commit 01d4503968f471f876fb44335800d2cf8dc5a2ce upstream.
For usec delays use udelay instead of scheduling, this should
allow reclocking to happen faster. This also was the cause
of reported 33s delays at bootup on certain systems.
fixes: freedesktop.org bug 25506
This fixes RH bugzilla #527874.
On resume the atom posting wasn't working, however vbe posting was
going fine, after 2 weeks over irc, and 8 hrs with the hardware,
I tracked it down to the memory device table and it access the MC
registers via IIO, it appears the rv515 atom iio table might not
be fully functional, so adding a readback before doing a write
either provides enough delay to make things resume correctly.
Thanks to Peng Huang at Red Hat for coming to Brisbane.
Add kernel modesetting support to radeon driver, use the ttm memory
manager to manage memory and DRM/GEM to provide userspace API.
In order to avoid backward compatibility issue and to allow clean
design and code the radeon kernel modesetting use different code path
than old radeon/drm driver.
When kernel modesetting is enabled the IOCTL of radeon/drm
driver are considered as invalid and an error message is printed
in the log and they return failure.
KMS enabled userspace will use new API to talk with the radeon/drm
driver. The new API provide functions to create/destroy/share/mmap
buffer object which are then managed by the kernel memory manager
(here TTM). In order to submit command to the GPU the userspace
provide a buffer holding the command stream, along this buffer
userspace have to provide a list of buffer object used by the
command stream. The kernel radeon driver will then place buffer
in GPU accessible memory and will update command stream to reflect
the position of the different buffers.
The kernel will also perform security check on command stream
provided by the user, we want to catch and forbid any illegal use
of the GPU such as DMA into random system memory or into memory
not owned by the process supplying the command stream. This part
of the code is still incomplete and this why we propose that patch
as a staging driver addition, future security might forbid current
experimental userspace to run.
This code support the following hardware : R1XX,R2XX,R3XX,R4XX,R5XX
(radeon up to X1950). Works is underway to provide support for R6XX,
R7XX and newer hardware (radeon from HD2XXX to HD4XXX).
Authors:
Jerome Glisse <jglisse@redhat.com>
Alex Deucher <alexdeucher@gmail.com>
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
