commit f8c08d8faee5567803c8c533865296ca30286bbf upstream.
To keep things manageable, the pre-gen9 cmdparser does not
attempt to track any form of nested BB_START's. This did not
prevent usermode from using nested starts, or even chained
batches because the cmdparser is not strictly enforced pre gen9.
Instead, the existence of a nested BB_START would cause the batch
to be emitted in insecure mode, and any privileged capabilities
would not be available.
For Gen9, the cmdparser becomes mandatory (for BCS at least), and
so not providing any form of nested BB_START support becomes
overly restrictive. Any such batch will simply not run.
We make heavy use of backward jumps in igt, and it is much easier
to add support for this restricted subset of nested jumps, than to
rewrite the whole of our test suite to avoid them.
Add the required logic to support limited backward jumps, to
instructions that have already been validated by the parser.
Note that it's not sufficient to simply approve any BB_START
that jumps backwards in the buffer because this would allow an
attacker to embed a rogue instruction sequence within the
operand words of a harmless instruction (say LRI) and jump to
that.
We introduce a bit array to track every instr offset successfully
validated, and test the target of BB_START against this. If the
target offset hits, it is re-written to the same offset in the
shadow buffer and the BB_START cmd is allowed.
Note: This patch deliberately ignores checkpatch issues in the
cmdtables, in order to match the style of the surrounding code.
We'll correct the entire file in one go in a later patch.
v2: set dispatch secure late (Mika)
v3: rebase (Mika)
v4: Clear whitelist on each parse
Minor review updates (Chris)
v5: Correct backward jump batching
v6: fix compilation error due to struct eb shuffle (Mika)
Signed-off-by: Jon Bloomfield <jon.bloomfield@intel.com>
Cc: Dave Airlie <airlied@redhat.com>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Tyler Hicks <tyhicks@canonical.com>
Signed-off-by: Mika Kuoppala <mika.kuoppala@linux.intel.com>
Reviewed-by: Chris Wilson <chris.p.wilson@intel.com>
This was the competing idea long ago, but it was only with the rewrite
of the idr as an radixtree and using the radixtree directly ourselves,
along with the realisation that we can store the vma directly in the
radixtree and only need a list for the reverse mapping, that made the
patch performant enough to displace using a hashtable. Though the vma ht
is fast and doesn't require any extra allocation (as we can embed the node
inside the vma), it does require a thread for resizing and serialization
and will have the occasional slow lookup. That is hairy enough to
investigate alternatives and favour them if equivalent in peak performance.
One advantage of allocating an indirection entry is that we can support a
single shared bo between many clients, something that was done on a
first-come first-serve basis for shared GGTT vma previously. To offset
the extra allocations, we create yet another kmem_cache for them.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Tvrtko Ursulin <tvrtko.ursulin@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20170816085210.4199-5-chris@chris-wilson.co.uk
Since we make call i915_gem_context_mark_guilty() concurrently when
resetting different engines in parallel, we need to make sure that our
updates are safe for the unlocked access.
Cc: Michel Thierry <michel.thierry@intel.com>
Cc: Mika Kuoppala <mika.kuoppala@linux.intel.com>
Reviewed-by: Mika Kuoppala <mika.kuoppala@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20170721123238.16428-12-chris@chris-wilson.co.uk
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Whilst the contents of the context is still protected by the big
struct_mutex, this is not much of an improvement. It is just one tiny
step towards reducing our BKL.
Reviewed-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20170620110547.15947-3-chris@chris-wilson.co.uk
If we move the actual cleanup of the context to a worker, we can allow
the final free to be called from any context and avoid undue latency in
the caller.
v2: Negotiate handling the delayed contexts free by flushing the
workqueue before calling i915_gem_context_fini() and performing the final
free of the kernel context directly
v3: Flush deferred frees before new context allocations
Link: http://patchwork.freedesktop.org/patch/msgid/20170620110547.15947-2-chris@chris-wilson.co.uk
Create a substruct to hold all the global context state under
drm_i915_private.
Link: http://patchwork.freedesktop.org/patch/msgid/20170620110547.15947-1-chris@chris-wilson.co.uk
The advent of full-ppgtt lead to an extra indirection between the object
and its binding. That extra indirection has a noticeable impact on how
fast we can convert from the user handles to our internal vma for
execbuffer. In order to bypass the extra indirection, we use a
resizable hashtable to jump from the object to the per-ctx vma.
rhashtable was considered but we don't need the online resizing feature
and the extra complexity proved to undermine its usefulness. Instead, we
simply reallocate the hastable on demand in a background task and
serialize it before iterating.
In non-full-ppgtt modes, multiple files and multiple contexts can share
the same vma. This leads to having multiple possible handle->vma links,
so we only use the first to establish the fast path. The majority of
buffers are not shared and so we should still be able to realise
speedups with multiple clients.
v2: Prettier names, more magic.
v3: Many style tweaks, most notably hiding the misuse of execobj[].rsvd2
GVTg has introduced the context status notifier to schedule the GVTg
workload. At that time, the notifier is bound to GVTg context only,
so GVTg is not aware of host workloads.
Now we are going to improve GVTg's guest workload scheduler policy,
and add Guc emulation support for new Gen graphics. Both these two
features require acknowledgment for all contexts running on hardware.
(But will not alter host workload.) So here try to make some change.
The change is simple:
1. Move the context status notifier head from i915_gem_context to
intel_engine_cs. Which means there is a notifier head per engine
instead of per context. Execlist driver still call notifier for
each context sched-in/out events of current engine.
2. At GVTg side, it binds a notifier_block for each physical engine
at GVTg initialization period. Then GVTg can hear all context
status events.
In this patch, GVTg do nothing for host context event, but later
will add a function there. But in any case, the notifier callback is
a noop if this is no active vGPU.
Since intel_gvt_init() is called at early initialization stage and
require the status notifier head has been initiated, I initiate it in
intel_engine_setup().
v2: remove a redundant newline. (chris)
Fixes: 3c7ba6359d70 ("drm/i915: Introduce execlist context status change notification")
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=100232
Signed-off-by: Changbin Du <changbin.du@intel.com>
Cc: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Cc: Tvrtko Ursulin <tvrtko.ursulin@linux.intel.com>
Cc: Zhi Wang <zhi.a.wang@intel.com>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Link: http://patchwork.freedesktop.org/patch/msgid/20170313024711.28591-1-changbin.du@intel.com
Acked-by: Zhenyu Wang <zhenyuw@linux.intel.com>
No hardware was ever shipped that needed more than 4096 byte alignment
and future hardware will not use this legacy path. So reduce the
alignment to make it easier and quicker to launch workloads.
Link: http://patchwork.freedesktop.org/patch/msgid/20170227135913.8056-3-chris@chris-wilson.co.uk
The kernel context (dev_priv->kernel_context) is unique in that it is
not associated with any user filp - it is the only one with
ctx->file_priv == NULL. This is a simpler test than comparing it against
dev_priv->kernel_context which involves some pointer dancing.
In checking that this is true, we notice that the gvt context is
allocating itself a i915_hw_ppgtt it doesn't use and not flagging that
its file_priv should be invalid.
Link: http://patchwork.freedesktop.org/patch/msgid/20170106152013.24684-5-chris@chris-wilson.co.uk
The existing kerneldoc was outdated, so time for a refresh.
v2: Use single line kdoc, mention functions for manipulation
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: http://patchwork.freedesktop.org/patch/msgid/20161231112012.29263-3-chris@chris-wilson.co.uk
