This patch allows to optionally attach the lvds-channel to a panel
supported by a drm_panel driver using of-graph bindings, instead of
supplying the modes via display-timings in the device tree.
This depends on of_graph_get_port_by_id and uses the OF graph to
link the optional DRM panel to the LDB lvds-channel. The output
port number is 1 on devices without the 4-port input multiplexer
(i.MX5) and 4 on devices with the mux (i.MX6).
Before:
ldb {
lvds-channel@0 {
display-timings {
native-timing = <&timing1>;
timing1: etm0700g0dh6 {
hactive = <800>;
vactive = <480>;
clock-frequency = <33260000>;
hsync-len = <128>;
hback-porch = <88>;
hfront-porch = <40>;
vsync-len = <2>;
vback-porch = <33>;
vfront-porch = <10>;
hsync-active = <0>;
vsync-active = <0>;
After:
ldb {
lvds-channel@0 {
port@4 {
reg = <4>;
lvds_out: endpoint {
remote_endpoint = <&panel_in>;
panel {
compatible = "edt,etm0700g0dh6", "simple-panel";
port {
panel_in: endpoint {
remote-endpoint = <&lvds_out>;
[Fixed build error due to missing select on DRM_PANEL --rmk]
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
DRM_GEM_CMA_HELPER is depend on HAVE_DMA_ATTRS, or it will break the
building. The related error (with allmodconfig under xtensa):
CC [M] drivers/gpu/drm/drm_gem_cma_helper.o
drivers/gpu/drm/drm_gem_cma_helper.c: In function 'drm_gem_cma_create':
drivers/gpu/drm/drm_gem_cma_helper.c:110:19: error: implicit declaration of function 'dma_alloc_writecombine' [-Werror=implicit-function-declaration]
cma_obj->vaddr = dma_alloc_writecombine(drm->dev, size,
drivers/gpu/drm/drm_gem_cma_helper.c:110:17: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
drivers/gpu/drm/drm_gem_cma_helper.c: In function 'drm_gem_cma_free_object':
drivers/gpu/drm/drm_gem_cma_helper.c:193:3: error: implicit declaration of function 'dma_free_writecombine' [-Werror=implicit-function-declaration]
dma_free_writecombine(gem_obj->dev->dev, cma_obj->base.size,
drivers/gpu/drm/drm_gem_cma_helper.c: In function 'drm_gem_cma_mmap_obj':
drivers/gpu/drm/drm_gem_cma_helper.c:330:8: error: implicit declaration of function 'dma_mmap_writecombine' [-Werror=implicit-function-declaration]
ret = dma_mmap_writecombine(cma_obj->base.dev->dev, vma,
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>
the original imx hdmi driver is under drm/imx/,
which depends on imx-drm, so move the imx hdmi
driver out to drm/bridge and rename it to dw_hdmi
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
Tested-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver updates from Greg KH:
"Here's the big staging tree pull request for 3.19-rc1.
We continued to delete more lines than were added, always a good
thing, but not at a huge rate this release, only about 70k lines
removed overall mostly from removing the horrid bcm driver.
Lots of normal staging driver cleanups and fixes all over the place,
well over a thousand of them, the shortlog shows all the horrid
details.
The "contentious" thing here is the movement of the Android binder
code out of staging into the "real" part of the kernel. This is code
that has been stable for a few years now and is working as-is in the
tens of millions of devices with no issues. Yes, the code is horrid,
and the userspace api leaves a lot to be desired, but it's not going
to change due to legacy issues that we have no control over. Because
so many devices and companies rely on this, and the code is stable,
might as well promote it out of staging.
This was all discussed at the Linux Plumbers conference, and everyone
participating agreed that this was the best way forward.
There is work happening to replace the binder code with something new
that is happening right now, but I don't expect to see the results of
that work for another year at the earliest. If that ever happens, and
Android switches over to it, I'll gladly remove this version.
As for maintainers, I'll be glad to maintain this code, I've been
doing it for the past few years with no problems. I'll send a
MAINTAINERS entry for it before 3.19-final is out, still need to talk
to the Google developers about if they are willing to help with it or
not, last I checked they were, which was good.
All of these patches have been in linux-next for a while with no
reported issues"
* tag 'staging-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1382 commits)
Staging: slicoss: Fix long line issues in slicoss.c
staging: rtl8712: remove unnecessary else after return
staging: comedi: change some printk calls to pr_err
staging: rtl8723au: hal: Removed the extra semicolon
lustre: Deletion of unnecessary checks before three function calls
staging: lustre: fix sparse warnings: static function declaration
staging: lustre: fixed sparse warnings related to static declarations
staging: unisys: remove duplicate header
staging: unisys: remove unneeded structure
staging: ft1000 : replace __attribute ((__packed__) with __packed
drivers: staging: rtl8192e: Include "asm/unaligned.h" instead of "access_ok.h" in "rtl819x_BAProc.c"
Drivers:staging:rtl8192e: Fixed checkpatch warning
Drivers:staging:clocking-wizard: Added a newline
staging: clocking-wizard: check for a valid clk_name pointer
staging: rtl8723au: Hal_InitPGData() avoid unnecessary typecasts
staging: rtl8723au: _DisableAnalog(): Avoid zero-init variables unnecessarily
staging: rtl8723au: Remove unnecessary wrapper _ResetDigitalProcedure1()
staging: rtl8723au: _ResetDigitalProcedure1_92C() reduce code obfuscation
staging: rtl8723au: Remove unnecessary wrapper _DisableRFAFEAndResetBB()
staging: rtl8723au: _DisableRFAFEAndResetBB8192C(): Reduce code obfuscation
The imx-drm driver was put into staging mostly for the following reasons,
all of which have been addressed or superseded:
- convert the irq driver to use linear irq domains
- work out the device tree bindings, this lead to the common of_graph
bindings being used
- factor out common helper functions, this mostly resulted in the
component framework and drm of_graph helpers.
Before adding new fixes, and certainly before adding new features,
move it into its proper place below drivers/gpu/drm.
