There is a second revision of B43 (a desktop gen4 part) floating around,
functionally equivalent to the original B43, so simply add the new
PCI-IDs.
Bugzilla: https://bugs.freedesktop.org/show_bugs.cgi?id=30221
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: stable@kernel.org
New pci ids for GT2 and GT2+ on desktop and mobile sandybridge,
and graphics device ids for server sandybridge. Also rename original
ids string to reflect GT1 version.
Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com>
To simplify the IS_GEN[234] macros and to enable switching.
Signed-off-by: Eric Anholt <eric@anholt.net>
Combine the iteration over active render rings into a common function.
This is in preparation for reusing the idle function to also retire
deferred free requests.
When trying to keep track of features between the kernel, the 2D driver,
mesa and the specs, it helps to list any other name by which the device
is referred to.
The original i965, including the revised G35 and Q35, requires an
alignment of 128K for the display surface with linear memory, so
increase the requirement from 64k for these chipsets. For the later
chipsets in the i965 family, only a 4k alignment is required. (So
long as we do not start performing asynchronous flips.)
Note the impact of this should be slight as on i965 we should be using a
tiled frontbuffer for anything up to a 4096x4096 display.
v2: compilation fixes and note that the docs do not exclude the G35 from
the extra alignment.
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
drivers/gpu/drm/i915/i915_drv.c|485 col 25| warning: symbol 'i915_pm_ops' was not declared. Should it be static?
drivers/gpu/drm/i915/i915_drv.c|100 col 18| warning: Initializer entry defined twice
drivers/gpu/drm/i915/i915_drv.c|101 col 3| also defined here
drivers/gpu/drm/i915/i915_drv.c|117 col 18| warning: Initializer entry defined twice
drivers/gpu/drm/i915/i915_drv.c|118 col 3| also defined here
About 0.2W power can be saved on one HP laptop.
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
* drm-platform:
drm: Make sure the DRM offset matches the CPU
drm: Add __arm defines to DRM
drm: Add support for platform devices to register as DRM devices
drm: Remove drm_resource wrappers
Allow platform devices without PCI resources to be DRM devices.
[airlied: fixup warnings with dev pointers]
Signed-off-by: Jordan Crouse <jcrouse@codeaurora.org>
The C99 specification states in section 6.11.5:
The placement of a storage-class specifier other than at the beginning
of the declaration specifiers in a declaration is an obsolescent
feature.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
While investigating Intel i5 Arrandale GPU lockups with -rc4, I
noticed a lock imbalance.
Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com>
The active list and request list move into the ringbuffer structure,
so each can track its active objects in the order they are in that
ring. The flushing list does not, as it doesn't matter which ring
caused data to end up in the render cache. Objects gain a pointer to
the ring they are active on (if any).
Signed-off-by: Zou Nan hai <nanhai.zou@intel.com>
Signed-off-by: Xiang Hai hao <haihao.xiang@intel.com>
Introduces a more complete intel_ring_buffer structure with callbacks
for setup and management of a particular ringbuffer, and converts the
render ring buffer consumers to use it.
[anholt: Fixed up whitespace fail and rebased against prep patches]
With the advent of the BSD ring, be clear about which ring this is.
The docs are pretty consistent with calling this the Render engine at
this point.
drivers/gpu/drm/i915/i915_dma.c
drivers/gpu/drm/i915/i915_drv.h
drivers/gpu/drm/radeon/r300.c
The BSD ringbuffer support that is landing in this branch
significantly conflicts with the Ironlake PIPE_CONTROL fix on master,
and requires it to be tested successfully anyway.
pci.ids and the datasheet both say it's 358e, not 35e8.
Signed-off-by: Adam Jackson <ajax@redhat.com>
PCH is the new name for south bridge from Ironlake/Sandybridge,
which contains most of the display outputs except eDP. This one
adds a probe function to detect current PCH type, and method to
detect Cougarpoint PCH.
This is a purely cosmetic change to make changes in this area easier.
And hey, it's not only clearer and typechecked, but actually shorter,
too!
[anholt: To clarify, this is a change to let us later make
drm_i915_gem_object subclass drm_gem_object, instead of having
drm_gem_object have a pointer to i915's private data]
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Acked-by: Dave Airlie <airlied@gmail.com>
It is causing hangs after a suspend/resume cycle with the default
powersave=1 module option on these chipsets since 2.6.32-rc.
BugLink: http://bugs.launchpad.net/bugs/492392
Signed-off-by: Robert Hooker <sarvatt@ubuntu.com>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
IS_GEN6 missed to include SandyBridge mobile chip, which failed in
i915_probe_agp() for memory config detection. Fix it with a device
info flag.
* 'gpu-switcher' of /ssd/git//linux-2.6:
vga_switcheroo: initial implementation (v15)
fb: for framebuffer handover don't exit the loop early.
drivers/gpu/drm/radeon/Makefile
drivers/gpu/drm/radeon/radeon.h
Many new laptops now come with 2 gpus, one to be used for low power
modes and one for gaming/on-ac applications. These GPUs are typically
wired to the laptop panel and VGA ports via a multiplexer unit which
is controlled via ACPI methods.
4 combinations of systems typically exist - with 2 ACPI methods.
Intel/ATI - Lenovo W500/T500 - use ATPX ACPI method
ATI/ATI - some ASUS - use ATPX ACPI Method
Intel/Nvidia - - use _DSM ACPI method
Nvidia/Nvidia - - use _DSM ACPI method.
TODO:
This patch adds support for the ATPX method and initial bits
for the _DSM methods that need to written by someone with
access to the hardware.
Add a proper non-debugfs interface - need to get some proper
testing first.
v2: add power up/down support for both devices
on W500 puts i915/radeon into D3 and cuts power to radeon.
v3: redo probing methods, no DMI list, drm devices call to
register with switcheroo, it tries to find an ATPX method on
any device and once there is two devices + ATPX it inits the
switcher.
v4: ATPX msg handling using buffers - should work on more machines
v5: rearchitect after more mjg59 discussion - move ATPX handling to
radeon driver.
v6: add file headers + initial nouveau bits (to be filled out).
v7: merge delayed switcher code.
v8: avoid suspend/resume of gpu that is off
v9: rearchitect - mjg59 is always right. - move all ATPX code to
radeon, should allow simpler DSM also proper ATRM handling
v10: add ATRM support for radeon BIOS, add mutex to lock vgasr_priv
v11: fix bug in resuming Intel for 2nd time.
v12: start fixing up nvidia code blindly.
v13: blindly guess at finishing nvidia code
v14: remove radeon audio hacks - fix up intel resume more like upstream
v15: clean up printks + remove unnecessary igd/dis pointers
mount debugfs
/sys/kernel/debug/vgaswitcheroo/switch - should exist if ATPX detected
+ 2 cards.
DIS - immediate change to discrete
IGD - immediate change to IGD
DDIS - delayed change to discrete
DIGD - delayed change to IGD
ON - turn on not in use
OFF - turn off not in use
Tested on W500 (Intel/ATI) and T500 (Intel/ATI)
See http://bugzilla.kernel.org/show_bug.cgi?id=15021
Make sure that the appropriate AGP module is loaded and probed before
trying to set up the DRM. The DRM already depends on the AGP core,
but in this case we know the specific AGP driver we need too, and can
help users avoid the trap of loading the AGP driver after the DRM
driver.
Disables CXSR until it's done, and sets the mobile bit on mobile.
The register's moved to the same location as the one for the BCS, it seems.
* anholt/drm-intel-next:
drm/i915: Record batch buffer following GPU error
drm/i915: give up on 8xx lid status
drm/i915: reduce some of the duplication of tiling checking
drm/i915: blow away userspace mappings before fence change
drm/i915: move a gtt flush to the correct place
agp/intel: official names for Pineview and Ironlake
drm/i915: overlay: drop superflous gpu flushes
drm/i915: overlay: nuke readback to flush wc caches
drm/i915: provide self-refresh status in debugfs
drm/i915: provide FBC status in debugfs
drm/i915: fix drps disable so unload & re-load works
drm/i915: Fix OGLC performance regression on 945
drm/i915: Deobfuscate the render p-state obfuscation
drm/i915: add dynamic performance control support for Ironlake
drm/i915: enable memory self refresh on 9xx
drm/i915: Don't reserve compatibility fence regs in KMS mode.
drm/i915: Keep MCHBAR always enabled
drm/i915: Replace open-coded eviction in i915_gem_idle()
Commit 84b79f8d2882b0a84330c04839ed4d3cefd2ff77 (drm/i915: Fix crash
while aborting hibernation) attempted to fix a regression introduced
by commit cbda12d77ea590082edb6d30bd342a67ebc459e0 (drm/i915:
implement new pm ops for i915), but it went too far trying to split
the freeze/suspend and resume/thaw parts of the code. As a result,
it introduced another regression, which only is visible on some systems.
Fix the problem by merging i915_drm_suspend() with
i915_drm_freeze() and moving some code from i915_resume()
into i915_drm_thaw(), so that intel_opregion_free() and
intel_opregion_init() are also executed in the freeze and thaw code
paths, respectively.
Reported-and-tested-by: Pedro Ribeiro <pedrib@gmail.com>
Tested-by: Tino Keitel <tino.keitel@tikei.de>
Acked-by: Eric Anholt <eric@anholt.net>
Ironlake (and 965GM, which this patch doesn't support) supports a
hardware performance and power management feature that allows it to
adjust to changes in GPU load over time with software help. The goal
if this is to maximize performance/power for a given workload.
This patch enables that feature, which is also a requirement for
supporting Intelligent Power Sharing, a feature which allows for
dynamic budgeting of power between the CPU and GPU in Arrandale
platforms.
Tested-by: ykzhao <yakui.zhao@intel.com>
[anholt: Resolved against the irq handler loop removal]
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Commit cbda12d77ea590082edb6d30bd342a67ebc459e0 (drm/i915: implement
new pm ops for i915) introduced the problem that if s2disk hibernation
is aborted, the system will crash, because i915_pm_freeze() does
nothing, while it should at least reverse some operations carried out
by i915_suspend().
Fix this issue by splitting the i915 suspend into a freeze part a
suspend part, where the latter is not executed before creating a
hibernation image, and the i915 resume into a "low-level" resume part
and a thaw part, where the former is not executed after the image has
been created.
Tested-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk>
Pineview doesn't has CXSR and need GTT-based hardware status page.
It fixes a X boot hung issue on Pinview since commit cfdf1f
Signed-off-by: Li Peng <peng.li@intel.com>
Acked-by: Zhao Yakui <yakui.zhao@intel.com>
Many platform support this feature, and it can provide significant
power savings when the reduced refresh rate is low. However, on some
platforms a secondary (reduced) timing is provided but not actually
supported by the hardware. This results in undesirable flicker at
runtime.
So disable the feature by default, but allow users to opt-in to the
reduced clock behavior with a new module parameter, lvds_downclock,
that can be set to 1 to enable the feature.
new pm ops for i915), among other things, removed the .suspend and
.resume pointers from the struct drm_driver object in i915_drv.c,
which broke resume without KMS on my MSI Wind U100.
Fix this by reverting that part of commit cbda12d77ea59.
[anholt: added comment explaining when .suspend/.resume matter]
git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel
* 'drm-intel-next' of git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel: (23 commits)
drm/i915: remove full registers dump debug
drm/i915: Add DP dpll limit on ironlake and use existing DPLL search function
drm/i915: Select the correct BPC for LVDS on Ironlake
drm/i915: Make the BPC in FDI rx/transcoder be consistent with that in pipeconf on Ironlake
drm/i915: Enable/disable the dithering for LVDS based on VBT setting
drm/i915: Permit pinning whilst the device is 'suspended'
drm/i915: Hold struct mutex whilst pinning power context bo.
drm/i915: fix unused var
drm/i915: Storage class should be before const qualifier
drm/i915: remove render reclock support
drm/i915: Fix RC6 suspend/resume
drm/i915: execbuf2 support
drm/i915: Reload hangcheck timer too for Ironlake
drm/i915: only enable hotplug for detected outputs
drm/i915: Track whether cursor needs physical address in intel_device_info
drm/i915: Implement IS_* macros using static tables
drm/i915: Move PCI IDs into i915 driver
drm/i915: Update LVDS connector status when receiving ACPI LID event
drm/i915: Add MALATA PC-81005 to ACPI LID quirk list
drm/i915: implement new pm ops for i915
drm_ioctl is called with the Big Kernel Lock held,
which shows up very high in statistics on vfs_ioctl.
Moving the lock into the drm_ioctl function itself
makes sure we blame the right subsystem and it gets
us one step closer to eliminating the locked version
of fops->ioctl.
Since drm_ioctl does not require the lock itself,
we only need to hold it while calling the specific
handler. The 32 bit conversion handlers do not
interact with any other code, so they don't need
the BKL here either and can just call drm_ioctl.
As a bonus, this cleans up all the other users
of drm_ioctl which now no longer have to find
the inode or call lock_kernel.
[airlied: squashed the non-driver bits
of the second patch in here, this provides
the flag for drivers to use to select unlocked
ioctls - but doesn't modify any drivers].
Cc: David Airlie <airlied@linux.ie>
Cc: dri-devel@lists.sourceforge.net
Signed-off-by: Kristian Høgsberg <krh@bitplanet.net>
Instead of using the IS_I9XX etc macros that expand to a ton of
comparisons, use new struct intel_device_info to capture the
capabilities of the different chipsets. The drm_i915_private struct
will be initialized to point to the device info that correspond to
the actual device and this way, testing for a specific capability is
just a matter of checking a bit field.
The old include/drm/drm_pciids.h used to be generated from the libdrm
git repo. We don't use that anymore so just use a local list in the
driver like everybody else.
One problem in i915 hibernate with current legacy pci pm ops is
that after we do freeze, we'll be forced to do resume once again,
which re-init some resources and do modesetting again, that is
unnecessary for hibernate. This patch trys to bypass that.
We can't resolve this within legacy pm framework, but can do it
easily with new pm ops. Suspend (S3) process has also been kept
without change.
This patch adds a new flag to the drmWaitVblank ioctl, which asks the drm
to return immediately and notify userspace when the specified vblank sequence
happens by sending an event back on the drm fd.
The event mechanism works with the other flags supported by the ioctls,
specifically, the vblank sequence can be specified relatively or absolutely,
and works for primary and seconday crtc.
The signal field of the vblank request is used to provide user data,
which will be sent back to user space in the vblank event.
Signed-off-by: Kristian Høgsberg <krh@redhat.com>
In commit c1c7af60892070e4b82ad63bbfb95ae745056de0 ("drm/i915: force
mode set at lid open time") the intel graphics driver was taught to
restore the LVDS mode on lid open.
That caused problems with interaction with the suspend/resume code,
which commonly runs at the same time (suspend is often caused by the lid
close event, while lid open is commonly a resume event), which was
worked around with in commit 06891e27a9b5dba5268bb80e41a283f51335afe7
("drm/i915: fix suspend/resume breakage in lid notifier").
However, in the meantime the lid event code had also grown a user event
notifier (commit 06324194eee97a51b5f172270df49ec39192d6cc: "drm/i915:
generate a KMS uevent at lid open/close time"), and now _that_ causes
problems with suspend/resume and some versions of Xorg reacting to those
uevents by setting the mode.
So this effectively reverts that commit 06324194ee, and makes the lid
open protection logic against suspend/resume more explicit. This fixes
at least one laptop. See
http://bugzilla.kernel.org/show_bug.cgi?id=14484
for more details.
Cc: Riccardo Magliocchetti <riccardo.magliocchetti@gmail.com>
Cc: Eric Anholt <eric@anholt.net>
Don't need extra config restore like for intel_agp, which
might cause resume hang issue found by Alan on 845G.
Cc: Stable Team <stable@kernel.org>
Cc: Alan Stern <stern@rowland.harvard.edu>
This should help GEM handle memory pressure sitatuions more gracefully.
We now unconditionally restore the mode at lid open time since some
platforms turn off the panel, pipes or other display elements when the
lid is closed. There's a problem with doing this at resume time
however.
At resume time, we'll get a lid event, but restoring the mode at that
time may not be safe (e.g. if we get the lid event before global state
has been restored), so check the suspended state and make sure our
restore is locked against other mode updates.
Tested-by: Ben Gamari <bgamari.foss@gmail.com>
This patch puts in place the machinery to attempt to reset the GPU. This
will be used when attempting to recover from a GPU hang.
Signed-off-by: Owain G. Ainsworth <oga@openbsd.org>
Signed-off-by: Ben Gamari <bgamari.foss@gmail.com>
Signed-off-by: Kyle McMartin <kyle@redhat.com>
There are several sources of unnecessary power consumption on Intel
graphics systems. The first is the LVDS clock. TFTs don't suffer from
persistence issues like CRTs, and so we can reduce the LVDS refresh rate
when the screen is idle. It will be automatically upclocked when
userspace triggers graphical activity. Beyond that, we can enable memory
self refresh. This allows the memory to go into a lower power state when
the graphics are idle. Finally, we can drop some clocks on the gpu
itself. All of these things can be reenabled between frames when GPU
activity is triggered, and so there should be no user visible graphical
changes.
Signed-off-by: Jesse Barnes <jesse.barnes@intel.com>
