drm_vblank_count() returns the software counter. We should not pretend
it's the hw counter since we use the hw counter to figuere out what the
software counter value should be. So instead provide a new function
drm_vblank_no_hw_counter() for drivers that don't have a real hw
counter. The new function simply returns 0, which is about the only
thing it can do.
Cc: Vincent Abriou <vincent.abriou@st.com>
Cc: Thierry Reding <treding@nvidia.com>
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Reviewed-by: Vincent Abriou <vincent.abriou@st.com>
[danvet: s/int pipe/unsigned int pipe/ to follow Thierry's interface
change.]
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
This continues the pattern started in commit cc1ef118fc09 ("drm/irq:
Make pipe unsigned and name consistent"). This is applied to the public
APIs and driver callbacks, so pretty much all drivers need to be updated
to match the new prototypes.
Cc: Christian König <christian.koenig@amd.com>
Cc: Alex Deucher <alexander.deucher@amd.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Inki Dae <inki.dae@samsung.com>
Cc: Jianwei Wang <jianwei.wang.chn@gmail.com>
Cc: Alison Wang <alison.wang@freescale.com>
Cc: Patrik Jakobsson <patrik.r.jakobsson@gmail.com>
Cc: Daniel Vetter <daniel.vetter@intel.com>
Cc: Jani Nikula <jani.nikula@linux.intel.com>
Cc: Philipp Zabel <p.zabel@pengutronix.de>
Cc: David Airlie <airlied@linux.ie>
Cc: Rob Clark <robdclark@gmail.com>
Cc: Ben Skeggs <bskeggs@redhat.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Mark Yao <mark.yao@rock-chips.com>
Cc: Benjamin Gaignard <benjamin.gaignard@linaro.org>
Cc: Thomas Hellstrom <thellstrom@vmware.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
This patch add support for Two Dimensional Animation and Compositing
Engine (2D-ACE) on the Freescale SoCs.
2D-ACE is a Freescale display controller. 2D-ACE describes
the functionality of the module extremely well its name is a value
that cannot be used as a token in programming languages.
Instead the valid token "DCU" is used to tag the register names and
function names.
The Display Controller Unit (DCU) module is a system master that
fetches graphics stored in internal or external memory and displays
them on a TFT LCD panel. A wide range of panel sizes is supported
and the timing of the interface signals is highly configurable.
Graphics are read directly from memory and then blended in real-time,
which allows for dynamic content creation with minimal CPU
intervention.
The features:
(1) Full RGB888 output to TFT LCD panel.
(2) Blending of each pixel using up to 4 source layers
dependent
on size of panel.
(3) Each graphic layer can be placed with one pixel resolution
in either axis.
(4) Each graphic layer support RGB565 and RGB888 direct colors
without alpha channel and BGRA8888 BGRA4444 ARGB1555 direct
colors
with an alpha channel and YUV422 format.
(5) Each graphic layer support alpha blending with 8-bit
resolution.
This is a simplified version, only one primary plane, one
framebuffer, one crtc, one connector and one encoder for TFT
LCD panel.
Signed-off-by: Alison Wang <b18965@freescale.com>
Signed-off-by: Xiubo Li <lixiubo@cmss.chinamobile.com>
Signed-off-by: Jianwei Wang <jianwei.wang.chn@gmail.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
