Signed-off-by: Ben Widawsky <ben@bwidawsk.net>
Signed-off-by: Keith Packard <keithp@keithp.com>
The read back of the available FIFO entries is vital for system
stability, but extremely costly. However, we only need a guide so as to
avoid eating into the reserved entries and since we are the only
consumer we can cache the read of the count from the last write.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Ben Widawsky <ben@bwidawsk.net>
This reverts commit a51f7a66fb5e4af5ec4286baef940d06594b59d2.
We still have a few Ironlake and Sandybridge machines which fail when
RC6 is enabled. Better luck next release?
We'll try again with the new fixes. Prepare to see this reverted when
we get regression reports...
According to the hardware documentation, GDRST is exactly the same as on
Sandybridge. So simply enable the existing code.
Signed-off-by: Kenneth Graunke <kenneth@whitecape.org>
This lets us make the various IRQ functions static and helps avoid
problems like the one fixed in "drm/i915: Use chipset-specific irq
installers" where one of the exported functions was called rather than
the chipset specific version.
This also fixes a UMS-mode bug -- the correct irq functions for IRL
and later chips were only getting loaded in the KMS path.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Provide a parameter to disable hanghcheck. This is useful mostly for
developers trying to debug known problems, and probably should not be
touched by normal users.
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
The failure is as follows:
1. Userspace gets forcewake lock, lock count >=1
2. GPU hang/reset occurs (forcewake bit is reset)
3. count is now incorrect
The failure can only occur when using the forcewake userspace lock.
This has the unfortunate consequence of messing up the driver as well as
userspace, unless userspace closes the debugfs file, the kernel will
never end up waking the GT since the refcount will be > 1.
The solution is to try to recover the correct forcewake state based on
the refcount. There is a period of time where userspace reads/writes may
occur after the reset, before the GT has been forcewaked. The interface
was never designed to be a perfect solution for userspace reads/writes,
and the kernel portion is fixed by this patch.
Suggested-by: Chris Wilson <chris@chris-wilson.co.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (169 commits)
drivers/gpu/drm/radeon/atom.c: fix warning
drm/radeon/kms: bump kms version number
drm/radeon/kms: properly set num banks for fusion asics
drm/radeon/kms/atom: move dig phy init out of modesetting
drm/radeon/kms/cayman: fix typo in register mask
drm/radeon/kms: fix typo in spread spectrum code
drm/radeon/kms: fix tile_config value reported to userspace on cayman.
drm/radeon/kms: fix incorrect comparison in cayman setup code.
drm/radeon/kms: add wait idle ioctl for eg->cayman
drm/radeon/cayman: setup hdp to invalidate and flush when asked
drm/radeon/evergreen/btc/fusion: setup hdp to invalidate and flush when asked
agp/uninorth: Fix lockups with radeon KMS and >1x.
drm/radeon/kms: the SS_Id field in the LCD table if for LVDS only
drm/radeon/kms: properly set the CLK_REF bit for DCE3 devices
drm/radeon/kms: fixup eDP connector handling
drm/radeon/kms: bail early for eDP in hotplug callback
drm/radeon/kms: simplify hotplug handler logic
drm/radeon/kms: rewrite DP handling
drm/radeon/kms/atom: add support for setting DP panel mode
drm/radeon/kms: atombios.h updates for DP panel mode
With FBC disabled by default, it should be safe to enable RC6. So let's
give it a try.
FBC has too many corner cases that we don't currently deal with, so
disable it by default so we can enable more important features like RC6,
which conflicts in some configurations.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=31742
This is a little less confusing than relying on the implicit zeroing of
the dev_priv.
Reviewed-by: Keith Packard <keithp@keithp.com>
There are several variants, set feature bits appropriately for both
mobile and desktop parts.
We can treat PantherPoint as CougarPoint as far as display goes.
My Q67 / i7-2600 box has rev09 Sandy Bridge graphics. It hangs
instantly when GNOME loads and it hangs so hard the reset button
doesn't work. Setting i915.semaphore=0 fixes it.
Semaphores were disabled in a1656b9090f7 ("drm/i915: Disable GPU
semaphores by default") in 2.6.38 but were then re-enabled (by mistake?)
by the merge 47ae63e0c2e5 ("Merge branch 'drm-intel-fixes' into
drm-intel-next").
(It's worth noting that the offending change is i915_drv.c, which was
not marked as a conflict - although a 'git show --cc' on the merge does
show that neither parent had it set to 1)
Signed-off-by: Andy Lutomirski <luto@mit.edu>
Provide a reference count to track the forcewake state of the GPU and
give a safe mechanism for userspace to wake the GT. This also potentially
saves a UC read if the GT is known to be awake already.
The reference count is atomic, but the register access and hardware wake
sequence is protected by struct_mutex.
* 'intel/drm-intel-next' of ../drm-next: (755 commits)
drm/i915: Only wait on a pending flip if we intend to write to the buffer
drm/i915/dp: Sanity check eDP existence
drm/i915: Rebind the buffer if its alignment constraints changes with tiling
drm/i915: Disable GPU semaphores by default
drm/i915: Do not overflow the MMADDR write FIFO
Revert "drm/i915: fix corruptions on i8xx due to relaxed fencing"
drm/i915: Don't save/restore hardware status page address register
drm/i915: don't store the reg value for HWS_PGA
drm/i915: fix memory corruption with GM965 and >4GB RAM
Linux 2.6.38-rc7
Revert "TPM: Long default timeout fix"
drm/i915: Re-enable GPU semaphores for SandyBridge mobile
drm/i915: Replace vblank PM QoS with "Interrupt-Based AGPBUSY#"
Revert "drm/i915: Use PM QoS to prevent C-State starvation of gen3 GPU"
drm/i915: Allow relocation deltas outside of target bo
drm/i915: Silence an innocuous compiler warning for an unused variable
fs/block_dev.c: fix new kernel-doc warning
ACPI: Fix build for CONFIG_NET unset
mm: <asm-generic/pgtable.h> must include <linux/mm_types.h>
x86: Use u32 instead of long to set reset vector back to 0
drivers/gpu/drm/i915/i915_gem.c
Apply the trivial conflicting regression fixes, but keep GPU semaphores
enabled.
drivers/gpu/drm/i915/i915_drv.h
drivers/gpu/drm/i915/i915_gem_execbuffer.c
Andi Kleen narrowed his GPU hangs on his Sugar Bay (SNB desktop) rev 09
down to the use of GPU semaphores, and we already know that they appear
broken up to Huron River (mobile) rev 08. (I'm optimistic that disabling
GPU semaphores is simply hiding another bug by the latency and
side-effects of the additional device interaction it introduces...)
However, use of semaphores is a massive performance improvement... Only
as long as the system remains stable. Enable at your peril.
Reported-by: Andi Kleen <andi-fd@firstfloor.org>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=33921
Whilst the GT is powered down (rc6), writes to MMADDR are placed in a
FIFO by the System Agent. This is a limited resource, only 64 entries, of
which 20 are reserved for Display and PCH writes, and so we must take
care not to queue up too many writes. To avoid this, there is counter
which we can poll to ensure there are sufficient free entries in the
fifo.
"Issuing a write to a full FIFO is not supported; at worst it could
result in corruption or a system hang."
Reported-and-Tested-by: Matt Turner <mattst88@gmail.com>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=34056
Seems like we are forever to be cursed with buggy firmware, so allow the
user to explicitly set the panel connection status.
Of secondary utility for cases where I run laptops with the lid closed,
but still want to configure the LVDS.
Grab the latest stabilisation bits from -fixes and some suspend and
resume fixes from linus.
drivers/gpu/drm/i915/i915_irq.c
The automatic powersaving feature is once again causing havoc, with 100%
reliable hangs on boot and resume on affected machines.
Reported-by: Francesco Allertsen <fallertsen@gmail.com>
Reported-by: Gui Rui <chaos.proton@gmail.com>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=28582
This abstracts the pci/platform interface out a step further,
we can go further but this is far enough for now to allow USB
to be plugged in.
The drivers now just call the init code directly for their
device type.
This is just an idea that might or might not be a good idea,
it basically adds two ioctls to create a dumb and map a dumb buffer
suitable for scanout. The handle can be passed to the KMS ioctls to create
a framebuffer.
It looks to me like it would be useful in the following cases:
a) in development drivers - we can always provide a shadowfb fallback.
b) libkms users - we can clean up libkms a lot and avoid linking
to libdrm_*.
c) plymouth via libkms is a lot easier.
Userspace bits would be just calls + mmaps. We could probably
mark these handles somehow as not being suitable for acceleartion
so as top stop people who are dumber than dumb.
Early chipsets (gen2/3) used function 1 as a placeholder for multi-head.
We used to ignore these since they were not assigned to
PCI_CLASS_DISPLAY_VGA. However with 934f992c7 we attempt to bind to all
Intel PCI_CLASS_DISPLAY devices (and functions) to work in multi-gpu
systems. This fails hard on gen2/3.
Reported-by: Ferenc Wágner <wferi@niif.hu>
Tested-by: Ferenc Wágner <wferi@niif.hu>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=28012
Cc: stable@kernel.org
Merge resume fixes from -fixes and an important fix for SDVO GMBUS.
Judging by comments in the BIOS, if the SDVO LVDS option h40 is enabled,
then we are supposed to query the real panel type via Int15. We don't do
this and so for the Sony Vaio VGC-JS210J which has otherwise default
values, we choose the wrong mode.
This patch adds a driver option, i915.vbt_sdvo_panel_type, which can be
used to override the value in the VBT.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=33691
Call drm_mode_config_reset() after an invalidation event to restore any
cached state to unknown.
Tested-by: Takashi Iwai <tiwai@suse.de>
Merge important suspend and resume regression fixes and resolve the
small conflict.
drivers/gpu/drm/i915/i915_dma.c
We only have sufficient information for accurate (sub-frame) timestamping
when the modesetting is under our control.
Reported-by: Chris Clayton <chris2553@googlemail.com>
Tested-by: Chris Clayton <chris2553@googlemail.com>
Reviewed-by: Mario Kleiner <mario.kleiner@tuebingen.mpg.de>
Starting with SandyBridge (though possible with earlier hacked BIOSes),
the BIOS may initialise the IGFX as secondary to a discrete GPU. Prior,
it would simply disable the integrated GPU. So we adjust our PCI class
mask to match any DISPLAY_CLASS device.
In such a configuration, the IGFX is not a primary VGA controller and
so should not take part in VGA arbitration, and the error return from
vga_client_register() is expected.
Move code around and invoke iomem annotation in a few more places in
order to silence sparse. Still a few more iomem annotations to go...
In order to workaround the issue with LVDS not working on the Lenovo
U160 apparently due to using the wrong SSC frequency, add an option to
disable SSC.
Suggested-by: Lukács, Árpád <lukacs.arpad@gmail.com>
Bugzillla: https://bugs.freedesktop.org/show_bug.cgi?id=32748
Cleanup several aspects of the rc6 code:
- misnamed intel_disable_clock_gating function (was only about rc6)
- remove commented call to intel_disable_clock_gating
- rc6 enabling code belongs in its own function (allows us to move the
actual clock gating enable call back into restore_state)
- allocate power & render contexts up front, only free on unload
(avoids ugly lazy init at rc6 enable time)
[ickle: checkpatch cleanup]
Enabling RC6 implies setting a graphics context. Make sure we do that
only after the ring has been enabled, otherwise our ring commands will
hang.
When bringing up new hardware, or otherwise experimenting, GPU hangs are
a way of life. However, the automatic GPU reset can do more harm than
good under these circumstances, as we may wish to capture a full trace for
debugging.
Based on a patch by Zhenyu Wang.
We need to track the state of the switch in drivers, so that after s/r
we don't resume the card we've explicitly switched off before. Also
don't allow a userspace open to occur if we've switched the gpu off.
v2: Change IS_IRONLAKE to IS_GEN5 to adapt to 2.6.37
This patch adds new functions for use by the drm core:
.get_vblank_timestamp() provides a precise timestamp
for the end of the most recent (or current) vblank
interval of a given crtc, as needed for the DRI2
implementation of the OML_sync_control extension.
It is a thin wrapper around the drm function
drm_calc_vbltimestamp_from_scanoutpos() which does
almost all the work.
.get_scanout_position() provides the current horizontal
and vertical video scanout position and "in vblank"
status of a given crtc, as needed by the drm for use by
drm_calc_vbltimestamp_from_scanoutpos().
The patch modifies the pageflip completion routine
to use these precise vblank timestamps as the timestamps
for pageflip completion events.
This code has been only tested on a HP-Mini Netbook with
Atom processor and Intel 945GME gpu. The codepath for
(IS_G4X(dev) || IS_GEN5(dev) || IS_GEN6(dev)) gpu's
has not been tested so far due to lack of hardware.
Signed-off-by: Mario Kleiner <mario.kleiner@tuebingen.mpg.de>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Add frame buffer compression on Sandybridge. The method is similar to
Ironlake, except that two new registers of type GTTMMADR must be written
with the right fence info.
Signed-off-by: Yuanhan Liu <yuanhan.liu@linux.intel.com>
Once we have read the value out of the GT power well, we need to remove
the FORCE WAKE bit to allow the system to auto-power down.
As suggested by Daniel Vetter, this is a safeguard should any of the
registers cause reference to PTE entries.
So we can remove the repeated initialisation.
The bulk of the change is to convert the growing list of rings into an
array so that the relationship between the rings and the semaphore sync
registers can be easily computed.
This will declare the machine wedged, but is better than truly wedging
the machine.
