linux-msm into gpio/next Conflicts: drivers/gpio/Kconfig drivers/gpio/Makefile
2011-08-01gpio_msm: Move Qualcomm MSM v2 gpio driver into driversDavid Brown
Migrate the driver for the v7-based MSM chips into drivers/gpio. The driver is unchanged, only moved. Change-Id: I810db5b50b71cdca4e869aa0d0310f7f48781a55 Signed-off-by: David Brown <davidb@codeaurora.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-08-01gpio_msm: Move Qualcomm v6 MSM driver into driversDavid Brown
Migrate the driver for the v6-based MSM chips into drivers/gpio. The driver is unchanged, only moved. Change-Id: I03ba597b95b4d62b42da112a8efac88d67aa40f9 Signed-off-by: David Brown <davidb@codeaurora.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-07-31tps65912: gpio: add gpio driverMargarita Olaya
TPS65912 has five GPIOs that can be configured for different purposes. Signed-off-by: Margarita Olaya Cabrera <magi@slimlogic.co.uk> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-07-28gpio: ab8500: fix MODULE_ALIAS for ab8500Axel Lin
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf (platform: prefix MODALIAS with "platform:"), the platform modalias is prefixed with "platform:". This patch changes the MODULE_ALIAS to "platform:ab8500-gpio". Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-22Merge branch 'gpio/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'gpio/next' of git://git.secretlab.ca/git/linux-2.6: (61 commits) gpio/mxc/mxs: fix build error introduced by the irq_gc_ack() renaming mcp23s08: add i2c support mcp23s08: isolate spi specific parts mcp23s08: get rid of setup/teardown callbacks gpio/tegra: dt: add binding for gpio polarity mcp23s08: remove unused work queue gpio/da9052: remove a redundant assignment for gpio->da9052 gpio/mxc: add device tree probe support ARM: mxc: use ARCH_NR_GPIOS to define gpio number gpio/mxc: get rid of the uses of cpu_is_mx() gpio/mxc: add missing initialization of basic_mmio_gpio shadow variables gpio: Move mpc5200 gpio driver to drivers/gpio GPIO: DA9052 GPIO module v3 gpio/tegra: Use engineering names in DT compatible property of/gpio: Add new method for getting gpios under different property names gpio/dt: Refine GPIO device tree binding gpio/ml-ioh: fix off-by-one for displaying variable i in dev_err gpio/pca953x: Deprecate meaningless device-tree bindings gpio/pca953x: Remove dynamic platform data pointer gpio/pca953x: Fix IRQ support. ...
2011-07-19gpio/mxc/mxs: fix build error introduced by the irq_gc_ack() renamingShawn Guo
The following commit renames irq_gc_ack() to irq_gc_ack_set_bit(), and makes gpio-mxc and gpio-mxs fail to build. 659fb32d1b67476f4ade25e9ea0e2642a5b9c4b5 genirq: replace irq_gc_ack() with {set,clr}_bit variants (fwd) The patch fixed a couple of typo of comma to semicolon. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-15gpio: wm831x: add a missing break in wm831x_gpio_dbg_showAxel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-15mcp23s08: add i2c supportPeter Korsgaard
Add i2c bindings for the mcp230xx devices. This is quite a lot simpler than the spi one as there's no funky sub addressing done (one struct i2c_client per struct gpio_chip). The mcp23s08_platform_data structure is reused for i2c, even though only a single mcp23s08_chip_info structure is needed. To use, simply fill out a platform_data structure and pass it in i2c_board_info, E.G.: static const struct mcp23s08_platform_data mcp23017_data = { .chip[0] = { .pullups = 0x00ff, }, .base = 240, }; static struct i2c_board_info __initdata i2c_devs[] = { { I2C_BOARD_INFO("mcp23017", 0x20), .platform_data = &smartview_mcp23017_data, }, ... }; Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-15mcp23s08: isolate spi specific partsPeter Korsgaard
Change spi member of struct mcp23s08 to be a ops-specific opaque data pointer, and move spi specific knowledge out of mcp23s08_probe_one(). No functional change, but is needed to add i2c support. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-15mcp23s08: get rid of setup/teardown callbacksPeter Korsgaard
There's no in-tree users, and bus notifiers are more generic anyway. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-14mcp23s08: remove unused work queuePeter Korsgaard
Never accessed anywhere. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-14gpio/da9052: remove a redundant assignment for gpio->da9052Axel Lin
We just set it twice in da9052_gpio_probe. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-11Merge branch 'master' into for-nextJiri Kosina
Sync with Linus' tree to be able to apply pending patches that are based on newer code already present upstream.
2011-07-08gpio/mxc: add device tree probe supportShawn Guo
The patch adds device tree probe support for gpio-mxc driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-08gpio/mxc: get rid of the uses of cpu_is_mx()Shawn Guo
The patch removes all the uses of cpu_is_mx(). Instead, it utilizes platform_device_id to distinguish the different gpio types, IMX1_GPIO on i.mx1, IMX21_GPIO on i.mx21 and i.mx27, IMX31_GPIO on all other i.mx SoCs. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-08gpio/langwell_gpio: ack the correct bit for langwell gpio interruptsMathias Nyman
The wrong bit was masked when acking langwell gpio interrupts. Reason for maskig the wrong bit was probably because__ffs() and ffs() functions return bit indexes differently (0..31 vs 1..32) This fixes langwell based devices from hanging when a gpio interrupt is triggered and undoes the breakage which occurred in change set 732063b92bb727b27e61580ce278dddefe31c6ad Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-07gpio/mxc: add missing initialization of basic_mmio_gpio shadow variablesLothar Waßmann
The bgpio_init() function does not initialise the shadow register for the GPIO direction register. Thus, when configuring the first GPIO with gpio_set_direction() all other GPIOs of the same bank will be configured as inputs. Since the bgpio layer cannot know whether the register is readable, the initialisation should be done by the caller of bgpio_init(). Also, the 'data' shadow variable that is used inside basic_mmio_gpio to cache the current value of the GPIO_DR register is initialised from the GPIO_PSR register within bgpio_init(). Thus when setting the output value of a certain GPIO, the other GPIO outputs of the same bank will be set or cleared depending on the pin state of the GPIO inputs during bgpio_init(). Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-07Update my e-mail addressMichael Büsch
Signed-off-by: Michael Buesch <m@bues.ch> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-06gpio: Move mpc5200 gpio driver to drivers/gpioGrant Likely
GPIO drivers are getting consolidated into drivers/gpio. While at it, change the driver name to mpc5200-gpio* to avoid collisions. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-06GPIO: DA9052 GPIO module v3ashishj3
DA9052 PMIC has 16 bit GPIO bus for peripheral control. This patch add support for the GPIO pins on the DA9052. Signed-off-by: David Dajun Chen <dchen@diasemi.com> Signed-off-by: Ashish Jangam <ashish.jangam@kpitcummins.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-05gpio/tegra: Use engineering names in DT compatible propertyStephen Warren
Engineering names are more stable than marketing names. Hence, use them for Device Tree compatible properties instead. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-05gpio: tps65910: add missing breaks in tps65910_gpio_initAxel Lin
2011-06-20treewide: remove duplicate includesVitaliy Ivanov
Many stupid corrections of duplicated includes based on the output of scripts/checkincludes.pl. Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-16gpio/ml-ioh: fix off-by-one for displaying variable i in dev_errAxel Lin
with the "for (; i != 0; i--)" sytax, i-- will be executed after the iteration. thus dev_err shows wrong i value. Switch to "while(--i >= 0)" which is better in readability. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-16gpio/pca953x: Deprecate meaningless device-tree bindingsDavid Jander
The property 'polarity' is handled by the GPIO core, and the 'gpio-base' should be assigned automatically. It is meaningless in the device-tree, since GPIO's are identified by the "chip-name"/offset pair. This way, the whole pca953x_get_alt_pdata() can hopefully soon go away. We still need to check whether we really want GPIO-interrupt functionality by simply looking if the I2C node has an interrupts property defined, since this property is not used for anything else. Signed-off-by: David Jander <david@protonic.nl> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-16gpio/pca953x: Remove dynamic platform data pointerDavid Jander
In the case that we obtain device-tree data to fill in platform_data, the new platform data struct was dynamically allocated, but the pointer to it was not used everywhere it should. It seems easier to fix this issue by removing the dynamic allocation altogether since its data is only used during driver probing. Signed-off-by: David Jander <david@protonic.nl> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-16gpio/pca953x: Fix IRQ support.David Jander
It seems that in the normal case, IRQ_NOREQUEST needs to be explicitly cleared, otherwise claiming the interrupt fails. In the case of sparse interrupts, the descriptor needs to be allocated first. Signed-off-by: David Jander <david@protonic.nl> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-16Merge branch 'for_3.1/gpio-cleanup' of ↵Grant Likely
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm into gpio/next
2011-06-16gpio/omap: cleanup show revision, remove cpu_is checks, display only onceKevin Hilman
Remove cpu_is_* checks from gpio_show_revision() by passing in the revision address offset from platform data. SoCs with no revision register (15xx, 7xx, and all MPUIOs) use -1 (actually, USHRT_MAX) to signify no register. While here, all GPIO banks are assumed to be the same revision, so fix show_revision() to only show the revision for the first bank it finds. This removes duplicate GPIO revision prints during boot. Thanks to Charulatha V <charu@ti.com> for finding/fixing a few -1s that were missed in the original patch. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-06-16gpio/omap: debounce remove SoC specific registers, use pdataKevin Hilman
Use register offsets passed in from pdata for accessing debounce registers. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-06-16gpio/omap: cleanup _set_gpio_wakeup(), remove ifdefsKevin Hilman
Make _set_gpio_wakeup() generic by removing ifdefs. Code for the various SoCs/bank-methods was already the same, except for the non-wakeup GPIO checking. But that flag is set on a per-SoC basis, so can be used for all SoCs. While here, use dev_err() and remove GPIO bank calculation assumption based on subtracting bank pointers. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-06-16gpio/omap: remove useless gpio_valid() & check_gpio() checksKevin Hilman
These functions are useless. They are only called in a few places, and where they are called, the GPIO has already been converted from an IRQ or masked, so these functions will never fail. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-06-16gpio/omap: convert MPUIO IRQ over to generic irq_chipKevin Hilman
MPUIO banks have their own dedicated IRQ chip interface, separate from the "normal" GPIO banks. Convert the MPUIO IRQ chip over to using the new generic IRQ chip interface. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-06-16gpio/omap: conslidate enable/disable of GPIO IRQs, remove ifdefsKevin Hilman
Cleanup GPIO IRQ enable/disable handling by removing SoC-specific Also split enable/disable IRQ into separate functions for better readability and also facilitate potentially moving to generic irq_chip in the future. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-06-16gpio/omap: consolidate IRQ status handling, remove #ifdefsKevin Hilman
Cleanup IRQ status handling by passing IRQ status register offsets via platform data. Cleans up clearing of GPIO IRQ status and GPIO ISR handler. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-06-16gpio/omap: consolidate direction, input, output, remove #ifdefsKevin Hilman
Add register offset fields to GPIO platform_data for registers. This patch adds registers that control direction, input and output data. Using these register offsets in the common driver allows removal of #ifdefs and greatly improves readability. Also create dedicated data out functions: one for banks with dedicated set/clear registers, and another for banks with a single mask register. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-06-16gpio/omap: remove get_gpio_bank()Charulatha V
use chip info to get the pointer to the struct gpio_bank for a given GPIO bank and remove get_gpio_bank(). Signed-off-by: Charulatha V <charu@ti.com>
2011-06-16gpio/omap: replace get_gpio_index() by using bank widthKevin Hilman
The get_gpio_index() function, littered with cpu_is_* checks can be easily replaced by using bitops based on the GPIO bank width. Do so. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-06-16gpio/omap: _get_gpio_irqbank_mask: replace hard-coded mask with bank->widthKevin Hilman
Replace hard-coded mask values with bank->width which is already coming from platform_data. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-06-16gpio/omap: move bank width into struct gpio_bankKevin Hilman
Rather than having a file-global bank_width variable, move it into struct gpio_bank so it can be bank-specific. Note the bank width is already passed per-bank via platform_data, so current code would be incorrect if any banks had different width. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-06-16gpio/omap: remove MPUIO handling from _clear_gpio_irqbank()Kevin Hilman
Remove the OMAP1 #ifdef and MPUIO special case for _clear_gpio_irqbank() The MPUIOs do not need a register access to ack/clear the IRQ status, since reading the IRQ status clears it. In addition, the MPUIO irq_chip has an empty ack method, so _clear_gpio_irqbank() is never used for MPUIOs. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-06-16gpio/omap: _clear_gpio_irqbank: fix flushing of posted writeKevin Hilman
In commit 78a1a6d3411de1a8b0dc1cb92754b5f12f251912 (ARM: OMAP4: Update the GPIO support) braces were mistakenly added to included the register read-back inside the cpu_is_* checking. Remove the braces, ensuring that a register read-back is done, even when the IRQSTATUS2 register is not written. Note that the register read-back might be IRQSTATUS1 or IRQSTATUS2 depending on the CPU, but a read-back of any register in that region will cause a flush of the posted writes. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-06-16gpio/omap4: Fix missing interrupts during device wakeup due to IOPAD.Ambresh K
If gpio pins from bank[2-5] are marked as wakeup enable and if the wake is through gpio IO pad wakeup, then that wakeup gpio interrupt is lost. In the current implementation, GPIO driver stores the context of DATAIN of all the gpio in the bank. During GPIO resuming, it checks DATAIN with wakeup enabled pins of gpio bank. If there is status change, then manually toggle GPIO_LEVELDETECT to generate pseudo interrupt. Reported-by: Philippe Mazet <p-mazet@ti.com> Tested-by: Philippe Mazet <p-mazet@ti.com> Signed-off-by: Ambresh K <ambresh@ti.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-15Merge branch 'gpio/next-tegra' into gpio/nextGrant Likely
