path: root/drivers/gpu/drm/radeon/r600_cs.c
2012-08-29drm/radeon: add proper checking of RESOLVE_BOX command for r600-r700Marek Olšák
Checking of the second colorbuffer was skipped on r700, because CB_TARGET_MASK was 0xf. With r600, CB_TARGET_MASK is changed to 0xff, so we must set the number of samples of the second colorbuffer to 1 in order to pass the CS checker. The DRM version is bumped, because RESOLVE_BOX is always rejected without this fix on r600. Signed-off-by: Marek Olšák <maraeo@gmail.com> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2012-08-29drm/radeon: initialize tracked CS stateMarek Olšák
This should help catch uninitialized registers and reject commands because of that. Signed-off-by: Marek Olšák <maraeo@gmail.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2012-08-29drm/radeon: fix reading CB_COLORn_MASK from the CSMarek Olšák
2012-08-20drm/radeon: fix checking of MSAA renderbuffers on r600-r700Marek Olšák
The MSAA checking was mostly unimplemented on r600-r700. The userspace submits GPU commands and the kernel driver computes how much memory the GPU will access and checks if it's all within buffer bounds the userspace allocated. This patch fixes the computations of the size of MSAA surfaces in memory. Signed-off-by: Marek Olšák <maraeo@gmail.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2012-08-20drm/radeon: allow CMASK and FMASK in the CS checker on r600-r700Marek Olšák
MSAA is impossible without them. Signed-off-by: Marek Olšák <maraeo@gmail.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Jerome Glisse <jglisse@redhat.com>
2012-08-13drm/radeon/kms: add MSAA texture support for r600-evergreenMarek Olšák
Most of the checking seems to be in place already. As you can see, log2(number of samples) resides in LAST_LEVEL. This is required for MSAA support (namely for depth-stencil resolve and blitting between MSAA resources). Signed-off-by: Marek Olšák <maraeo@gmail.com> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2012-08-13drm/radeon/kms: reorder code in r600_check_texture_resourceMarek Olšák
2012-08-09drm/radeon/kms: allow "invalid" DB formats as a means to disable DBMarek Olšák
Signed-off-by: Marek Olšák <maraeo@gmail.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-06-16drm/radeon: add support for STRMOUT_BASE_UPDATE on 7xxAlex Deucher
Required for streamout. Bump drm minor. Marek v2: fix pkt->count check Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Michel Dänzer <michel.daenzer@amd.com> Signed-off-by: Marek Olšák <maraeo@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-05-09drm/radeon: make the ib an inline objectJerome Glisse
No need to malloc it any more. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Christian König <deathsimple@vodafone.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-26drm/radeon/kms: add htile support to the cs checker v3Jerome Glisse
For 6xx+. Required for mesa to use htile support for HiZ/HiS. Userspace will check radeon version 2.14 with is bumped either by tiling patch or stream out patch. This patch only add support for htile relocation which should be enough for any userspace to implement the hyperz (using htile buffer) feature. v2: Jerome: Fix size checking for htile buffer. v3: Jerome: Adapt on top of r600/evergreen cs checker changes, also check htile surface in case only stencil is present. Signed-off-by: Pierre-Eric Pelloux-Prayer <pelloux@gmail.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/radeon/kms: skip db/cb/streamout checking when possible on r600Marek Olšák
Signed-off-by: Marek Olšák <maraeo@gmail.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/radeon/kms: compute GPU addresses correctly on r600Marek Olšák
2012-03-20drm/radeon/kms: skip cb/db checking if SX_MISC is 1 on r600+Marek Olšák
2012-03-15drm: Merge tag 'v3.3-rc7' into drm-core-nextDave Airlie
Merge the fixes so far into core-next, needed to test intel driver. Conflicts: drivers/gpu/drm/i915/intel_ringbuffer.c
2012-02-29drm/radeon: fix uninitialized variableChristian König
Without this fix the driver randomly treats textures as arrays and I'm really wondering why gcc isn't complaining about it. Signed-off-by: Christian König <deathsimple@vodafone.de> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-13drm/radeon: add support for evergreen/ni tiling informations v11Jerome Glisse
evergreen and northern island gpu needs more informations for 2D tiling than previous r6xx/r7xx. Add field to tiling ioctl to allow userspace to provide those. The v8 cs checking change to track color view on r6xx/r7xx doesn't affect old userspace as old userspace always emited 0 for this register. v2 fix r6xx/r7xx 2D tiling computation v3 fix r6xx/r7xx height align for untiled surface & add support for tile split on evergreen and newer v4 improve tiling debugging output v5 fix tile split code for evergreen and newer v6 set proper tile split for crtc register v7 fix tile split limit value v8 add COLOR_VIEW checking to r6xx/r7xx checker, add evergreen cs checking, update safe reg for r600, evergreen and cayman. Evergreen checking need some work around for stencil alignment issues v9 fix tile split value range, fix compressed texture handling and mipmap calculation, allow evergreen check to be silencious in front of current broken userspace (depth/stencil alignment issue) v10 fix eg 3d texture and compressed texture, fix r600 depth array, fix r600 color view computation, add support for evergreen stencil split v11 more verbose debugging in some case Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-13drm/radeon/kms: add support for streamout v7Marek Olšák
v2: agd5f: add strmout CS checking, copy_dw register checking v3: agd5f: don't use cs_check_reg() for copy_dw checking as it will incorrectly patch the command stream for certain regs. v4: agd5f: add warning if safe reg check fails for copy_dw v5: agd5f: add stricter checking for 6xx/7xx v6: agd5f: add range checking for copy_dw on eg+, add sx_surface_sync to safe reg list for 7xx. v7: agd5f: add stricter checking for eg+ Signed-off-by: Marek Olšák <maraeo@gmail.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-01-06drm/radeon: GPU virtual memory support v22Jerome Glisse
Virtual address space are per drm client (opener of /dev/drm). Client are in charge of virtual address space, they need to map bo into it by calling DRM_RADEON_GEM_VA ioctl. First 16M of virtual address space is reserved by the kernel. Once using 2 level page table we should be able to have a small vram memory footprint for each pt (there would be one pt for all gart, one for all vram and then one first level for each virtual address space). Plan include using the sub allocator for a common vm page table area and using memcpy to copy vm page table in & out. Or use a gart object and copy things in & out using dma. v2: agd5f fixes: - Add vram base offset for vram pages. The GPU physical address of a vram page is FB_OFFSET + page offset. FB_OFFSET is 0 on discrete cards and the physical bus address of the stolen memory on integrated chips. - VM_CONTEXT1_PROTECTION_FAULT_DEFAULT_ADDR covers all vmid's >= 1 v3: agd5f: - integrate with the semaphore/multi-ring stuff v4: - rebase on top ttm dma & multi-ring stuff - userspace is now in charge of the address space - no more specific cs vm ioctl, instead cs ioctl has a new chunk v5: - properly handle mem == NULL case from move_notify callback - fix the vm cleanup path v6: - fix update of page table to only happen on valid mem placement v7: - add tlb flush for each vm context - add flags to define mapping property (readable, writeable, snooped) - make ring id implicit from ib->fence->ring, up to each asic callback to then do ring specific scheduling if vm ib scheduling function v8: - add query for ib limit and kernel reserved virtual space - rename vm->size to max_pfn (maximum number of page) - update gem_va ioctl to also allow unmap operation - bump kernel version to allow userspace to query for vm support v9: - rebuild page table only when bind and incrementaly depending on bo referenced by cs and that have been moved - allow virtual address space to grow - use sa allocator for vram page table - return invalid when querying vm limit on non cayman GPU - dump vm fault register on lockup v10: agd5f: - Move the vm schedule_ib callback to a standalone function, remove the callback and use the existing ib_execute callback for VM IBs. v11: - rebase on top of lastest Linus v12: agd5f: - remove spurious backslash - set IB vm_id to 0 in radeon_ib_get() v13: agd5f: - fix handling of RADEON_CHUNK_ID_FLAGS v14: - fix va destruction - fix suspend resume - forbid bo to have several different va in same vm v15: - rebase v16: - cleanup left over of vm init/fini v17: agd5f: - cs checker v18: agd5f: - reworks the CS ioctl to better support multiple rings and VM. Rather than adding a new chunk id for VM, just re-use the IB chunk id and add a new flags for VM mode. Also define additional dwords for the flags chunk id to define the what ring we want to use (gfx, compute, uvd, etc.) and the priority. v19: - fix cs fini in weird case of no ib - semi working flush fix for ni - rebase on top of sa allocator changes v20: agd5f: - further CS ioctl cleanups from Christian's comments v21: agd5f: - integrate CS checker improvements v22: agd5f: - final cleanups for release, only allow VM CS on cayman Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-11-20drm/radeon/kms: add a CS ioctl flag not to rewrite tiling flags in the CSMarek Olšák
This adds a new optional chunk to the CS ioctl that specifies optional flags to the CS parser. Why this is useful is explained below. Note that some regs no longer need the NOP relocation packet if this feature is enabled. Tested on r300g and r600g with this flag disabled and enabled. Assume there are two contexts sharing the same mipmapped tiled texture. One context wants to render into the first mipmap and the other one wants to render into the last mipmap. As you probably know, the hardware has a MACRO_SWITCH feature, which turns off macro tiling for small mipmaps, but that only applies to samplers. (at least on r300-r500, though later hardware likely behaves the same) So we want to just re-set the tiling flags before rendering (writing packets), right? ... No. The contexts run in parallel, so they may set the tiling flags simultaneously and then fire their command streams also simultaneously. The last one setting the flags wins, the other one loses. Another problem is when one context wants to render into the first and the last mipmap in one CS. Impossible. It must flush before changing tiling flags and do the rendering into the smaller mipmaps in another CS. Yet another problem is that writing copy_blit in userspace would be a mess involving re-setting tiling flags to please the kernel, and causing races with other contexts at the same time. The only way out of this is to send tiling flags with each CS, ideally with each relocation. But we already do that through the registers. So let's just use what we have in the registers. Signed-off-by: Marek Olšák <maraeo@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-10-18drm/radeon: Remove now unused functions in radeon driverAndi Kleen
With the dropped inlines gccs starts warning about genuinely unused functions. Remove r600_bpe_from_format, evergreen_cs_track_validate_cb, evergreen-cs_packet_next_is_pkt3_nop which are all unused. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-10-18drm/radeon: Drop inlines from evergreen_cs.c / r600_cs.cAndi Kleen
Fixes evergreen_cs_parse 4080 23124 +19044 and others compared to a non force inline kernel. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-08-04drm/radeon: off by one in check_reg() functionsDan Carpenter
This off by one range check was copy and pasted a couple places. It's not really harmful, but we should fix it anyway. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-06-21drm/radeon/kms: add initial CS checker support for computeAlex Deucher
- Add some new compute regs - Add new dispatch packets for evergreen/cayman Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-06-02drm/radeon/kms: add missing Evergreen texture formats to the CS parserMarek Olšák
BC6 and BC7 are described in ARB_texture_compression_bptc. No idea what FMT_32_AS_32_32_32_32 is good for. Signed-off-by: Marek Olšák <maraeo@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-03-17drm: radeon: *_cs_packet_parse_vline() cleanupPaul Bolle
Simplify the way the return value is set a number of times (mostly on error). Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-03-14Merge remote branch 'intel/drm-intel-next' of ../drm-next into drm-core-nextDave Airlie
* 'intel/drm-intel-next' of ../drm-next: (755 commits) drm/i915: Only wait on a pending flip if we intend to write to the buffer drm/i915/dp: Sanity check eDP existence drm/i915: Rebind the buffer if its alignment constraints changes with tiling drm/i915: Disable GPU semaphores by default drm/i915: Do not overflow the MMADDR write FIFO Revert "drm/i915: fix corruptions on i8xx due to relaxed fencing" drm/i915: Don't save/restore hardware status page address register drm/i915: don't store the reg value for HWS_PGA drm/i915: fix memory corruption with GM965 and >4GB RAM Linux 2.6.38-rc7 Revert "TPM: Long default timeout fix" drm/i915: Re-enable GPU semaphores for SandyBridge mobile drm/i915: Replace vblank PM QoS with "Interrupt-Based AGPBUSY#" Revert "drm/i915: Use PM QoS to prevent C-State starvation of gen3 GPU" drm/i915: Allow relocation deltas outside of target bo drm/i915: Silence an innocuous compiler warning for an unused variable fs/block_dev.c: fix new kernel-doc warning ACPI: Fix build for CONFIG_NET unset mm: <asm-generic/pgtable.h> must include <linux/mm_types.h> x86: Use u32 instead of long to set reset vector back to 0 ... Conflicts: drivers/gpu/drm/i915/i915_gem.c
2011-03-01drm/r600: parse the set predication command. (v2)Dave Airlie
This is required for NV_conditional_render and EXT_transform_feedback. v2: add evergreen support. Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-02-28drm/radeon: make sure ib reads are in-order.Dave Airlie
have to read values from the IB in order as we could cross a page boundary at any time and won't be able to go backwards. Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-02-28drm/radeon/r600_cs: off by one errorsDan Carpenter
There are a bunch of off by one errors in the sanity checks here. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-02-23drm/radeon: overhaul texture checking. (v3)Dave Airlie
the texture checking code didn't work for block formats like s3tc, this overhauls it to work for all types. v2: add texture array support. v3: add subsampled formats Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-02-14drm/radeon/kms: improve 6xx/7xx CS error outputAlex Deucher
Makes debugging CS rejections much easier. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-12-16drm/radeon/kms: disable the r600 cb offset checker for linear surfacesAlex Deucher
There are too many strange corner cases triggered in old userspace drivers out there to that it's nearly impossible to not break some obscure app. Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-11-26Revert "drm/radeon/kms: fix typo in r600 cs checker"Alex Deucher
This reverts commit d33ef52d9db8a36900dd53f2e32db9a521ace259. This change seems to expose a bug in the 3D driver tiggered by certain apps, so revert it to keep userspace working. Reported-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-11-18drm/radeon/kms: fix typo in r600 cs checkerAlex Deucher
Looks like a typo in: drm/radeon/r600: fix tiling issues in CS checker. (f30df2fad0c901e74ac9a52a488a54c69a373a41) Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-11-18drm/radeon/kms: fix and unify tiled buffer alignment checking for r6xx/7xxAlex Deucher
Tiled buffers have the same alignment requirements regardless of whether the surface is for db, cb, or textures. Previously, the calculations where inconsistent for each buffer type. - Unify the alignment calculations in a common function - Standardize the alignment units (pixels for pitch/height/depth, bytes for base) - properly check the buffer base alignments Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-10-28drm/radeon/kms: fix tiled db height calculation on 6xx/7xxAlex Deucher
Calculate height based on the slice bitfield rather than the size. Same as Dave's CB fix. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-10-27drm/radeon/kms: fix r6xx/7xx 1D tiling CS checker v2Alex Deucher
broken by: drm/radeon/r600: fix tiling issues in CS checker. v2: only apply it to 1D tiling case. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-10-26drm/radeon/kms: fix 2D tile height alignment in the r600 CS checkerAlex Deucher
macro tile heights are aligned to num channels, not num banks. Noticed by Dave Airlie. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-10-26drm/radeon/r600: fix tiling issues in CS checker.Dave Airlie
The CS checker had some incorrect alignment requirements for 2D surfaces, this made rendering to mipmap levels that were 2D broken. Also the CB height was being worked out from the BO size, this doesn't work at all when rendering mipmap levels, instead we work out what height userspace wanted from slice max and use that to check it fits inside the BO, however the DDX send the wrong slice max for an unaligned buffer so we have to workaround for that even though its a userspace bug. Reviewed-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-09-15drm/radeon/kms: only warn on mipmap size checks in r600 cs checker (v2)Alex Deucher
The texture base address registers are in units of 256 bytes. The original CS checker treated these offsets as bytes, so the original check was wrong. I fixed the units in a patch during the 2.6.36 cycle, but this ended up breaking some existing userspace (probably due to a bug in either userspace texture allocation or the drm texture mipmap checker). So for now, until we come up with a better fix, just warn if the mipmap size it too large. This will keep existing userspace working and it should be just as safe as before when we were checking the wrong units. These are GPU MC addresses, so if they fall outside of the VRAM or GART apertures, they end up at the GPU default page, so this should be safe from a security perspective. v2: Just disable the warning. It just spams the log and there's nothing the user can do about it. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Cc: Jerome Glisse <glisse@freedesktop.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-12drm/radeon: drop old and broken mesa warningDave Airlie
This never really got fixed in mesa, and the kernel deals with the problem just fine, so don't got reporting things that confuse people. Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-12drm/radeon/kms: another r6xx/r7xx CS checker fixAlex Deucher
add default case for buffer formats Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Cc: Andre Maasikas <amaasikas@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-10drm/radeon/kms: r600 CS parser fixesAlex Deucher
- buffer offsets in the base regs are 256b aligned so shift properly when comparing, fixed by Andre Maasikas - mipmap size was calculated wrong when nlevel=0 - texture bo offsets were used after the bo base address was added - vertex resource size register is size - 1, not size Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Cc: Andre Maasikas <amaasikas@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-02Merge tag 'v2.6.35-rc6' into drm-radeon-nextDave Airlie
Need this to avoid conflicts with future radeon fixes
2010-08-02drm/radeon/kms: fix CS alignment checking for tiling (v2)Alex Deucher
Covers depth, cb, and textures. Hopefully I got this right. v2: - fix bugs: https://bugs.freedesktop.org/show_bug.cgi?id=28327 https://bugs.freedesktop.org/show_bug.cgi?id=28381 - use ALIGNED(), IS_ALIGNED() macros Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-02drm/radeon/kms: add tiling support to the cs checker for r6xx/r7xxAlex Deucher
Check for relocs for DB_DEPTH_INFO, CB_COLOR*_INFO, and texture resources. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-07-22drm/radeon/kms: drop taking lock around crtc lookup.Dave Airlie
We only add/remove crtcs at driver load, you cannot remove when the GPU is running a CS packet since the fd is open, when GPU hotplugging on radeons actually is needed all this locking needs a review and I've started re-working kms core locking to deal with this better. But for now avoid long delays in CS processing when hotplug detect is happening in a different thread. this fixes a regression introduced with hotplug detection. Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-03-31drm/radeon/r6xx/r7xx: CS parser fixesAlex Deucher
- Drop some more safe regs taht userspace shouldn't hit - Constant base regs need relocs. This allows us to use constant buffers rather than the constant register file. Also we don't want userspace to be able to set arbitrary mc base values for the const caches. - Track SQ_CONFIG so we know whether userspace is using the cfile or constant buffers. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
