path: root/drivers/gpu/drm/gma500/gtt.c
2014-07-08drm/gem: remove misleading gfp parameter to get_pages()David Herrmann
drm_gem_get_pages() currently allows passing a 'gfp' parameter that is passed to shmem combined with mapping_gfp_mask(). Given that the default mapping_gfp_mask() is GFP_HIGHUSER, it is _very_ unlikely that anyone will ever make use of that parameter. In fact, all drivers currently pass redundant flags or 0. This patch removes the 'gfp' parameter. The only reason to keep it is to remove flags like __GFP_WAIT. But in its current form, it can only be used to add flags. So to remove __GFP_WAIT, you'd have to drop it from the mapping_gfp_mask, which again is stupid as this mask is used by shmem-core for other allocations, too. If any driver ever requires that parameter, we can introduce a new helper that takes the raw 'gfp' parameter. The caller'd be responsible to combine it with mapping_gfp_mask() in a suitable way. The current drm_gem_get_pages() helper would then simply use mapping_gfp_mask() and call the new helper. This is what shmem_read_mapping_pages{_gfp,} does right now. Moreover, the gfp-zone flag-usage is not obvious: If you pass a modified zone, shmem core will WARN() or even BUG(). In other words, the following must be true for 'gfp' passed to shmem_read_mapping_pages_gfp(): gfp_zone(mapping_gfp_mask(mapping)) == gfp_zone(gfp) Add a comment to drm_gem_read_pages() explaining that constraint. Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
2014-03-17drm/gma500: Add backing type and base align to psb_gem_create()Patrik Jakobsson
We'll need this for our gem create ioctl in a later patch. Signed-off-by: Patrik Jakobsson <patrik.r.jakobsson@gmail.com>
2014-03-17drm/gma500: Hook up the MMUPatrik Jakobsson
Properly init the MMU and add MMU entries when adding GTT entries Signed-off-by: Patrik Jakobsson <patrik.r.jakobsson@gmail.com>
2013-10-09drm/gma500: fix things after get/put page helpersRob Clark
Commit 8b9ba7a3 'drm/gma500: use gem get/put page helpers' was missing a line, which resulted in garbled screen. Signed-off-by: Rob Clark <robdclark@gmail.com> Tested-by: Guillaume CLÉMENT <gclement@baobob.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-08-19drm/gma500: use gem get/put page helpersRob Clark
Signed-off-by: Rob Clark <robdclark@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-04-17Merge branch 'gma500-next' of git://github.com/patjak/drm-gma500 into drm-nextDave Airlie
Patrik writes: I haven't had much review or testing on other platforms than Poulsbo but at least the following Cedarview bug has been squashed and no regressions reported: https://bugs.freedesktop.org/show_bug.cgi?id=58527 * 'gma500-next' of git://github.com/patjak/drm-gma500: drm/gma500: Add debugging info to psb_gtt_restore() drm/gma500: Check connector status before restoring sdvo gma500:fix build failure for 3.9-rc5 drm/gma500: Fix hibernation problems on sdvo encoders drm/gma500: Add hooks for hibernation drm/gma500: Activate the gtt rebuild on suspend/resume drm/gma500: Add support for rebuilding the gtt drm/gma500: Change fb name so pm-utils doesn't apply quirks gma500: Make VGA and HDMI connector hotpluggable drm/gma500: Clean up various defines drm/gma500: Remove unnecessary function exposure drm/gma500: Type clock limits directly into array and remove defines drm/gma500: Calculate clock in one function instead of three identical drm/gma500: Remove unused i8xx clock limits gma500: medfield: Fix possible NULL pointer dereference drivers: gpu: drm: gma500: Replaced calls kzalloc & memcpy with kmemdup gma500: remove unused drm_psb_no_fb
2013-04-15drm/gma500: Add debugging info to psb_gtt_restore()Patrik Jakobsson
This makes it easier to see what's going on during resume/restore. Signed-off-by: Patrik Jakobsson <patrik.r.jakobsson@gmail.com>
2013-04-07drm/gma500: Add support for rebuilding the gttPatrik Jakobsson
2013-02-22new helper: file_inode(file)Al Viro
2012-05-11gma500: Clean up some of the noiseAlan Cox
We have a lot of debug type stuff we don't actually need any more. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-05-07gma500: gtt: fix __iomem sparse warningsKirill A. Shutemov
Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-05-07gma500: psb_gtt_init(): drop unused variableKirill A. Shutemov
2012-04-27gma500: Set the mapping maskAlan Cox
Some boards such as the Intel D2700MUD allow you to have over 4GB of RAM. The GTT on the PVR based devices is 32bit however. Hugh Dickins points out that we should therefore be setting the mapping gfp mask. This is not the whole fix for the problem. Some further shmem patches will be needed to deal with the corner cases. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-04-27gma500: mark framebuffer pages write combiningAlan Cox
We don't want them uncached, combining will do nicely and fixes the performance problem with the generic modesetting X server. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-15drm: Merge tag 'v3.3-rc7' into drm-core-nextDave Airlie
Merge the fixes so far into core-next, needed to test intel driver. Conflicts: drivers/gpu/drm/i915/intel_ringbuffer.c
2012-03-10gma500: gtt: mark psb_gtt_entry() and psb_gtt_alloc() as staticKirill A. Shutemov
2012-03-05drm, gma500: Fix Cedarview boot failures in 3.3-rcAlan Cox
Production GMA3600/3650 hardware turns out to be subtly different to the development platforms. This combined with a minor driver bug is causing the kernel to hang on these platforms. This patch does the following - turn down a couple of messages that were meant to be debug and are causing much confusion - ensure the hotplug interrupt is disabled on Cedartrail systems. - fix a bug where gtt roll mode called psbfb_sync, which tries to sync the 2D engine. On other devices it is harmless as the 2D engine is present but not in use when in gtt roll mode, on Cedartrail it causes a hang Without these changes 3.3-rc hangs on boot on Cedartrail based systems. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-24gma500: Fix shmem mappingAlan Cox
GMA500 did it the old way and it's been on the TODO list to fix. Current kernels now blow up if we use the old way so we'd better do the work! Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-06gma500: gtt based hardware scrolling consoleAlan Cox
Add support for GTT based scrolling. Instead of pushing bits around we simply use the GTT to change the mappings. This provides us with a very fast way to scroll the display providing we have enough memory to allocate on 4K line boundaries. In practice this seems to be the case except for very big displays such as HDMI, and the usual configurations are netbooks/tablets. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-12-06gma500: do a pass over the FIXME tagsAlan Cox
2011-11-16gma500: introduce the GTT and MMU handling logicAlan Cox
This fits alongside the GEM support to manage our resources on the card itself. It's not actually clear we need to configure the MMU at all. Further research is needed before removing it entirely. For now we suck it in (slightly abused) from the old semi-free driver. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
