path: root/drivers/gpu/drm/radeon/rs400d.h
2009-10-02drm/radeon/kms: Convert RS400/RS480 to new init path & fix legacy VGA (V3)Jerome Glisse
Also cleanup register specific to RS400/RS480. This patch also fix legacy VGA register used to disable VGA access we were programming wrong register. Now we should properly disable VGA on r100 up to rs400 asics. Note that RS400/RS480 resume is broken, it hangs the computer while reprogramming dynamic clock, doesn't work either without that patch. We need to spend more time investigating this issue. Version 2 of the patch remove dead code that was left commented out in the previous version. Version 3 correct the placement on IGP of the VRAM inside GPU address space to match the stollen RAM placement of IGP. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
