path: root/drivers/gpu/drm/radeon/evergreen_smc.h
2014-03-06drm/radeon/dpm: fix typo in EVERGREEN_SMC_FIRMWARE_HEADER_softRegistersAlex Deucher
Should be at 0x8 rather than 0. fixes: https://bugzilla.kernel.org/show_bug.cgi?id=60523 Noticed by ArtForz on #radeon Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2013-06-27drm/radeon/kms: add dpm support for evergreen (v4)Alex Deucher
This adds dpm support for evergreen asics. This includes: - clockgating - dynamic engine clock scaling - dynamic memory clock scaling - dynamic voltage scaling - dynamic pcie gen1/gen2 switching (requires additional acpi support) Set radeon.dpm=1 to enable. v2: reduce stack usage, rename ulv struct v3: fix thermal interrupt check notices by Jerome v4: fix state enable Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
