Adds documentation to most of the functions in
radeon_asic.c
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Reviewed-by: Christian König <christian.koenig@amd.com>
Since it is now identical to evergreen_gpu_is_lockup.
Signed-off-by: Christian König <deathsimple@vodafone.de>
Reviewed-by: Jerome Glisse <jglisse@redhat.com>
Since it is now identical to r100_gpu_is_lockup.
Different rings have different criteria to test
if they are stuck.
v2: rebased on current drm-next
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Trinity (TN) is an APU with:
- Cayman 3D
- DCE6.1 display
v2: fix typo.
Reviewed-by: Christian König<christian.koenig@amd.com>
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
tidy up the radeon_asic struct.
tidy up radeon_asic struct.
Each ring type may need a different variant.
tidy up the radeon_asic struct, handle multiple
rings better.
Not all rings use PM4, so the cs_parser also needs to be per ring.
Required for future functionality.
We need to synchronize across rings when doing a bo move to make
sure we the buffer is idle if it's in use by a different ring than
the ring doing the move.
v2: fix fence setup for bo moves
v3: add missing ring lock/unlock
Virtual address space are per drm client (opener of /dev/drm).
Client are in charge of virtual address space, they need to
map bo into it by calling DRM_RADEON_GEM_VA ioctl.
First 16M of virtual address space is reserved by the kernel.
Once using 2 level page table we should be able to have a small
vram memory footprint for each pt (there would be one pt for all
gart, one for all vram and then one first level for each virtual
address space).
Plan include using the sub allocator for a common vm page table
area and using memcpy to copy vm page table in & out. Or use
a gart object and copy things in & out using dma.
v2: agd5f fixes:
- Add vram base offset for vram pages. The GPU physical address of a
vram page is FB_OFFSET + page offset. FB_OFFSET is 0 on discrete
cards and the physical bus address of the stolen memory on
integrated chips.
- VM_CONTEXT1_PROTECTION_FAULT_DEFAULT_ADDR covers all vmid's >= 1
v3: agd5f:
- integrate with the semaphore/multi-ring stuff
v4:
- rebase on top ttm dma & multi-ring stuff
- userspace is now in charge of the address space
- no more specific cs vm ioctl, instead cs ioctl has a new
chunk
v5:
- properly handle mem == NULL case from move_notify callback
- fix the vm cleanup path
v6:
- fix update of page table to only happen on valid mem placement
v7:
- add tlb flush for each vm context
- add flags to define mapping property (readable, writeable, snooped)
- make ring id implicit from ib->fence->ring, up to each asic callback
to then do ring specific scheduling if vm ib scheduling function
v8:
- add query for ib limit and kernel reserved virtual space
- rename vm->size to max_pfn (maximum number of page)
- update gem_va ioctl to also allow unmap operation
- bump kernel version to allow userspace to query for vm support
v9:
- rebuild page table only when bind and incrementaly depending
on bo referenced by cs and that have been moved
- allow virtual address space to grow
- use sa allocator for vram page table
- return invalid when querying vm limit on non cayman GPU
- dump vm fault register on lockup
v10: agd5f:
- Move the vm schedule_ib callback to a standalone function, remove
the callback and use the existing ib_execute callback for VM IBs.
v11:
- rebase on top of lastest Linus
v12: agd5f:
- remove spurious backslash
- set IB vm_id to 0 in radeon_ib_get()
v13: agd5f:
- fix handling of RADEON_CHUNK_ID_FLAGS
v14:
- fix va destruction
- fix suspend resume
- forbid bo to have several different va in same vm
v15:
- rebase
v16:
- cleanup left over of vm init/fini
v17: agd5f:
- cs checker
v18: agd5f:
- reworks the CS ioctl to better support multiple rings and
VM. Rather than adding a new chunk id for VM, just re-use the
IB chunk id and add a new flags for VM mode. Also define additional
dwords for the flags chunk id to define the what ring we want to use
(gfx, compute, uvd, etc.) and the priority.
v19:
- fix cs fini in weird case of no ib
- semi working flush fix for ni
- rebase on top of sa allocator changes
v20: agd5f:
- further CS ioctl cleanups from Christian's comments
v21: agd5f:
- integrate CS checker improvements
v22: agd5f:
- final cleanups for release, only allow VM CS on cayman
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
cayman is wb only and doesn't have a VC.
Emitting fences, semaphores and ib works differently
on different ring, so its is easier to maintain
separate functions for each ring.
Every ring seems to have the concept of read and
write pointers. Make the register offset variable
so we can use the functions for different types of rings.
They are used to sync between rings, while fences
sync between a ring and the cpu.
v2 Fix radeon_semaphore_driver_fini when no semaphore were
allocated.
v3 Initialize list early on to avoid issue in case or early
error
The new power tables need to be handled differently when setting
up the profiles.
factor out most of evergreen blit code and use the refactored code
from r600 that is now common for both r600 and evergreen
Signed-off-by: Ilija Hadzic <ihadzic@research.bell-labs.com>
No need to assign the same copy callback for both
copy blit and dma.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
Only support 4 rather than 6.
Allows us to use the 3D engine for memory management
and allows us to use vram beyond the BAR aperture.
v2: fix copy paste typo
Reported-by: Nils Wallménius <nils.wallmenius@gmail.com>
None of the latest GPUs had this hooked up, this is necessary for
correct operation in a lot of cases, however we should test this on a few
GPUs in these families as we've had problems in this area before.
Reviewed-by: Alex Deucher <alexdeucher@gmail.com>
cc: stable@kernel.org
btc and cayman asics use the same callback for
pcie port registers.
This commit changed an internal radeon structure, that meant a new driver
in -next had to be fixed up, merge in the commit and fix up the driver.
Also fixes a trivial nouveau merge.
drivers/gpu/drm/nouveau/nouveau_mem.c
Looks like these got passed over with both being merged at the same
time but not quite meeting in the middle.
should fix: https://bugs.freedesktop.org/show_bug.cgi?id=34137
along with Michael's phoronix article.
Reported-by: Chi-Thanh Christopher Nguyen
Article-written-by: Michael Larabel @ phoronix
Adds new packet to disable DX9 constant emulation.
Cc: stable@kernel.org
* 'drm-radeon-fusion' of ../drm-radeon-next:
drm/radeon/kms: add Ontario APU ucode loading support
drm/radeon/kms: add Ontario Fusion APU pci ids
drm/radeon/kms: enable MSIs on fusion APUs
drm/radeon/kms: add power table parsing support for Ontario fusion APUs
drm/radeon/kms: refactor atombios power state fetching
drm/radeon/kms: add bo blit support for Ontario fusion APUs
drm/radeon/kms: add thermal sensor support for fusion APUs
drm/radeon/kms: fill in GPU init for AMD Ontario Fusion APUs
drm/radeon/kms: add radeon_asic struct for AMD Ontario fusion APUs
drm/radeon/kms: evergreen.c updates for fusion
drm/radeon/kms: MC setup changes for fusion APUs
drm/radeon/kms: move r7xx/evergreen to its own vram_gtt setup function
drm/radeon/kms: add support for ss overrides on Fusion APUs
drm/radeon/kms: Add support for external encoders on fusion APUs
drm/radeon/kms: atom changes for DCE4.1 devices
drm/radeon/kms: add new family id for AMD Ontario APUs
drm/radeon/kms: upstream power table updates
drm/radeon/kms: upstream atombios.h updates
drm/radeon/kms: upstream ObjectID.h updates
drm/radeon/kms: setup mc chremap properly on r7xx/evergreen
This adds support for dri2 pageflipping.
v2: precision updates from Mario Kleiner.
v3: Multihead fixes from Mario Kleiner; missing crtc offset
add note about update pending bit on pre-avivo chips
Signed-off-by: Mario Kleiner <mario.kleiner@tuebingen.mpg.de>
This patch implements blit support for bo moves using
the 3D engine. It uses the same method as r6xx/r7xx:
- store the base state in an IB
- emit variable state and vertex buffers to do the blit
This allows the hw to move bos using the 3D engine and allows
full use of vram beyond the pci aperture size.
This code was originally for forcing some clocks on certain asics.
However, this code was later moved to asic specific functions
for all of the affected asics. The only users of the original
code at this point were r600, rv770, and evergreen and the code
was not relevant for those asics. So, remove it.
They don't have an atombios so don't attempt to use it for
eng/mem clocks.
Reported by spoonb on #radeon
fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=28671
Advanced validation is not implemented yet.
The mesa code that uses this will be released soon.
