A variety of tweaks to the NVIF library interfaces, mostly ripping out
things that turned out to be not so useful.
- Removed refcounting from nvif_object, callers are expected to not be
stupid instead.
- nvif_client is directly reachable from anything derived from nvif_object,
removing the need for heuristics to locate it
- _new() versions of interfaces, that allocate memory for the object
they construct, have been removed. The vast majority of callers used
the embedded _init() interfaces.
- No longer storing constructor arguments (and the data returned from
nvkm) inside nvif_object, it's more or less unused and just wastes
memory.
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
The PFIFO<->EVO sync buffers will be fixed up later when inter-channel
sync in general is improved.
This is an attempt at isolating some of the changes necessary to port
to NVIF in a separate commit.
The real linux interfaces are soooo much easier on the eyes ...
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Not required anymore as flips are always done on the kernel's channel,
which means we can use a proper software object class instead.
This is a HUGE commit, but it's not nearly as bad as it looks - any problems
can be isolated to a particular chipset and engine combination. It was
simply too difficult to port each one at a time, the compat layers are
*already* ridiculous.
Most of the changes here are simply to the glue, the process for each of the
engine modules was to start with a standard skeleton and copy+paste the old
code into the appropriate places, fixing up variable names etc as needed.
v2: Marcin Slusarz <marcin.slusarz@gmail.com>
- fix find/replace bug in license header
v3: Ben Skeggs <bskeggs@redhat.com>
- bump indirect pushbuf size to 8KiB, 4KiB barely enough for userspace and
left no space for kernel's requirements during GEM pushbuf submission.
- fix duplicate assignments noticed by clang
v4: Marcin Slusarz <marcin.slusarz@gmail.com>
- add sparse annotations to nv04_fifo_pause/nv04_fifo_start
- use ioread32_native/iowrite32_native for fifo control registers
v5: Ben Skeggs <bskeggs@redhat.com>
- rebase on v3.6-rc4, modified to keep copy engine fix intact
- nv10/fence: unmap fence bo before destroying
- fixed fermi regression when using nvidia gr fuc
- fixed typo in supported dma_mask checking
Cosmetic cleanup only.
Kepler GRAPH has (well, sorta) fixed subchannel<->class assignments, make
this match up to keep it happy without trapping.
This reverts commit a81f15499887d3f9f24ec70bb9b7e778942a6b7b.
Gah, we have a released userspace component using fixed subc assignment
that conflicts with this. To avoid breaking ABI this needs to be
reverted.
All available subchannels are now available for userspace to do with as it
pleases on NVC0+.
On all earlier chipsets, the kernel still uses a software object on subc 0
to implement the page flip completion method. I hope to find some decent
way of addressing this too, but it's a tad tricker prior to fermi.
'mappable' isn't really used at all, nor is it necessary anymore as the
bo code is capable of moving buffers to mappable vram as required.
'no_vm' isn't necessary anymore either, any places that don't want to be
mapped into a GPU address space should allocate the VRAM directly instead.
Also imports a couple of helper functions that'll be used to implement
page flipping in the following commits..
This should prevent a number of races from occuring, the most obvious of
which will be exposed when we start making use of the "display sync" evo
channel for page flipping. The DS channel will reject any command stream
that doesn't completely agree with the current "master" state.
Signed-off-by: Francisco Jerez <currojerez@riseup.net>
This commit breaks the userspace interface, and requires a new libdrm for
nouveau to operate again.
The multiple GEM_PUSHBUF ioctls that were present in 0.0.15 for
compatibility purposes are now gone, and replaced with the new ioctl which
allows for multiple push buffers to be submitted (necessary for hw index
buffers in the nv50 3d driver) and relocations to be applied on any buffer.
A number of other ioctls (CARD_INIT, GEM_PIN, GEM_UNPIN) that were needed
for userspace modesetting have also been removed.
PFIFO on G80 and up has a new mode where the main ring buffer is simply a
ring of pointers to indirect buffers containing the actual command/data
packets. In order to be able to implement index buffers in the 3D driver
we need to be able to submit data-only push buffers right after the cmd
packet header, which is only possible using the new command submission
method.
This commit doesn't make it possible to implement index buffers yet, some
userspace interface changes will be required, but it does allow for
testing/debugging of the hardware-side support in the meantime.
It will be useful for various synchronization purposes, mostly stolen
from "[PATCH] drm/nv50: synchronize user channel after buffer object
move on kernel channel" by Maarten Maathuis.
This adds a drm/kms staging non-API stable driver for GPUs from NVIDIA.
This driver is a KMS-based driver and requires a compatible nouveau
userspace libdrm and nouveau X.org driver.
This driver requires firmware files not available in this kernel tree,
interested parties can find them via the nouveau project git archive.
This driver is reverse engineered, and is in no way supported by nVidia.
Support for nearly the complete range of nvidia hw from nv04->g80 (nv50)
is available, and the kms driver should support driving nearly all
output types (displayport is under development still) along with supporting
suspend/resume.
This work is all from the upstream nouveau project found at
nouveau.freedesktop.org.
The original authors list from nouveau git tree is:
Anssi Hannula <anssi.hannula@iki.fi>
Maarten Maathuis <madman2003@gmail.com>
Marcin KoĆcielnicki <koriakin@0x04.net>
Matthew Garrett <mjg@redhat.com>
Matt Parnell <mparnell@gmail.com>
Patrice Mandin <patmandin@gmail.com>
Pekka Paalanen <pq@iki.fi>
Xavier Chantry <shiningxc@gmail.com>
along with project founder Stephane Marchesin <marchesin@icps.u-strasbg.fr>
