We already express the drm/agp depencies correctly in Kconfig, so we
can rip this remnant from the shared drm core days.
Aside: Pretty much all the #ifdefs in radeon/nouveau could be killed
if ttm would provide dummy functions. I'm not going to volunteer for
that though.
v2: Use IS_ENABLED(CONFIG_AGP) as suggested by Ville
v3: Polish from Ville's review.
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Reviewed-by: Christian König <christian.koenig@amd.com> (v2)
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
And replace the drm_core_ prefix with drm_legacy_ since really, this
isn't core stuff.
Also drop drm_core_dropmap since it's unused.
v2: Fix up i810.ko fully which somehow slipped through.
Move internal declarations to drm_legacy.h and add drm_legacy_*() prefix
to all legacy functions.
[airlied: add a bit of an explaination to drm_legacy.h]
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
Reviewed-by: Thierry Reding <treding@nvidia.com>
Less yelling ftw!
Again just use the version provided by the linux core.
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Dave Airlie <airlied@gmail.com>
Convert #include "..." to #include <path/...> in drivers/gpu/.
Acked-by: Dave Airlie <airlied@redhat.com>
Acked-by: Dave Jones <davej@redhat.com>
Remove redundant DRM UAPI header #inclusions from drivers/gpu/.
Remove redundant #inclusions of core DRM UAPI headers (drm.h, drm_mode.h and
drm_sarea.h). They are now #included via drmP.h and drm_crtc.h via a preceding
patch.
Without this patch and the patch to make include the UAPI headers from the core
headers, after the UAPI split, the DRM C sources cannot find these UAPI headers
because the DRM code relies on specific -I flags to make #include "..." work
on headers in include/drm/ - but that does not work after the UAPI split without
adding more -I flags.
So that we don't get build failures once the implicit module.h
presence is removed.
Fixed brace and spacing coding style issues.
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Almost all r128's private ioctls require that the CCE state has
already been initialised. However, most do not test that this has
been done, and will proceed to dereference a null pointer. This may
result in a security vulnerability, since some ioctls are
unprivileged.
This adds a macro for the common initialisation test and changes all
ioctl implementations that require prior initialisation to use that
macro.
Also, r128_do_init_cce() does not test that the CCE state has not
been initialised already. Repeated initialisation may lead to a crash
or resource leak. This adds that test.
Firmware blob looks like this:
__be32 datah
__be32 datal
It hasn't been used in ages, and having the user tell your how much
memory is being freed at free time is a recipe for disaster even if it
was ever used.
Signed-off-by: Eric Anholt <eric@anholt.net>
This should allow r128 to start working again since PAT changes.
taken from F-11 kernel.
This changes drm_local_map to use a resource_size for its "offset"
member instead of an unsigned long, thus allowing 32-bit machines
with a >32-bit physical address space to be able to store there
their register or framebuffer addresses when those are above 4G,
such as when using a PCI video card on a recent AMCC 440 SoC.
This patch isn't as "trivial" as it sounds: A few functions needed
to have some unsigned long/int changed to resource_size_t and a few
printk's had to be adjusted.
But also, because userspace isn't capable of passing such offsets,
I had to modify drm_find_matching_map() to ignore the offset passed
in for maps of type _DRM_FRAMEBUFFER or _DRM_REGISTERS.
If we ever support multiple _DRM_FRAMEBUFFER or _DRM_REGISTERS maps
for a given device, we might have to change that trick, but I don't
think that happens on any current driver.
Signed-off-by: Dave Airlie <airlied@linux.ie>
With the coming of kernel based modesetting and the memory manager stuff,
the everything in one directory approach was getting very ugly and
starting to be unmanageable.
This restructures the drm along the lines of other kernel components.
It creates a drivers/gpu/drm directory and moves the hw drivers into
subdirectores. It moves the includes into an include/drm, and
sets up the unifdef for the userspace headers we should be exporting.
