commit 63ee41d794d9c555f84205517a68509848988760 upstream.
The IPS driver is designed to be able to run detached from i915 and
just not enable GPU turbo in that case, in order to avoid module
dependencies between the two drivers. This means that we don't know
what the load order between the two is going to be, and we had
previously only supported IPS after (optionally) i915, but not i915
after IPS. If the wrong order was chosen, you'd get no GPU turbo, and
something like half the possible graphics performance.
Signed-off-by: Eric Anholt <eric@anholt.net>
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
commit 8316f33766a82907c694267ff911e45e256f09f9 upstream.
The DisplayPort standard (1.1a) states that:
The I2C-over-AUX Reply field is valid only when Native AUX CH Reply
field is AUX_ACK (00). When Native AUX CH Reply field is not 00, then,
I2C-over-AUX Reply field must be 00 and be ignored.
This fixes broken EDID reading when using an active DisplayPort to
duallink DVI converter. If the AUX CH replier chooses to defer the
transaction, a short read occurs and erroneous data is returned as
the i2c reply due to a lack of length checking and failure to check
for AUX ACK.
As a result, broken EDIDs can look like:
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: bc bc bc ff bc bc bc ff bc bc bc ac bc bc bc 45 ???.???.???????E
10: bc bc bc 10 bc bc bc 34 bc bc bc ee bc bc bc 4c ???????4???????L
20: bc bc bc 50 bc bc bc 00 bc bc bc 40 bc bc bc 00 ???P???.???@???.
30: bc bc bc 01 bc bc bc 01 bc bc bc a0 bc bc bc 40 ???????????????@
40: bc bc bc 00 bc bc bc 00 bc bc bc 00 bc bc bc 55 ???.???.???.???U
50: bc bc bc 35 bc bc bc 31 bc bc bc 20 bc bc bc fc ???5???1??? ????
60: bc bc bc 4c bc bc bc 34 bc bc bc 46 bc bc bc 00 ???L???4???F???.
70: bc bc bc 38 bc bc bc 11 bc bc bc 20 bc bc bc 20 ???8??????? ???
80: bc bc bc ff bc bc bc ff bc bc bc ff bc bc bc ff ???.???.???.???.
which can lead to:
[drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder
[drm:drm_edid_block_valid] *ERROR* Raw EDID:
<3>30 30 30 30 30 30 30 32 38 32 30 32 63 63 31 61 000000028202cc1a
<3>28 00 02 8c 00 00 00 00 18 00 00 00 00 00 00 00 (...............
<3>20 4c 61 73 74 20 62 65 61 63 6f 6e 3a 20 33 32 Last beacon: 32
<3>32 30 6d 73 20 61 67 6f 46 00 05 8c 00 00 00 00 20ms agoF.......
<3>36 00 00 00 00 00 00 00 00 0c 57 69 2d 46 69 20 6.........Wi-Fi
<3>52 6f 75 74 65 72 01 08 82 84 8b 96 24 30 48 6c Router......$0Hl
<3>03 01 01 06 02 00 00 2a 01 00 2f 01 00 32 04 0c .......*../..2..
<3>12 18 60 dd 09 00 10 18 02 00 00 01 00 00 18 00 ..`.............
Signed-off-by: David Flynn <davidf@rd.bbc.co.uk>
[ickle: fix up some surrounding checkpatch warnings]
commit 220cad3cbf553f893432919b458da36489373fc6 upstream.
The pipe is always set to 8BPC, but here we were leaving whatever
previous bits were set by the BIOS in place.
Tested-by: Keith Packard <keithp@keithp.com>
commit 48fcfc888b48ad49dd83faa107264bbfb0089cad upstream.
Fixes issue where i915_gfx_val was reporting values several
orders of magnitude higher than physically possible (without
leaving scorch marks on my thighs at least.)
Signed-off-by: Kyle McMartin <kyle@redhat.com>
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit ba84cd1f2b5dd49bda9300c5a11373f7e14c3c66 upstream.
Commit d09c23de intended to add a 30ms delay to give the ADD time to
detect any TVs connected. However, it used the sdvo->is_tv flag to do so
which is dependent upon the previous detection result and not whether the
output supports TVs.
commit 0ddc1289f3ffd779779ddd3922f26ae7d0a21604 upstream.
Just makes sure that writes are not being aliased by the CPU cache and
do make it out to main memory.
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=24977
commit 382b09362711d7d03272230a33767015a277926e upstream.
Needed on Ibex Peak and Cougar Point or the panel won't always come on.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit c2873e9633fe908dccd36dbb1d370e9c59a1ca62 upstream.
A physically mapped hardware status page is allocated at driver load
time but was never freed. Call the existing code to free this page at
driver unload time on hardware which uses this kind.
Signed-off-by: Keith Packard <keithp@keithp.com>
[ickle: call before tearing down registers on KMS-only path, as pointed
out by Dave Airlie]
commit 1510a97182b4ddb5fe3c4e8d05240f7cd6fd13e7 upstream.
After disabling the hotplug interrupts for VGA detection on Ironlake, be
sure to re-enable them again afterwards.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=30378
Signed-off-by: Yuanhan Liu <yuanhan.liu@intel.com>
commit 2d7b8366ae4a9ec2183c30e432a4a9a495c82bcd upstream.
On Sandybridge, the bit definition for hotplug on SDE has changed, so
update the code to new definition.
The i915 driver has quite a few module unload bugs, the known ones at
least have fixes that are targeting 2.6.37. However, in order to
maintain a stable kernel, we should prevent this known random memory
corruption following driver unload. This should have very low impact on
normal users who are unlikely to need to unload the i915 driver.
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: stable@kernel.org
since the handle references are all tied to a file_priv, and when it disappears
all the handle refs go with it.
The fbcon ones we'd only notice on unload, but the nouveau notifier one
would would happen on reboot.
nouveau: Reported-by: Marc Dionne <marc.c.dionne@gmail.com>
nouveau: Tested-by: Marc Dionne <marc.c.dionne@gmail.com>
i915 unload: Reported-by: Keith Packard <keithp@keithp.com>
Acked-by: Ben Skeggs <bskeggs@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel
* 'drm-intel-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel:
drm/i915: Rephrase pwrite bounds checking to avoid any potential overflow
drm/i915: Sanity check pread/pwrite
drm/i915: Use pipe state to tell when pipe is off
drm/i915: vblank status not valid while training display port
drivers/gpu/drm/i915/i915_gem.c: Add missing error handling code
drm/i915: Fix refleak during eviction.
drm/i915: fix GMCH power reporting
... and do the same for pread.
Move the access control up from the fast paths, which are no longer
universally taken first, up into the caller. This then duplicates some
sanity checking along the slow paths, but is much simpler.
Tracked as CVE-2010-2962.
Reported-by: Kees Cook <kees@ubuntu.com>
Instead of waiting for the display line value to settle, we can simply
wait for the pipe configuration register 'state' bit to turn off.
Contrarywise, disabling the plane will not cause the display line
value to stop changing, so instead we wait for the vblank interrupt
bit to get set. And, we only do this when we're not about to wait for
the pipe to turn off.
While the display port is in training mode, vblank interrupts don't
occur. Because we have to wait for the display port output to turn on
before starting the training sequence, enable the output in 'normal'
mode so that we can tell when a vblank has occurred, then start the
training sequence.
Extend the error handling code with operations found in other nearby error
handling code
A simplified version of the sematic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
@r@
statement S1,S2,S3;
constant C1,C2,C3;
*if (...)
{... S1 return -C1;}
*if (...)
{... when != S1
return -C2;}
*if (...)
{... S1 return -C3;}
// </smpl>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
vmwgfx: Fix fb VRAM pinning failure due to fragmentation
vmwgfx: Remove initialisation of dev::devname
vmwgfx: Enable use of the vblank system
vmwgfx: vt-switch (master drop) fixes
drm/vmwgfx: Fix breakage introduced by commit "drm: block userspace under allocating buffer and having drivers overwrite it (v2)"
drm: Hold the mutex when dropping the last GEM reference (v2)
drm/gem: handlecount isn't really a kref so don't make it one.
drm: i810/i830: fix locked ioctl variant
drm/radeon/kms: add quirk for MSI K9A2GM motherboard
drm/radeon/kms: fix potential segfault in r600_ioctl_wait_idle
drm: Prune GEM vma entries
drm/radeon/kms: fix up encoder info messages for DFP6
drm/radeon: fix PCI ID 5657 to be an RV410
Now that we hold onto a reference whilst evicting objects, we need to
be sure that we drop all the references taken -- even on the error
paths.
There were lots of places being inconsistent since handle count
looked like a kref but it really wasn't.
Fix this my just making handle count an atomic on the object,
and have it increase the normal object kref.
Now i915/radeon/nouveau drivers can drop the normal reference on
userspace object creation, and have the handle hold it.
This patch fixes a memory leak or corruption on unload, because
the driver had no way of knowing if a handle had been actually
added for this object, and the fbcon object needed to know this
to clean itself up properly.
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
The IPS driver needs to know the current power consumption of the GMCH
in order to make decisions about when to increase or decrease the CPU
and/or GPU power envelope. So fix up the divisions to save the results
so the numbers are actually correct (contrary to some earlier comments
and code, these functions do not modify the first argument and use it
for the result).
In the event that the external chipset doesn't implement the
GET_SUPPORTED_ENHANCEMENTS commands, gracefully treat it as having no
enhancments rather than bailing.
Reported-and-tested-by: Woody Suwalski <terraluna977@gmail.com>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=18342
We weren't unlinking the freed connector from the drm lists, and so
hit some use-after-free if we failed to initialise the connector.
A minor typo caused a single fence register to be incorrectly
programmed, resulting in occassional tiling corruption.
Reported-and-tested-by: Hans de Bruin <bruinjm@xs4all.nl>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=18962
During heavy aperture thrashing we may be forced to wait upon several active
objects during eviction. The active list may be the last reference to
these objects and so the action of waiting upon one of them may cause
another to be freed (and itself unbound). To prevent the object
disappearing underneath us, we need to acquire and hold a reference
whilst unbinding.
This should fix the reported page refcount OOPS:
kernel BUG at drivers/gpu/drm/i915/i915_gem.c:1444!
RIP: 0010:[<ffffffffa0093026>] [<ffffffffa0093026>] i915_gem_object_put_pages+0x25/0xf5 [i915]
Call Trace:
[<ffffffffa009481d>] i915_gem_object_unbind+0xc5/0x1a7 [i915]
[<ffffffffa0098ab2>] i915_gem_evict_something+0x3bd/0x409 [i915]
[<ffffffffa0027923>] ? drm_gem_object_lookup+0x27/0x57 [drm]
[<ffffffffa0093bc3>] i915_gem_object_bind_to_gtt+0x1d3/0x279 [i915]
[<ffffffffa0095b30>] i915_gem_object_pin+0xa3/0x146 [i915]
[<ffffffffa0027948>] ? drm_gem_object_lookup+0x4c/0x57 [drm]
[<ffffffffa00961bc>] i915_gem_do_execbuffer+0x50d/0xe32 [i915]
Reported-by: Shawn Starr <shawn.starr@rogers.com>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=18902
There is a second revision of B43 (a desktop gen4 part) floating around,
functionally equivalent to the original B43, so simply add the new
PCI-IDs.
Bugzilla: https://bugs.freedesktop.org/show_bugs.cgi?id=30221
With 5 places to update when adding handling for fence registers, it is
easy to overlook one or two. Correct that oversight, but fence
management should be improved before a new set of registers is added.
Bugzilla: https://bugs.freedesktop.org/show_bug?id=30199
Original patch by: Yuanhan Liu <yuanhan.liu@intel.com>
These are not fatal errors, so do not alarm the user by filling the
logs with *** ERROR ***. Especially as we know that g4x CRT detection
is a little sticky.
On the one hand the errors are valid since they are warning us of a
stall -- we poll the register whilst holding the mode lock so not even
the mouse will update. On the other hand, those stalls were already present
yet nobody complained.
Reported-by: Andi Kleen <andi@firstfloor.org>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=18332
v2: Julien Cristau pointed out that @nondestructive results in
double-negatives and confusion when trying to interpret the parameter,
so use @force instead. Much easier to type as well. ;-)
And fix the miscompilation of vmgfx reported by Sedat Dilek.
Destructive load-detection is very expensive and due to failings
elsewhere can trigger system wide stalls of up to 600ms. A simple
first step to correcting this is not to invoke such an expensive
and destructive load-detection operation automatically.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=29536
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=16265
Reported-by: Bruno Prémont <bonbons@linux-vserver.org>
Tested-by: Sitsofe Wheeler <sitsofe@yahoo.com>
This should fix the mysterious mode setting failures reported during
boot up and after resume, generally for i8xx class machines.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=16478
Reported-and-tested-by: Xavier Chantry <chantry.xavier@gmail.com>
Buzilla: https://bugs.freedesktop.org/show_bug.cgi?id=29413
Tested-by: Daniel Vetter <daniel@ffwll.ch>
We don't know how to enable it safely, especially as outputs turn on and
off. When disabling LP1 we also need to make sure LP2 and 3 are already
disabled.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=29173
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=29082
Reported-by: Chris Lord <chris@linux.intel.com>
Tested-by: Daniel Vetter <daniel.vetter@ffwll.ch>
If we are busy, then we may have woken up the wait_request handler but
not yet serviced it before the hang check fires. So in hang check,
double check that the i915_gem_do_wait_request() is still pending the
wake-up before declaring all hope lost.
Fixes regression with e78d73b16bcde921c9cf458d2e4de8e4fc2518f3.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=30073
Reported-and-tested-by: Sitsofe Wheeler <sitsofe@yahoo.com>
This reverts commit b9421ae8f30958deea98d71477b4a77a066856b4.
This warning was so prelevant, even for apparently working machines,
that it was just causing fear, anxiety and panic.
The root cause still remains, so we will add some better debugging when
we focus on fixing it.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=17021
Reported-by: Maciej Rutecki <maciej.rutecki@gmail.com>
This reverts commit 0f3ee801b332d6ff22285386675fe5aaedf035c3.
Enabling LVDS on pipe A was causing excessive wakeups on otherwise idle
systems due to i915 interrupts. So restrict the LVDS to pipe B once more,
whilst the issue is properly diagnosed.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=16307
Reported-and-tested-by: Enrico Bandiello <enban@postal.uv.es>
Poked-by: Florian Mickler <florian@mickler.org>
Cc: Adam Jackson <ajax@redhat.com>
This reverts commit ce17178094f368d9e3f39b2cb4303da5ed633dd4.
This commit has been independently bisected a few times as being the cause
of a s2ram failure.
Reported-and-tested-by: Kyle McMartin <kyle@mcmartin.ca>
Reported-and-tested-by: Andy Isaacson <adi@hexapodia.org>
Cc: Zou Nan hai <nanhai.zou@intel.com>
New pci ids for GT2 and GT2+ on desktop and mobile sandybridge,
and graphics device ids for server sandybridge. Also rename original
ids string to reflect GT1 version.
Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com>
MI_FLUSH is being deprecated, but still available on Sandybridge.
Make sure it's enabled as userspace still uses MI_FLUSH.
Sandybridge GTT has new cache control bits in PTE, which controls
graphics page cache in LLC or LLC/MLC, so we need to extend the mask
function to respect the new bits.
And set cache control to always LLC only by default on Gen6.
Arguably this is a bug in drm-core in that we should not be called twice
in succession with DPMS_ON, however this is still occuring and we see
FDI link training failures on the second call leading to the occassional
blank display. For the time being ignore the repeated call.
Original patch by Dave Airlie <airlied@redhat.com>
We were passing garbage values into the panel-fitter control register
when disabling it on Ironlake - those values (filter modes and reserved
MBZ bits) would have then be re-used the next time panel-fitting was
enabled.
When we miss the flip prepare interrupt, we never get into the
software state needed to restart userspace, resulting in a freeze of a
full-screen OpenGL application (such as a compositor).
Work around this by checking DSPxSURF/DSPxBASE to see if the page flip
has actually happened. If it has, do the work we would have done when
the flip prepare interrupt comes in.
Also, add debugfs information to tell us what's going on (based on the
patch from Chris Wilson attached to bugs.fdo bug #29798).
Signed-off-by: Simon Farnsworth <simon.farnsworth@onelan.co.uk>
We reset intel_encoder for every matching encoder whilst iterating over
the encoders attached to this crtc when changing mode. As such in a
cloned configuration intel_encoder may not correspond to the correct
is_edp encoder.
By scoping intel_encoder to the loop, not only is the compiler able to
spot this mistake, we also improve readiability for ourselves.
[It might not be a mistake, within this function it is unclear as to
whether it is permissable for eDP to be cloned...]
We were failing when trying to allocate the resource for MMIO of the
MCHBAR because we forgot to specify what type of resource we wanted.
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Only stop trying if the aux channel sucessfully reports that the
transmission was completed, otherwise try again. On the 5th failure,
bail and report that something is amiss.
This fixes a sporadic failure in reading the EDID for my external panel
over DP.
If the VBIOS tells us the mapping of the SDVO device onto the DDC bus,
use it. However, if there is no VBIOS available that mapping is
uninitialised and we should fallback to our earlier guess.
Fix regression introduced in b1083333 (which in turn is a fix for the
regression caused by the introduction of this guess, 14571b4).
References:
Bug 29499 - [945GM] Screen disconnected because of missing VBIOS
https://bugs.freedesktop.org/show_bug.cgi?id=29499
Bug 15109 - i945GM fails to detect EDID on DVI port
https://bugzilla.kernel.org/show_bug.cgi?id=15109
Reported-and-tested-by: Paul Neumann <paul104x@yahoo.de>
Cc: Zhenyu Wang <zhenyuw@linux.intel.com>
Adam Hill reported that his Arrandale system required a much longer, up
to 200x500us, wait for the panel to initialise or else modesetting would
fail.
References:
https://bugs.freedesktop.org/show_bug.cgi?id=29141
Reported-and-tested-by: Adam Hill <sidepipeuk@yahoo.co.uk>
Lets try to avoid repeating old bugs.
