They need this to get all the EXPORT_SYMBOL variants and THIS_MODULE
Drivers using multiple framebuffers got broken by commit
41c2e75e60200a860a74b7c84a6375c105e7437f which ignored the framebuffer
(or register) map offset when looking for existing maps. The rationale
was that the kernel-userspace ABI is fixed at a 32-bit offset, so the
real offsets could not always be handed over for comparison.
Instead of ignoring the offset we will compare the lower 32 bit. Drivers
using multiple framebuffers should just make sure that the lower 32 bit
are different. The existing drivers in question are practically limited
to 32-bit systems so that should be fine for them.
It is assumed that current drivers always specify a correct framebuffer
map offset, even if this offset was ignored since above commit. So this
patch should not change anything for drivers using only one framebuffer.
Drivers needing multiple framebuffers with 64-bit map offsets will need
to cook up something, for instance keeping an ID in the lower bit which
is to be aligned away when it comes to using the offset.
All of above applies to _DRM_REGISTERS as well.
Signed-off-by: Tormod Volden <debian.tormod@gmail.com>
Remove an obsolete Alpha adjustment, and modify another,
to go with the current Alpha architecture support.
Signed-off-by: Jay Estabrook <jay.estabrook@gmail.com>
Tested-by: Matt Turner <mattst88@gmail.com>
Currently most, if not all, memory allocation in drm_bufs.c is followed by initializing the memory with 0.
Replace the use of kmalloc+memset with kzalloc.
Signed-off-by: Davidlohr Bueso <dave@gnu.org>
* drm-platform:
drm: Make sure the DRM offset matches the CPU
drm: Add __arm defines to DRM
drm: Add support for platform devices to register as DRM devices
drm: Remove drm_resource wrappers
Add __arm defines to specify behavior specific for
an ARM processor.
Signed-off-by: Jordan Crouse <jcrouse@codeaurora.org>
Remove the drm_resource wrappers and directly use the
actual PCI and/or platform functions in their place.
[airlied: fixup nouveau properly to build]
Reviewed-by: Matt Turner <mattst88@gmail.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
[Ss]ytem => [Ss]ystem
udpate => update
paramters => parameters
orginal => original
Signed-off-by: Thomas Weber <swirl@gmx.li>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
drm_pci_alloc() has input of address mask for setting pci dma
mask on the device, which should be properly setup by drm driver.
And leave it as a param for drm_pci_alloc() would cause confusion
or mistake would corrupt the correct dma mask setting, as seen on
intel hw which set wrong dma mask for hw status page. So remove
it from drm_pci_alloc() function.
Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com>
Fix the error message: this is add, not rm.
Move the closing brace to proper spot: _DRM_GEM branch should not be
included in the block.
Signed-off-by: Pekka Paalanen <pq@iki.fi>
It hasn't been used in ages, and having the user tell your how much
memory is being freed at free time is a recipe for disaster even if it
was ever used.
Signed-off-by: Eric Anholt <eric@anholt.net>
A driver will use the _DRM_DRIVER map flag to indicate that it wants
to be responsible for removing the map itself, bypassing the DRM's
automagic cleanup code.
Since the multi-master changes this has been broken, resulting in some
drivers having their registers unmapped before it's finished with them.
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
Currently, userspace can fail to obtain the SAREA mapping (among other
reasons) if it passes SAREA_MAX to drmAddMap without aligning it to the
page size. This breaks for example on PowerPC with 64K pages and radeon
despite the kernel radeon actually doing the right rouding in the first
place.
The way SAREA_MAX is defined with a bunch of ifdef's and duplicated
between libdrm and the X server is gross, ultimately it should be
retrieved by userspace from the kernel, but in the meantime, we have
plenty of existing userspace built with bad values that need to work.
This patch works around broken userspace by rounding the requested size
in drm_addmap_core() of any SHM map to the page size. Since the backing
memory for SHM maps is also allocated within addmap_core, there is no
danger of adjacent memory being exposed due to the increased map size.
The only side effect is that drivers that previously tried to create or
access SHM maps using a size < PAGE_SIZE and failed (getting -EINVAL),
will now succeed at the cost of a little bit more memory used if that
happens to be when the map is created.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Platforms such as sparc64 have D-cache aliasing issues. We
cannot allow virtual mappings in different contexts to be such
that two cache lines can be loaded for the same backing data.
Updates to one cache line won't be seen by accesses to the other
cache line.
Code in sparc64 and other architectures solve this problem by
making sure that all userland mappings of MAP_SHARED objects have
the same virtual address base. They implement this by keying
off of the page offset, and using that to choose a suitably
consistent virtual address for mmap() requests.
Making things even worse, getting this wrong on sparc64 can result
in hangs during DRM lock acquisition. This is because, at least on
UltraSPARC-III, normal loads consult the D-cache but atomics such
as 'cas' (which is what cmpxchg() is implement using) only consult
the L2 cache. So if a D-cache alias is inserted, the load can
see different data than the atomic, and we'll loop forever because
the atomic compare-and-exchange will never complete successfully.
So to make this all work properly, we need to make sure that the
hash address computed by drm_map_handle() preserves the SHMLBA
relevant bits, and that's what this patch does for _DRM_SHM mappings.
As a historical note, many years ago this bug didn't exist because we
used to just use the low 32-bits of the address as the hash and just
hope for the best. This preserved the SHMLBA bits properly. But when
the hashtab code was added to DRM, this was no longer the case.
This changes drm_local_map to use a resource_size for its "offset"
member instead of an unsigned long, thus allowing 32-bit machines
with a >32-bit physical address space to be able to store there
their register or framebuffer addresses when those are above 4G,
such as when using a PCI video card on a recent AMCC 440 SoC.
This patch isn't as "trivial" as it sounds: A few functions needed
to have some unsigned long/int changed to resource_size_t and a few
printk's had to be adjusted.
But also, because userspace isn't capable of passing such offsets,
I had to modify drm_find_matching_map() to ignore the offset passed
in for maps of type _DRM_FRAMEBUFFER or _DRM_REGISTERS.
If we ever support multiple _DRM_FRAMEBUFFER or _DRM_REGISTERS maps
for a given device, we might have to change that trick, but I don't
think that happens on any current driver.
Signed-off-by: Dave Airlie <airlied@linux.ie>
Once upon a time, the DRM made the distinction between the drm_map
data structure exchanged with user space and the drm_local_map used
in the kernel.
For some reasons, while the BSD port still has that "feature", the
linux part abused drm_map for kernel internal usage as the local
map only existed as a typedef of the struct drm_map.
This patch fixes it by declaring struct drm_local_map separately
(though its content is currently identical to the userspace variant),
and changing the kernel code to only use that, except when it's a
user<->kernel interface (ie. ioctl).
This allows subsequent changes to the in-kernel format
I've also replaced the use of drm_local_map_t with struct drm_local_map
in a couple of places. Mostly by accident but they are the same (the
former is a typedef of the later) and I have some remote plans and
half finished patch to completely kill the drm_local_map_t typedef
so I left those bits in.
Acked-by: Eric Anholt <eric@anholt.net>
The DRM uses its own wrappers to obtain resources from PCI devices,
which currently convert the resource_size_t into an unsigned long.
This is broken on 32-bit platforms with >32-bit physical address
space.
This fixes them, along with a few occurences of unsigned long used
to store such a resource in drivers.
Currently only one waiter is woken up, leaving other waiters
hanging waiting for the DRM lock.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
this exports the locked version of the symbol as struct_mutex locks it all.
Add core support for mapping of GEM objects. Drivers should provide a
vm_operations_struct if they want to support page faulting of objects.
The code for handling GEM object offsets was taken from TTM, which was
written by Thomas Hellström.
This is step one towards having multiple masters sharing a drm
device in order to get fast-user-switching to work.
It splits out the information associated with the drm master
into a separate kref counted structure, and allocates this when
a master opens the device node. It also allows the current master
to abdicate (say while VT switched), and a new master to take over
the hardware.
It moves the Intel and radeon drivers to using the sarea from
within the new master structures.
With the coming of kernel based modesetting and the memory manager stuff,
the everything in one directory approach was getting very ugly and
starting to be unmanageable.
This restructures the drm along the lines of other kernel components.
It creates a drivers/gpu/drm directory and moves the hw drivers into
subdirectores. It moves the includes into an include/drm, and
sets up the unifdef for the userspace headers we should be exporting.
