In order to satisfy all the various Kconfig options between
USB and DRM, we need to split the USB code out into a separate module
and export symbols to it.
This fixes build problems in -next reported by sfr.
reported by sfr on -next merge.
This is an initial drm/kms driver for the displaylink devices.
Supports fb_defio,
supports KMS dumb interface
supports 24bpp via conversion to 16bpp, hw can do this better.
supports hot unplug using new drm core features.
On an unplug, it disables connector polling, unplugs connectors
from sysfs, unplugs fbdev layer (using Kay's API), drops all the
USB device URBs, and call the drm core to unplug the device.
This driver is based in large parts on udlfb.c so I've licensed
it under GPLv2.
No longer used.
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Alan Cox <alan@linux.intel.com>
This patch is a DRM Driver for Samsung SoC Exynos4210 and now enables
only FIMD yet but we will add HDMI support also in the future.
this patch is based on git repository below:
git://people.freedesktop.org/~airlied/linux.git
branch name: drm-next
commit-id: 88ef4e3f4f616462b78a7838eb3ffc3818d30f67
you can refer to our working repository below:
http://git.infradead.org/users/kmpark/linux-2.6-samsung
branch name: samsung-drm
We tried to re-use lowlevel codes of the FIMD driver(s3c-fb.c
based on Linux framebuffer) but couldn't so because lowlevel codes
of s3c-fb.c are included internally and so FIMD module of this driver has
its own lowlevel codes.
We used GEM framework for buffer management and DMA APIs(dma_alloc_*)
for buffer allocation so we can allocate physically continuous memory
for DMA through it and also we could use CMA later if CMA is applied to
mainline.
Refer to this link for CMA(Continuous Memory Allocator):
http://lkml.org/lkml/2011/7/20/45
this driver supports only physically continuous memory(non-iommu).
Links to previous versions of the patchset:
v1: < https://lwn.net/Articles/454380/ >
v2: < http://www.spinics.net/lists/kernel/msg1224275.html >
v3: < http://www.spinics.net/lists/dri-devel/msg13755.html >
v4: < http://permalink.gmane.org/gmane.comp.video.dri.devel/60439 >
v5: < http://comments.gmane.org/gmane.comp.video.dri.devel/60802 >
Changelog v2:
DRM: add DRM_IOCTL_SAMSUNG_GEM_MMAP ioctl command.
this feature maps user address space to physical memory region
once user application requests DRM_IOCTL_SAMSUNG_GEM_MMAP ioctl.
DRM: code clean and add exception codes.
Changelog v3:
DRM: Support multiple irq.
FIMD and HDMI have their own irq handler but DRM Framework can regiter
only one irq handler this patch supports mutiple irq for Samsung SoC.
DRM: Consider modularization.
each DRM, FIMD could be built as a module.
DRM: Have indenpendent crtc object.
crtc isn't specific to SoC Platform so this patch gets a crtc
to be used as common object.
created crtc could be attached to any encoder object.
Changelog v4:
DRM: remove is_defult from samsung_fb.
is_default isn't used for default framebuffer.
DRM: code refactoring to fimd module.
this patch is be considered with multiple display objects and
would use its own request_irq() to register a irq handler instead of
drm framework's one.
DRM: remove find_samsung_drm_gem_object()
DRM: move kernel private data structures and definitions to driver folder.
samsung_drm.h would contain only public information for userspace
ioctl interface.
DRM: code refactoring to gem modules.
buffer module isn't dependent of gem module anymore.
DRM: fixed security issue.
DRM: remove encoder porinter from specific connector.
samsung connector doesn't need to have generic encoder.
Changelog v5:
DRM: updated fimd(display controller) driver.
added various pixel formats, color key and pixel blending features.
DRM: removed end_buf_off from samsung_drm_overlay structure.
this variable isn't used and end buffer address would be
calculated by each sub driver.
DRM: use generic function for mmap_offset.
replaced samsung_drm_gem_create_mmap_offset() and
samsung_drm_free_mmap_offset() with generic ones applied
to mainline recentrly.
DRM: removed unnecessary codes and added exception codes.
DRM: added comments and code clean.
Changelog v6:
DRM: added default config options.
DRM: added padding for 64-bit align.
DRM: changed prefix 'samsung' to 'exynos'
Signed-off-by: Inki Dae <inki.dae@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Signed-off-by: Seung-Woo Kim <sw0312.kim@samsung.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reviewed-by: Dave Airlie <airlied@redhat.com>
Reviewed-by: Rob Clark <robdclark@gmail.com>
This adds an initial framework to plug USB graphics devices
into the drm/kms subsystem.
I've started writing a displaylink driver using this interface.
This driver is one of the last users of the big kernel
lock, which is going away. All the hardware supported
by this driver also works with the newer i915 driver,
and recent X.org releases only work with that driver
anyway.
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: dri-devel@lists.freedesktop.org
The information supplied by userspace through these ioctls is only
accessible by dev->drw_idr. But there's no in-tree user of that.
Also userspace does not really care about return values of these ioctls,
either. Only hw/xfree86/dri/dri.c from the xserver actually checks the
return from adddraw and keeps on trying to create a kernel drawable
every time somebody creates a dri drawable. But since that's now a noop,
who cares.
Therefore it's safe to replace these three ioctls with noops and rip
out the implementation.
Reviewed-by: Kristian Høgsberg <krh@bitplanet.net>
Reviewed-by: Michel Dänzer <michel@daenzer.net>
I wrote this for the prime sharing work, but I also noticed other external
non-upstream drivers from a large company carrying a similiar patch, so I
may as well ship it in master.
Emit a trace point for vblank events. This can be helpful for mapping
drawing activity against the vblank frequency and period.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Allow platform devices without PCI resources to be DRM devices.
[airlied: fixup warnings with dev pointers]
Signed-off-by: Jordan Crouse <jcrouse@codeaurora.org>
Allocating multiple pages of memory for data that is coming
from user space may fail. To fix memory allocation failures
the buffer object should be split to multiple independ pages.
drm buffer provides generic interface to copy and process
large data arrays from user space.
Interface includes allocation and free functions to allocate
the buffer object and data storage pages.
All access operations are performed relative to a internal
pointer which is advanced with drm_buffer_advance function.
The buffer can be accessed using drm_buffer_pointer_to_XXX
functions if it is known that requested object doesn't split
over a page boundary. These functions don't do any error
checking to maximize performance.
If there is large object which could be split there is special
drm_buffer_read_object function. drm_buffer_read_object takes
a pointer as argument which is used as temporary store for
data if it is split over boundary in the buffer.
Signed-off-by: Pauli Nieminen <suokkos@gmail.com>
This commit adds the vmwgfx driver for the VWware Virtual GPU aka SVGA.
The driver is under staging the same as Nouveau and Radeon KMS. Hopefully
the 2D ioctls are bug free and don't need changing, so that part of the
API should be stable. But there there is a pretty big chance that the 3D API
will change in the future.
Signed-off-by: Thomas Hellström <thellstrom@vmware.com>
Signed-off-by: Jakob Bornecrantz <jakob@vmware.com>
This adds a drm/kms staging non-API stable driver for GPUs from NVIDIA.
This driver is a KMS-based driver and requires a compatible nouveau
userspace libdrm and nouveau X.org driver.
This driver requires firmware files not available in this kernel tree,
interested parties can find them via the nouveau project git archive.
This driver is reverse engineered, and is in no way supported by nVidia.
Support for nearly the complete range of nvidia hw from nv04->g80 (nv50)
is available, and the kms driver should support driving nearly all
output types (displayport is under development still) along with supporting
suspend/resume.
This work is all from the upstream nouveau project found at
nouveau.freedesktop.org.
The original authors list from nouveau git tree is:
Anssi Hannula <anssi.hannula@iki.fi>
Ben Skeggs <bskeggs@redhat.com>
Francisco Jerez <currojerez@riseup.net>
Maarten Maathuis <madman2003@gmail.com>
Marcin Kościelnicki <koriakin@0x04.net>
Matthew Garrett <mjg@redhat.com>
Matt Parnell <mparnell@gmail.com>
Patrice Mandin <patmandin@gmail.com>
Pekka Paalanen <pq@iki.fi>
Xavier Chantry <shiningxc@gmail.com>
along with project founder Stephane Marchesin <marchesin@icps.u-strasbg.fr>
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
Both radeon and nouveau can re-use this code so move it up a level
so they can. However the hw interfaces for aux ch are different
enough that the code to translate from mode, address, bytes
to actual hw interfaces isn't generic, so move that code into the
Intel driver.
Allow the KMS module to work properly, and also rename
it to KMS_HELPER so its clearer what its for.
I really don't want to have core drm module rely on CONFIG_FB,
so this is the easiest answer.
Initially I always meant this code to be shared, but things
ran away from me before I got to it.
This refactors the i915 and radeon kms fbdev interaction layers
out into generic helpers + driver specific pieces.
It moves all the panic/sysrq enhancements to the core file,
and stores a linked list of kernel fbs. This could possibly be
improved to only store the fb which has fbcon on it for panics
etc.
radeon retains some specific codes used for a big endian
workaround.
changes:
fix oops in v1
fix freeing path for crtc_info
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Define some helper functions to make easier to detach a KMS encoder
implementation from the drm module of the GPU it's used in. This is
mainly useful for some external I2C encoders known to be present on
cards with GPUs from several different manufacturers.
Signed-off-by: Francisco Jerez <currojerez@riseup.net>
TTM need to be initialized before radeon if KMS is enabled otherwise
the kernel will crash hard.
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
Signed-off-by: Dave Airlie <airlied@linux.ie>
TTM is a GPU memory manager subsystem designed for use with GPU
devices with various memory types (On-card VRAM, AGP,
PCI apertures etc.). It's essentially a helper library that assists
the DRM driver in creating and managing persistent buffer objects.
TTM manages placement of data and CPU map setup and teardown on
data movement. It can also optionally manage synchronization of
data on a per-buffer-object level.
TTM takes care to provide an always valid virtual user-space address
to a buffer object which makes user-space sub-allocation of
big buffer objects feasible.
TTM uses a fine-grained per buffer-object locking scheme, taking
care to release all relevant locks when waiting for the GPU.
Although this implies some locking overhead, it's probably a big
win for devices with multiple command submission mechanisms, since
the lock contention will be minimal.
TTM can be used with whatever user-space interface the driver
chooses, including GEM. It's used by the upcoming Radeon KMS DRM driver
and is also the GPU memory management core of various new experimental
DRM drivers.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
The old mechanism to formatting proc files is extremely ugly. The
seq_file API was designed specifically for cases like this and greatly
simplifies the process.
Also, most of the files in /proc really don't belong there. This patch
introduces the infrastructure for putting these into debugfs and exposes
all of the proc files in debugfs as well.
Signed-off-by: Ben Gamari <bgamari@gmail.com>
Signed-off-by: Eric Anholt <eric@anholt.net>
Add mode setting support to the DRM layer.
This is a fairly big chunk of work that allows DRM drivers to provide
full output control and configuration capabilities to userspace. It was
motivated by several factors:
- the fb layer's APIs aren't suited for anything but simple
configurations
- coordination between the fb layer, DRM layer, and various userspace
drivers is poor to non-existent (radeonfb excepted)
- user level mode setting drivers makes displaying panic & oops
messages more difficult
- suspend/resume of graphics state is possible in many more
configurations with kernel level support
This commit just adds the core DRM part of the mode setting APIs.
Driver specific commits using these new structure and APIs will follow.
Co-authors: Jesse Barnes <jbarnes@virtuousgeek.org>, Jakob Bornecrantz <jakob@tungstengraphics.com>
Contributors: Alan Hourihane <alanh@tungstengraphics.com>, Maarten Maathuis <madman2003@gmail.com>
GEM allows the creation of persistent buffer objects accessible by the
graphics device through new ioctls for managing execution of commands on the
device. The userland API is almost entirely driver-specific to ensure that
any driver building on this model can easily map the interface to individual
driver requirements.
GEM is used by the 2d driver for managing its internal state allocations and
will be used for pixmap storage to reduce memory consumption and enable
zero-copy GLX_EXT_texture_from_pixmap, and in the 3d driver is used to enable
GL_EXT_framebuffer_object and GL_ARB_pixel_buffer_object.
With the coming of kernel based modesetting and the memory manager stuff,
the everything in one directory approach was getting very ugly and
starting to be unmanageable.
This restructures the drm along the lines of other kernel components.
It creates a drivers/gpu/drm directory and moves the hw drivers into
subdirectores. It moves the includes into an include/drm, and
sets up the unifdef for the userspace headers we should be exporting.
