path: root/drivers/gpu/drm/omapdrm
2016-08-29drm/atomic-helper: Add NO_DISABLE_AFTER_MODESET flag support for plane commitLiu Ying
Drivers may set the NO_DISABLE_AFTER_MODESET flag in the 'flags' parameter of the helper drm_atomic_helper_commit_planes() if the relevant display controllers(e.g., IPUv3 for imx-drm) require to disable a CRTC's planes when the CRTC is disabled. The helper would skip the ->atomic_disable call for a plane if the CRTC of the old plane state needs a modesetting operation. Of course, the drivers need to disable the planes in their CRTC disable callbacks since no one else would do that. Suggested-by: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Philipp Zabel <p.zabel@pengutronix.de> Cc: David Airlie <airlied@linux.ie> Cc: Russell King <linux@armlinux.org.uk> Cc: Peter Senna Tschudin <peter.senna@gmail.com> Cc: Lucas Stach <l.stach@pengutronix.de> Signed-off-by: Liu Ying <gnuiyl@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/1472461923-14364-1-git-send-email-gnuiyl@gmail.com
2016-08-19drm: Allow drivers to modify plane_state in prepare_fb/cleanup_fbChris Wilson
The drivers have to modify the atomic plane state during the prepare_fb callback so they track allocations, reservations and dependencies for this atomic operation involving this fb. In particular, how else do we set the plane->fence from the framebuffer! Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: dri-devel@lists.freedesktop.org Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/20160818180017.20508-1-chris@chris-wilson.co.uk
2016-08-12Revert "gpu: drm: omapdrm: dss-of: add missing of_node_put after calling ↵Peter Chen
of_parse_phandle" This reverts commit 2ab9f5879162499e1c4e48613287e3f59e593c4f Author: Peter Chen <peter.chen@nxp.com> Date: Fri Jul 15 11:17:03 2016 +0800 gpu: drm: omapdrm: dss-of: add missing of_node_put after calling of_parse_phandle The of_get_next_parent will drop refcount on the passed node, so the reverted patch is wrong, thanks for Tomi Valkeinen points it. Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Peter Chen <peter.chen@nxp.com> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Sean Paul <seanpaul@chromium.org> Link: http://patchwork.freedesktop.org/patch/msgid/1470908694-16362-1-git-send-email-peter.chen@nxp.com
2016-08-12drm: Remove superflous linux/fb.h includesDaniel Vetter
Everyone who uses the fbdev emulation helpers doesn't need to include fb.h directly. Remove it. Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/1470847958-28465-3-git-send-email-daniel.vetter@ffwll.ch
2016-08-08drm: BIT(DRM_ROTATE_?) -> DRM_ROTATE_?Joonas Lahtinen
Only property creation uses the rotation as an index, so convert the to figure the index when needed. v2: Use the new defines to build the _MASK defines (Sean) Cc: intel-gfx@lists.freedesktop.org Cc: linux-arm-msm@vger.kernel.org Cc: freedreno@lists.freedesktop.org Cc: malidp@foss.arm.com Cc: David Airlie <airlied@linux.ie> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Cc: Liviu Dudau <Liviu.Dudau@arm.com> Cc: Sean Paul <seanpaul@chromium.org> Acked-by: Liviu Dudau <Liviu.Dudau@arm.com> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> (v1) Signed-off-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com> Signed-off-by: Sean Paul <seanpaul@chromium.org> Link: http://patchwork.freedesktop.org/patch/msgid/1469771405-17653-1-git-send-email-joonas.lahtinen@linux.intel.com
2016-08-01Merge tag 'drm-for-v4.8' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Merge drm updates from Dave Airlie: "This is the main drm pull request for 4.8. I'm down with a cold at the moment so hopefully this isn't in too bad a state, I finished pulling stuff last week mostly (nouveau fixes just went in today), so only this message should be influenced by illness. Apologies to anyone who's major feature I missed :-) Core: Lockless GEM BO freeing Non-blocking atomic work Documentation changes (rst/sphinx) Prep for new fencing changes Simple display helpers Master/auth changes Register/unregister rework Loads of trivial patches/fixes. New stuff: ARM Mali display driver (not the 3D chip) sii902x RGB->HDMI bridge Panel: Support for new panels Improved backlight support Bridge: Convert ADV7511 to bridge driver ADV7533 support TC358767 (DSI/DPI to eDP) encoder chip support i915: BXT support enabled by default GVT-g infrastructure GuC command submission and fixes BXT workarounds SKL/BKL workarounds Demidlayering device registration Thundering herd fixes Missing pci ids Atomic updates amdgpu/radeon: ATPX improvements for better dGPU power control on PX systems New power features for CZ/BR/ST Pipelined BO moves and evictions in TTM GPU scheduler improvements GPU reset improvements Overclocking on dGPUs with amdgpu Polaris powermanagement enabled nouveau: GK20A/GM20B volt and clock improvements. Initial support for GP100/GP104 GPUs, GP104 will not yet support acceleration due to NVIDIA having not released firmware for them as of yet. exynos: Exynos5433 SoC with IOMMU support. vc4: Shader validation for branching imx-drm: Atomic mode setting conversion Reworked DMFC FIFO allocation External bridge support analogix-dp: RK3399 eDP support Lots of fixes. rockchip: Lots of small fixes. msm: DT bindings cleanups Shrinker and madvise support ASoC HDMI codec support tegra: Host1x driver cleanups SOR reworking for DP support Runtime PM support omapdrm: PLL enhancements Header refactoring Gamma table support arcgpu: Simulator support virtio-gpu: Atomic modesetting fixes. rcar-du: Misc fixes. mediatek: MT8173 HDMI support sti: ASOC HDMI codec support Minor fixes fsl-dcu: Suspend/resume support Bridge support amdkfd: Minor fixes. etnaviv: Enable GPU clock gating hisilicon: Vblank and other fixes" * tag 'drm-for-v4.8' of git://people.freedesktop.org/~airlied/linux: (1575 commits) drm/nouveau/gr/nv3x: fix instobj write offsets in gr setup drm/nouveau/acpi: fix lockup with PCIe runtime PM drm/nouveau/acpi: check for function 0x1B before using it drm/nouveau/acpi: return supported DSM functions drm/nouveau/acpi: ensure matching ACPI handle and supported functions drm/nouveau/fbcon: fix font width not divisible by 8 drm/amd/powerplay: remove enable_clock_power_gatings_tasks from initialize and resume events drm/amd/powerplay: move clockgating to after ungating power in pp for uvd/vce drm/amdgpu: add query device id and revision id into system info entry at CGS drm/amdgpu: add new definition in bif header drm/amd/powerplay: rename smum header guards drm/amdgpu: enable UVD context buffer for older HW drm/amdgpu: fix default UVD context size drm/amdgpu: fix incorrect type of info_id drm/amdgpu: make amdgpu_cgs_call_acpi_method as static drm/amdgpu: comment out unused defaults_staturn_pro static const structure to fix the build drm/amdgpu: enable UVD VM only on polaris drm/amdgpu: increase timeout of IB test drm/amdgpu: add destroy session when generate VCE destroy msg. drm/amd: fix deadlock of job_list_lock V2 ...
2016-07-22GPU-DRM-OMAP: Delete unnecessary checks before two function callsMarkus Elfring
The following functions test whether their argument is NULL and then return immediately. * backlight_device_unregister * drm_gem_object_unreference_unlocked Thus the test around the calls is not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/72ff4670-4f3d-c7ed-4f37-e49f2bbc7aba@users.sourceforge.net
2016-07-19Merge remote-tracking branch 'airlied/drm-next' into topic/drm-miscDaniel Vetter
Backmerge drm-next to be able to apply Chris' connector_unregister_all cleanup (need latest i915 and sun4i state for that). Also there's a trivial conflict in ttm_bo.c that git rerere fails to remember. Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
2016-07-18drm/omap: make fbdev support really optionalTobias Jakobi
Currently enabling OMAP DRM support automatically pulls in fbdev dependency. However this dep is unnecessary since DRM core already handles this for us (DRM_FBDEV_EMULATION). Signed-off-by: Tobias Jakobi <tjakobi@math.uni-bielefeld.de> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/1468586897-32298-4-git-send-email-tjakobi@math.uni-bielefeld.de
2016-07-15gpu: drm: omapdrm: dss-of: add missing of_node_put after calling ↵Peter Chen
of_parse_phandle of_node_put needs to be called when the device node which is got from of_parse_phandle has finished using. Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Peter Chen <peter.chen@nxp.com> Signed-off-by: Sean Paul <seanpaul@chromium.org>
2016-07-15gpu: drm: omapdrm: connector-dvi: add missing of_node_put after calling ↵Peter Chen
2016-07-02Back-merge tag 'v4.7-rc5' into drm-nextDave Airlie
Linux 4.7-rc5 The fsl-dcu pull needs -rc3 so go to -rc5 for now.
2016-06-30Merge branch 'd_real' of ↵Al Viro
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs into work.misc
2016-06-21drm: Lobotomize set_busid nonsense for !pci driversDaniel Vetter
We already have a fallback in place to fill out the unique from dev->unique, which is set to something reasonable in drm_dev_alloc. Which means we only need to have a special set_busid for pci devices, to be able to care the backwards compat code for drm 1.1 around, which libdrm still needs. While developing and testing this patch things blew up in really interesting ways, and the code is rather confusing in naming things between the kernel code, ioctl #defines and libdrm. For the next brave dragon slayer, document all this madness properly in the userspace interface section of gpu.tmpl. v2: Make drm_dev_set_unique static and update kerneldoc. v3: Entire rewrite, plus document what's going on for posterity in the gpu docbook uapi section. v4: Drop accidental amdgpu hunk (Emil). v5: Drop accidental omapdrm vblank counter change (Emil). v6: Rebase on top of the sphinx conversion. Cc: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Cc: Emil Velikov <emil.l.velikov@gmail.com> Tested-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> (virt_gpu) Reviewed-by: Emil Velikov <emil.l.velikov@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
2016-06-21drm/omapdrm: don't call drm_helper_disable_unused_functionsDaniel Vetter
It's a legacy helper function which won't do good with atomic helpers. Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1465510479-21180-1-git-send-email-daniel.vetter@ffwll.ch
2016-06-10drm: omap: Rely on the default ->best_encoder() behaviorBoris Brezillon
We have a 1:1 relationship between connectors and encoders and the driver is relying on the atomic helpers: we can drop the custom ->best_encoder() implementation and let the core call drm_atomic_helper_best_encoder() for us. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/1465300095-16971-17-git-send-email-boris.brezillon@free-electrons.com
2016-06-10drm/atomic-helper: Massage swap_state signature somewhatDaniel Vetter
- dev is redundant, we have state->atomic - add stall parameter, which must be set when swapping needs to stall for preceeding commits to stop looking at ->state pointers. Currently all drivers need this to be, just prep work for a glorious future. v2: Rebased on top of commit e7cf0963f816fa44190caaf51aeffaa614c340c6 Author: Gerd Hoffmann <kraxel@redhat.com> Date: Tue May 31 08:50:47 2016 +0200 virtio-gpu: add atomic_commit function Cc: Gerd Hoffmann <kraxel@redhat.com> Reviewed-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com> Cc: Maarten Lankhorst <maarten.lankhorst@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/1465509992-19284-1-git-send-email-daniel.vetter@ffwll.ch Link: http://patchwork.freedesktop.org/patch/msgid/1465388359-8070-2-git-send-email-daniel.vetter@ffwll.ch
2016-06-09drm/omap: fix unused variable warning in dsi & hdmiTomi Valkeinen
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2016-06-09Merge tag 'omapdrm-4.8' of ↵Dave Airlie
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux into drm-next omapdrm changes for 4.8 * Update MAINTAINERS file for omapdrm and tilcdc * PLL refactoring to allow versatile use of the PLL clocks * Public omapdss header refactoring to separate omapfb and omapdrm * Gamma table support * Support reset GPIO and vcc regulator in omapdrm's panel-dpi * Minor cleanups * tag 'omapdrm-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (69 commits) drm/omapdrm: Implement gamma_lut atomic crtc properties drm/omapdrm: Workaround for errata i734 (LCD1 Gamma) in DSS dispc drm/omapdrm: Add gamma table support to DSS dispc drm: drm_helper_crtc_enable_color_mgmt() => drm_crtc_enable_color_mgmt() drm/omap: rename panel/encoder Kconfig names drm: omapdrm: add DSI mapping drm: omapdrm: Remove unused omap_framebuffer_bo function drm: omapdrm: Remove unused omap_gem_tiled_size function drm: omapdrm: panel-lgphilips-lb035q02: Remove unused backlight GPIO drm/omap: panel-dpi: implement support for a vcc regulator drm/omap: panel-dpi: make (limited) use of a reset gpio devicetree/bindings: add reset-gpios and vcc-supply for panel-dpi MAINTAINERS: Add maintainer for TI LCDC DRM driver MAINTAINERS: Add maintainer for OMAP DRM driver drm/omap: fix pitch round-up drm/omap: remove align_pitch() drm/omap: remove unnecessary pitch round-up drm/omap: remove unneeded gpio includes drm/omap: Remove the video/omapdss.h and move it's content to local header file [media] omap_vout: Switch to use the video/omapfb_dss.h header file ...
2016-06-09Merge tag 'topic/drm-misc-2016-06-07' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-next As promised, piles of prep work all around: - drm_atomic_state rework, prep for nonblocking commit helpers - fence patches from Gustavo and Christian to prep for atomic fences and some cool work in ttm/amdgpu from Christian - drm event prep for both nonblocking commit and atomic fences - Gustavo seems on a crusade against the non-kms-native version of the vblank functions. - prep work from Boris to nuke all the silly ->best_encoder implementations we have (we really only need that for truly dynamic cases like dvi-i vs dvi-d or dp mst selecting the right transcoder on intel) - prep work from Laurent to rework the format handling functions - and few small things all over * tag 'topic/drm-misc-2016-06-07' of git://anongit.freedesktop.org/drm-intel: (47 commits) drm/dsi: Implement set tear scanline drm/fb_cma_helper: Implement fb_mmap callback drm/qxl: Remove useless drm_fb_get_bpp_depth() call drm/ast: Remove useless drm_fb_get_bpp_depth() call drm/atomic: Fix remaining places where !funcs->best_encoder is valid drm/core: Change declaration for gamma_set. Documentation: add fence-array to kernel DocBook drm/shmobile: use drm_crtc_vblank_{get,put}() drm/radeon: use drm_crtc_vblank_{get,put}() drm/qxl: use drm_crtc_vblank_{get,put}() drm/atmel: use drm_crtc_vblank_{get,put}() drm/armada: use drm_crtc_vblank_{get,put}() drm/amdgpu: use drm_crtc_vblank_{get,put}() drm/virtio: use drm_crtc_send_vblank_event() drm/udl: use drm_crtc_send_vblank_event() drm/qxl: use drm_crtc_send_vblank_event() drm/atmel: use drm_crtc_send_vblank_event() drm/armada: use drm_crtc_send_vblank_event() drm/doc: Switch to sphinx/rst fixed-width quoting drm/doc: Drop kerneldoc for static functions in drm_irq.c ...
2016-06-09Merge tag 'topic/lockless-gem-bo-freeing-2016-06-01' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-next lockless gem bo freeing patches (and the oddball related patch) for all the drivers who's maintainers are asleep at the helm - includes you ;-) I based this on top of drm-fixes to include Chris' fix for the cma issue. * tag 'topic/lockless-gem-bo-freeing-2016-06-01' of git://anongit.freedesktop.org/drm-intel: (21 commits) drm/arcpgu: Use lockless gem BO free callback drm/sun4i: Use lockless gem BO free callback drm/omapdrm: Nuke dummy fb->dirty callback drm/msm: Nuke dummy fb->dirty callback drm/rockchip: Use cma gem vm ops drm/sti: Use lockless gem BO free callback drm: sti: remove useless call to dev->struct_mutex drm/virtio: Use lockless gem BO free callback drm/tilcdc: Use lockless gem BO free callback drm/shmob: Use lockless gem BO free callback drm/rockchip: Use lockless gem BO free callback drm/rcar-du: Use lockless gem BO free callback drm/qxl: Use lockless gem BO free callback drm/nouveau: Use lockless gem BO free callback drm/mga200g: Use lockless gem BO free callback drm/fls-dcu: Use lockless gem BO free callback drm/cirrus: Use lockless gem BO free callback drm/bochs: Use lockless gem BO free callback drm/atmel: Use lockless gem BO free callback drm/ast: Use lockless gem BO free callback ...
2016-06-07drm/omapdrm: Implement gamma_lut atomic crtc propertiesJyri Sarha
Implement gamma_lut atomic crtc properties, set crtc gamma size to 256 for all crtcs and use drm_atomic_helper_legacy_gamma_set() as gamma_set func. The tv-out crtc has 1024 element gamma table (with 10bit precision) in HW, but current Xorg server does not accept anything else but 256 elements so that is used for all CRTCs. The dss dispc API converts table of any length for HW and uses linear interpolation in the process. The default gamma table is restored if gamma_lut property is deleted. Signed-off-by: Jyri Sarha <jsarha@ti.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2016-06-07drm/omapdrm: Workaround for errata i734 (LCD1 Gamma) in DSS dispcJyri Sarha
Workaround for errata i734 in DSS dispc - LCD1 Gamma Correction Is Not Working When GFX Pipe Is Disabled For gamma tables to work on LCD1 the GFX plane has to be used at least once after DSS HW has come out of reset. The workaround sets up a minimal LCD setup with GFX plane and waits for one vertical sync irq before disabling the setup and continuing with the context restore. The physical outputs are gated during the operation. For details see: OMAP543x Multimedia Device Silicon Revision 2.0 Silicon Errata Literature Number: SWPZ037E Or some other relevant errata document for the DSS IP version. Signed-off-by: Jyri Sarha <jsarha@ti.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2016-06-07drm/omapdrm: Add gamma table support to DSS dispcJyri Sarha
Add gamma table support to DSS dispc. DSS driver initializes the default gamma table at component bind time and holds a copy of all gamma tables in its internal data structure. Each call to dispc_mgr_set_gamma() updates the internal table and triggers write to the HW, if it is enabled. The tables are restored to HW in PM resume callback. The drivers internal data structure match the HW tables in size and in number of significant bits per color component. The dispc_mgr_set_gamma() converts the size of any given table for the internal data structure using linear interpolation. Default gamma table is restored if NULL is given in place of gamma lut. dispc_mgr_gamma_size() gives HW gamma table size for the channel and returns 0 if gamma table is not supported by the HW or the DSS driver. Signed-off-by: Jyri Sarha <jsarha@ti.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2016-06-07Merge omapdss header refactoringTomi Valkeinen
Merge omapdss public header refactoring, which separates the public header into omapdrm and omapfb parts.
2016-06-06Merge branch '4.8/omapdrm-pll' (omapdrm PLL work)Tomi Valkeinen
Merge omapdrm PLL work, which makes it possible to use the DSS PLLs in a versatile manner, for example, HDMI PLL can be used for LCDs.
2016-06-06drm/omap: rename panel/encoder Kconfig namesTomi Valkeinen
omapdrm is using much too generic Kconfig names for its panels and encoders. Rename them to have "DRM_OMAP" in the name. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2016-06-06drm: omapdrm: add DSI mappingSebastian Reichel
This sets proper connector type for DSI connected panels. Signed-off-By: Sebastian Reichel <sre@kernel.org> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2016-06-06drm: omapdrm: Remove unused omap_framebuffer_bo functionLaurent Pinchart
The function is never used, remove it. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2016-06-06drm: omapdrm: Remove unused omap_gem_tiled_size functionLaurent Pinchart
2016-06-06drm: omapdrm: panel-lgphilips-lb035q02: Remove unused backlight GPIOLaurent Pinchart
The backlight GPIO was supported with platform data only. Now that the driver only supports DT, the backlight GPIO is never initialized. Remove it. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2016-06-06drm/omap: panel-dpi: implement support for a vcc regulatorUwe Kleine-König
To allow supporting displays that need some logic to enable power to the display try to get a vcc-supply property from the device tree and drive the resulting regulator accordingly. Reviewed-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2016-06-06drm/omap: panel-dpi: make (limited) use of a reset gpioUwe Kleine-König
Some displays have a reset input. To assert that the display is functional the reset gpio must be deasserted. Teach the driver to get and drive such a gpio accordingly. Reviewed-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2016-06-06drm/omap: fix pitch round-upTomi Valkeinen
At the moment we calculate the buffer's pitch with: pitch = width * DIV_ROUND_UP(bpp, 8) For CLUT modes with bpp of 1/2/4/8 this gives wrong result, and the correct pitch is: pitch = DIV_ROUND_UP(width * bpp, 8) In practice this doesn't change anything, as we don't support CLUT modes, but it's better to have the pitch calculation correct. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2016-06-06drm/omap: remove align_pitch()Tomi Valkeinen
The previous commit removed aligning the pitch to SGX's pitch requirement from align_pitch(). What's left is effectively a function that returns width * bytespp. To clean up the driver, we can remove the function and have the calculation inline in the two places which call align_pitch(). Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2016-06-06drm/omap: remove unnecessary pitch round-upTomi Valkeinen
omapdrm checks if the pixel stride is divisible by 8. This is meant to ensure that the byte stride is 32, which is required by SGX. The check is not correct, as it checks for pixels, not bytes, and thus needlessly increases the stride for, e.g., NV12. Also, SGX driver is not supported in the mainline, and the TI's SGX driver nowadays does the memory allocation itself and doesn't rely on omapdrm to figure out the correct pitch. So we can just remove the whole roundup. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2016-06-06drm/omap: remove unneeded gpio includesTomi Valkeinen
encoder-opa362.c and panel-sharp-ls037v7dw01.c do not use the legacy GPIO API, so we can remove the including of gpio.h and of_gpio.h. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2016-06-03drm/omap: Remove the video/omapdss.h and move it's content to local header filePeter Ujfalusi
Move the contents of the video/omapdss.h header file to omapdrm/dss local header file and remove the original global header. The omapfb stach is using video/omapfb_dss.h so this change will complete the separation of the two driver implementation. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
2016-06-03drm/omap: Do not include video/omapdss.h directly in driversPeter Ujfalusi
All drivers to include the omapdrm/dss/omapdss.h header file. This header includes the <video/omapdss.h> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
2016-06-03omapdss: hdmi audio: Make header file independent of video/omapdss.hPeter Ujfalusi
Clean up the header files regarding to hdmi audio so the omap-hdmi-audio.h file will only need to include the platform_data/omapdss.h file. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> CC: Mark Brown <broonie@kernel.org> CC: Jyri Sarha <jsarha@ti.com> CC: Liam Girdwood <liam.r.girdwood@linux.intel.com>
2016-06-03drm/omap: Remove reference to pdata->default_devicePeter Ujfalusi
The default_device is no longer used, it is a leftower from legacy. The else if (pdata->default_device) is always going to be false. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
2016-06-03drm/omap: connector-analog-tv: Support only Composite type in legacy bootPeter Ujfalusi
In legacy mode (non DT mode) support only composite connector type. The only user for this is rx51, using composite type. Dropping the connector_type selection via pdata will allow cleanups in omapdss (drm vs fbdev). Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
2016-06-03drm/omap: displays: Do not include video/omap-panel-data.h if not neededPeter Ujfalusi
Some panel/encoder/connector driver includes omap-panel-data.h but they do not need it. Remove the inclusion of video/omap-panel-data.h from these drivers. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
2016-06-03drm/omap: fix unused variable warning.Dave Airlie
2016-06-02drm/omap: Use for_each_plane_in_stateDaniel Vetter
We want to hide drm_atomic_stat internals a bit better. v2: Use drm_crtc_mask (Maarten). Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Reviewed-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1464818821-5736-7-git-send-email-daniel.vetter@ffwll.ch
2016-06-01drm/omapdrm: Nuke dummy fb->dirty callbackDaniel Vetter
It's an optional hook. Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1464630800-30786-23-git-send-email-daniel.vetter@ffwll.ch
2016-05-31drm/omap: include gpio/consumer.h where neededArnd Bergmann
A lot of the display drivers for OMAP use the gpio descriptor functions that are only available in linux/gpio.h if GPIOLIB is enabled and otherwise produce a build error: drivers/gpu/drm/omapdrm/displays/encoder-opa362.c: In function 'opa362_enable': drivers/gpu/drm/omapdrm/displays/encoder-opa362.c:101:3: error: implicit declaration of function 'gpiod_set_value_cansleep' [-Werror=implicit-function-declaration] drivers/gpu/drm/omapdrm/displays/panel-dpi.c: In function 'panel_dpi_probe_pdata': drivers/gpu/drm/omapdrm/displays/panel-dpi.c:189:23: error: implicit declaration of function 'gpio_to_desc' [-Werror=implicit-function-declaration] drivers/gpu/drm/omapdrm/displays/panel-sharp-ls037v7dw01.c: In function 'sharp_ls_enable': drivers/gpu/drm/omapdrm/displays/panel-sharp-ls037v7dw01.c:120:3: error: implicit declaration of function 'gpiod_set_value_cansleep' [-Werror=implicit-function-declaration] This replaces the existing linux/gpio.h with linux/gpio/consumer.h where needed. In case of panel-lgphilips-lb035q02.c however, we also have to include linux/gpio.h to get the definition of gpio_is_valid and gpio_set_value_cansleep that are used for the non-DT case. Signed-off-by: Arnd Bergmann <arnd@arndb.de> [tomi.valkeinen@ti.com: resolved conflicts] Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2016-05-31drm/omap: include linux/seq_file.h where neededArnd Bergmann
The omapdrm driver relies on this header to be included implicitly, but this does not always work, and I get this error in randconfig builds: gpu/drm/omapdrm/dss/hdmi_phy.c: In function 'hdmi_phy_dump': gpu/drm/omapdrm/dss/hdmi_phy.c:34:2: error: implicit declaration of function 'seq_printf' [-Werror=implicit-function-declaration] gpu/drm/omapdrm/dss/hdmi_wp.c: In function 'hdmi_wp_dump': gpu/drm/omapdrm/dss/hdmi_wp.c:26:2: error: implicit declaration of function 'seq_printf' [-Werror=implicit-function-declaration] gpu/drm/omapdrm/dss/hdmi_pll.c: In function 'hdmi_pll_dump': gpu/drm/omapdrm/dss/hdmi_pll.c:30:2: error: implicit declaration of function 'seq_printf' [-Werror=implicit-function-declaration] This adds the #include statements in all files that have a seq_printf statement. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2016-05-31Revert "drm/omap: no need to select OMAP2_DSS"Peter Ujfalusi
This reverts commit 1c278e5e3718d15475ec08ee2135f37a6b13361c. If DRM_OMAP does not select OMAP2_DSS it is possible to build a kernel with DRM_OMAP only and not selecting OMAP2_DSS. Since omapdrm depends on OMAP2_DSS this will result on broken kernel build. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2016-05-31drm/omap: Remove regulator API abusePeter Ujfalusi
regulator_can_change_voltage() is deprecated and it's use is not necessary as commit: 6a0028b3dd67b regulator: Deprecate regulator_can_change_voltage() describers it clearly. Also, regulator_set_voltage() is misused in the driver, as it is supposed to be used only in cases where the regulator voltage needs to be changed dynamically at runtime. In DSS's case, we always want a fixed voltage, set in the .dts files. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
