path: root/drivers/gpu/drm/drm_info.c
2011-03-14Merge remote branch 'intel/drm-intel-next' of ../drm-next into drm-core-nextDave Airlie
* 'intel/drm-intel-next' of ../drm-next: (755 commits) drm/i915: Only wait on a pending flip if we intend to write to the buffer drm/i915/dp: Sanity check eDP existence drm/i915: Rebind the buffer if its alignment constraints changes with tiling drm/i915: Disable GPU semaphores by default drm/i915: Do not overflow the MMADDR write FIFO Revert "drm/i915: fix corruptions on i8xx due to relaxed fencing" drm/i915: Don't save/restore hardware status page address register drm/i915: don't store the reg value for HWS_PGA drm/i915: fix memory corruption with GM965 and >4GB RAM Linux 2.6.38-rc7 Revert "TPM: Long default timeout fix" drm/i915: Re-enable GPU semaphores for SandyBridge mobile drm/i915: Replace vblank PM QoS with "Interrupt-Based AGPBUSY#" Revert "drm/i915: Use PM QoS to prevent C-State starvation of gen3 GPU" drm/i915: Allow relocation deltas outside of target bo drm/i915: Silence an innocuous compiler warning for an unused variable fs/block_dev.c: fix new kernel-doc warning ACPI: Fix build for CONFIG_NET unset mm: <asm-generic/pgtable.h> must include <linux/mm_types.h> x86: Use u32 instead of long to set reset vector back to 0 ... Conflicts: drivers/gpu/drm/i915/i915_gem.c
2011-02-14drm: do not leak kernel addresses via /proc/dri/*/vmaKees Cook
In the continuing effort to avoid kernel addresses leaking to unprivileged users, this patch switches to %pK for /proc/dri/*/vma. Signed-off-by: Kees Cook <kees.cook@canonical.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-02-07drm: rework PCI/platform driver interface.Dave Airlie
This abstracts the pci/platform interface out a step further, we can go further but this is far enough for now to allow USB to be plugged in. The drivers now just call the init code directly for their device type. Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-10-06Merge remote branch 'korg/drm-fixes' into drm-vmware-nextDave Airlie
necessary for some of the vmware fixes to be pushed in. Conflicts: drivers/gpu/drm/drm_gem.c drivers/gpu/drm/i915/intel_fb.c include/drm/drmP.h
2010-10-01drm: Move the GTT accounting to i915Chris Wilson
Only drm/i915 does the bookkeeping that makes the information useful, and the information maintained is driver specific, so move it out of the core and into its single user. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Dave Airlie <airlied@redhat.com>
2010-10-01drm/gem: handlecount isn't really a kref so don't make it one.Dave Airlie
There were lots of places being inconsistent since handle count looked like a kref but it really wasn't. Fix this my just making handle count an atomic on the object, and have it increase the normal object kref. Now i915/radeon/nouveau drivers can drop the normal reference on userspace object creation, and have the handle hold it. This patch fixes a memory leak or corruption on unload, because the driver had no way of knowing if a handle had been actually added for this object, and the fbcon object needed to know this to clean itself up properly. Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-06-01drm: Add support for platform devices to register as DRM devicesJordan Crouse
Allow platform devices without PCI resources to be DRM devices. [airlied: fixup warnings with dev pointers] Signed-off-by: Jordan Crouse <jcrouse@codeaurora.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-03-28drm: merge Linux master into HEADDave Airlie
Conflicts: drivers/gpu/drm/drm_info.c drivers/gpu/drm/drm_proc.c drivers/gpu/drm/i915/i915_gem_debugfs.c
2009-03-28Merge branch 'linus' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/sparc/kernel/time_64.c drivers/gpu/drm/drm_proc.c Manual merge to resolve build warning due to phys_addr_t type change on x86: drivers/gpu/drm/drm_info.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-27drm: Convert proc files to seq_file and introduce debugfsBen Gamari
The old mechanism to formatting proc files is extremely ugly. The seq_file API was designed specifically for cases like this and greatly simplifies the process. Also, most of the files in /proc really don't belong there. This patch introduces the infrastructure for putting these into debugfs and exposes all of the proc files in debugfs as well. Signed-off-by: Ben Gamari <bgamari@gmail.com> Signed-off-by: Eric Anholt <eric@anholt.net>
2009-03-13drm: fix warnings about new mappings in info code.Dave Airlie
This fixes up the warnings in the debugfs code that conflicted with the mapping fixups. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-03-13drm: Convert proc files to seq_file and introduce debugfsBen Gamari
The old mechanism to formatting proc files is extremely ugly. The seq_file API was designed specifically for cases like this and greatly simplifies the process. Also, most of the files in /proc really don't belong there. This patch introduces the infrastructure for putting these into debugfs and exposes all of the proc files in debugfs as well. This contains the i915 hooks rewrite as well, to make bisectability better. Signed-off-by: Ben Gamari <bgamari@gmail.com> Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
