So that we don't get build failures once the implicit module.h
presence is removed.
This abstracts the pci/platform interface out a step further,
we can go further but this is far enough for now to allow USB
to be plugged in.
The drivers now just call the init code directly for their
device type.
SMP i810 systems were practically nonexistent and the configuration
was not officially supported by Intel at the time when Pentium-III
was common.
With this change, it is still possible to build a distribution kernel
that has support for SMP and includes the i810 driver without the BKL.
As a precaution, check for the theoretical SMP case at run time and
refuse to load the driver.
We also need to disable CONFIG_PREEMPT builds for this driver.
Cc: dri-devel@lists.freedesktop.org
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (476 commits)
vmwgfx: Implement a proper GMR eviction mechanism
drm/radeon/kms: fix r6xx/7xx 1D tiling CS checker v2
drm/radeon/kms: properly compute group_size on 6xx/7xx
drm/radeon/kms: fix 2D tile height alignment in the r600 CS checker
drm/radeon/kms/evergreen: set the clear state to the blit state
drm/radeon/kms: don't poll dac load detect.
gpu: Add Intel GMA500(Poulsbo) Stub Driver
drm/radeon/kms: MC vram map needs to be >= pci aperture size
drm/radeon/kms: implement display watermark support for evergreen
drm/radeon/kms/evergreen: add some additional safe regs v2
drm/radeon/r600: fix tiling issues in CS checker.
drm/i915: Move gpu_write_list to per-ring
drm/i915: Invalidate the to-ring, flush the old-ring when updating domains
drm/i915/ringbuffer: Write the value passed in to the tail register
agp/intel: Restore valid PTE bit for Sandybridge after bdd3072
drm/i915: Fix flushing regression from 9af90d19f
drm/i915/sdvo: Remove unused encoding member
i915: enable AVI infoframe for intel_hdmi.c [v4]
drm/i915: Fix current fb blocking for page flip
drm/i915: IS_IRONLAKE is synonymous with gen == 5
Fix up conflicts in
- drivers/gpu/drm/i915/{i915_gem.c, i915/intel_overlay.c}: due to the
new simplified stack-based kmap_atomic() interface
- drivers/gpu/drm/vmwgfx/vmwgfx_drv.c: added .llseek entry due to BKL
removal cleanups.
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
necessary for some of the vmware fixes to be pushed in.
drivers/gpu/drm/drm_gem.c
drivers/gpu/drm/i915/intel_fb.c
include/drm/drmP.h
The i810 and i830 device drivers may replace their file operations
on an open file descriptor. My previous patch to move the BKL
out of the common DRM code into these drivers only caught the
default file operations, not the ones that actually end up being
used.
Found while trying to come up with a way to kill the BKL for
good in these drivers.
The drm device drivers currently allow seeking on the
character device but never care about the actual
file position.
When we change the default llseek operation to be
no_llseek, calling llseek on a drm device would
return an error condition, which is an API change.
Explicitly setting noop_llseek lets us keep the
current API.
Cc: David Airlie <airlied@linux.ie>
Every driver used the default implementation. Fold that one into
the only callsite and drop the callback.
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
All drivers happily copy&pasted the default implementation without
checking whether this callback is used at all. It's not. Sigh.
Kill it.
(v2)
With the current screwed but its ABI, ioctls for the drm, Linus pointed out that we could allow userspace to specify the allocation size, but we pass it to the driver which then uses it blindly to store a struct. Now if userspace specifies the allocation size as smaller than the driver needs, the driver can possibly overwrite memory.
This patch restructures the driver ioctls so we store the structure size we are expecting, and make sure we allocate at least that size. The copy from/to userspace are still restricted to the size the user specifies, this allows ioctl structs to grow on both sides of the equation.
Up until now we didn't really use the DRM_IOCTL defines in the kernel, so this cleans them up and adds them for nouveau.
v2:
fix nouveau pushbuf arg (thanks to Ben for pointing it out)
Reported-by: Linus Torvalds <torvalds@linuxfoundation.org>
This restricts the use of the big kernel lock to the i830 and i810
device drivers. The three remaining users in common code (open, ioctl
and release) get converted to a new mutex, the drm_global_mutex,
making the locking stricter than the big kernel lock.
This may have a performance impact, but only in those cases that
currently don't use DRM_UNLOCKED flag in the ioctl list and would
benefit from that anyway.
The reason why i810 and i830 cannot use drm_global_mutex in their
mmap functions is a lock-order inversion problem between the current
use of the BKL and mmap_sem in these drivers. Since the BKL has
release-on-sleep semantics, it's harmless but it would cause trouble
if we replace the BKL with a mutex.
Instead, these drivers get their own ioctl wrappers that take the
BKL around every ioctl call and then set their own handlers as
DRM_UNLOCKED.
Fixed brace, macro and spacing coding style issues, and a C99 comment.
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
drm_ioctl is called with the Big Kernel Lock held,
which shows up very high in statistics on vfs_ioctl.
Moving the lock into the drm_ioctl function itself
makes sure we blame the right subsystem and it gets
us one step closer to eliminating the locked version
of fops->ioctl.
Since drm_ioctl does not require the lock itself,
we only need to hold it while calling the specific
handler. The 32 bit conversion handlers do not
interact with any other code, so they don't need
the BKL here either and can just call drm_ioctl.
As a bonus, this cleans up all the other users
of drm_ioctl which now no longer have to find
the inode or call lock_kernel.
[airlied: squashed the non-driver bits
of the second patch in here, this provides
the flag for drivers to use to select unlocked
ioctls - but doesn't modify any drivers].
Cc: dri-devel@lists.sourceforge.net
It hasn't been used in ages, and having the user tell your how much
memory is being freed at free time is a recipe for disaster even if it
was ever used.
Signed-off-by: Eric Anholt <eric@anholt.net>
Once upon a time, the DRM made the distinction between the drm_map
data structure exchanged with user space and the drm_local_map used
in the kernel.
For some reasons, while the BSD port still has that "feature", the
linux part abused drm_map for kernel internal usage as the local
map only existed as a typedef of the struct drm_map.
This patch fixes it by declaring struct drm_local_map separately
(though its content is currently identical to the userspace variant),
and changing the kernel code to only use that, except when it's a
user<->kernel interface (ie. ioctl).
This allows subsequent changes to the in-kernel format
I've also replaced the use of drm_local_map_t with struct drm_local_map
in a couple of places. Mostly by accident but they are the same (the
former is a typedef of the later) and I have some remote plans and
half finished patch to completely kill the drm_local_map_t typedef
so I left those bits in.
Acked-by: Eric Anholt <eric@anholt.net>
Signed-off-by: Dave Airlie <airlied@linux.ie>
With the coming of kernel based modesetting and the memory manager stuff,
the everything in one directory approach was getting very ugly and
starting to be unmanageable.
This restructures the drm along the lines of other kernel components.
It creates a drivers/gpu/drm directory and moves the hw drivers into
subdirectores. It moves the includes into an include/drm, and
sets up the unifdef for the userspace headers we should be exporting.
