Covers depth, cb, and textures. Hopefully I got this right.
v2: - fix bugs:
https://bugs.freedesktop.org/show_bug.cgi?id=28327
https://bugs.freedesktop.org/show_bug.cgi?id=28381
- use ALIGNED(), IS_ALIGNED() macros
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
Check for relocs for DB_DEPTH_INFO, CB_COLOR*_INFO, and texture
resources.
- Drop some more safe regs taht userspace shouldn't hit
- Constant base regs need relocs. This allows us to use
constant buffers rather than the constant register file.
Also we don't want userspace to be able to set arbitrary
mc base values for the const caches.
- Track SQ_CONFIG so we know whether userspace is using
the cfile or constant buffers.
drivers/gpu/drm/radeon/r600_cs.c: In function ‘r600_cs_track_check’:
drivers/gpu/drm/radeon/r600_cs.c:166: warning: ‘bpe’ may be used uninitialized in this function
drivers/gpu/drm/radeon/r600_cs.c:166: note: ‘bpe’ was declared here
drivers/gpu/drm/radeon/r600_cs.c: In function ‘r600_cs_parse’:
drivers/gpu/drm/radeon/r600_cs.c:938: warning: ‘bpe’ may be used uninitialized in this function
drivers/gpu/drm/radeon/r600_cs.c:938: note: ‘bpe’ was declared here
radeon_cs kfree the tracker structure but for r6xx/r7xx we want
to kfree it inside the parse function because we share it with
the UMS code path. Set tracker to NULL after freeing it will
avoid double free.
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
This patch add cs checker to r600/r700 hw. Command stream checking
will rewrite some of the cs value in order to restrict GPU access
to BO size. This doesn't break old userspace but just enforce safe
value. It should break any things that was using the r600/r700 cs
ioctl to do forbidden things (malicious software), though we are
not aware of such things.
Here is the list of thing we check :
- enforcing resource size
- enforcing color buffer slice tile max, will restrict cb access
- enforcing db buffer slice tile max, will restrict db access
We don't check for shader bigger than the BO in which they are
supposed to be, such use would lead to GPU lockup and is harmless
from security POV, as far as we can tell (note that even checking
for this wouldn't prevent someone to write bogus shader that lead
to lockup).
This patch has received as much testing as humanly possible with
old userspace to check that it didn't break such configuration.
However not all the applications out there were tested, thus it
might broke some odd, rare applications.
[airlied: fix rules for cs checker for parallel builds]
This just adds a little more info to the warning for old -ati/mesa
userspaces.
This patch workaround a possible security issue which can allow
user to abuse drm on r6xx/r7xx hw to access any system ram memory.
This patch doesn't break userspace, it detect "valid" old use of
CB_COLOR[0-7]_FRAG & CB_COLOR[0-7]_TILE registers and overwritte
the address these registers are pointing to with the one of the
last color buffer. This workaround will work for old mesa &
xf86-video-ati and any old user which did use similar register
programming pattern as those (we expect that there is no others
user of those ioctl except possibly a malicious one). This patch
add a warning if it detects such usage, warning encourage people
to update their mesa & xf86-video-ati. New userspace will submit
proper relocation.
Fix for xf86-video-ati / mesa (this kernel patch is enough to
prevent abuse, fix for userspace are to set proper cs stream and
avoid kernel warning) :
http://cgit.freedesktop.org/xorg/driver/xf86-video-ati/commit/?id=95d63e408cc88b6934bec84a0b1ef94dfe8bee7b
http://cgit.freedesktop.org/mesa/mesa/commit/?id=46dc6fd3ed5ef96cda53641a97bc68c3bc104a9f
Abusing this register to perform system ram memory is not easy,
here is outline on how it could be achieve. First attacker must
have access to the drm device and be able to submit command stream
throught cs ioctl. Then attacker must build a proper command stream
for r6xx/r7xx hw which will abuse the FRAG or TILE buffer to
overwrite the GPU GART which is in VRAM. To achieve so attacker
as to setup CB_COLOR[0-7]_FRAG or CB_COLOR[0-7]_TILE to point
to the GPU GART, then it has to find a way to write predictable
value into those buffer (with little cleverness i believe this
can be done but this is an hard task). Once attacker have such
program it can overwritte GPU GART to program GPU gart to point
anywhere in system memory. It then can reusse same method as he
used to reprogram GART to overwritte the system ram through the
GART mapping. In the process the attacker has to be carefull to
not overwritte any sensitive area of the GART table, like ring
or IB gart entry as it will more then likely lead to GPU lockup.
Bottom line is that i think it's very hard to use this flaw
to get system ram access but in theory one can achieve so.
Side note: I am not aware of anyone ever using the GPU as an
attack vector, nevertheless we take great care in the opensource
driver to try to detect and forbid malicious use of GPU. I don't
think the closed source driver are as cautious as we are.
Signed-off-by: Dave Airlie <airlied@linux.ie>
Use kzalloc rather than kcalloc(1,...)
The use of the allocated memory that looks like an array is &p->relocs[0],
but this should be the same as p->relocs.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
- kcalloc(1,
+ kzalloc(
// </smpl>
Add some additional regs that require relocs.
Both r100/r600 had this wrong, use the macro to extract the register
to relocate.
Convert the rv515 asic support to new init path also add an explanation
in radeon.h about the new init path. There is also few cleanups
associated with this change (others asic calling rv515 helper
functions).
The legacy r600 path shares code, but doesn't share quite enough
to get the freeing correct. Free the pages here also.
Need add reloc offset to the offset in the actual
packet. Fixes use of the DRAW_INDEX packet by the 3D
driver.
[airlied: modified first one where idx_value == ib[idx+0]
Provides support for anti-tearing functionality
in the ddx.
this avoids reading back the IB on AGP, also it avoids
the race where since we haven't fetched the page from the main IB
and written it to the gpu one, reading back fetches 0.
This avoids needing to do a kmalloc > PAGE_SIZE for the main
indirect buffer chunk, it adds an accessor for all reads from
the chunk and caches a single page at a time for subsequent
reads.
changes since v1:
Use a two page pool which should be the most common case
a single packet spanning > PAGE_SIZE will be hit, but I'm
having trouble seeing anywhere we currently generate anything like that.
hopefully proper short page copying at end
added parser_error flag to set deep errors instead of having to test
every ib value fetch.
fixed bug in patch that went to list.
radeon_share.h was begining to give problem with include order in
respect of radeon.h. It's easier and also i think cleaner to move
what was in radeon_share.h into radeon.h. At the same time use the
extern keyword for function shared accross the module.
This adds the r600 KMS + CS support to the Linux kernel.
The r600 TTM support is quite basic and still needs more
work esp around using interrupts, but the polled fencing
should work okay for now.
Also currently TTM is using memcpy to do VRAM moves,
the code is here to use a 3D blit to do this, but
isn't fully debugged yet.
Authors:
