This is the 4.14.159 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6sx.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/input/keyboard/imx_keypad.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
commit 984d7a929ad68b7be9990fc9c5cfa5d5c9fc7942 upstream.
Bail from the pci_driver probe function instead of from the drm_driver
load function.
This avoid /dev/dri/card0 temporarily getting registered and then
unregistered again, sending unwanted add / remove udev events to
userspace.
Specifically this avoids triggering the (userspace) bug fixed by this
plymouth merge-request:
https://gitlab.freedesktop.org/plymouth/plymouth/merge_requests/59
Note that despite that being a userspace bug, not sending unnecessary
udev events is a good idea in general.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1490490
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Cc: stable@vger.kernel.org
[ Upstream commit 73d8e6c7b841d9bf298c8928f228fb433676635c ]
Do not try to allocate any amount of memory requested by the user.
Instead limit it to 128 registers. Actually the longest series of
consecutive allowed registers are 48, mmGB_TILE_MODE0-31 and
mmGB_MACROTILE_MODE0-15 (0x2644-0x2673).
Bug: https://bugs.freedesktop.org/show_bug.cgi?id=111273
Signed-off-by: Trek <trek00@inbox.ru>
[ Upstream commit 77efe48a729588527afb4d5811b9e0acb29f5e51 ]
Comparing adev->family with CHIP constants is not correct.
adev->family can only be compared with AMDGPU_FAMILY constants and
adev->asic_type is the struct member to compare with CHIP constants.
They are separate identification spaces.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Fixes: 62a37553414a ("drm/amdgpu: add si implementation v10")
Cc: Ken Wang <Qingqing.Wang@amd.com>
Cc: Alex Deucher <alexander.deucher@amd.com>
Cc: "Christian König" <christian.koenig@amd.com>
Cc: "David (ChunMing) Zhou" <David1.Zhou@amd.com>
This is the 4.14.126 stable release
drivers/gpio/gpio-vf610.c:
Follow commit 338aa10750ba gpio: vf610: Do not share irq_chip
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c:
Follow commit 67793bd3b394 drm/bridge: adv7511: Fix low refresh rate selection
Use drm_mode_vrefresh(mode) helper
drivers/net/ethernet/freescale/fec_main.c:
Keep downstream file.
drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c
Follow commit 46953f97224d brcmfmac: fix missing checks for kmemdup
sound/soc/fsl/Kconfig:
Follow commit ea751227c813 ASoC: imx: fix fiq dependencies
Logical Conflicts:
sound/soc/fsl/fsl_sai.c:
Revert upstream d7325abe29b as downstream fixed it differently
drivers/clk/imx/clk-imx6sl.c
Revert upstream bda9f846ae0 as downstream implemented it differently 68c736e9378
commit 25f09f858835b0e9a06213811031190a17d8ab78 upstream.
Recommended by the hw team.
Reviewed-and-Tested-by: Huang Rui <ray.huang@amd.com>
commit 9d6fea5744d6798353f37ac42a8a653a2607ca69 upstream.
In case we need to use them for GPU reset prior initializing the
asic. Fixes a crash if the driver attempts to reset the GPU at driver
load time.
Acked-by: Christian König <christian.koenig@amd.com>
[ Upstream commit 3d2aca8c8620346abdba96c6300d2c0b90a1d0cc ]
We don't hold a reference to the old fence, so it can go away
any time we are waiting for it to signal.
Signed-off-by: Christian König <christian.koenig@amd.com>
Reviewed-by: Chunming Zhou <david1.zhou@amd.com>
This will allow __drm_mode_object_file to be extended to perform
access control checks based on the file in use.
v2: Also fix up vboxvideo driver in staging
[airlied: merging early as this is an API change]
Suggested-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Keith Packard <keithp@keithp.com>
(cherry picked from commit 418da17214aca5ef5f0b6f7588905ee7df92f98f)
commit d55d8be0747c96db28a1d08fc24d22ccd9b448ac upstream.
Some new variants require different firmwares.
Signed-off-by: Junwei Zhang <Jerry.Zhang@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
[ Upstream commit ad97d9de45835b6a0f71983b0ae0cffd7306730a ]
Driver shouldn't try to access any GFX registers until RLC is idle.
During the test, it took 12 seconds for RLC to clear the BUSY bit
in RLC_GPM_STAT register which is un-acceptable for driver.
As per RLC engineer, it would take RLC Ucode less than 10,000 GFXCLK
cycles to finish its critical section. In a lowest 300M enginer clock
setting(default from vbios), 50 us delay is enough.
This commit fix the hang when RLC introduce the work around for XGMI
which requires more cycles to setup more registers than normal
Signed-off-by: shaoyunl <shaoyun.liu@amd.com>
Acked-by: Felix Kuehling <Felix.Kuehling@amd.com>
commit a81a7c9c9ea3042ab02d66ac35def74abf091c15 upstream.
Some variants require different MC firmware images.
Reviewed-by: Junwei Zhang <Jerry.Zhang@amd.com>
commit d7fd67653f847327e545bdb198b901ee124afd7c upstream.
Some new variants require updated firmware.
Reviewed-by: Evan Quan <evan.quan@amd.com>
commit d9997b64c52b70bd98c48f443f068253621d1ffc upstream.
This caused a confusing error message, but there is functionally
no problem since the default method is DIRECT.
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
[ Upstream commit caaa4c8a6be2a275bd14f2369ee364978ff74704 ]
A wrong register bit was examinated for checking SDMA status so it reports
false failures. This typo only appears on gfx_v7. gfx_v8 checks the correct
bit.
Acked-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Amber Lin <Amber.Lin@amd.com>
Reviewed-by: Felix Kuehling <Felix.Kuehling@amd.com>
Signed-off-by: Felix Kuehling <Felix.Kuehling@amd.com>
commit 61ea6f5831974ebd1a57baffd7cc30600a2e26fc upstream.
The vce cancel_delayed_work_sync never be called.
driver call the function in error path.
This caused the A+A suspend hang when runtime pm enebled.
As we will visit the smu in the idle queue. this will cause
smu hang because the dgpu has been suspend, and the dgpu also
will be waked up. As the smu has been hang, so the dgpu resume
will failed.
Reviewed-by: Christian König <christian.koenig@amd.com>
Reviewed-by: Feifei Xu <Feifei.Xu@amd.com>
Signed-off-by: Rex Zhu <Rex.Zhu@amd.com>
[ Upstream commit 0165de983272d1fae0809ed9db47c46a412279bc ]
Slowly leaking memory one page at a time :)
Reviewed-by: Andrey Grodzovsky <andrey.grodzovsky@amd.com>
commit b3fc2ab37e27f8d6588a4755382346ba2335a7c7 upstream.
Needs ATPX rather than _PR3.
Bug: https://bugzilla.kernel.org/show_bug.cgi?id=200517
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
[ Upstream commit 2ab4d0e74256fc49b7b270f63c1d1e47c2455abc ]
For SI/Kv, the power state is managed by function
amdgpu_pm_compute_clocks.
when dpm enabled, we should call amdgpu_pm_compute_clocks
to update current power state instand of set boot state.
this change can fix the oops when kfd driver was enabled on Kv.
Tested-by: Michel Dänzer <michel.daenzer@amd.com>
[ Upstream commit 8ef23364b654d44244400d79988e677e504b21ba ]
This is required by gfx hw and can fix the rlc hang when
do s3 stree test on Cz/St.
Signed-off-by: Hang Zhou <hang.zhou@amd.com>
commit 30f3984ede683b98a4e8096e200df78bf0609b4f upstream.
Add new pci id.
Reviewed-by: Rex Zhu <Rex.Zhu@amd.com>
commit 4d77c0f676e910fb1f1870738aa4bd168f253621 upstream.
Setup psp firmware loading for VCN, and make VCN block
booting from tmr mac address.
Signed-off-by: James Zhu <James.Zhu@amd.com>
Acked-by: Huang Rui <ray.huang@amd.com>
Reviewed-by: Likun Gao <Likun.Gao@amd.com>
Signed-off-by: Likun Gao <Likun.Gao@amd.com>
commit 235ac9de625a0a586093ad81b3de6f7d7ab913ed upstream.
Add VCN support in PSP driver
commit c9ca989696ff28ffb015cc2b7c5577938ef2626c upstream.
Add the new firmware id for VCN into the enum
commit abf412b3efb2f943d9b98a489e9aca836be21333 upstream.
amdgpu IP blocks booting need Trust Memory Region(tmr) mc address
of its firmware which is loaded by PSP
Reviewed-by: Likun Gao <likun.gao@amd.com>
commit 435198f33b56d7b875a8173a0227ddf0de285aa1 upstream.
Update tmr mc address with firmware loading address
which is returned from PSP firmware
commit 226127a67e31a9518d9516d3e4890759b379d874 upstream.
We were testing the register offset, instead of the value stored in the
register, therefore always timing out the loop.
This reduces suspend time of the system in the bug report below by ~600
ms.
Bugzilla: https://bugs.freedesktop.org/107277
Tested-by: Paul Menzel <pmenzel@molgen.mpg.de>
Signed-off-by: Michel Dänzer <michel.daenzer@amd.com>
[ Upstream commit 0859df22ab7cfb3ad2df2caed76cadce6ac33a80 ]
The phys and vm versions had the values swapped.
[ Upstream commit 9b3f217faf48603c91d4ca44a18e6ff74c3c1c0c ]
This fixes an issue introduced by change "allow framebuffer in GART
memory as well" which could lead to a shared buffer ending up
pinned in vram. Use GTT if it is included in the domain, otherwise
return an error.
Signed-off-by: Samuel Li <Samuel.Li@amd.com>
commit 5e9244ff585239630f15f8ad8e676bc91a94ca9e upstream.
Preparation for the following fix, no functional change intended.
commit 6fa39bc1e01dab8b4f54b23e95a181a2ed5a2d38 upstream.
It can be quite big, and there's no need for it to be physically
contiguous. This is less likely to fail under memory pressure (has
actually happened while running piglit).
commit a0b2ac29415bb44d1c212184c1385a1abe68db5c upstream.
It missed vcn.fw_version setting when init vcn microcode, and it will be used to
report vcn ucode version via amdgpu_firmware_info sysfs interface.
Signed-off-by: Huang Rui <ray.huang@amd.com>
commit 08ebb6e9f4fd7098c28e0ebbb42847cf0488ebb8 upstream.
1. fix set vce clocks failed on Cz/St
which lead 1s delay when boot up.
2. remove the workaround in vce_v3_0.c
Reviewed-by: Huang Rui <ray.huang@amd.com>
Acked-by: Shirish S <shirish.s@amd.com>
commit 819a23f83e3b2513cffbef418458a47ca02c36b3 upstream.
fix the issue set uvd clock failed on CZ/ST
[ Upstream commit dbf797655a43c6318ebb90b899e6583fcadc6472 ]
issue:
sometime GFX/MM ib test hit timeout under SRIOV env, root cause
is that engine doesn't come back soon enough so the current
IB test considered as timed out.
fix:
for SRIOV GFX IB test wait time need to be expanded a lot during
SRIOV runtimei mode since it couldn't really begin before GFX engine
come back.
for SRIOV MM IB test it always need more time since MM scheduling
is not go together with GFX engine, it is controled by h/w MM
scheduler so no matter runtime or exclusive mode MM IB test
always need more time.
v2:
use ring type instead of idx to judge
Signed-off-by: Monk Liu <Monk.Liu@amd.com>
[ Upstream commit 9f0178fb67699992d38601cb923b434f9986dd68 ]
otherwise there will be DMAR reading error comes out from CP since
GFX is still alive and CPC's WPTR_POLL is still enabled, which would
lead to DMAR read error.
fix:
we can hault CPG after hw_fini, but cannot halt CPC becaues KIQ
stil need to be alive to let RLCV invoke, but its WPTR_POLL could
be disabled.
[ Upstream commit 7420f482ea5163bf6dae39a5c7628d5397cd6307 ]
This patch fixes kernel build in ARCH=frv
Signed-off-by: Oded Gabbay <oded.gabbay@gmail.com>
[ Upstream commit 585b7f161c85bd5ca675b97580faf21c506541e3 ]
DDR4 has a 64-bit width not 128-bits. It was reporting
twice the width. Tested with my Ryzen 2400G.
Signed-off-by: Tom St Denis <tom.stdenis@amd.com>
commit 75569c182e4f65cd8826a5853dc9cbca703cbd0e upstream.
Otherwise, the SQ may skip some of the register writes, or shader waves may
be allocated where we don't expect them, so that as a result we don't actually
reset all of the register SRAMs. This can lead to spurious ECC errors later on
if a shader uses an uninitialized register.
Signed-off-by: Nicolai Hähnle <nicolai.haehnle@amd.com>
commit 20ca25e86c56f5490bdc80318f4fc06466e4c21b upstream.
Required for dpm setup on some asics. Fixes a NULL dereference
on asics that require it.
Bug: https://bugs.freedesktop.org/show_bug.cgi?id=102553
Tested-by: Abel Garcia Dorta <mercuriete@yahoo.es>
commit 41212e2fe72b26ded7ed78224d9eab720c2891e2 upstream.
The calculation of the lane widths via ATOM_PPLIB_PCIE_LINK_WIDTH_MASK and
ATOM_PPLIB_PCIE_LINK_WIDTH_SHIFT macros did not increment the resulting
value, per the comment in pptable.h ("lanes - 1"), and per usage elsewhere.
Port of the radeon fix to amdgpu.
Acked-by: Chunming Zhou <david1.zhou@amd.com>
commit 4a8e06f7aad797e92413a3042d09d3b385fa1fda upstream.
Needs to be a 32 bit mask.
commit a20ee0b1f8b42e2568f3a4408003d22b2dfcc706 upstream.
If these bos are evicted and are in the validated list
things blow up, so do not put them in there. Notably,
that tries to add the bo to the LRU twice, which results
in a BUG_ON in ttm_bo.c.
While for the bo_list an alternative would be to not allow
always valid bos in there, that does not work for the user
fence.
v2: Fixed whitespace issue pointed out by checkpatch.pl
Signed-off-by: Bas Nieuwenhuizen <basni@chromium.org>
commit 13b40935cf64f59b93cf1c716a2033488e5a228c upstream.
_PR3 doesn't seem to work properly, use ATPX instead.
Bug: https://bugs.freedesktop.org/show_bug.cgi?id=104064
commit 7d617264eb22b18d979eac6e85877a141253034e upstream.
Turning off the sink in this case causes various issues, because
userspace expects it to stay on until it turns it off explicitly.
Instead, turn the sink off and back on when a display is connected
again. This dance seems necessary for link training to work correctly.
Bugzilla: https://bugs.freedesktop.org/105308
commit 342038d92403b3efa1138a8599666b9f026279d6 upstream.
We unmapped imported DMA-bufs when the GEM handle was dropped, not when the
hardware was done with the buffere.
CC: stable@vger.kernel.org
[ Upstream commit 129d65c18ecfb249aceb540c31fdaf79bd5a11ff ]
this fix the issue that access memory after freed
after driver unloaded.
[ Upstream commit 34a4d2bf06b3ab92024b8e26d6049411369d1f1a ]
[ Upstream commit a9efcc19161e20623c285fac967a32842972cebe ]
Use proper powerplay function. This fixes OpenCL initialization
problems.
Acked-by: Oded Gabbay <oded.gabbay@gmail.com>
commit f8bee6135e167f5b35b7789c74c2956dad14d0d5 upstream.
When UVD is in VM mode, there is not uvd handle exchanged,
uvd.handles are always 0. So vcpu_bo always need save,
Otherwise amdgpu driver will fail during suspend/resume.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=105021
Reviewed-by: Leo Liu <leo.liu@amd.com>
