path: root/drivers/gpu/drm/i915/i915_suspend.c
2014-05-22drm/i915: disable GT power saving early during system suspendImre Deak
Atm, we disable GT power saving during the end of the suspend sequence in i915_save_state(). Doing the disabling at that point seems arbitrary. One reason to disable it early though is to have a quiescent HW state before we do anything else (for example save registers). So move the disabling earlier, which also takes care canceling of the deferred RPS enabling work done by intel_disable_gt_powersave(). Note that after the move we'll call intel_disable_gt_powersave() only in case modeset is enabled, but that's anyway the only case where we have it enabled in the first place. Signed-off-by: Imre Deak <imre.deak@intel.com> Reviewed-by: Robert Beckett <robert.beckett@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-01-25drm/i915: Kill most of the FBC register save/restoreVille Syrjälä
We will anyway re-enable FBC normally after resume, so trying to save and restore the register makes little sense. We do need to preserve the FBC1 interval bits in FBC_CONTROL since we only initialize them during driver load, and try to preserve them after that. v2: s/I915_HAS_FBC/HAS_FBC/ and fix the check for gen4 Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-01-24drm/i915: Only restore backlight combination mode reg for umsDaniel Vetter
This was forgotten in commit 565ee3897f0cb1e9b09905747b3784e6605767e8 Author: Jani Nikula <jani.nikula@intel.com> Date: Wed Nov 13 12:56:29 2013 +0200 drm/i915: do not save/restore backlight registers in KMS Since the confusion was likely due to the duplicated definition for this pci config register, let's unify that, too. Cc: Jani Nikula <jani.nikula@intel.com> Reviewed-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-01-10drm/i915: Drop I915_ prefix from HAS_FBCDaniel Vetter
My OCD just couldn't let this slide. Spotted while reviewing Ville's patch to only flip planes when we have FBC. Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-11-14drm/i915: do not save/restore backlight registers in KMSJani Nikula
The backlight enable code now has the smarts to do the right thing. Only do backlight register save/restore in UMS. Some VLV specific code gets dropped as UMS is not supported on VLV. v2: Move save/restore to UMS instead of removing completely (Daniel). Signed-off-by: Jani Nikula <jani.nikula@intel.com> Reviewed-by: Imre Deak <imre.deak@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-11-13drm/i915: make backlight info per-connectorJani Nikula
Move from dev_priv to connector->panel. We still don't allow multiple sysfs interfaces, though. There should be no functional changes, except for a slight reordering of connector backlight and sysfs destroy calls. (This change happens now that the backlight device is actually per-connector, even though the destroy calls became per-connector earlier.) Signed-off-by: Jani Nikula <jani.nikula@intel.com> Reviewed-by: Imre Deak <imre.deak@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-11-06drm/i915/vlv: use per-pipe backlight controls v2Jesse Barnes
With the connector and pipe passed around, we can now set the backlight on the right pipe on VLV/BYT. v2: drop combination mode check for VLV (Jani) add save/restore code for VLV backlight regs (Jani) check for existing modulation freq when initializing backlight regs (Jani) Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=67245 Tested-by: Joe Konno <joe.konno@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-10-11drm/i915: don't save/restore CACHE_MODE_0 on gen7+Jesse Barnes
On gen7+, CACHE_MODE_0 moved, so we're clobbering some other reg rather than restoring CACHE_MODE_0. Don't do that. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Reviewed-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-09-13drm/i915: don't save/restore LBB on Gen5+Paulo Zanoni
Because this PCI config register doesn't exist on Gen5+. Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-07-09Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "Okay this is the big one, I was stalled on the fbdev pull req as I stupidly let fbdev guys merge a patch I required to fix a warning with some patches I had, they ended up merging the patch from the wrong place, but the warning should be fixed. In future I'll just take the patch myself! Outside drm: There are some snd changes for the HDMI audio interactions on haswell, they've been acked for inclusion via my tree. This relies on the wound/wait tree from Ingo which is already merged. Major changes: AMD finally released the dynamic power management code for all their GPUs from r600->present day, this is great, off by default for now but also a huge amount of code, in fact it is most of this pull request. Since it landed there has been a lot of community testing and Alex has sent a lot of fixes for any bugs found so far. I suspect radeon might now be the biggest kernel driver ever :-P p.s. radeon.dpm=1 to enable dynamic powermanagement for anyone. New drivers: Renesas r-car display unit. Other highlights: - core: GEM CMA prime support, use new w/w mutexs for TTM reservations, cursor hotspot, doc updates - dvo chips: chrontel 7010B support - i915: Haswell (fbc, ips, vecs, watermarks, audio powerwell), Valleyview (enabled by default, rc6), lots of pll reworking, 30bpp support (this time for sure) - nouveau: async buffer object deletion, context/register init updates, kernel vp2 engine support, GF117 support, GK110 accel support (with external nvidia ucode), context cleanups. - exynos: memory leak fixes, Add S3C64XX SoC series support, device tree updates, common clock framework support, - qxl: cursor hotspot support, multi-monitor support, suspend/resume support - mgag200: hw cursor support, g200 mode limiting - shmobile: prime support - tegra: fixes mostly I've been banging on this quite a lot due to the size of it, and it seems to okay on everything I've tested it on." * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (811 commits) drm/radeon/dpm: implement vblank_too_short callback for si drm/radeon/dpm: implement vblank_too_short callback for cayman drm/radeon/dpm: implement vblank_too_short callback for btc drm/radeon/dpm: implement vblank_too_short callback for evergreen drm/radeon/dpm: implement vblank_too_short callback for 7xx drm/radeon/dpm: add checks against vblank time drm/radeon/dpm: add helper to calculate vblank time drm/radeon: remove stray line in old pm code drm/radeon/dpm: fix display_gap programming on rv7xx drm/nvc0/gr: fix gpc firmware regression drm/nouveau: fix minor thinko causing bo moves to not be async on kepler drm/radeon/dpm: implement force performance level for TN drm/radeon/dpm: implement force performance level for ON/LN drm/radeon/dpm: implement force performance level for SI drm/radeon/dpm: implement force performance level for cayman drm/radeon/dpm: implement force performance levels for 7xx/eg/btc drm/radeon/dpm: add infrastructure to force performance levels drm/radeon: fix surface setup on r1xx drm/radeon: add support for 3d perf states on older asics drm/radeon: set default clocks for SI when DPM is disabled ...
2013-06-16drm/i915: Restore fences after resume and GPU resetsChris Wilson
Stéphane Marchesin found that fences for pinned objects (i.e. the scanout) were not being restored upon resume, leading to corruption on the display and reference counting issues. This is due to a bug in commit 312817a39f17dbb4de000165b5b724e3728cd91c [2.6.38] Author: Chris Wilson <chris@chris-wilson.co.uk> Date: Mon Nov 22 11:50:11 2010 +0000 drm/i915: Only save and restore fences for UMS that zapped the pinned fences even though they were in use. Fortuitously, whilst we forced a VT switch during suspend and resume, no fences were ever pinned at the time. However, we now can do switchless S3 transitions and so the old bug finally surfaces. Reported-by: Stéphane Marchesin <marcheu@chromium.org> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Stéphane Marchesin <marcheu@chromium.org> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-04-25drm/i915: protect backlight registers and data with a spinlockJani Nikula
Backlight data and registers are fiddled through LVDS/eDP modeset enable/disable hooks, backlight sysfs files, asle interrupts, and register save/restore. Protect the backlight related registers and driver private fields using a spinlock. The locking in register save/restore covers a little more than is strictly necessary, including non-modeset case, for simplicity. v2: Cover register access, save/restore, i915_read_blc_pwm_ctl() and code paths leading there. Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-03-17drm/i915: don't save/restore PCH_LVDS on LPTPaulo Zanoni
Because the register does not exist on LPT. The interesting fact is that reading/writing PCH_LVDS on LPT does *not* give us "unclaimed register" messages, but the register value is always 0. Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-02-20drm/i915: don't restore LVDS enable state blindly v2Jesse Barnes
We still rely on a few LVDS bits, but restoring the enable bit can cause trouble at this point, so don't. v2: use the right mask to prevent restore (Daniel) conditionalize on KMS support (Denial) Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Reviewed-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-01-31drm/i915: Introduce i915_vgacntrl_reg()Ville Syrjälä
The VGACNTRL register has moved around between different platforms. To handle the differences add i915_vgacntrl_reg() which returns the correct offset for the VGACNTRL register. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-01-31drm/i915: move DP save/restore into i915_ums.cDaniel Vetter
Note that this slightly changes the order, but we only move it within the block of registers that restore encoder state. Specifically LVDS is now restored after DP, whereas previously it was done before. Legacy vga is still restored afterwards, which seems to be the important thing (if there's anything important in this restore ordering at all). Reviewed-by: Imre Deak <imre.deak@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-01-31drm/i915: dont save/restore VGA state for kmsDaniel Vetter
The only thing we really care about that it is off. To do so, reuse the recently created i915_redisable_vga function, which is already used to put obnoxious firmware into check on lid reopening. Reviewed-by: Imre Deak <imre.deak@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-01-31drm/i915: extract ums suspend/resume into i915_ums.cDaniel Vetter
Similarly to how i915_dma.c is shaping up to be the dungeon hole for all things supporting dri1, create a new one to hide all the crazy things which are only really useful for ums support. Biggest part is the register suspend/resume support. Unfortunately a lot of it is still intermingled with bits and pieces we might still need, so needs more analysis and needs to stay in i915_suspend.c for now. Reviewed-by: Imre Deak <imre.deak@intel.com> v2: s/modeset_reg/display_reg/ as suggested by Imre, to avoid confusion between the kernel modeset code and display save/restore to support ums. v3: Fixup alphabetical order in the Makefile, spotted by Chris Wilson. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-01-28drm/i915: move modeset checks out of save/restore_modeset_regDaniel Vetter
That way the control flow is clearer, and it prepares the stage to extract these ums functions and hide them somewhere. There's still tons of display stuff outside of these, but that requires more work. Reviewed-by: Imre Deak <imre.deak@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-01-24drm/i915: don't save/restore DSPARB on gen5+Paulo Zanoni
Because the register does not exist in gen5+. This patch solves "unclaimed register" messages on Haswell after suspend/resume. Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Reviewed-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-11-21drm/i915: Remove save/restore of physical HWS_PGA registerChris Wilson
Now that we always restore the HWS registers (both physical and GTT virtual addresses) when re-initialising the rings, we can eliminate the superfluous save/restore of the register across suspend and resume. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-11-11drm/i915: move the suspend/resume register file out of dev_privDaniel Vetter
dev_priv has grown way too big, and grouping memebers into substructs and moving them out of line helps re-gain some overview. Unfortunatley I couldn't just call the substruct save and drop the prefix, since that will make most member names clash with registers #defines. Changes in i915_drv.h done by hand, everything else changed with s/\<save\([A-Z]*\)/regfile.save\1/ in vim. Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-10-22Merge tag 'v3.7-rc2' into drm-intel-next-queuedDaniel Vetter
Linux 3.7-rc2 Backmerge to solve two ugly conflicts: - uapi. We've already added new ioctl definitions for -next. Do I need to say more? - wc support gtt ptes. We've had to revert this for snb+ for 3.7 and also fix a few other things in the code. Now we know how to make it work on snb+, but to avoid losing the other fixes do the backmerge first before re-enabling wc gtt ptes on snb+. And a few other minor things, among them git getting confused in intel_dp.c and seemingly causing a conflict out of nothing ... Conflicts: drivers/gpu/drm/i915/i915_reg.h drivers/gpu/drm/i915/intel_display.c drivers/gpu/drm/i915/intel_dp.c drivers/gpu/drm/i915/intel_modes.c include/drm/i915_drm.h Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-10-18drm/i915: don't save/restor ADPA for kmsDaniel Vetter
We now no longer rely on this. This is step 1 on a long journey to rid us of the save/restore madness, which tends to lightly paper over many issues, and cause tons of bad things itself ... Reviewed-by: Paulo Zanoni <paulo.r.zanoni@intel.com> [danvet: satisfy Paulo's ocd and drop the needless braces.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-10-17drm/i915: don't save/restore HWS_PGA reg for kmsDaniel Vetter
We already do that as part of the ringbuffer re-setup at resume time. Furthermore the register offset has moved on gen6+ around quite a bit, and on ilk/gm45 we also need to restore the HWS reg for the bsd ring, not just the render ring. So again in kms mode this is only confusing a best, hence don't bother. v2: Fixup logic, noticed by Paulo Zanoni. Reviewed-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Tested-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-10-17drm/i915: don't save/restore irq regs for kmsDaniel Vetter
We already call drm_irq_install/uninstall at the right time, which will set up the irq registers with the correct values (through the preinstall hooks). For kms this is at best harmless, in the worst case we get an interrupt when we don't really expect it. v2: Fixup the logic, noticed by Paulo Zanoni. Reviewed-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Tested-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-10-17drm/i915: don't save/restore DP regs for kmsDaniel Vetter
We completely compute these anew in each modeset, hence we don't rely on them containing anything valid after resume. To avoid breaking any ums setup due to reordering of the reads/writes simply don't reorder anything, but bracket the reads/writes into if (!kms) conditionals. More churn, but safer. v2: Fixup the logic, noticed by Paulo Zanoni. Reviewed-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Tested-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-10-02UAPI: (Scripted) Convert #include "..." to #include <path/...> in drivers/gpu/David Howells
Convert #include "..." to #include <path/...> in drivers/gpu/. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Dave Airlie <airlied@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-02UAPI: (Scripted) Remove redundant DRM UAPI header #inclusions from drivers/gpu/.David Howells
Remove redundant DRM UAPI header #inclusions from drivers/gpu/. Remove redundant #inclusions of core DRM UAPI headers (drm.h, drm_mode.h and drm_sarea.h). They are now #included via drmP.h and drm_crtc.h via a preceding patch. Without this patch and the patch to make include the UAPI headers from the core headers, after the UAPI split, the DRM C sources cannot find these UAPI headers because the DRM code relies on specific -I flags to make #include "..." work on headers in include/drm/ - but that does not work after the UAPI split without adding more -I flags. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Dave Airlie <airlied@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-07-20Merge tag 'v3.5-rc7' into drm-nextDave Airlie
Merge Linus tree into drm to fixup conflicts in radeon code for further testing before upstream merge. Signed-off-by: Dave Airlie <airlied@redhat.com> Conflicts: drivers/gpu/drm/i915/i915_dma.c drivers/gpu/drm/i915/intel_display.c drivers/gpu/drm/radeon/radeon_gart.c
2012-06-25drm/i915: wrap up gt powersave enabling functionsDaniel Vetter
... instead of calling each one for each generation indiviudally. Notice that we've already managed to be inconsistent, the resume path is missing an IS_VLV check. As a nice benefit we can mark all the platform specific enable/disable functions as static and hide them in intel_pm.c Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-06-23drm/i915: Fix eDP blank screen after S3 resume on HP desktopsTakashi Iwai
This patch fixes the problem on some HP desktop machines with eDP which give blank screens after S3 resume. It turned out that BLC_PWM_CPU_CTL must be written after BLC_PWM_CPU_CTL2. Otherwise it doesn't take effect on these SNB machines. Tested with 3.5-rc3 kernel. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=49233 Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-05-19drm/i915: gen6_enable_rps() wants to be called after ring initialisationChris Wilson
Currently we call gen6_enable_rps() (which writes into the per-ring register mmio space) from intel_modeset_init_hw() which is called before we initialise the rings. If we defer intel_modeset_init_hw() until afterwards (in the intel_modeset_gem_init() phase) all is well. v2: Rectify ordering of gem vs display HW init upon resume. (Daniel) v3: Fix up locking. (Paulo) Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> [danvet: Smash Paulo's locking fix onto Chris' patch.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-05-03drm/i915: manage PCH PLLs separately from pipesJesse Barnes
PCH PLLs aren't required for outputs on the CPU, so we shouldn't just treat them as part of the pipe. So split the code out and manage PCH PLLs separately, allocating them when needed or trying to re-use existing PCH PLL setups when the timings match. v2: add num_pch_pll field to dev_priv (Daniel) don't NULL the pch_pll pointer in disable or DPMS will fail (Jesse) put register offsets in pll struct (Chris) v3: Decouple enable/disable of PLLs from get/put. v4: Track temporary PLL disabling during modeset v5: Tidy PLL initialisation by only checking for num_pch_pll == 0 (Eugeni) v6: Avoid mishandling allocation failure by embedding the small array of PLLs into the device struct Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=44309 Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> (up to v2) Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> (v3+) Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Tested-by: Jesse Barnes <jbarnes@virtuousgeek.org> Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-04-12drm/i915: re-init modeset hw state after gpu resetDaniel Vetter
After a gpu reset we need to re-init some of the hw state we only initialize when modeset is enabled, like rc6, hw contexts or render/GT core clock gating and workaround register settings. Note that this patch has a small change in the resume code: - rc6 on gen6+ is only restored for the modeset case (for more consistency with other callsites). This is no problem because recent kernels refuse to load drm/i915 without kms on gen6+ - rc6/emon on ilk is only restored for the modeset case. This is no problem because rc6 is disabled by default on ilk, and ums on ilk has never really been a supported option outside of horrible rhel backports. v2: Chris Wilson noticed that we not only fail to restore the clock gating settings after gpu reset. v3: Move the call to modeset_init_hw in _reset out of the struct_mutext protected area - other callers don't hold it, too. Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2012-01-24drm/i915: Re-enable gen7 RC6 and GPU turbo after resume.Eric Anholt
Signed-off-by: Eric Anholt <eric@anholt.net> Cc: stable@vger.kernel.org Reviewed-by: Keith Packard <keithp@keithp.com> Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Reviewed-by: Kenneth Graunke <kenneth@whitecape.org> Signed-off-by: Keith Packard <keithp@keithp.com>
2012-01-09drm/i915: handle 3rd pipeEugeni Dodonov
We don't need to check 3rd pipe specifically, as it shares PLL with some other one. Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Keith Packard <keithp@keithp.com>
2012-01-09drm/i915: simplify pipe checkingEugeni Dodonov
This is also handled by i915_reg.h, so just reuse this trick to reduce universe entropy. Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org> Reviewed-by: Cyril Brulebois <kibi@debian.org> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-11-03drm/i915: Ivybridge still has fences!Daniel Vetter
So don't forget to restore them on resume and dump them into the error state. Cc: stable@kernel.org Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-09-19Drivers: i915: Fix all space related issues.Akshay Joshi
Various issues involved with the space character were generating warnings in the checkpatch.pl file. This patch removes most of those warnings. Signed-off-by: Akshay Joshi <me@akshayjoshi.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-08-15drm/i915: Cannot set clock gating under UMSKeith Packard
The clock gating functions are only assigned under KMS, so don't try to call them under UMS. Signed-off-by: Keith Packard <keithp@keithp.com> Tested-by: Justin P. Mattock <justinmattock@gmail.com>
2011-07-29Merge branch 'drm-intel-fixes' into drm-intel-nextKeith Packard
2011-07-29drm/i915/pch: Save/restore PCH_PORT_HOTPLUG across suspendAdam Jackson
At least on a Lenovo X220 the HPD bits of this are enabled at boot but cleared after resume, which means plug interrupts stop working. This also happens to fix DP displays re-lighting on resume. I'm quite certain that's an accident: the first DP link train inevitably fails on that machine, and it's only serendipity that we're getting multiple plug interrupts and the second train works. But I shall take my victories where I get them. Signed-off-by: Adam Jackson <ajax@redhat.com> Tested-by: Keith Packard <keithp@keithp.com> Reviewed-by: Keith Packard <keithp@keithp.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-07-08drm/i915: Only export the generic intel_disable_fbc() interfaceChris Wilson
As the enable/disable routines will be gain additional complexity in future patches, it is necessary that all callers do not bypass the generic interface by calling into the chipset routines directly. to do this we make the chipset routines static, so there is no choice. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-06-29Merge branch 'drm-intel-fixes' into drm-intel-nextKeith Packard
2011-06-29drm/i915: Hold struct_mutex during i915_save_state/i915_restore_stateKeith Packard
Lots of register access in these functions, some of which requires the struct mutex. These functions now hold the struct mutex across the calls to i915_save_display and i915_restore_display, and so the internal mutex calls in those functions have been removed. To ensure that no-one else was calling them (and hence violating the new required locking invarient), those functions have been made static. gen6_enable_rps locks the struct mutex, and so i915_restore_state unlocks the mutex around calls to that function. Reviewed-by: Ben Widawsky <ben@bwidawsk.net> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-06-28drm/i915: load a ring frequency scaling table v3Jesse Barnes
The ring frequency scaling table tells the PCU to treat certain GPU frequencies as if they were a given CPU frequency for purposes of scaling the ring frequency. Normally the PCU will scale the ring frequency based on the CPU P-state, but with the table present, it will also take the GPU frequency into account. The main downside of keeping the ring frequency high while the CPU is at a low frequency (or asleep altogether) is increased power consumption. But then if you're keeping your GPU busy, you probably want the extra performance. v2: - add units to debug table header (from Eric) - use tsc_khz as a fallback if the cpufreq driver doesn't give us a freq (from Chris) v3: - fix comments & debug output - remove unneeded force wake get/put Reviewed-by: Ben Widawsky <ben@bwidawsk.net> Tested-by: Eric Anholt <eric@anholt.net> Reviewed-by: Eric Anholt <eric@anholt.net> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-06-22drm/i915: save/resume forcewake lock fixesBen Widawsky
The lock must be held for the saving and restoring of VGA state. Signed-off-by: Ben Widawsky <ben@bwidawsk.net> CC: Alexander Zhaunerchyk <alex.vizor@gmail.com> CC: Andrey Rahmatullin <wrar@wrar.name> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-05-13drm/i915: split PCH clock gating initJesse Barnes
Ibex Peak and CougarPoint already require a different setting (added here), and future chips will likely follow that precedent. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Reviewed-by: Keith Packard <keithp@keithp.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-05-13drm/i915: split clock gating init into per-chipset functionsJesse Barnes
This helps contain the mess to init_display() instead. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Reviewed-by: Keith Packard <keithp@keithp.com> Signed-off-by: Keith Packard <keithp@keithp.com>
