commit 9f1f46a45a681d357d1ceedecec3671a5ae957f4 upstream.
The problem this patch solves is that the forcewake accounting
necessary for register reads is protected by dev->struct_mutex. But the
hangcheck and error_capture code need to access registers without
grabbing this mutex because we hold it while waiting for the gpu.
So a new lock is required. Because currently the error_state capture
is called from the error irq handler and the hangcheck code runs from
a timer, it needs to be an irqsafe spinlock (note that the registers
used by the irq handler (neglecting the error handling part) only uses
registers that don't need the forcewake dance).
We could tune this down to a normal spinlock when we rework the
error_state capture and hangcheck code to run from a workqueue. But
we don't have any read in a fastpath that needs forcewake, so I've
decided to not care much about overhead.
This prevents tests/gem_hangcheck_forcewake from i-g-t from killing my
snb on recent kernels - something must have slightly changed the
timings. On previous kernels it only trigger a WARN about the broken
locking.
v2: Drop the previous patch for the register writes.
v3: Improve the commit message per Chris Wilson's suggestions.
Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com>
Signed-off-by: Keith Packard <keithp@keithp.com>
Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com>
commit 8109021313c7a3d8947677391ce6ab9cd0bb1d28 upstream.
This was forgotten in the original multi-threaded forcewake
conversion:
commit 8d715f0024f64ad1b1be85d8c081cf577944c847
Author: Keith Packard <keithp at keithp.com>
Date: Fri Nov 18 20:39:01 2011 -0800
drm/i915: add multi-threaded forcewake support
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
This adds a default setting for semaphores parameter, and enables
semaphores by default on IVB.
For now, as semaphores interaction with VTd causes random issues on
SNB, we do not enable them by default. But they can still be enabled
via the semaphores=1 kernel parameter.
v2: enables semaphores on SNB when IO remapping is disabled, with base
on Keith Packard patch.
CC: Daniel Vetter <daniel.vetter@ffwll.ch>
CC: Ben Widawsky <ben@bwidawsk.net>
CC: Keith Packard <keithp@keithp.com>
CC: Jesse Barnes <jbarnes@virtuousgeek.org>
CC: Chris Wilson <chris@chris-wilson.co.uk>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=42696
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=40564
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=41353
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=38862
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
RC6 should always work on IVB, and should work on SNB whenever IO
remapping is disabled. RC6 never works on Ironlake. Make the default
value for the parameter follow these guidelines. Setting the value
to either 0 or 1 will force the specified behavior.
Reviewed-by: Kenneth Graunke <kenneth@whitecape.org>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=38567
Cc: Ted Phelps <phelps@gnusto.com>
Cc: Peter <pab1612@gmail.com>
Cc: Lukas Hejtmanek <xhejtman@fi.muni.cz>
Cc: Andrew Lutomirski <luto@mit.edu>
On IVB C0+ with newer BIOSes, the forcewake handshake has changed. There's
now a bitfield for different driver components to keep the GT powered
on. On Linux, we centralize forcewake handling in one place, so we
still just need a single bit, but we need to use the new registers if MT
forcewake is enabled.
This needs testing on affected machines. Please reply with your
tested-by if you had problems after a BIOS upgrade and this patch fixes
them.
v2: force MT mode. shift by 16
v3: set MT force wake bits then check ECOBUS
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=42923
Tested-by: Manoj Iyer <manoj.iyer@canonical.com>
Tested-by: Robert Hooker <robert.hooker@canonical.com>
Tested-by: Keith Packard <keithp@keithp.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (31 commits)
drm: integer overflow in drm_mode_dirtyfb_ioctl()
drivers/gpu/vga/vgaarb.c: add missing kfree
drm/radeon/kms/atom: unify i2c gpio table handling
drm/radeon/kms: fix up gpio i2c mask bits for r4xx for real
ttm: Don't return the bo reserved on error path
drm/radeon/kms: add a CS ioctl flag not to rewrite tiling flags in the CS
drm/i915: Fix inconsistent backlight level during disabled
drm, i915: Fix memory leak in i915_gem_busy_ioctl().
drm/i915: Use DPCD value for max DP lanes.
drm/i915: Initiate DP link training only on the lanes we'll be using
drm/i915: Remove trailing white space
drm/i915: Try harder during dp pattern 1 link training
drm/i915: Make DP prepare/commit consistent with DP dpms
drm/i915: Let panel power sequencing hardware do its job
drm/i915: Treat PCH eDP like DP in most places
drm/i915: Remove link_status field from intel_dp structure
drm/i915: Move common PCH_PP_CONTROL setup to ironlake_get_pp_control
drm/i915: Module parameters using '-1' as default must be signed type
drm/i915: Turn on another required clock gating bit on gen6.
drm/i915: Turn on a required 3D clock gating bit on Sandybridge.
into drm-fixes
* 'drm-intel-fixes' of git://people.freedesktop.org/~keithp/linux: (25 commits)
drm/i915: enable cacheable objects on Ivybridge
drm/i915: add constants to size fence arrays and fields
drm/i915: Ivybridge still has fences!
drm/i915: forcewake warning fixes in debugfs
drm/i915: Fix object refcount leak on mmappable size limit error path.
drm/i915: Use mode_config.mutex in ironlake_panel_vdd_work
Testing i915_panel_use_ssc for the default value was broken, so the
driver would never autodetect the correct value.
Reviewed-by: Michel Alexandre Salim <salimma@fedoraproject.org>
Tested-by: Michel Alexandre Salim <salimma@fedoraproject.org>
Cc: stable@kernel.org
docs-move
So that we don't get build failures once the implicit module.h
presence is removed.
... not DISPLAY_VGA, because we ignore the VGA subclass with our
class_mask.
It confused me until Chris Wilson clued me up.
Reviewed-by: Adam Jackson <ajax@redhat.com>
With the tracing code in there they are far too big to inline.
.text savings compared to a non force inline kernel:
i915_restore_display 4393 12036 +7643
i915_save_display 4295 11459 +7164
i915_handle_error 2979 6666 +3687
i915_driver_irq_handler 2923 5086 +2163
i915_ringbuffer_info 458 1661 +1203
i915_save_vga - 1200 +1200
i915_driver_irq_uninstall 453 1624 +1171
i915_driver_irq_postinstall 913 2078 +1165
ironlake_enable_drps 719 1872 +1153
i915_restore_vga - 1142 +1142
intel_display_capture_error_state 784 2030 +1246
intel_init_emon 719 2016 +1297
and more ...
[AK: these are older numbers, with the new SNB forcewake checks
it will be even worse]
Acked-by: Ben Widawsky <ben@bwidawsk.net>
The reference clock configuration must be done before any mode setting
can occur as all outputs must be disabled to change
anything. Initialize the clocks after turning everything off during
the initialization process.
Also, re-initialize the refclk at resume time.
Allow SSC to be enabled even when the BIOS disables it for testing SSC paths.
Make the default FBC behaviour chipset specific, allowing us to turn
it on by default for Ironlake and older where it has been seen to
cause trouble with screen updates.
Tested-by: Francis Moreau <francis.moro@gmail.com>
Various issues involved with the space character were generating
warnings in the checkpatch.pl file. This patch removes most of those
warnings.
Signed-off-by: Akshay Joshi <me@akshayjoshi.com>
Signed-off-by: Michael Witten <mfwitten@gmail.com>
Signed-off-by: Ben Widawsky <ben@bwidawsk.net>
The read back of the available FIFO entries is vital for system
stability, but extremely costly. However, we only need a guide so as to
avoid eating into the reserved entries and since we are the only
consumer we can cache the read of the count from the last write.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Ben Widawsky <ben@bwidawsk.net>
This reverts commit a51f7a66fb5e4af5ec4286baef940d06594b59d2.
We still have a few Ironlake and Sandybridge machines which fail when
RC6 is enabled. Better luck next release?
We'll try again with the new fixes. Prepare to see this reverted when
we get regression reports...
According to the hardware documentation, GDRST is exactly the same as on
Sandybridge. So simply enable the existing code.
Signed-off-by: Kenneth Graunke <kenneth@whitecape.org>
This lets us make the various IRQ functions static and helps avoid
problems like the one fixed in "drm/i915: Use chipset-specific irq
installers" where one of the exported functions was called rather than
the chipset specific version.
This also fixes a UMS-mode bug -- the correct irq functions for IRL
and later chips were only getting loaded in the KMS path.
Provide a parameter to disable hanghcheck. This is useful mostly for
developers trying to debug known problems, and probably should not be
touched by normal users.
The failure is as follows:
1. Userspace gets forcewake lock, lock count >=1
2. GPU hang/reset occurs (forcewake bit is reset)
3. count is now incorrect
The failure can only occur when using the forcewake userspace lock.
This has the unfortunate consequence of messing up the driver as well as
userspace, unless userspace closes the debugfs file, the kernel will
never end up waking the GT since the refcount will be > 1.
The solution is to try to recover the correct forcewake state based on
the refcount. There is a period of time where userspace reads/writes may
occur after the reset, before the GT has been forcewaked. The interface
was never designed to be a perfect solution for userspace reads/writes,
and the kernel portion is fixed by this patch.
Suggested-by: Chris Wilson <chris@chris-wilson.co.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (169 commits)
drivers/gpu/drm/radeon/atom.c: fix warning
drm/radeon/kms: bump kms version number
drm/radeon/kms: properly set num banks for fusion asics
drm/radeon/kms/atom: move dig phy init out of modesetting
drm/radeon/kms/cayman: fix typo in register mask
drm/radeon/kms: fix typo in spread spectrum code
drm/radeon/kms: fix tile_config value reported to userspace on cayman.
drm/radeon/kms: fix incorrect comparison in cayman setup code.
drm/radeon/kms: add wait idle ioctl for eg->cayman
drm/radeon/cayman: setup hdp to invalidate and flush when asked
drm/radeon/evergreen/btc/fusion: setup hdp to invalidate and flush when asked
agp/uninorth: Fix lockups with radeon KMS and >1x.
drm/radeon/kms: the SS_Id field in the LCD table if for LVDS only
drm/radeon/kms: properly set the CLK_REF bit for DCE3 devices
drm/radeon/kms: fixup eDP connector handling
drm/radeon/kms: bail early for eDP in hotplug callback
drm/radeon/kms: simplify hotplug handler logic
drm/radeon/kms: rewrite DP handling
drm/radeon/kms/atom: add support for setting DP panel mode
drm/radeon/kms: atombios.h updates for DP panel mode
With FBC disabled by default, it should be safe to enable RC6. So let's
give it a try.
FBC has too many corner cases that we don't currently deal with, so
disable it by default so we can enable more important features like RC6,
which conflicts in some configurations.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=31742
This is a little less confusing than relying on the implicit zeroing of
the dev_priv.
Reviewed-by: Keith Packard <keithp@keithp.com>
There are several variants, set feature bits appropriately for both
mobile and desktop parts.
We can treat PantherPoint as CougarPoint as far as display goes.
My Q67 / i7-2600 box has rev09 Sandy Bridge graphics. It hangs
instantly when GNOME loads and it hangs so hard the reset button
doesn't work. Setting i915.semaphore=0 fixes it.
Semaphores were disabled in a1656b9090f7 ("drm/i915: Disable GPU
semaphores by default") in 2.6.38 but were then re-enabled (by mistake?)
by the merge 47ae63e0c2e5 ("Merge branch 'drm-intel-fixes' into
drm-intel-next").
(It's worth noting that the offending change is i915_drv.c, which was
not marked as a conflict - although a 'git show --cc' on the merge does
show that neither parent had it set to 1)
Signed-off-by: Andy Lutomirski <luto@mit.edu>
Provide a reference count to track the forcewake state of the GPU and
give a safe mechanism for userspace to wake the GT. This also potentially
saves a UC read if the GT is known to be awake already.
The reference count is atomic, but the register access and hardware wake
sequence is protected by struct_mutex.
* 'intel/drm-intel-next' of ../drm-next: (755 commits)
drm/i915: Only wait on a pending flip if we intend to write to the buffer
drm/i915/dp: Sanity check eDP existence
drm/i915: Rebind the buffer if its alignment constraints changes with tiling
drm/i915: Disable GPU semaphores by default
drm/i915: Do not overflow the MMADDR write FIFO
Revert "drm/i915: fix corruptions on i8xx due to relaxed fencing"
drm/i915: Don't save/restore hardware status page address register
drm/i915: don't store the reg value for HWS_PGA
drm/i915: fix memory corruption with GM965 and >4GB RAM
Linux 2.6.38-rc7
Revert "TPM: Long default timeout fix"
drm/i915: Re-enable GPU semaphores for SandyBridge mobile
drm/i915: Replace vblank PM QoS with "Interrupt-Based AGPBUSY#"
Revert "drm/i915: Use PM QoS to prevent C-State starvation of gen3 GPU"
drm/i915: Allow relocation deltas outside of target bo
drm/i915: Silence an innocuous compiler warning for an unused variable
fs/block_dev.c: fix new kernel-doc warning
ACPI: Fix build for CONFIG_NET unset
mm: <asm-generic/pgtable.h> must include <linux/mm_types.h>
x86: Use u32 instead of long to set reset vector back to 0
drivers/gpu/drm/i915/i915_gem.c
Apply the trivial conflicting regression fixes, but keep GPU semaphores
enabled.
drivers/gpu/drm/i915/i915_drv.h
drivers/gpu/drm/i915/i915_gem_execbuffer.c
Andi Kleen narrowed his GPU hangs on his Sugar Bay (SNB desktop) rev 09
down to the use of GPU semaphores, and we already know that they appear
broken up to Huron River (mobile) rev 08. (I'm optimistic that disabling
GPU semaphores is simply hiding another bug by the latency and
side-effects of the additional device interaction it introduces...)
However, use of semaphores is a massive performance improvement... Only
as long as the system remains stable. Enable at your peril.
Reported-by: Andi Kleen <andi-fd@firstfloor.org>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=33921
Whilst the GT is powered down (rc6), writes to MMADDR are placed in a
FIFO by the System Agent. This is a limited resource, only 64 entries, of
which 20 are reserved for Display and PCH writes, and so we must take
care not to queue up too many writes. To avoid this, there is counter
which we can poll to ensure there are sufficient free entries in the
fifo.
"Issuing a write to a full FIFO is not supported; at worst it could
result in corruption or a system hang."
Reported-and-Tested-by: Matt Turner <mattst88@gmail.com>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=34056
Seems like we are forever to be cursed with buggy firmware, so allow the
user to explicitly set the panel connection status.
Of secondary utility for cases where I run laptops with the lid closed,
but still want to configure the LVDS.
Grab the latest stabilisation bits from -fixes and some suspend and
resume fixes from linus.
drivers/gpu/drm/i915/i915_irq.c
The automatic powersaving feature is once again causing havoc, with 100%
reliable hangs on boot and resume on affected machines.
Reported-by: Francesco Allertsen <fallertsen@gmail.com>
Reported-by: Gui Rui <chaos.proton@gmail.com>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=28582
This abstracts the pci/platform interface out a step further,
we can go further but this is far enough for now to allow USB
to be plugged in.
The drivers now just call the init code directly for their
device type.
This is just an idea that might or might not be a good idea,
it basically adds two ioctls to create a dumb and map a dumb buffer
suitable for scanout. The handle can be passed to the KMS ioctls to create
a framebuffer.
It looks to me like it would be useful in the following cases:
a) in development drivers - we can always provide a shadowfb fallback.
b) libkms users - we can clean up libkms a lot and avoid linking
to libdrm_*.
c) plymouth via libkms is a lot easier.
Userspace bits would be just calls + mmaps. We could probably
mark these handles somehow as not being suitable for acceleartion
so as top stop people who are dumber than dumb.
Early chipsets (gen2/3) used function 1 as a placeholder for multi-head.
We used to ignore these since they were not assigned to
PCI_CLASS_DISPLAY_VGA. However with 934f992c7 we attempt to bind to all
Intel PCI_CLASS_DISPLAY devices (and functions) to work in multi-gpu
systems. This fails hard on gen2/3.
Reported-by: Ferenc Wágner <wferi@niif.hu>
Tested-by: Ferenc Wágner <wferi@niif.hu>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=28012
Merge resume fixes from -fixes and an important fix for SDVO GMBUS.
