We need this code to init the PCH SSC refclk and the FDI registers.
The BIOS does this too and that's why VGA worked before this patch,
until you tried to suspend the machine...
This patch implements the "Sequence to enable CLKOUT_DP for FDI usage
and configure PCH FDI/IO" from our documentation.
v2:
- Squash Damien Lespiau's reset spelling fix on top.
- Add a comment that we don't need to bother about the ULT special
case Damien noticed, since ULT won't have VGA.
- Add a comment to rip out the SDV codepaths once haswell ships for
real.
Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com> (v1)
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
There seem to be indeed some awkwards machines around, mostly those
without OpRegion support, where the firmware changes the display hw
state behind our backs when closing the lid.
This force-restore logic has been originally introduced in
commit c1c7af60892070e4b82ad63bbfb95ae745056de0
Author: Jesse Barnes <jbarnes@virtuousgeek.org>
Date: Thu Sep 10 15:28:03 2009 -0700
drm/i915: force mode set at lid open time
but after the modeset-rework we've disabled it in the vain hope that
it's no longer required:
commit 3b7a89fce3e3dc96b549d6d829387b4439044d0d
Author: Daniel Vetter <daniel.vetter@ffwll.ch>
Date: Mon Sep 17 22:27:21 2012 +0200
drm/i915: fix OOPS in lid_notify
Alas, no.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=54677
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=57434
Tested-by: Krzysztof Mazur <krzysiek@podlesie.net>
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Since it should be working a little bit better now.
We need to enable a special bit, otherwise none of the DP functions
requiring the PCH will work.
Version 2: store the PCH ID inside dev_priv, as suggested by Daniel
Vetter.
Reviewed-by: Damien Lespiau <damien.lespiau@intel.com>
We don't check if the "unclaimed register" bit is set before we call
writel, so if it was already set before, we might print a misleading
message about "unclaimed write" on the wrong register.
This patch makes us check the unclaimed bit before the writel, so we
can print a new "Unknown unclaimed register before writing to %x"
message.
But disabled by default. This essentially reverts
commit bcd5023c961a44c7149936553b6929b2b233dd27
Author: Dave Airlie <airlied@redhat.com>
Date: Mon Mar 14 14:17:55 2011 +1000
drm/i915: disable opregion lid detection for now
but leaves the autodetect mode disabled. There's also the explicit lid
status option added in
commit fca874092597ef946b8f07031d8c31c58b212144
Author: Chris Wilson <chris@chris-wilson.co.uk>
Date: Thu Feb 17 13:44:48 2011 +0000
drm/i915: Add a module parameter to ignore lid status
Which overloaded the meaning for the panel_ignore_lid parameter even
more. To fix up this mess, give the non-negative numbers 0,1 the
original meaning back and use negative numbers to force a given state.
So now we have
1 - disable autodetect, return unknown
0 - enable autodetect
-1 - force to disconnected/lid closed
-2 - force to connected/lid open
v2: My C programmer license has been revoked ...
v3: Beautify the code a bit, as suggested by Chris Wilson.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=27622
Tested-by: Andreas Sturmlechner <andreas.sturmlechner@gmail.com>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
[pzanoni: rebase, print it's an LP PCH]
Tested-by: Josh Triplett <josh@joshtriplett.org>
into drm-next
Daniel writes:
Highlights of this -next round:
- ivb fdi B/C fixes
- hsw sprite/plane offset fixes from Damien
- unified dp/hdmi encoder for hsw, finally external dp support on hsw
(Paulo)
- kill-agp and some other prep work in the gtt code from Ben
- some fb handling fixes from Ville
- massive pile of patches to align hsw VGA with the spec and make it
actually work (Paulo)
- pile of workarounds from Jesse, mostly for vlv, but also some other
related platforms
- start of a dev_priv reorg, that thing grew out of bounds and chaotic
- small bits&pieces all over the place, down to better error handling for
load-detect on gen2 (Chris, Jani, Mika, Zhenyu, ...)
On top of the previous pile (just copypasta):
- tons of hsw dp prep patches form Paulo
- round scheduled work items and timers to nearest second (Chris)
- some hw workarounds (Jesse&Damien)
- vlv dp support and related fixups (Vijay et al.)
- basic haswell dp support, not yet wired up for external ports (Paulo)
- edp support (Paulo)
- tons of refactorings to prepare for the above (Paulo)
- panel rework, unifiying code between lvds and edp panels (Jani)
- panel fitter scaling modes (Jani + Yuly Novikov)
- panel power improvements, should now work without the BIOS setting it up
- extracting some dp helpers from radeon/i915 and move them to
drm_dp_helper.c
- randome pile of workarounds (Damien, Ben, ...)
- some cleanups for the register restore code for suspend/resume
- secure batchbuffer support, should enable tear-free blits on gen6+
Chris)
- random smaller fixlets and cleanups.
* 'for-airlied' of git://people.freedesktop.org/~danvet/drm-intel: (231 commits)
drm/i915: Restore physical HWS_PGA after resume
drm/i915: Report amount of usable graphics memory in MiB
drm/i915/i2c: Track users of GMBUS force-bit
drm/i915: Allocate the proper size for contexts.
drm/i915: Update load-detect failure paths for modeset-rework
drm/i915: Clear unused fields of mode for framebuffer creation
drm/i915: Always calculate 8xx WM values based on a 32-bpp framebuffer
drm/i915: Fix sparse warnings in from AGP kill code
drm/i915: Missed lock change with rps lock
drm/i915: Move the remaining gtt code
drm/i915: flush system agent TLBs on SNB
drm/i915: Kill off now unused gen6+ AGP code
drm/i915: Calculate correct stolen size for GEN7+
drm/i915: Stop using AGP layer for GEN6+
drm/i915: drop the double-OP_STOREDW usage in blt_ring_flush
drm/i915: don't rewrite the GTT on resume v4
drm/i915: protect RPS/RC6 related accesses (including PCU) with a new mutex
drm/i915: put ring frequency and turbo setup into a work queue v5
drm/i915: don't block resume on fb console resume v2
drm/i915: extract l3_parity substruct from dev_priv
The BIOS shouldn't be touching this memory across suspend/resume, so
just leave it alone. This saves us ~6ms on resume on my T420 (retested
with write combined PTEs).
v2: change gtt restore default on pre-gen4 (Chris)
move needs_gtt_restore flag into dev_priv
v3: make sure we restore GTT on resume from hibernate (Daniel)
use opregion support as the cutoff for restore from resume (Chris)
v4: use a better check for opregion (Chris)
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
[danvet: Kill the needs_gtt_restore indirection and check directly for
OpRegion. Also explain in a comment what's going on.]
Communicating via the mailbox registers with the PCU can take quite
awhile. And updating the ring frequency or enabling turbo is not
something that needs to happen synchronously, so take it out of our init
and resume paths to speed things up (~200ms on my T420).
v2: add comment about why we use a work queue (Daniel)
make sure work queue is idle on suspend (Daniel)
use a delayed work queue since there's no hurry (Daniel)
v3: make cleanup symmetric and just call cancel work directly (Daniel)
v4: schedule the work using round_jiffies_up to batch work better (Chris)
v5: fix the right schedule_delayed_work call (Chris)
References: https://bugs.freedesktop.org/show_bug.cgi?id=54089
Signed-of-by: Jesse Barnes <jbarnes@virtuougseek.org>
[danvet: bikeshed the placement of the new delayed work, move it to
all the other gen6 power mgmt stuff.]
The console lock can be contended, so rather than prevent other drivers
after us from being held up, queue the console suspend into the global
work queue that can happen anytime. I've measured this to take around
200ms on my T420. Combined with the ring freq/turbo change, we should
save almost 1/2 a second on resume.
v2: use console_trylock() to try to resume the console immediately (Chris)
[danvet: move dev_priv->console_resume_work next to the fbdev
pointer.]
So we can write them properly.
Reviewed-by: Antti Koskipää <antti.koskipaa@intel.com>
Workaround for dual port PS dispatch on GT1.
v2: pull in register definition & offset handling
v3: use IVB GT1 macro to get the right regs (Ben)
v4: add for VLV too (Ben)
v5: don't read the reg, it's masked so we'll only enable the one extra bit (Chris)
v6: use a _GT2 suffix for the second reg (Chris)
v2: use correct register
v3: remove extra hunks, pull in register definitions & offset check directly
v4: add GT1 vs GT2 distinction for IVB portion (Ben)
References: https://bugs.freedesktop.org/show_bug.cgi?id=50233
Reviewed-by: Ben Widawsky <ben@bwidawsk.net>
We don't really support fancy north display/pch combinations, so
put a big yelling WARN_ON in there. It /should/ be impossible, but
alas, the rumours don't stop (mostly due to really early silicon
sometimes using older PCHs).
v2: Fixup the logic fumble noticed by Paulo Zanoni. I should actually
try to test run the patch next time around ...
Reviewed-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
Or at least our best understanding of it.
v2: Fixup commit message and put the wa name into the comment block.
And actually update the commit, too.
Linux 3.7-rc2
Backmerge to solve two ugly conflicts:
- uapi. We've already added new ioctl definitions for -next. Do I need to say more?
- wc support gtt ptes. We've had to revert this for snb+ for 3.7 and
also fix a few other things in the code. Now we know how to make it
work on snb+, but to avoid losing the other fixes do the backmerge
first before re-enabling wc gtt ptes on snb+.
And a few other minor things, among them git getting confused in
intel_dp.c and seemingly causing a conflict out of nothing ...
drivers/gpu/drm/i915/i915_reg.h
drivers/gpu/drm/i915/intel_display.c
drivers/gpu/drm/i915/intel_dp.c
drivers/gpu/drm/i915/intel_modes.c
include/drm/i915_drm.h
git://people.freedesktop.org/~danvet/drm-intel into drm-fixes
Daniel writes:
The big thing is the disabling of the hsw support by default, cc: stable.
We've aimed for basic hsw support in 3.6, but due to a few bad
happenstances we've screwed up and only 3.8 will have better modeset
support than vesa. To avoid yet another round of fallout from such a
gaffle on for the next platform we've added a module option to disable
early hw support by default. That should also give us more flexibility in
bring-up.
Otherwise just small fixes:
- 3 fixes from Egbert for sdvo corner cases
- invert-brightness quirk entry from Egbert
- revert a dp link training change, it regresses some setups
- and shut up a spurious WARN in our gem fault handler.
- regression fix for an oops on bit17 swizzling machines, introduce in 3.7
- another no-lvds quirk
* 'drm-intel-fixes' of git://people.freedesktop.org/~danvet/drm-intel:
drm/i915: Initialize obj->pages before use by i915_gem_object_do_bit17_swizzle()
drm/i915: Add no-lvds quirk for Supermicro X7SPA-H
drm/i915: Insert i915_preliminary_hw_support variable.
drm/i915: shut up spurious WARN in the gtt fault handler
Revert "drm/i915: Try harder to complete DP training pattern 1"
DRM/i915: Restore sdvo_flags after dtd->mode->dtd Roundrtrip.
DRM/i915: Don't clone SDVO LVDS with analog.
DRM/i915: Add QUIRK_INVERT_BRIGHTNESS for NCR machines.
DRM/i915: Don't delete DPLL Multiplier during DAC init.
Some BIOSes may forcibly suspend RC6 during their operation which
trigger a warning as we find the hardware in a perplexing state upon
first use. So far that appears to be the worst symptom as fortuituously
we use the same values as the BIOS for programming the FORCEWAKE register.
Reported-by: Oleksij Rempel <bug-track@fisher-privat.net>
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
... instead of relying on the register save/restore madness to do this.
To extract a bit of code call drm_mode_config_reset both on resume
and boot-up and move the hw state frobbing from the crt_init to the
->reset callback. The crt connector is the only one with a ->reset
callback, hence we can easily do this.
On the worst scenario, users with new hardwares and old kernel from
enabling times can get black screens. So, from now on, this
perliminary_hw_support module parameter shall be used by all upcoming
platforms that are still under enabling. The second option would be to
merge the pci ids after basic modeset works, but that makes testing
and development while bringing up hw a rather tedious afair.
Although it is uncomfortable for developers use this extra variable it
brings more stability for end users.
Signed-off-by: Rodrigo Vivi <rodrigo.vivi@gmail.com>
Reviewed-by: Dave Airlie <airlied@redhat.com>
[danvet: dropped the i915_ param prefix, i915.i915_ is just tedious.]
Pull drm merge (part 1) from Dave Airlie:
"So first of all my tree and uapi stuff has a conflict mess, its my
fault as the nouveau stuff didn't hit -next as were trying to rebase
regressions out of it before we merged.
Highlights:
- SH mobile modesetting driver and associated helpers
- some DRM core documentation
- i915 modesetting rework, haswell hdmi, haswell and vlv fixes, write
combined pte writing, ilk rc6 support,
- nouveau: major driver rework into a hw core driver, makes features
like SLI a lot saner to implement,
- psb: add eDP/DP support for Cedarview
- radeon: 2 layer page tables, async VM pte updates, better PLL
selection for > 2 screens, better ACPI interactions
The rest is general grab bag of fixes.
So why part 1? well I have the exynos pull req which came in a bit
late but was waiting for me to do something they shouldn't have and it
looks fairly safe, and David Howells has some more header cleanups
he'd like me to pull, that seem like a good idea, but I'd like to get
this merge out of the way so -next dosen't get blocked."
Tons of conflicts mostly due to silly include line changes, but mostly
mindless. A few other small semantic conflicts too, noted from Dave's
pre-merged branch.
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (447 commits)
drm/nv98/crypt: fix fuc build with latest envyas
drm/nouveau/devinit: fixup various issues with subdev ctor/init ordering
drm/nv41/vm: fix and enable use of "real" pciegart
drm/nv44/vm: fix and enable use of "real" pciegart
drm/nv04/dmaobj: fixup vm target handling in preparation for nv4x pcie
drm/nouveau: store supported dma mask in vmmgr
drm/nvc0/ibus: initial implementation of subdev
drm/nouveau/therm: add support for fan-control modes
drm/nouveau/hwmon: rename pwm0* to pmw1* to follow hwmon's rules
drm/nouveau/therm: calculate the pwm divisor on nv50+
drm/nouveau/fan: rewrite the fan tachometer driver to get more precision, faster
drm/nouveau/therm: move thermal-related functions to the therm subdev
drm/nouveau/bios: parse the pwm divisor from the perf table
drm/nouveau/therm: use the EXTDEV table to detect i2c monitoring devices
drm/nouveau/therm: rework thermal table parsing
drm/nouveau/gpio: expose the PWM/TOGGLE parameter found in the gpio vbios table
drm/nouveau: fix pm initialization order
drm/nouveau/bios: check that fixed tvdac gpio data is valid before using it
drm/nouveau: log channel debug/error messages from client object rather than drm client
drm/nouveau: have drm debugging macros build on top of core macros
Convert #include "..." to #include <path/...> in drivers/gpu/.
Acked-by: Dave Airlie <airlied@redhat.com>
Acked-by: Dave Jones <davej@redhat.com>
Remove redundant DRM UAPI header #inclusions from drivers/gpu/.
Remove redundant #inclusions of core DRM UAPI headers (drm.h, drm_mode.h and
drm_sarea.h). They are now #included via drmP.h and drm_crtc.h via a preceding
patch.
Without this patch and the patch to make include the UAPI headers from the core
headers, after the UAPI split, the DRM C sources cannot find these UAPI headers
because the DRM code relies on specific -I flags to make #include "..." work
on headers in include/drm/ - but that does not work after the UAPI split without
adding more -I flags.
As a quick reference I'll detail the motivation and design of the new code a
bit here (mostly stitched together from patchbomb announcements and commits
introducing the new concepts).
The crtc helper code has the fundamental assumption that encoders and crtcs can
be enabled/disabled in any order, as long as we take care of depencies (which
means that enabled encoders need an enabled crtc to feed them data,
essentially).
Our hw works differently. We already have tons of ugly cases where crtc code
enables encoder hw (or encoder->mode_set enables stuff that should only be
enabled in enocder->commit) to work around these issues. But on the disable
side we can't pull off similar tricks - there we actually need to rework the
modeset sequence that controls all this. And this is also the real motivation
why I've finally undertaken this rewrite: eDP on my shiny new Ivybridge
Ultrabook is broken, and it's broken due to the wrong disable sequence ...
The new code introduces a few interfaces and concepts:
- Add new encoder->enable/disable functions which are directly called from the
crtc->enable/disable function. This ensures that the encoder's can be
enabled/disabled at a very specific in the modeset sequence, controlled by our
platform specific code (instead of the crtc helper code calling them at a time
it deems convenient).
- Rework the dpms code - our code has mostly 1:1 connector:encoder mappings and
does support cloning on only a few encoders, so we can simplify things quite a
bit.
- Also only ever disable/enable the entire output pipeline. This ensures that
we obey the right sequence of enabling/disabling things, trying to be clever
here mostly just complicates the code and results in bugs. For cloneable
encoders this requires a bit of special handling to ensure that outputs can
still be disabled individually, but it simplifies the common case.
- Add infrastructure to read out the current hw state. No amount of careful
ordering will help us if we brick the hw on the initial modeset setup. Which
could happen if we just randomly disable things, oblivious to the state set up
by the bios. Hence we need to be able to read that out. As a benefit, we grow a
few generic functions useful to cross-check our modeset code with actual hw
state.
With all this in place, we can copy&paste the crtc helper code into the
drm/i915 driver and start to rework it:
- As detailed above, the new code only disables/enables an entire output pipe.
As a preparation for global mode-changes (e.g. reassigning shared resources) it
keeps track of which pipes need to be touched by a set of bitmasks.
- To ensure that we correctly disable the current display pipes, we need to
know the currently active connector/encoder/crtc linking. The old crtc helper
simply overwrote these links with the new setup, the new code stages the new
links in ->new_* pointers. Those get commited to the real linking pointers once
the old output configuration has been torn down, before the ->mode_set
callbacks are called.
- Finally the code adds tons of self-consistency checks by employing the new hw
state readout functions to cross-check the actual hw state with what the
datastructure think it should be. These checks are done both after every
modeset and after the hw state has been read out and sanitized at boot/resume
time. All these checks greatly helped in tracking down regressions and bugs in
the new code.
With this new basis, a lot of cleanups and improvements to the code are now
possible (besides the DP fixes that ultimately made me write this), but not yet
done:
- I think we should create struct intel_mode and use it as the adjusted mode
everywhere to store little pieces like needs_tvclock, pipe dithering values or
dp link parameters. That would still be a layering violation, but at least we
wouldn't need to recompute these kinds of things in intel_display.c. Especially
the port bpc computation needed for selecting the pipe bpc and dithering
settings in intel_display.c is rather gross.
- In a related rework we could implement ->mode_valid in terms of ->mode_fixup
in a generic way - I've hunted down too many bugs where ->mode_valid did the
right thing, but ->mode_fixup didn't. Or vice versa, resulting in funny bugs
for user-supplied modes.
- Ditch the idea to rework the hdp handling in the common crtc helper code and
just move things to i915.ko. Which would rid us of the ->detect crtc helper
dependencies.
- LVDS wire pair and pll enabling is all done in the crtc->mode_set function
currently. We should be able to move this to the crtc_enable callbacks (or in
the case of the LVDS wire pair enabling, into some encoder callback).
Last, but not least, this new code should also help in enabling a few neat
features: The hw state readout code prepares (but there are still big pieces
missing) for fastboot, i.e. avoiding the inital modeset at boot-up and just
taking over the configuration left behind by the bios. We also should be able
to extend the configuration checks in the beginning of the modeset sequence and
make better decisions about shared resources (which is the entire point behind
the atomic/global modeset ioctl).
Tested-by: Jani Nikula <jani.nikula@intel.com>
Tested-by: Ben Widawsky <ben@bwidawsk.net>
Tested-by: Damien Lespiau <damien.lespiau@intel.com>
Tested-by: Rodrigo Vivi <rodrigo.vivi@gmail.com>
Acked-by: Chris Wilson <chris@chris-wilson.co.uk>
Tested-by: Vijay Purushothaman <vijay.a.purushothaman@intel.com>
Acked-by: Vijay Purushothaman <vijay.a.purushothaman@intel.com>
Tested-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
Acked-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
Tested-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Since this only calls crtc helper functions, of which a shocking
amount are NULL.
Now the curious thing is how the new modeset code worked with this
function call still present:
Thanks to the hw state readout and the suspend fixes to properly
quiescent the register state, nothing is actually enabled at resume
(if the bios doesn't set up anything). Which means resume_force_mode
doesn't actually do anything and hence nothing blows up at resume
time.
The other reason things do work is that the fbcon layer has it's own
resume notifier callback, which restores the mode. And thanks to the
force vt switch at suspend/resume, that then forces X to restore it's
own mode.
Hence everything still worked (as long as the bios doesn't enable
anything). And we can just kill the call to resume_force_mode.
The upside of both this patch and the preceeding patch to quiescent
the modeset state is that our resume path is much simpler:
- We now longer restore bogus register values (which most often would
enable the backlight a bit and a few ports), causing flickering.
- We now longer call resume_force_mode to restore a mode that the
fbcon layer would overwrite right away anyway.
We need this to avoid confusing the hw state readout code with the cpt
pch plls at resume time: We'd read the new pipe state (which is
disabled), but still believe that we have a life pll connected to that
pipe (from before the suspend). Hence properly disable pipes to clear
out all the residual state.
This has the neat side-effect that we don't enable ports prematurely
by restoring bogus state from the saved register values.
Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
... instead of resetting a few things and hoping that this will work
out.
To properly disable the output pipelines at the initial modeset after
resume or boot up we need to have an accurate picture of which outputs
are enabled and connected to which crtcs. Otherwise we risk disabling
things at the wrong time, which can lead to hangs (or at least royally
confused panels), both requiring a walk to the reset button to fix.
Hence read out the hw state with the freshly introduce get_hw_state
functions and then sanitize it afterwards.
For a full modeset readout (which would allow us to avoid the initial
modeset at boot up) a few things are still missing:
- Reading out the mode from the pipe, especially the dotclock
computation is quite some fun.
- Reading out the parameters for the stolen memory framebuffer and
wrapping it up.
- Reading out the pch pll connections - luckily the disable code
simply bails out if the crtc doesn't have a pch pll attached (even
for configurations that would need one).
This patch here turned up tons of smelly stuff around resume: We
restore tons of register in seemingly random way (well, not quite, but
we're not too careful either), which leaves the hw in a rather
ill-defined state: E.g. the port registers are sometimes
unconditionally restore (lvds, crt), leaving us with an active
encoder/connector but no active pipe connected to it. Luckily the hw
state sanitizer detects this madness and fixes things up a bit.
v2: When checking whether an encoder with active connectors has a crtc
wire up to it, check for both the crtc _and_ it's active state.
v3:
- Extract intel_sanitize_encoder.
- Manually disable active encoders without an active pipe.
v4: Correclty fix up the pipe<->plane mapping on machines where we
switch pipes/planes. Noticed by Chris Wilson, who also provided the
fixup.
v5: Spelling fix in a comment, noticed by Paulo Zanoni
ERR_INT on HSW will display unclaimed MMIO accesses. This can be either
the result of a driver bug writing to an invalid addresses, or the
result of RC6.
Signed-off-by: Ben Widawsky <ben@bwidawsk.net>
Reviewed-by: Antti Koskipaa <antti.koskipaa@linux.intel.com>
Backmerge Linux 3.6-rc2 to resolve a few funny conflicts before we put
even more madness on top:
- drivers/gpu/drm/i915/i915_irq.c: Just a spurious WARN removed in
-fixes, that has been changed in a variable-rename in -next, too.
- drivers/gpu/drm/i915/intel_ringbuffer.c: -next remove scratch_addr
(since all their users have been extracted in another fucntion),
-fixes added another user for a hw workaroudn.
Also properly indent the HB IDs.
Reviewed-by: Rodrigo Vivi <rodrigo.vivi@gmail.com>
Will be used more in the next patch.
The interface's immediate purpose is to do synchronous timestamp queries
as required by GL_TIMESTAMP. The GPU has a register for reading the
timestamp but because that would normally require root access through
libpciaccess, the IOCTL can provide this service instead.
Currently the implementation whitelists only the render ring timestamp
register, because that is the only thing we need to expose at this time.
v2: make size implicit based on the register offset
Add a generation check
Reviewed-by: Eric Anholt <eric@anholt.net>
Cc: Jacek Lawrynowicz <jacek.lawrynowicz@intel.com>
[danvet: fixup the ioctl numerb:]
All leftover users either haven't set DRIVER_HAVE_DMA, in which
case this will never be called, or use the drm_core implementation.
Call that directly in the only callsite.
Simply failing to reset the gpu because someone else might still hold
the mutex isn't a great idea - I see reliable silent reset failures.
And gpu reset simply needs to be reliable and Just Work.
"But ... the deadlocks!"
We already kick all processes waiting for the gpu before launching the
reset work item. New waiters need to check the wedging state anyway
and then bail out. If we have places that can deadlock, we simply need
to fix them.
"But ... testing!"
We have the gpu hangman, and if the current gpu load gem_exec_nop
isn't good enough to hit a specific case, we can add a new one.
"But ... don't we return -EAGAIN for non-interruptible calls to
wait_seqno now?"
Yep, but this problem already exists in the current code. A follow up
patch will remedy this by returning -EIO for non-interruptible sleeps
if the gpu died and the low-level wait bails out with -EAGAIN.
Tested-by: Chris Wilson <chris@chris-wilson.co.uk>
This function is used to set the PCH_DREF_CONTROL register, which does
not exist on LPT anymore.
Previously we had has_pch_split to tell us whether we had a PCH or not
and we also had dev_priv->pch_type to tell us which kind of PCH it
was, but it could only be used if we were 100% sure we did have a PCH.
Now that PCH_NONE was added to dev_priv->pch_type we don't need
has_pch_split anymore: we can just check for pch_type != PCH_NONE.
The HAS_PCH_{IBX,CPT,LPT} macros use dev_priv->pch_type, so they can
only be called after intel_detect_pch. The HAS_PCH_SPLIT macro looks
at dev_priv->info->has_pch_split, which is available earlier.
Since the goal is to implement HAS_PCH_SPLIT using dev_priv->pch_type
instead of dev_priv->info->has_pch_split, we need to make sure that
intel_detect_pch is called before any calls to HAS_PCH_SPLIT are made.
So we moved the intel_detect_pch call to an earlier stage.
This commit moves force wake support routines into intel_pm modules, and
exports the gen6_gt_check_fifodbg routine (used in I915_READ).
Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com>
Acked-by: Ben Widawsky <ben@bwidawsk.net>
There is a different ACK register for force wake on Haswell, so account
for that.
As a w/a to prevent reads sporadically returning 0, we need to wait for
the GT thread to return to TC0 before proceeding to read the registers.
v2: adapt for Haswell changes (Eugeni).
v3: use wait_for_atomic_us for thread status polling.
v3: *really* use wait_for_atomic for polling.
References: https://bugs.freedesktop.org/show_bug.cgi?id=50243
Tidy up the routines for interacting with the GT (in particular the
forcewake dance) which are scattered throughout the code in a single
structure.
v2: use wait_for_atomic for polling.
This is the quick&dirty way Dave Airlie suggested to workaround the
midlayer drm agp brain-damange. Note that i915_probe is only called
when the driver has ksm enabled, so no need to check for that.
We also need to move the intel_agp_enabled check at the right place.
Note that the only thing this does is enforce the correct module load
order (by using a symbol from intel-agp.ko) to ensure that the fake
agp driver is ready before the drm core tries to set up the agp stuff.
v2: Add a comment to explain why gen3 needs all this legacy fake agp
stuff - we've shipped an XvMC library with a kms-enabled ddx that
requires it (but only on gen3).
v3: Make it clear that this is only a gen3 issue in the comment.
Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com>
I want to merge the "no more fake agp on gen6+" patches into
drm-intel-next (well, the last pieces). But a patch in 3.5-rc4 also
adds a new use of dev->agp. Hence the backmarge to sort this out, for
otherwise drm-intel-next merged into Linus' tree would conflict in the
relevant code, things would compile but nicely OOPS at driver load :(
Conflicts in this merge are just simple cases of "both branches
changed/added lines at the same place". The only tricky part is to
keep the order correct wrt the unwind code in case of errors in
intel_ringbuffer.c (and the MI_DISPLAY_FLIP #defines in i915_reg.h
together, obviously).
With the code in place, we can bind the driver, should make bisect possible.
Since the offsets have all moved around.
v2: switch IS_DISPLAYREG and IS_VALLEYVIEW checks around since the latter is
cheaper (Daniel)
bail out early in IS_DISPLAYREG if the reg is in the new range (Daniel)
[danvet: Fixup if cascading fail that broke HAS_FORCEWAKE machines.]
It seems to blow up my ilk in all kinds of strange ways. And now that
we're no longer resetting the entire modeset state, it shouldn't be
necessary any longer.
commit f817586cebf1b946d1f327f9a596048efd6b64e9
Date: Tue Apr 10 15:50:11 2012 +0200
drm/i915: re-init modeset hw state after gpu reset
safe for the introduction of modeset_init_hw, that one is nice to
prevent code duplication between driver load and resume.
v2: Add a comment to the code to warn future travellers of the dragon
dungeon ahead, suggested by Chris Wilson.
I've added a bit of logic such that running the hangman test on chips
without any hw reset support at all doesn't wedge the gpu because the
reset failed. This relied on checking for non-null stop_rings.
Unfortunately I've botched a rebase somewhere and stop_rings is still
cleared at the old place before the reset code.
Fix this up so that running the i-g-t tests on gen2/3 doesn't result
in a wedged gpu.
v2: Actually remove the lines instead of adding them twice ... my git
license should be revoked immediately.
It's the only way we know how to make the GPU actually forget about the
default context.
Very basic code for context setup/destruction in the driver.
Adds the file i915_gem_context.c This file implements HW context
support. On gen5+ a HW context consists of an opaque GPU object which is
referenced at times of context saves and restores. With RC6 enabled,
the context is also referenced as the GPU enters and exists from RC6
(GPU has it's own internal power context, except on gen5). Though
something like a context does exist for the media ring, the code only
supports contexts for the render ring.
In software, there is a distinction between contexts created by the
user, and the default HW context. The default HW context is used by GPU
clients that do not request setup of their own hardware context. The
default context's state is never restored to help prevent programming
errors. This would happen if a client ran and piggy-backed off another
clients GPU state. The default context only exists to give the GPU some
offset to load as the current to invoke a save of the context we
actually care about. In fact, the code could likely be constructed,
albeit in a more complicated fashion, to never use the default context,
though that limits the driver's ability to swap out, and/or destroy
other contexts.
All other contexts are created as a request by the GPU client. These
contexts store GPU state, and thus allow GPU clients to not re-emit
state (and potentially query certain state) at any time. The kernel
driver makes certain that the appropriate commands are inserted.
There are 4 entry points into the contexts, init, fini, open, close.
The names are self-explanatory except that init can be called during
reset, and also during pm thaw/resume. As we expect our context to be
preserved across these events, we do not reinitialize in this case.
As Adam Jackson pointed out, The cutoff of 1MB where a HW context is
considered too big is arbitrary. The reason for this is even though
context sizes are increasing with every generation, they have yet to
eclipse even 32k. If we somehow read back way more than that, it
probably means BIOS has done something strange, or we're running on a
platform that wasn't designed for this.
v2: rename load/unload to init/fini (daniel)
remove ILK support for get_size() (indirectly daniel)
add HAS_HW_CONTEXTS macro to clarify supported platforms (daniel)
added comments (Ben)
Empirical evidence suggests that we need to: On at least one ivb
machine when running the hangman i-g-t test, the rings don't properly
initialize properly - the RING_START registers seems to be stuck at
all zeros.
Holding forcewake around this register init sequences makes chip reset
reliable again. Note that this is not the first such issue:
commit f01db988ef6f6c70a6cc36ee71e4a98a68901229
Author: Sean Paul <seanpaul@chromium.org>
Date: Fri Mar 16 12:43:22 2012 -0400
drm/i915: Add wait_for in init_ring_common
added delay loops to make RING_START and RING_CTL initialization
reliable on the blt ring at boot-up. So I guess it won't hurt if we do
this unconditionally for all force_wake needing gpus.
To avoid copy&pasting of the HAS_FORCE_WAKE check I've added a new
intel_info bit for that.
v2: Fixup missing commas in static struct and properly handling the
error case in init_ring_common, both noticed by Jani Nikula.
Cc: stable@vger.kernel.org
Reported-and-tested-by: Yang Guang <guang.a.yang@intel.com>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=50522
