commit 92db7f6c860b8190571a9dc1fcbc16d003422fe8 upstream.
This change was verified to fix both issues with no video I've
investigated. I've also checked checksum calculation with fglrx on:
RV620, HD54xx, HD5450, HD6310, HD6320.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Now all the asic specific stuff ist mostly hid in radeon_asic.*
Reviewed-by: Alex Deucher <alexdeucher@gmail.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
We will need method of selecting encoder that should receive HDMI block. For
now we assign HDMI block to first enabled encoder. Hopefully there are not many
RS6x0 chips with two digital encoders.
[airlied: add RS740 checks as per Alex suggestion.]
Reported-by: Dan Carpenter
Implements irq support for HDMI audio output. Now the polling timer
is only enabled if irq support isn't available.
Signed-off-by: Christian König <deathsimple@vodafone.de>
Rework HDMI audio polling timer, only enable it when
at least one HDMI encoder needs it. Preparation for
replacing it with irq support.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
We still have many magic numbers in HDMI/audio to define
Older GPUs are little different, HDMI blocks are not hard-wired, but routable.
We should just find some free HDMI block and route it to choosen encoder. In
case of RS6x0 there is only one HDMI block, we don't enable HDMI on RS6x00 yet
however.
We almost always used first HDMI block for first encoder and second for sencod.
Exception was KLDSCP_LVTMA. Analyzing code picking DIG encoder shows the same
behaviour. It shows HDMI block are related to DIGs, which relation we now use.
We already know same offsets are used for different encoders/transmitters, so
just numeric them instead naming incorrectly. Additionaly we found additional
registers needed for RV770+
Adding basic HDMI support for R600 KMS, ported from radeonhd ddx.
[airlied:- checkpatch cleanups]
Signed-off-by: Christian Koenig <deathsimple@vodafone.de>
