If we fail to set the bit when needed we get some nice FDI link
training failures (AKA "black screen on VGA output").
While we don't really know how to properly choose whether we need to
set the bit or not (VBT?), just read the initial value set by the BIOS
and store it for later usage.
Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
We need this code to init the PCH SSC refclk and the FDI registers.
The BIOS does this too and that's why VGA worked before this patch,
until you tried to suspend the machine...
This patch implements the "Sequence to enable CLKOUT_DP for FDI usage
and configure PCH FDI/IO" from our documentation.
v2:
- Squash Damien Lespiau's reset spelling fix on top.
- Add a comment that we don't need to bother about the ULT special
case Damien noticed, since ULT won't have VGA.
- Add a comment to rip out the SDV codepaths once haswell ships for
real.
Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com> (v1)
This way we should be able to write mPHY registers using the Sideband
Interface in the next commit. Also fixed some syntax oddities in the
related code.
Reviewed-by: Damien Lespiau <damien.lespiau@intel.com>
Should be useful to know what the driver thought the other ring's seqno
was when it last used a semaphore.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Mika Kuoppala <mika.kuoppala@intel.com>
Based on the work by Mika Kuoppala, we realised that we need to handle
seqno wraparound prior to committing our changes to the ring. The most
obvious point then is to grab the seqno inside intel_ring_begin(), and
then to reuse that seqno for all ring operations until the next request.
As intel_ring_begin() can fail, the callers must already be prepared to
handle such failure and so we can safely add further checks.
This patch looks like it should be split up into the interface
changes and the tweaks to move seqno wrapping from the execbuffer into
the core seqno increment. However, I found no easy way to break it into
incremental steps without introducing further broken behaviour.
v2: Mika found a silly mistake and a subtle error in the existing code;
inside i915_gem_retire_requests() we were resetting the sync_seqno of
the target ring based on the seqno from this ring - which are only
related by the order of their allocation, not retirement. Hence we were
applying the optimisation that the rings were synchronised too early,
fortunately the only real casualty there is the handling of seqno
wrapping.
v3: Do not forget to reset the sync_seqno upon module reinitialisation,
ala resume.
Cc: Mika Kuoppala <mika.kuoppala@intel.com>
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=863861
Reviewed-by: Mika Kuoppala <mika.kuoppala@intel.com> [v2]
There seem to be indeed some awkwards machines around, mostly those
without OpRegion support, where the firmware changes the display hw
state behind our backs when closing the lid.
This force-restore logic has been originally introduced in
commit c1c7af60892070e4b82ad63bbfb95ae745056de0
Author: Jesse Barnes <jbarnes@virtuousgeek.org>
Date: Thu Sep 10 15:28:03 2009 -0700
drm/i915: force mode set at lid open time
but after the modeset-rework we've disabled it in the vain hope that
it's no longer required:
commit 3b7a89fce3e3dc96b549d6d829387b4439044d0d
Author: Daniel Vetter <daniel.vetter@ffwll.ch>
Date: Mon Sep 17 22:27:21 2012 +0200
drm/i915: fix OOPS in lid_notify
Alas, no.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=54677
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=57434
Tested-by: Krzysztof Mazur <krzysiek@podlesie.net>
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
For now, this code is just used by the eDP AUX channel frequency.
We need to enable a special bit, otherwise none of the DP functions
requiring the PCH will work.
Version 2: store the PCH ID inside dev_priv, as suggested by Daniel
Vetter.
Now that we always restore the HWS registers (both physical and GTT
virtual addresses) when re-initialising the rings, we can eliminate the
superfluous save/restore of the register across suspend and resume.
drivers/gpu/drm/i915/i915_drv.h:1545:2: warning: '______f' is static but
declared in inline function 'i915_gem_chipset_flush' which is not static
Reported-by: kbuild test robot <fengguang.wu@intel.com>
dri-devel-Reference: <50a4d41c.586VhmwghPuKZbkB%fengguang.wu@intel.com>
Signed-off-by: Ben Widawsky <ben@bwidawsk.net>
into drm-next
Daniel writes:
Highlights of this -next round:
- ivb fdi B/C fixes
- hsw sprite/plane offset fixes from Damien
- unified dp/hdmi encoder for hsw, finally external dp support on hsw
(Paulo)
- kill-agp and some other prep work in the gtt code from Ben
- some fb handling fixes from Ville
- massive pile of patches to align hsw VGA with the spec and make it
actually work (Paulo)
- pile of workarounds from Jesse, mostly for vlv, but also some other
related platforms
- start of a dev_priv reorg, that thing grew out of bounds and chaotic
- small bits&pieces all over the place, down to better error handling for
load-detect on gen2 (Chris, Jani, Mika, Zhenyu, ...)
On top of the previous pile (just copypasta):
- tons of hsw dp prep patches form Paulo
- round scheduled work items and timers to nearest second (Chris)
- some hw workarounds (Jesse&Damien)
- vlv dp support and related fixups (Vijay et al.)
- basic haswell dp support, not yet wired up for external ports (Paulo)
- edp support (Paulo)
- tons of refactorings to prepare for the above (Paulo)
- panel rework, unifiying code between lvds and edp panels (Jani)
- panel fitter scaling modes (Jani + Yuly Novikov)
- panel power improvements, should now work without the BIOS setting it up
- extracting some dp helpers from radeon/i915 and move them to
drm_dp_helper.c
- randome pile of workarounds (Damien, Ben, ...)
- some cleanups for the register restore code for suspend/resume
- secure batchbuffer support, should enable tear-free blits on gen6+
Chris)
- random smaller fixlets and cleanups.
* 'for-airlied' of git://people.freedesktop.org/~danvet/drm-intel: (231 commits)
drm/i915: Restore physical HWS_PGA after resume
drm/i915: Report amount of usable graphics memory in MiB
drm/i915/i2c: Track users of GMBUS force-bit
drm/i915: Allocate the proper size for contexts.
drm/i915: Update load-detect failure paths for modeset-rework
drm/i915: Clear unused fields of mode for framebuffer creation
drm/i915: Always calculate 8xx WM values based on a 32-bpp framebuffer
drm/i915: Fix sparse warnings in from AGP kill code
drm/i915: Missed lock change with rps lock
drm/i915: Move the remaining gtt code
drm/i915: flush system agent TLBs on SNB
drm/i915: Kill off now unused gen6+ AGP code
drm/i915: Calculate correct stolen size for GEN7+
drm/i915: Stop using AGP layer for GEN6+
drm/i915: drop the double-OP_STOREDW usage in blt_ring_flush
drm/i915: don't rewrite the GTT on resume v4
drm/i915: protect RPS/RC6 related accesses (including PCU) with a new mutex
drm/i915: put ring frequency and turbo setup into a work queue v5
drm/i915: don't block resume on fb console resume v2
drm/i915: extract l3_parity substruct from dev_priv
This fixes a regression for SDVO from
commit fbfcc4f3a0cf8bbde87646b74241faa8e37426bf
Author: Jani Nikula <jani.nikula@intel.com>
Date: Mon Oct 22 16:12:18 2012 +0300
drm/i915/sdvo: restore i2c adapter config on intel_sdvo_init() failures
As SDVOB and SDVOC are multiplexed on the same pin, if a chipset does
not have the second SDVO encoder, it will then remove the force-bit
setting on the common i2c adapter during teardown. All subsequent
attempts of trying to use GMBUS with SDVOB then fail.
Cc: Jani Nikula <jani.nikula@intel.com>
[danvet: fixup inversion in the debug printout, noticed by Jani
Nikulai.]
As a quick hack we make the old intel_gtt structure mutable so we can
fool a bunch of the existing code which depends on elements in that data
structure. We can/should try to remove this in a subsequent patch.
This should preserve the old gtt init behavior which upon writing these
patches seems incorrect. The next patch will fix these things.
The one exception is VLV which doesn't have the preserved flush control
write behavior. Since we want to do that for all GEN6+ stuff, we'll
handle that in a later patch. Mainstream VLV support doesn't actually
exist yet anyway.
v2: Update the comment to remove the "voodoo"
Check that the last pte written matches what we readback
v3: actually kill cache_level_to_agp_type since most of the flags will
disappear in an upcoming patch
v4: v3 was actually not what we wanted (Daniel)
Make the ggtt bind assertions better and stricter (Chris)
Fix some uncaught errors at gtt init (Chris)
Some other random stuff that Chris wanted
v5: check for i==0 in gen6_ggtt_bind_object to shut up gcc (Ben)
Reviewed-by [v4]: Chris Wilson <chris@chris-wilson.co.uk>
[danvet: Make the cache_level -> agp_flags conversion for pre-gen6 a
tad more robust by mapping everything != CACHE_NONE to the cached agp
flag - we have a 1:1 uncached mapping, but different modes of
cacheable (at least on later generations). Suggested by Chris Wilson.]
This allows the power related code to run independently of the rest of
the pipeline, extending the resume and init time improvements into
userspace, which would otherwise have been blocked on the struct mutex
if we were doing PCU communication.
v2: Also convert the locking for the rps sysfs interface.
Suggested-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> (v1)
Communicating via the mailbox registers with the PCU can take quite
awhile. And updating the ring frequency or enabling turbo is not
something that needs to happen synchronously, so take it out of our init
and resume paths to speed things up (~200ms on my T420).
v2: add comment about why we use a work queue (Daniel)
make sure work queue is idle on suspend (Daniel)
use a delayed work queue since there's no hurry (Daniel)
v3: make cleanup symmetric and just call cancel work directly (Daniel)
v4: schedule the work using round_jiffies_up to batch work better (Chris)
v5: fix the right schedule_delayed_work call (Chris)
References: https://bugs.freedesktop.org/show_bug.cgi?id=54089
Signed-of-by: Jesse Barnes <jbarnes@virtuougseek.org>
[danvet: bikeshed the placement of the new delayed work, move it to
all the other gen6 power mgmt stuff.]
The console lock can be contended, so rather than prevent other drivers
after us from being held up, queue the console suspend into the global
work queue that can happen anytime. I've measured this to take around
200ms on my T420. Combined with the ring freq/turbo change, we should
save almost 1/2 a second on resume.
v2: use console_trylock() to try to resume the console immediately (Chris)
[danvet: move dev_priv->console_resume_work next to the fbdev
pointer.]
Pretty astonishing how far apart these two members landed ... Especially since
I've already removed almost 200 lines in between.
Also, move dev_priv->counter there, it's only used in i915_dma.c
And also move the dri1 dungeon at the end of dev_priv where no one
cares about it.
And give the structs slightly more generic names. I've decided to keep
the short rps/ips prefix, since that's just easier and less churn.
dev_priv has grown way too big, and grouping memebers into substructs
and moving them out of line helps re-gain some overview.
Unfortunatley I couldn't just call the substruct save and drop the prefix, since
that will make most member names clash with registers #defines. Changes in
i915_drv.h done by hand, everything else changed with
s/\<save\([A-Z]*\)/regfile.save\1/ in vim.
v2: use correct register
v3: remove extra hunks, pull in register definitions & offset check directly
v4: add GT1 vs GT2 distinction for IVB portion (Ben)
References: https://bugs.freedesktop.org/show_bug.cgi?id=50233
Reviewed-by: Ben Widawsky <ben@bwidawsk.net>
Reviewed-by: Antti Koskipää <antti.koskipaa@intel.com>
Now that we no longer pretend to have flexibility in matching any
north display block with any pch, we can ditch this.
v2: Fix the embarassing rebase fail that Paulo Zanoni spotted.
Reviewed-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
Some subsequent commits will need to know what generation we're running
on to do different pte encoding for the ppgtt. Since it's not much
hassle or overhead to store it in the ppgtt structure, do that.
After all relevant pipes are disabled and after we've updated all the
state with the staged state, but before we call the per-crtc
->mode_set functions there's a very natural point to set up any
shared/global resources like
- shared plls (obviously only the setup, the enabling needs to be
separately handling with a separate refcount)
- global watermark state like the DSPARB on gmch platforms
- workaround bits that depend upon the exact global output
configuration
- enabling the right set of refclocks
- enabling/disabling manual power wells.
Now for a lot of these things we can't move them into this function
yet, most often because we only compute the required information in
the per-crtc ->mode_set callback. Which is too late. But due to a
bunch of reasons (check-only atomic modeset, fastboot&hw state checks,
...) we need to separate the computation of that state from the actual
hw frobbery anyway. So we can move things into this new callback step-
by-step.
Others can't be moved here (or implemented at all) because our code
lacks the smarts to properly update them. E.g. the DSPARB can only be
updated when all pipes are disabled, so if we decide to change it's
value, we need to disable _all_ pipes. The infrastructure for that is
already in place (with the various pipe masks that driver the modeset
logic). But again we need to move a few things out of ->mode_set
first before we can even implement the correct decision making.
In any case, we need to start somewhere, so let's start with the
callback: Some small follow-up patches will make immediate good use of
it.
Before Haswell we used to have the CPU pipes and the PCH transcoders.
We had the same amount of pipes and transcoders, and there was a 1:1
mapping between them. After Haswell what we used to call CPU pipe was
split into CPU pipe and CPU transcoder. So now we have 3 CPU pipes (A,
B and C), 4 CPU transcoders (A, B, C and EDP) and 1 PCH transcoder
(only used for VGA).
For all the outputs except for EDP we have an 1:1 mapping on the CPU
pipes and CPU transcoders, so if you're using CPU pipe A you have to
use CPU transcoder A. When have an eDP output you have to use
transcoder EDP and you can attach this CPU transcoder to any of the 3
CPU pipes. When using VGA you need to select a pair of matching CPU
pipes/transcoders (A/A, B/B, C/C) and you also need to enable/use the
PCH transcoder.
For now we're just creating the cpu_transcoder definitions and setting
cpu_transcoder to TRANSCODER_EDP on DDI eDP code, but none of the
registers was ported to use transcoder instead of pipe. The goal is to
keep the code backwards-compatible since on all cases except when
using eDP we must have pipe == cpu_transcoder.
V2: Comment the haswell_crtc_off chunk, suggested by Damien Lespiau
and Daniel Vetter.
We currently need the haswell_crtc_off chunk because TRANSCODER_EDP
can be used by any CRTC, so when you stop using it you have to stop
saying you're using it, otherwise you may have at some point 2 CRTCs
claiming they're using TRANSCODER_EDP (a disabled CRTC and an enabled
one), then the HW state readout code will get completely confused.
In other words:
Imagine the following case:
xrandr --output eDP1 --auto --crtc 0
xrandr --output eDP1 --off
xrandr --output eDP1 --auto --crtc 2
After the last command you could get a "pipe A assertion failure
(expected off, current on)" because CRTC 0 still claims it's using
TRANSCODER_EDP, so the HW state readout function will read it
(through PIPECONF) and expect it to be off, when it's actually on
because it's being used by CRTC 2.
So when we make "intel_crtc->cpu_transcoder = intel_crtc->pipe" we
make sure we're pointing to our own original CRTC which is certainly
not used by any other CRTC.
Signed-off-by: Mika Kuoppala <mika.kuoppala@intel.com>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Get rid of saved int_lvds_connector and int_edp_connector in
drm_i915_private.
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Based on earlier work by Chris Wilson <chris@chris-wilson.co.uk>
CC: Chris Wilson <chris@chris-wilson.co.uk>
Linux 3.7-rc2
Backmerge to solve two ugly conflicts:
- uapi. We've already added new ioctl definitions for -next. Do I need to say more?
- wc support gtt ptes. We've had to revert this for snb+ for 3.7 and
also fix a few other things in the code. Now we know how to make it
work on snb+, but to avoid losing the other fixes do the backmerge
first before re-enabling wc gtt ptes on snb+.
And a few other minor things, among them git getting confused in
intel_dp.c and seemingly causing a conflict out of nothing ...
drivers/gpu/drm/i915/i915_reg.h
drivers/gpu/drm/i915/intel_display.c
drivers/gpu/drm/i915/intel_dp.c
drivers/gpu/drm/i915/intel_modes.c
include/drm/i915_drm.h
Some BIOSes may forcibly suspend RC6 during their operation which
trigger a warning as we find the hardware in a perplexing state upon
first use. So far that appears to be the worst symptom as fortuituously
we use the same values as the BIOS for programming the FORCEWAKE register.
Reported-by: Oleksij Rempel <bug-track@fisher-privat.net>
On the worst scenario, users with new hardwares and old kernel from
enabling times can get black screens. So, from now on, this
perliminary_hw_support module parameter shall be used by all upcoming
platforms that are still under enabling. The second option would be to
merge the pci ids after basic modeset works, but that makes testing
and development while bringing up hw a rather tedious afair.
Although it is uncomfortable for developers use this extra variable it
brings more stability for end users.
Signed-off-by: Rodrigo Vivi <rodrigo.vivi@gmail.com>
Reviewed-by: Dave Airlie <airlied@redhat.com>
[danvet: dropped the i915_ param prefix, i915.i915_ is just tedious.]
There is a special mechanism for communicating with the PCU already
being used for the ring frequency stuff. As we'll be needing this for
other commands, extract it now to make future code less error prone and
the current code more reusable.
I'm not entirely sure if this code matches 1:1 with the previous code
behaviorally. Functionally however, it should be the same.
CC: Jesse Barnes <jbarnes@virtuousgeek.org>
[danvet: Fixup compile fail reported by Wu Fengguang.]
Note that just because we have n == MAX elements left, does not imply
that there are only MAX elements left in the scatterlist and so we may
not be on the last chain, and the nth element may in fact be a chain ptr.
This is exercised by the improved hangman tests and the gem_exec_big
test in i-g-t.
This regression has been introduced in
commit 9da3da660d8c19a54f6e93361d147509be3fff84
Author: Chris Wilson <chris@chris-wilson.co.uk>
Date: Fri Jun 1 15:20:22 2012 +0100
drm/i915: Replace the array of pages with a scatterlist
v2: KISS, replace the direct lookup with a for_each_sg() [danvet]
v3: Try to be clever again.
The intention was to allow the caller to avoid a failure to queue a
request having already written commands to the ring. However, this is a
moot point as the i915_add_request() can fail for other reasons than a
mere allocation failure and those failure cases are more likely than
ENOMEM. So the overlay code already had to handle i915_add_request()
failures, and due to
commit 3bb73aba1ed5198a2c1dfaac4f3c95459930d84a
Date: Fri Jul 20 12:40:59 2012 +0100
drm/i915: Allow late allocation of request for i915_add_request()
the error handling code in intel_overlay.c was subject to causing
double-frees, as found by coverity.
Rather than further complicate i915_add_request() and callers, realise
the battle is lost and adapt intel_overlay.c to take advantage of the
late allocation of requests.
v2: Handle callers passing in a NULL seqno.
v3: Ditto. This time for sure.
Reviewed-by: Jani Nikula <jani.nikula@intel.com>
Problems with the previous code:
- HDMI just uses WRPLL1 for everything, so dual head cases might not
work sometimes.
- At encoder->mode_set we just write the PLL register without doing
any kind of check (e.g., check if the PLL is already being used).
- There is no way to fail and return error codes at
encoder->mode_set.
- We write to PORT_CLK_SEL at mode_set and we never disable it.
- Machines hang due to wrong clock enable/disable sequence.
So here we rewrite the code, making it a little more like the
pre-Haswell PLL mode set code:
- Check PLL availability at ironlake_crtc_mode_set.
- Try to use both WRPLLs.
- Check if PLLs are used before actually trying to use them, and
properly fail with error messages.
- Enable/disable PORT_CLK_SEL at the right place.
- Add some WARNs to check for bugs.
The next improvement will be to try to reuse PLLs if the timings
match, but this is content for another patch and it's already
documented with a TODO comment.
round_jiffies() aligns the wakeup time to the nearest second in order to
batch wakeups and reduce system load, which is useful for unimportant
coarse timers like our hangcheck.
v2: round_jiffies_relative() returns the relative jiffie value, whereas
we need the absolute value for the timer.
Suggested-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
By providing a callback for when we need to bind the pages, and then
release them again later, we can shorten the amount of time we hold the
foreign pages mapped and pinned, and importantly the dmabuf objects then
behave as any other normal object with respect to the shrinker and
memory management.
Magic numbers are bad mmmkay. In this case in particular the value is
especially weird because the docs say multiple things. We'll need this
value for sysfs, so extracting it is useful for that as well.
Rather than have multiple data structures for describing our page layout
in conjunction with the array of pages, we can migrate all users over to
a scatterlist.
One major advantage, other than unifying the page tracking structures,
this offers is that we replace the vmalloc'ed array (which can be up to
a megabyte in size) with a chain of individual pages which helps reduce
memory pressure.
The disadvantage is that we then do not have a simple array to iterate,
or to access randomly. The common case for this is in the relocation
processing, which will typically fit within a single scatterlist page
and so be almost the same cost as the simple array. For iterating over
the array, the extra function call could be optimised away, but in
reality is an insignificant cost of either binding the pages, or
performing the pwrite/pread.
v2: Fix drm_clflush_sg() to not invoke wbinvd as well! And fix the
trivial compile error from rebasing.
We need to refcount our pages in order to prevent reaping them at
inopportune times, such as when they currently vmapped or exported to
another driver. However, we also wish to keep the lazy deallocation of
our pages so we need to take a pin/unpinned approach rather than a
simple refcount.
In order to specialise functions depending upon the type of object, we
can attach vfuncs to each object via a new ->ops pointer.
For instance, this will be used in future patches to only bind pages from
a dma-buf for the duration that the object is used by the GPU - and so
prevent them from pinning those pages for the entire of the object.
v2: Bonus comments.
As a quick reference I'll detail the motivation and design of the new code a
bit here (mostly stitched together from patchbomb announcements and commits
introducing the new concepts).
The crtc helper code has the fundamental assumption that encoders and crtcs can
be enabled/disabled in any order, as long as we take care of depencies (which
means that enabled encoders need an enabled crtc to feed them data,
essentially).
Our hw works differently. We already have tons of ugly cases where crtc code
enables encoder hw (or encoder->mode_set enables stuff that should only be
enabled in enocder->commit) to work around these issues. But on the disable
side we can't pull off similar tricks - there we actually need to rework the
modeset sequence that controls all this. And this is also the real motivation
why I've finally undertaken this rewrite: eDP on my shiny new Ivybridge
Ultrabook is broken, and it's broken due to the wrong disable sequence ...
The new code introduces a few interfaces and concepts:
- Add new encoder->enable/disable functions which are directly called from the
crtc->enable/disable function. This ensures that the encoder's can be
enabled/disabled at a very specific in the modeset sequence, controlled by our
platform specific code (instead of the crtc helper code calling them at a time
it deems convenient).
- Rework the dpms code - our code has mostly 1:1 connector:encoder mappings and
does support cloning on only a few encoders, so we can simplify things quite a
bit.
- Also only ever disable/enable the entire output pipeline. This ensures that
we obey the right sequence of enabling/disabling things, trying to be clever
here mostly just complicates the code and results in bugs. For cloneable
encoders this requires a bit of special handling to ensure that outputs can
still be disabled individually, but it simplifies the common case.
- Add infrastructure to read out the current hw state. No amount of careful
ordering will help us if we brick the hw on the initial modeset setup. Which
could happen if we just randomly disable things, oblivious to the state set up
by the bios. Hence we need to be able to read that out. As a benefit, we grow a
few generic functions useful to cross-check our modeset code with actual hw
state.
With all this in place, we can copy&paste the crtc helper code into the
drm/i915 driver and start to rework it:
- As detailed above, the new code only disables/enables an entire output pipe.
As a preparation for global mode-changes (e.g. reassigning shared resources) it
keeps track of which pipes need to be touched by a set of bitmasks.
- To ensure that we correctly disable the current display pipes, we need to
know the currently active connector/encoder/crtc linking. The old crtc helper
simply overwrote these links with the new setup, the new code stages the new
links in ->new_* pointers. Those get commited to the real linking pointers once
the old output configuration has been torn down, before the ->mode_set
callbacks are called.
- Finally the code adds tons of self-consistency checks by employing the new hw
state readout functions to cross-check the actual hw state with what the
datastructure think it should be. These checks are done both after every
modeset and after the hw state has been read out and sanitized at boot/resume
time. All these checks greatly helped in tracking down regressions and bugs in
the new code.
With this new basis, a lot of cleanups and improvements to the code are now
possible (besides the DP fixes that ultimately made me write this), but not yet
done:
- I think we should create struct intel_mode and use it as the adjusted mode
everywhere to store little pieces like needs_tvclock, pipe dithering values or
dp link parameters. That would still be a layering violation, but at least we
wouldn't need to recompute these kinds of things in intel_display.c. Especially
the port bpc computation needed for selecting the pipe bpc and dithering
settings in intel_display.c is rather gross.
- In a related rework we could implement ->mode_valid in terms of ->mode_fixup
in a generic way - I've hunted down too many bugs where ->mode_valid did the
right thing, but ->mode_fixup didn't. Or vice versa, resulting in funny bugs
for user-supplied modes.
- Ditch the idea to rework the hdp handling in the common crtc helper code and
just move things to i915.ko. Which would rid us of the ->detect crtc helper
dependencies.
- LVDS wire pair and pll enabling is all done in the crtc->mode_set function
currently. We should be able to move this to the crtc_enable callbacks (or in
the case of the LVDS wire pair enabling, into some encoder callback).
Last, but not least, this new code should also help in enabling a few neat
features: The hw state readout code prepares (but there are still big pieces
missing) for fastboot, i.e. avoiding the inital modeset at boot-up and just
taking over the configuration left behind by the bios. We also should be able
to extend the configuration checks in the beginning of the modeset sequence and
make better decisions about shared resources (which is the entire point behind
the atomic/global modeset ioctl).
Tested-by: Jani Nikula <jani.nikula@intel.com>
Tested-by: Ben Widawsky <ben@bwidawsk.net>
Tested-by: Damien Lespiau <damien.lespiau@intel.com>
Tested-by: Rodrigo Vivi <rodrigo.vivi@gmail.com>
Acked-by: Chris Wilson <chris@chris-wilson.co.uk>
Tested-by: Vijay Purushothaman <vijay.a.purushothaman@intel.com>
Acked-by: Vijay Purushothaman <vijay.a.purushothaman@intel.com>
Tested-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
Acked-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
Tested-by: Jesse Barnes <jbarnes@virtuousgeek.org>
... instead of resetting a few things and hoping that this will work
out.
To properly disable the output pipelines at the initial modeset after
resume or boot up we need to have an accurate picture of which outputs
are enabled and connected to which crtcs. Otherwise we risk disabling
things at the wrong time, which can lead to hangs (or at least royally
confused panels), both requiring a walk to the reset button to fix.
Hence read out the hw state with the freshly introduce get_hw_state
functions and then sanitize it afterwards.
For a full modeset readout (which would allow us to avoid the initial
modeset at boot up) a few things are still missing:
- Reading out the mode from the pipe, especially the dotclock
computation is quite some fun.
- Reading out the parameters for the stolen memory framebuffer and
wrapping it up.
- Reading out the pch pll connections - luckily the disable code
simply bails out if the crtc doesn't have a pch pll attached (even
for configurations that would need one).
This patch here turned up tons of smelly stuff around resume: We
restore tons of register in seemingly random way (well, not quite, but
we're not too careful either), which leaves the hw in a rather
ill-defined state: E.g. the port registers are sometimes
unconditionally restore (lvds, crt), leaving us with an active
encoder/connector but no active pipe connected to it. Luckily the hw
state sanitizer detects this madness and fixes things up a bit.
v2: When checking whether an encoder with active connectors has a crtc
wire up to it, check for both the crtc _and_ it's active state.
v3:
- Extract intel_sanitize_encoder.
- Manually disable active encoders without an active pipe.
v4: Correclty fix up the pipe<->plane mapping on machines where we
switch pipes/planes. Noticed by Chris Wilson, who also provided the
fixup.
v5: Spelling fix in a comment, noticed by Paulo Zanoni
Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Because that's what we're essentially calling. This is the first step
in untangling the crtc_helper induced dpms handling mess we have - at
the crtc level we only have 2 states and the magic is just in
selecting which one (and atm there isn't even much magic, but on
recent platforms where not even the crt output has more than 2 states
we could do better).
Like with the equivalent change for gen6+ rps state, this helps in
clarifying the code (and in fixing a few places that have fallen through
the cracks in the locking review).
Using the extracted INSTDONE reading, and our new register definitions,
update our hangcheck detection and error collection to use it. This
primarily means changing == to memcmp, and changing = to memcpy.
Hopefully this will give more info on error dump, and provide more
accurate hangcheck detection (both are actually TBD).
Also, remove the reading of instdone1 from the ring error collection
function, and just crap everything in capture_error_state (that could be
split into a separate patch if it wasn't so trivial).
v2: Now assuming i915_get_extra_instdone does the memset we can clean up the
code a bit (Jani)
v3: use ARRAY_SIZE as requested earlier by Jani (didn't change sizeof)
Updated commit msg
As we wish to create specialised object constructions in the near
future that share the same basic GEM object struct, export the default
initializer.
Avoid stalling and waiting for the GPU by checking to see if there is
sufficient inactive space in the aperture for us to bind the buffer
prior to writing through the GTT. If there is inadequate space we will
have to stall waiting for the GPU, and incur overheads moving objects
about. Instead, only incur the clflush overhead on the target object by
writing through shmem.
