remove declared but unused functions from drmP.h, fix the comments
where necessary. Also, remove drm_mem_info which is unused.
They need this to get all the EXPORT_SYMBOL variants and THIS_MODULE
There's no point in jumping through two indirections. So kill one
and call the kernels agp functions directly.
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
No caller (rightly) cares about it, so drop it.
"agpmem" is never NULL here.
Cc: Eric Anholt <eric@anholt.net>
This switches AGP to use an array of pages for tracking the
pages allocated to the GART. This should enable GEM on PAE to work
a lot better as we can pass highmem pages to the PAT code and it will
do the right thing with them.
It hasn't been used in ages, and having the user tell your how much
memory is being freed at free time is a recipe for disaster even if it
was ever used.
Signed-off-by: Eric Anholt <eric@anholt.net>
Once upon a time, the DRM made the distinction between the drm_map
data structure exchanged with user space and the drm_local_map used
in the kernel.
For some reasons, while the BSD port still has that "feature", the
linux part abused drm_map for kernel internal usage as the local
map only existed as a typedef of the struct drm_map.
This patch fixes it by declaring struct drm_local_map separately
(though its content is currently identical to the userspace variant),
and changing the kernel code to only use that, except when it's a
user<->kernel interface (ie. ioctl).
This allows subsequent changes to the in-kernel format
I've also replaced the use of drm_local_map_t with struct drm_local_map
in a couple of places. Mostly by accident but they are the same (the
former is a typedef of the later) and I have some remote plans and
half finished patch to completely kill the drm_local_map_t typedef
so I left those bits in.
Acked-by: Eric Anholt <eric@anholt.net>
Signed-off-by: Dave Airlie <airlied@linux.ie>
this solves a regression from
http://bugzilla.kernel.org/show_bug.cgi?id=12441
Reported-by: Daniel Vetter <daniel@ffwll.ch>
GEM allows the creation of persistent buffer objects accessible by the
graphics device through new ioctls for managing execution of commands on the
device. The userland API is almost entirely driver-specific to ensure that
any driver building on this model can easily map the interface to individual
driver requirements.
GEM is used by the 2d driver for managing its internal state allocations and
will be used for pixmap storage to reduce memory consumption and enable
zero-copy GLX_EXT_texture_from_pixmap, and in the 3d driver is used to enable
GL_EXT_framebuffer_object and GL_ARB_pixel_buffer_object.
With new userspace libpciaccess we can get a conflicting mapping
on the PCIE GART table in the video RAM. Always try and map it _wc.
With the coming of kernel based modesetting and the memory manager stuff,
the everything in one directory approach was getting very ugly and
starting to be unmanageable.
This restructures the drm along the lines of other kernel components.
It creates a drivers/gpu/drm directory and moves the hw drivers into
subdirectores. It moves the includes into an include/drm, and
sets up the unifdef for the userspace headers we should be exporting.
