path: root/drivers/gpu/drm/radeon/atom.h
2012-04-02drm/radeon/kms: fix fans after resumeAlex Deucher
On pre-R600 asics, the SpeedFanControl table is not executed as part of ASIC_Init as it is on newer asics. Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=29412 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Michel Dänzer <michel.daenzer@amd.com> Cc: stable@vger.kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-10-19drm/radeon/kms/atom: fix handling of FB scratch indicesAlex Deucher
FB scratch indices are dword indices, but we were treating them as byte indices. As such, we were getting the wrong FB scratch data for non-0 indices. Fix the indices and guard the indexing against indices larger than the scratch allocation. Fixes memory corruption on some boards if data was written past the end of the FB scratch array. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Reported-by: Dave Airlie <airlied@redhat.com> Tested-by: Dave Airlie <airlied@redhat.com> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-02drm/radeon/kms: add ioport register accessAlex Deucher
This is required for the NB_MISC regs on rs780/rs880 which means HDMI/DVI/DP ports using PCIEPHY won't work without it. It might also help with s/r (asic init) issues on other atombios cards. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=28774 and similar issues reported by Alberto Milone. [airlied: Squash io fix patch] Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Tested-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-03-31drm/radeon/kms/atom: make sure tables are valid (v2)Alex Deucher
Check that atom cmd and data tables are valid before using them. (v2) - fix some whitespace errors noticed by Rafał Miłecki - check a few more cases Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-03-15drm/radeon/kms: catch atombios infinite loop and break out of itJerome Glisse
In somecase the atombios code might lead to infinite loop because the GPU is in broken state, this patch track the jump history and will abort atombios execution if we are stuck executing the same jump for more than 1sec. Note that otherwise in some case we might enter an infinite loop in the kernel context which is bad. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-01-21drm/radeon/kms/atom: upstream parser updatesAlex Deucher
Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2009-12-23drm/radeon/kms: prevent parallel AtomBIOS callsRafał Miłecki
This just adds a mutex around the atombios table execution so we don't call it from two contexts at once. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-08drm/radeon/kms: add support to atom parser for FB read/writeDave Airlie
FB read/write really doesn't need to access the actual VRAM, we can just use a scratch area. This is required for using atom displayport calls later. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-06-15drm/radeon: introduce kernel modesetting for radeon hardwareJerome Glisse
Add kernel modesetting support to radeon driver, use the ttm memory manager to manage memory and DRM/GEM to provide userspace API. In order to avoid backward compatibility issue and to allow clean design and code the radeon kernel modesetting use different code path than old radeon/drm driver. When kernel modesetting is enabled the IOCTL of radeon/drm driver are considered as invalid and an error message is printed in the log and they return failure. KMS enabled userspace will use new API to talk with the radeon/drm driver. The new API provide functions to create/destroy/share/mmap buffer object which are then managed by the kernel memory manager (here TTM). In order to submit command to the GPU the userspace provide a buffer holding the command stream, along this buffer userspace have to provide a list of buffer object used by the command stream. The kernel radeon driver will then place buffer in GPU accessible memory and will update command stream to reflect the position of the different buffers. The kernel will also perform security check on command stream provided by the user, we want to catch and forbid any illegal use of the GPU such as DMA into random system memory or into memory not owned by the process supplying the command stream. This part of the code is still incomplete and this why we propose that patch as a staging driver addition, future security might forbid current experimental userspace to run. This code support the following hardware : R1XX,R2XX,R3XX,R4XX,R5XX (radeon up to X1950). Works is underway to provide support for R6XX, R7XX and newer hardware (radeon from HD2XXX to HD4XXX). Authors: Jerome Glisse <jglisse@redhat.com> Dave Airlie <airlied@redhat.com> Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
