The previous commit fixes the problem, these commits make sure we actually
fail properly if it happens again.
I've squashed the commits from Chris since they are all fixing one issue.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
After thinking it over a lot it made more sense for the core to deal with
the output polling especially so it can notify X.
v2: drop plans for fake connector - per Michel's comments - fix X patch sent to xorg-devel, add intel polled/hpd setting, add initial nouveau polled/hpd settings.
v3: add config lock take inside polling, add intel/nouveau poll init/fini calls
v4: config lock was a bit agressive, only needed around connector list reading.
otherwise it could re-enter.
glisse: discard drm_helper_hpd_irq_event
v3: Reviewed-by: Michel Dänzer <michel@daenzer.net>
It removes a hack from nouveau code which had to detect which
region to pass to kick vesafb/efifb.
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Cc: Eric Anholt <eric@anholt.net>
Cc: Ben Skeggs <bskeggs@redhat.com>
Cc: Thomas Hellstrom <thellstrom@vmware.com>
Cc: Dave Airlie <airlied@redhat.com>
Cc: Peter Jones <pjones@redhat.com>
* drm-fbdev-cleanup:
drm/fb: remove drm_fb_helper_setcolreg
drm/kms/fb: use slow work mechanism for normal hotplug also.
drm/kms/fb: add polling support for when nothing is connected.
drm/kms/fb: provide a 1024x768 fbcon if no outputs found.
drm/kms/fb: separate fbdev connector list from core drm connectors
drm/kms/fb: move to using fb helper crtc grouping instead of core crtc list
drm/fb: fix fbdev object model + cleanup properly.
drivers/gpu/drm/i915/i915_drv.h
drivers/gpu/drm/nouveau/nouveau_drv.h
This patch is against the drm-fbdevfix1 branch. It removes the
drm_fb_helper_setcolreg function. The reason is that fb_setcolreg is only
used in the case where fb_setcmap is called and no fb_ops->fb_setcmap is
used. In the drm case we always need a fb_setcmap hook to handle multiple
crtcs so we don't need a fb_setcolreg hook. Please apply.
Signed-off-by: James Simmons <jsimmons@infradead.org>
a) slow work is always used now for any fbcon hotplug, as its not
a fast task and is more suited to being ran under slow work.
b) attempt to not do any fbdev changes when X is running as we'll
just mess it up. This hooks set_par to hopefully do the changes
once X hands control to fbdev.
This also adds the nouveau/intel hotplug support.
When we are running in a headless environment we have no idea what
output the user might plug in later, we only have hotplug detect
from the digital outputs. So if we detect no connected outputs at
initialisation, start a slow work operation to poll every 5 seconds
for an output.
this is only hooked up for radeon so far, on hw where we have full
hotplug detection there is no need for this.
This breaks the connection between the core drm connector list
and the fbdev connector usage, and allows them to become disjoint
in the future. It also removes the untype void* that was in the
connector struct to support this.
All connectors are added to the fbdev now but this could be
changed in the future.
This move to using the list of crtcs in the fb helper and cleans up the
whole picking code, now we store the crtc/connectors we want directly
into the modeset and we use the modeset directly to set the mode.
Fixes from James Simmons and Ben Skeggs.
The fbdev layer in the kms code should act like a consumer of the kms services and avoid having relying on information being store in the kms core structures in order for it to work.
This patch
a) removes the info pointer/psuedo palette from the core drm_framebuffer structure and moves it to the fbdev helper layer, it also removes the core drm keeping a list of kernel kms fbdevs.
b) migrated all the fb helper functions out of the crtc helper file into the fb helper file.
c) pushed the fb probing/hotplug control into the driver
d) makes the surface sizes into a structure for ease of passing
This changes the intel/radeon/nouveau drivers to use the new helper.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
* 'gpu-switcher' of /ssd/git//linux-2.6:
vga_switcheroo: initial implementation (v15)
fb: for framebuffer handover don't exit the loop early.
drivers/gpu/drm/i915/i915_dma.c
drivers/gpu/drm/radeon/Makefile
drivers/gpu/drm/radeon/radeon.h
Many new laptops now come with 2 gpus, one to be used for low power
modes and one for gaming/on-ac applications. These GPUs are typically
wired to the laptop panel and VGA ports via a multiplexer unit which
is controlled via ACPI methods.
4 combinations of systems typically exist - with 2 ACPI methods.
Intel/ATI - Lenovo W500/T500 - use ATPX ACPI method
ATI/ATI - some ASUS - use ATPX ACPI Method
Intel/Nvidia - - use _DSM ACPI method
Nvidia/Nvidia - - use _DSM ACPI method.
TODO:
This patch adds support for the ATPX method and initial bits
for the _DSM methods that need to written by someone with
access to the hardware.
Add a proper non-debugfs interface - need to get some proper
testing first.
v2: add power up/down support for both devices
on W500 puts i915/radeon into D3 and cuts power to radeon.
v3: redo probing methods, no DMI list, drm devices call to
register with switcheroo, it tries to find an ATPX method on
any device and once there is two devices + ATPX it inits the
switcher.
v4: ATPX msg handling using buffers - should work on more machines
v5: rearchitect after more mjg59 discussion - move ATPX handling to
radeon driver.
v6: add file headers + initial nouveau bits (to be filled out).
v7: merge delayed switcher code.
v8: avoid suspend/resume of gpu that is off
v9: rearchitect - mjg59 is always right. - move all ATPX code to
radeon, should allow simpler DSM also proper ATRM handling
v10: add ATRM support for radeon BIOS, add mutex to lock vgasr_priv
v11: fix bug in resuming Intel for 2nd time.
v12: start fixing up nvidia code blindly.
v13: blindly guess at finishing nvidia code
v14: remove radeon audio hacks - fix up intel resume more like upstream
v15: clean up printks + remove unnecessary igd/dis pointers
mount debugfs
/sys/kernel/debug/vgaswitcheroo/switch - should exist if ATPX detected
+ 2 cards.
DIS - immediate change to discrete
IGD - immediate change to IGD
DDIS - delayed change to discrete
DIGD - delayed change to IGD
ON - turn on not in use
OFF - turn off not in use
Tested on W500 (Intel/ATI) and T500 (Intel/ATI)
* korg/drm-radeon-testing: (62 commits)
drm/radeon/kms: update new pll algo
drm/radeon/kms: add support for square microtiles on r3xx-r5xx
drm/radeon/kms: force pinning buffer into visible VRAM
drm/radeon/kms/evergreen: fix typo in cursor code
drm/radeon/kms: implement reading active PCIE lanes on R600+
drm/radeon/kms: for downclocking non-mobility check PERFORMANCE state
drm/radeon/kms: simplify storing current and requested PM mode
drm/radeon: fixes for r6xx/r7xx gfx init
drm/radeon/rv740: fix backend setup
drm/radeon/kms: fix R3XX/R4XX memory controller initialization
[rfc] drm/radeon/kms: pm debugging check for vbl.
drm/radeon: Fix memory allocation failures in the preKMS command stream checking.
drm: Add generic multipart buffer.
drm/radeon/kms: simplify memory controller setup V2
drm/radeon: Add asic hook for dma copy to r200 cards.
drm/radeon/kms: Create asic structure for r300 pcie cards.
drm/radeon/kms: remove unused r600_gart_clear_page
drm/radeon/kms: remove HDP flushes from fence emit (v2)
drm/radeon/kms: add LVDS pll quirk for Dell Studio 15
drm/radeon/kms: simplify picking power state
drivers/gpu/drm/radeon/atom.c
drivers/gpu/drm/radeon/atombios.h
drivers/gpu/drm/radeon/atombios_dp.c
drivers/gpu/drm/radeon/r600.c
drivers/gpu/drm/radeon/r600_audio.c
drivers/gpu/drm/radeon/r600_cp.c
drivers/gpu/drm/radeon/radeon_connectors.c
drivers/gpu/drm/radeon/radeon_ring.c
drivers/gpu/drm/radeon/rv770.c
Get rid of _location and use _start/_end also simplify the
computation of vram_start|end & gtt_start|end. For R1XX-R2XX
we place VRAM at the same address of PCI aperture, those GPU
shouldn't have much memory and seems to behave better when
setup that way. For R3XX and newer we place VRAM at 0. For
R6XX-R7XX AGP we place VRAM before or after AGP aperture this
might limit to limit the VRAM size but it's very unlikely.
For IGP we don't change the VRAM placement.
Tested on (compiz,quake3,suspend/resume):
PCI/PCIE:RV280,R420,RV515,RV570,RV610,RV710
AGP:RV100,RV280,R420,RV350,RV620(RPB*),RV730
IGP:RS480(RPB*),RS690,RS780(RPB*),RS880
RPB: resume previously broken
V2 correct commit message to reflect more accurately the bug
and move VRAM placement to 0 for most of the GPU to avoid
limiting VRAM.
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
* 'drm-radeon-linus' of ../drm-next:
drm/radeon/kms: retry auxch on 0x20 timeout value.
drm/radeon: Skip dma copy test in benchmark if card doesn't have dma engine.
drm/radeon/kms: fix screen clearing before fbcon.
drm/radeon/kms: add quirk for VGA without DDC on rv730 XFX card.
drm/radeon/kms: don't crash if no DDC bus on VGA/DVI connector.
drm/radeon/kms: change Kconfig text to reflect the new option.
drm/radeon/kms: suspend and resume audio stuff
This memset_io was added to debug something way back and got
left behind, memset the fb to black so the borders don't be all white.
Set the number of crtcs in rdev at crtc init and use it
whenever we need the crtc count rather than recalculating
it everytime.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (189 commits)
drm/radeon/kms: fix warning about cur_placement being uninitialised.
drm/ttm: Print debug information on memory manager when eviction fails
drm: Add memory manager debug function
drm/radeon/kms: restore surface registers on resume.
drm/radeon/kms/r600/r700: fallback gracefully on ucode failure
drm/ttm: Initialize eviction placement in case the driver callback doesn't
drm/radeon/kms: cleanup structure and module if initialization fails
drm/radeon/kms: actualy set the eviction placements we choose
drm/radeon/kms: Fix NULL ptr dereference
drm/radeon/kms/avivo: add support for new pll selection algo
drm/radeon/kms/avivo: fix some bugs in the display bandwidth setup
drm/radeon/kms: fix return value from fence function.
drm/radeon: Remove tests for -ERESTART from the TTM code.
drm/ttm: Have the TTM code return -ERESTARTSYS instead of -ERESTART.
drm/radeon/kms: Convert radeon to new TTM validation API (V2)
drm/ttm: Rework validation & memory space allocation (V3)
drm: Add search/get functions to get a block in a specific range
drm/radeon/kms: fix avivo tiling regression since radeon object rework
drm/i915: Remove a debugging printk from hangcheck
drm/radeon/kms: make sure i2c id matches
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
The locking & protection of radeon object was somewhat messy.
This patch completely rework it to now use ttm reserve as a
protection for the radeon object structure member. It also
shrink down the various radeon object structure by removing
field which were redondant with the ttm information. Last it
converts few simple functions to inline which should with
performances.
airlied: rebase on top of r600 and other changes.
making the pinned console smaller gives X a bit more room to play with.
The previous patches had some unwanted side effects, I've fixed
the lack of 32bpp working, and fixed up 16bpp so it should also work.
this also adds the interface to allow the driver to set a preferred
console depth so for example low memory rn50 can set it to 8bpp.
It also catches 24bpp on cards that can't do it and forces 32bpp.
Tested on r100/r600/i945.
This adds support for the setcmap api and fixes the 8bpp
support at least on radeon hardware. It adds a new load_lut
hook which can be called once the color map is setup.
Also add single crtc for RN50 chips.
changes in v2:
fix vblank init to respect single crtc flag
fix r100 mode bandwidth to respect single crtc flag
[note this requires an fb patch posted to linux-fbdev-devel already]
This uses the normal video= command line option to control the kms
output setup at boot time. It is used to override the autodetection
done by kms.
video= normally takes a framebuffer as the first parameter, in kms
it will take a connector name, DVI-I-1, or LVDS-1 etc. If no output
connector is specified the mode string will apply to all connectors.
The mode specification used will match down the probed modes, and if
no mode is found it will add a CVT mode that matches.
video=1024x768 - all connectors match a 1024x768 mode or add a CVT on
video=VGA-1:1024x768, VGA-1 connector gets mode only.
The same strings as used in current fb modedb.c are used, except I've
added three more letters, e, D, d, e = enable, D = enable Digital,
d = disable, which allow a connector to be forced into a certain state.
Signed-off-by: Michel Dänzer <daenzer@vmware.com>
this hopefully will bring back suspend/resume under kms.
Initially I always meant this code to be shared, but things
ran away from me before I got to it.
This refactors the i915 and radeon kms fbdev interaction layers
out into generic helpers + driver specific pieces.
It moves all the panic/sysrq enhancements to the core file,
and stores a linked list of kernel fbs. This could possibly be
improved to only store the fb which has fbcon on it for panics
etc.
radeon retains some specific codes used for a big endian
workaround.
changes:
fix oops in v1
fix freeing path for crtc_info
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
This gets rid of some ugliness, we shuold probably find a way
for the GPU to zero this.
This will allow efi/vesa to handoff to radeon.
This adds new set/get tiling interfaces where the pitch
and macro/micro tiling enables can be set. Along with
a flag to decide if this object should have a surface when mapped.
The only thing we need to allocate with a mapped surface should be
the frontbuffer. Note rotate scanout shouldn't require one, and
back/depth shouldn't either, though mesa needs some fixes.
It fixes the TTM interfaces along Thomas's suggestions, and I've tested
the surface stealing code with two X servers and not seen any lockdep issues.
I've stopped tiling the fbcon frontbuffer, as I don't see there being
any advantage other than testing, I've left the testing commands in there,
just flip the fb_tiled to true in radeon_fb.c
Open: Can we integrate endian swapping in with this?
Future features:
texture tiling - need to relocate texture registers TXOFFSET* with tiling info.
This also merges Michel's cleanup surfaces regs at init time patch
even though it makes sense on its own, this patch really relies on it.
Some PowerMac firmwares set up a tiling surface at the beginning of VRAM
which messes us up otherwise.
that patch is:
For now handle it via r/g/b offsets and disallow 16 bpp modes on big endian
machines.
Might lure userspace into trying silly things otherwise.
Signed-off-by: Dave Airlie <airlied@linux.ie>
smem.start is a physical address which kernel can remap to access
video memory of the fb buffer. We now pin the fb buffer into vram
by doing so we are loosing vram but fbdev need to be reworked to
allow change in framebuffer address.
Add kernel modesetting support to radeon driver, use the ttm memory
manager to manage memory and DRM/GEM to provide userspace API.
In order to avoid backward compatibility issue and to allow clean
design and code the radeon kernel modesetting use different code path
than old radeon/drm driver.
When kernel modesetting is enabled the IOCTL of radeon/drm
driver are considered as invalid and an error message is printed
in the log and they return failure.
KMS enabled userspace will use new API to talk with the radeon/drm
driver. The new API provide functions to create/destroy/share/mmap
buffer object which are then managed by the kernel memory manager
(here TTM). In order to submit command to the GPU the userspace
provide a buffer holding the command stream, along this buffer
userspace have to provide a list of buffer object used by the
command stream. The kernel radeon driver will then place buffer
in GPU accessible memory and will update command stream to reflect
the position of the different buffers.
The kernel will also perform security check on command stream
provided by the user, we want to catch and forbid any illegal use
of the GPU such as DMA into random system memory or into memory
not owned by the process supplying the command stream. This part
of the code is still incomplete and this why we propose that patch
as a staging driver addition, future security might forbid current
experimental userspace to run.
This code support the following hardware : R1XX,R2XX,R3XX,R4XX,R5XX
(radeon up to X1950). Works is underway to provide support for R6XX,
R7XX and newer hardware (radeon from HD2XXX to HD4XXX).
Authors:
