Rework the sdma structures in the driver to
consolidate all of the sdma info into a single
structure and allow for asics that may have
different numbers of sdma instances.
Reviewed-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
The wrong define was used to check if the hqd is still active
v2: Don't use SHIFT as the MASK is already shifted
Signed-off-by: Oded Gabbay <oded.gabbay@gmail.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
This patch adds the gfx7 interface file between amdgpu and amdkfd. This
interface file mirrors (some) of the functions in radeon_kfd.c
(the interface file between radeon and amdkfd).
The gfx7 interface is used when it is run on a Kaveri-based system.
This interface file was used for bring-up of amdkfd on amdgpu and for
debugging purposes. For users who would like to run HSA on Kaveri, please
use the radeon graphic driver.
Note: CONFIG_DRM_AMDGPU_CIK must be selected for amdgpu to handle Kaveri.
v2: removed MTYPE_NONCACHED enum definition as it is defined in another
patch
