Some architectures require that delays longer than a few
miliseconds are called through mdelay. This was triggered
on ARM randconfig builds.
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
They are used to sync between rings, while fences
sync between a ring and the cpu.
v2 Fix radeon_semaphore_driver_fini when no semaphore were
allocated.
v3 Initialize list early on to avoid issue in case or early
error
Signed-off-by: Christian König <deathsimple@vodafone.de>
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
So that we don't get build failures once the implicit module.h
presence is removed.
The writeback ring pointer and IH ring pointer are read using le32_to_cpu
so we do not want the chip to byteswap them on big-endian.
We still want to byteswap the ring itself and the IBs, so we don't touch
that but we remove setting of the byteswap bits in CP_RB_RPTR_ADDR and
IH_CNTL.
In general, for things like that where we control all the accessors easily,
we are better off doing the swap in SW rather than HW. Paradoxally, it does
keep the code closer to x86 and avoid using poorly tested HW features.
I also changed the use of RADEON_ to R600_ in a couple of cases to be more
consistent with the surrounding code.
Reviewed-by: Michel Dänzer <michel@daenzer.net>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
agd5f: minor cleanups
Signed-off-by: Cédric Cano <ccano@interfaceconcept.com>
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
0 is a valid DMA address from pci_map_page(), use pci_dma_mapping_error()
instead to check for errors
[airlied: fix warning + two other places with errors.]
This fixes some issues with the last gfx init patch.
- updated swizzle modes for backend map setup
- fix programming of a few gfx regs
- properly handle pipe/backend setup on LE cards
This patch fixes occlusion queries and rendering errors
on rv740 boards. Hardcoding the backend map is not an optimal
solution, but a better fix is being worked on.
This patch add cs checker to r600/r700 hw. Command stream checking
will rewrite some of the cs value in order to restrict GPU access
to BO size. This doesn't break old userspace but just enforce safe
value. It should break any things that was using the r600/r700 cs
ioctl to do forbidden things (malicious software), though we are
not aware of such things.
Here is the list of thing we check :
- enforcing resource size
- enforcing color buffer slice tile max, will restrict cb access
- enforcing db buffer slice tile max, will restrict db access
We don't check for shader bigger than the BO in which they are
supposed to be, such use would lead to GPU lockup and is harmless
from security POV, as far as we can tell (note that even checking
for this wouldn't prevent someone to write bogus shader that lead
to lockup).
This patch has received as much testing as humanly possible with
old userspace to check that it didn't break such configuration.
However not all the applications out there were tested, thus it
might broke some odd, rare applications.
[airlied: fix rules for cs checker for parallel builds]
This adds the r600 KMS + CS support to the Linux kernel.
The r600 TTM support is quite basic and still needs more
work esp around using interrupts, but the polled fencing
should work okay for now.
Also currently TTM is using memcpy to do VRAM moves,
the code is here to use a 3D blit to do this, but
isn't fully debugged yet.
Authors:
Loosely based on a patch by
Jaswinder Singh Rajput <jaswinderlinux@gmail.com>.
KMS support by Dave Airlie <airlied@redhat.com>.
For Radeon 100- to 500-series, firmware blobs look like:
struct {
__be32 datah;
__be32 datal;
} cp_ucode[256];
For Radeon 600-series, there are two separate firmware blobs:
__be32 me_ucode[PM4_UCODE_SIZE * 3];
__be32 pfp_ucode[PFP_UCODE_SIZE];
For Radeon 700-series, likewise:
__be32 me_ucode[R700_PM4_UCODE_SIZE];
__be32 pfp_ucode[R700_PFP_UCODE_SIZE];
These are new AMD IGP chips
This adds the PCI IDs for the rv790 which are equiv to the rv770.
This adds drm support for the RV740 family of chips to the r600 support code.
Copy/paste error. The RV670 microcode should work ok, so it's
not a show stopper.
This fixes page table init on rs600.
This update was done in mainline radeon, but not in the r600.
This fixes 2 bugs:
1. the AGP calculation wasn't consistent with the PCI(E) calc for the
RPTR_ADDR registers. This consolidates the writes and fixes it up.
2. The scratch address was being incorrectly calculated, this breaks
it out into a lot more linear steps.
Fix this sparse warning:
drivers/gpu/drm/radeon/r600_cp.c:1811:52: warning: Using plain integer as NULL pointer
drivers/gpu/drm/radeon/radeon_cp.c:1363:52: warning: Using plain integer as NULL pointer
drivers/gpu/drm/radeon/radeon_state.c:1983:61: warning: Using plain integer as NULL pointer
Signed-off-by: Hannes Eder <hannes@hanneseder.net>
This realigns the r600 pci mapping calls with the ati pcigart ones,
fixing the direction and using the correct interface.
Suggested by Jerome Glisse.
This attempts to fixup the r600 GART accessors so they work on other arches.
RS600s are an AMD IGP for Intel CPUs, that look like RS690s from
a lot of perspectives but look like r600s from a memory controller
point of view.
This fixes the ioremap issues with r600 AGP.
This adds support for 2D/Xv acceleration in the X.org 2D driver,
to the drm. It doesn't yet provide any 3D support hooks.
