Making it easier to control when it is executed.
Signed-off-by: Christian König <deathsimple@vodafone.de>
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
The IB pool is in gart memory, so it is completely
superfluous to unpin / repin it on suspend / resume.
So we can skip the locking. Also renames sw_int to
ring_int, cause that better matches its purpose.
Signed-off-by: Christian Koenig <christian.koenig@amd.com>
1. It is really dangerous to have more than one
spinlock protecting the same information.
2. radeon_irq_set sometimes wasn't called with lock
protection, so it can happen that more than one
CPU would tamper with the irq regs at the same
time.
3. The pm.gui_idle variable was assuming that the 3D
engine wasn't becoming idle between testing the
register and setting the variable. So just remove
it and test the register directly.
v2: Also handle the hpd irq code the same way.
v3: Rename hpd parameter for clarification.
Call it in the asic startup callback on all asics.
Previously r600 and rv770 called it in the startup
and resume callbacks while all the other asics called
it in the startup callback.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Reviewed-by: Rafał Miłecki <zajec5@gmail.com>
Removing all the different error messages and
having just one standard behaviour over all
chipset generations.
Reviewed-by: Jerome Glisse <jglisse@redhat.com>
It makes no sense at all to have more than one flag.
- add support for rs6xx
- add support for DCE4/5
- fixup 6xx/7xx
Merge the fixes so far into core-next, needed to test
intel driver.
drivers/gpu/drm/i915/intel_ringbuffer.c
tidy up radeon_asic struct.
Reviewed-by: Christian König<christian.koenig@amd.com>
Each ring type may need a different variant.
Required for future functionality.
Reviewed-by: Christian König <christian.koenig@amd.com>
If accel is not working many subsystem such as the ib pool might not be
initialized properly that can lead to segfault inside kernel when cs
ioctl is call with non working acceleration. To avoid this make sure
the accel working flag is false when an error in GPU startup happen and
return EBUSY from cs ioctl if accel is not working.
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
MSI_REARM_EN register is a write only trigger register.
There is no need RMW when re-arming.
May fix:
https://bugs.freedesktop.org/show_bug.cgi?id=41668
CC: stable@vger.kernel.org
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Signed-off-by: Michel Dänzer <michel.daenzer@amd.com>
It would previously write basically random bits to PCI configuration space...
Not very surprising that the GPU tended to stop responding completely. The
resulting MCE even froze the whole machine sometimes.
Now resetting the GPU after a lockup has at least a fighting chance of
succeeding.
Cc: stable@vger.kernel.org
Somewhat specializaed sub-allocator designed to perform sub-allocation
for command buffer not only for current cs ioctl but for future command
submission ioctl as well. Patch also convert current ib pool to use
the sub allocator. Idea is that ib poll buffer can be share with other
command buffer submission not having 64K granularity.
v2 Harmonize pool handling and add suspend/resume callback to pin/unpin
sa bo (tested on rv280, rv370, r420, rv515, rv610, rv710, redwood, cayman,
rs480, rs690, rs880)
v3 Simplify allocator
v4 Fix radeon_ib_get error path to properly free fence
Add a start fence driver helper function which will be call
once for each ring and will compute cpu/gpu addr for fence
depending on wether to use wb buffer or scratch reg.
This patch replace initialize fence driver separately which
was broken in regard of GPU lockup. The fence list for created,
emited, signaled must be initialize once and only from the
asic init callback not from the startup call back which is
call from the gpu reset.
v2: With this in place we no longer need to know the number of
rings in fence_driver_init, also writing to the scratch reg
before knowing its offset is a bad idea.
v3: rebase on top of change to previous patch in the serie
For supporting multiple CP ring buffers, async DMA
engines and UVD. We still need a way to synchronize
between engines.
v2 initialize unused fence driver ring to avoid issue in
suspend/unload
Avoid infinite loops waiting for surface updates if a GPU
reset happens while waiting for a page flip.
See:
https://bugs.freedesktop.org/show_bug.cgi?id=43191
Cc: stable@kernel.org
Reviewed-by: Mario Kleiner <mario.kleiner@tuebingen.mpg.de>
Tested-by: Simon Farnsworth <simon.farnsworth@onelan.co.uk>
After GPU lockup VRAM gart table is unpinned and thus its pointer
becomes unvalid. This patch move the unpin code to a common helper
function and set pointer to NULL so that page update code can check
if it should update GPU page table or not. That way bo still bound
to GART can be unbound (pci_unmap_page for all there page) properly
while there is no need to update the GPU page table.
V2 move the test for null gart out of the loop, small optimization
Polarity needs to be set accordingly to connector status (connected
or disconnected). Set it up in hpd_init() so first hotplug works
reliably no matter what is the initial set of connector. hpd_init()
also covers resume so HPD will work correctly after resume as well.
Cc: Jerome Glisse <j.glisse@gmail.com>
This was previously done for r300 only. Use %016llX instead of %08X for
printing the table address.
Also fix typos in gart warning messages.
Signed-off-by: Tormod Volden <debian.tormod@gmail.com>
Reviewed-by: Michel Dänzer <michel@daenzer.net>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (135 commits)
drm/radeon/kms: fix DP training for DPEncoderService revision bigger than 1.1
drm/radeon/kms: add missing vddci setting on NI+
drm/radeon: Add a rmb() in IH processing
drm/radeon: ATOM Endian fix for atombios_crtc_program_pll()
drm/radeon: Fix the definition of RADEON_BUF_SWAP_32BIT
drm/radeon: Do an MMIO read on interrupts when not uisng MSIs
drm/radeon: Writeback endian fixes
drm/radeon: Remove a bunch of useless _iomem casts
drm/gem: add support for private objects
DRM: clean up and document parsing of video= parameter
DRM: Radeon: Fix section mismatch.
drm: really make debug levels match in edid failure code
drm/radeon/kms: fix i2c map for rv250/280
drm/nouveau/gr: disable fifo access and idle before suspend ctx unload
drm/nouveau: pass flag to engine fini() method on suspend
drm/nouveau: replace nv04_graph_fifo_access() use with direct reg bashing
drm/nv40/gr: rewrite/split context takedown functions
drm/nouveau: detect disabled device in irq handler and return IRQ_NONE
drm/nouveau: ignore connector type when deciding digital/analog on DVI-I
drm/nouveau: Add a quirk for Gigabyte NX86T
Just defining rdev->rmmio properly in the first place should do
the trick. In some cases, the cast were also complete dups as
the original variable was already of the right type.
BUS_CNTL is at 0x30 on rs600, not 0x4c.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
This is needed for setting voltages other than vddc.
Avoid touching the flip setup regs while
acceleration is running. Set them at modeset
rather than during pageflip. Touching these
regs while acceleration is active caused hangs
on pre-avivo chips. These chips do not seem
to be affected, but better safe than sorry,
plus it avoids repeatedly reprogramming the
regs every flip.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits)
doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore
Update cpuset info & webiste for cgroups
dcdbas: force SMI to happen when expected
arch/arm/Kconfig: remove one to many l's in the word.
asm-generic/user.h: Fix spelling in comment
drm: fix printk typo 'sracth'
Remove one to many n's in a word
Documentation/filesystems/romfs.txt: fixing link to genromfs
drivers:scsi Change printk typo initate -> initiate
serial, pch uart: Remove duplicate inclusion of linux/pci.h header
fs/eventpoll.c: fix spelling
mm: Fix out-of-date comments which refers non-existent functions
drm: Fix printk typo 'failled'
coh901318.c: Change initate to initiate.
mbox-db5500.c Change initate to initiate.
edac: correct i82975x error-info reported
edac: correct i82975x mci initialisation
edac: correct commented info
fs: update comments to point correct document
target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c
Trivial conflict in fs/eventpoll.c (spelling vs addition)
So we used to use lpfn directly to restrict VRAM when we couldn't
access the unmappable area, however this was removed in
93225b0d7bc030f4a93165347a65893685822d70 as it also restricted
the gtt placements. However it was only later noticed that this
broke on some hw.
This removes the active_vram_size, and just explicitly sets it
when it changes, TTM/drm_mm will always use the real_vram_size,
and the active vram size will change the TTM size used for lpfn
setting.
We should re-work the fpfn/lpfn to per-placement at some point
I suspect, but that is too late for this kernel.
Hopefully this addresses:
https://bugs.freedesktop.org/show_bug.cgi?id=35254
v2: fix reported useful VRAM size to userspace to be correct.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
First, we were calling mc_stop() at the top of the function
which turns off all MC (memory controller) clients,
then checking if the GPU is idle. If it was idle we
returned without re-enabling the MC clients which would
lead to a blank screen, etc. This patch checks if the
GPU is idle before calling mc_stop().
Second, if the reset failed, we were returning without
re-enabling the MC clients. This patch re-enables
the MC clients before returning regardless of whether
the reset was successful or not.
Cc: Jerome Glisse <jglisse@redhat.com>
With cmwq, there's no reason for radeon to use a dedicated workqueue.
Drop dev_priv->wq and use system_wq instead.
Because radeon_driver_irq_uninstall_kms() may be called from
unsleepable context, the work items can't be flushed from there.
Instead, init and flush from radeon_irq_kms_init/fini().
While at it, simplify canceling/flushing of rdev->pm.dynpm_idle_work.
Always initialize and sync cancel instead of being unnecessarily smart
about it.
Acked-by: Alex Deucher <alexdeucher@gmail.com>
Cc: dri-devel@lists.freedesktop.org
In the vblank irq handler, calls to actual vblank handling,
or at least drm_handle_vblank(), need to happen before
calls to radeon_crtc_handle_flip().
Reason: The high precision pageflip timestamping
and some other pageflip optimizations will need the updated
vblank count and timestamps for the current vblank interval.
These are calculated in drm_handle_vblank(), therefore it
must go first.
Signed-off-by: Mario Kleiner <mario.kleiner@tuebingen.mpg.de>
This adds support for dri2 pageflipping.
v2: precision updates from Mario Kleiner.
v3: Multihead fixes from Mario Kleiner; missing crtc offset
add note about update pending bit on pre-avivo chips
Coalesce long formats.
Align arguments.
Add missing newlines.
drivers/gpu/drm/i915/intel_fb.c
drivers/gpu/drm/radeon/r600_blit_kms.c
drivers/gpu/drm/ttm/ttm_bo.c
We should not allocate any object into unmappable vram if we
have no means to access them which on all GPU means having the
CP running and on newer GPU having the blit utility working.
This patch limit the vram allocation to visible vram until
we have acceleration up and running.
Note that it's more than unlikely that we run into any issue
related to that as when acceleration is not woring userspace
should allocate any object in vram beside front buffer which
should fit in visible vram.
V2 use real_vram_size as mc_vram_size could be bigger than
the actual amount of vram
[airlied: fixup r700_cp_stop case]
When writeback is enabled, the GPU shadows writes to certain
registers into a buffer in memory. The driver can then read
the values from the shadow rather than reading back from the
register across the bus. Writeback can be disabled by setting
the no_wb module param to 1.
On r6xx/r7xx/evergreen, the following registers are shadowed:
- CP scratch registers
- CP read pointer
- IH write pointer
On r1xx-rr5xx, the following registers are shadowed:
- CP read pointer
v2:
- Combine wb patches for r6xx-evergreen and r1xx-r5xx
- Writeback is disabled on AGP boards since it tends to be
unreliable on AGP using the gart.
- Check radeon_wb_init return values properly.
Intel variants don't support it.
Need this to avoid conflicts with future radeon fixes
On systems using kexec, the new kernel is booted straight from the old kernel, without any warning to the graphics driver. So the GPU is basically left as-is in a running state, however the CPU side is completly reset.
Without stating the saneness of anyone using kexec on live systems, we should at least try not to crash the GPU. This patch resets 3 registers to 0 that could cause bad things to happen to the running system.
This allows kexec to work on a Power6/RN50 system.
We will need method of selecting encoder that should receive HDMI block. For
now we assign HDMI block to first enabled encoder. Hopefully there are not many
RS6x0 chips with two digital encoders.
[airlied: add RS740 checks as per Alex suggestion.]
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
The asics in question have the following requirements with regard to
their gart setups:
1. The GART aperture size has to be in the form of 2^X bytes, where X is from 25 to 31
2. The GART aperture MC base has to be aligned to a boundary equal to the size of the
aperture.
3. The GART page table has to be aligned to the boundary equal to the size of the table.
4. The GART page table size is: table_entry_size * (aperture_size / page_size)
5. The GART page table has to be allocated in non-paged, non-cached, contiguous system
memory.
This patch takes care 2. The rest should already be handled properly.
This fixes a regression noticed by: Torsten Kaiser <just.for.lkml@googlemail.com>
Tested-by: Torsten Kaiser <just.for.lkml@googlemail.com>
* drm-platform:
drm: Make sure the DRM offset matches the CPU
drm: Add __arm defines to DRM
drm: Add support for platform devices to register as DRM devices
drm: Remove drm_resource wrappers
- This enables voltage adjustment on r6xx+ and certain
r5xx asics.
- Voltage drop support is already available for most
r1xx-r5xx asics.
V2: endian fix for voltage table.
Remove the drm_resource wrappers and directly use the
actual PCI and/or platform functions in their place.
[airlied: fixup nouveau properly to build]
Signed-off-by: Jordan Crouse <jcrouse@codeaurora.org>
Reviewed-by: Matt Turner <mattst88@gmail.com>
- Separate dynpm and profile based power management methods. You can select the pm method
by echoing the selected method ("dynpm" or "profile") to power_method in sysfs.
- Expose basic 4 profile in profile method
"default" - default clocks
"auto" - select between low and high based on ac/dc state
"low" - DC, low power mode
"high" - AC, performance mode
The current base profile is "default", but it should switched to "auto" once we've tested
on more systems. Switching the state is a matter of echoing the requested profile to
power_profile in sysfs. The lowest power states are selected automatically when dpms turns
the monitors off in all states but default.
- Remove dynamic fence-based reclocking for the moment. We can revisit this later once we
have basic pm in.
- Move pm init/fini to modesetting path. pm is tightly coupled with display state. Make sure
display side is initialized before pm.
- Add pm suspend/resume functions to make sure pm state is properly reinitialized on resume.
- Remove dynpm module option. It's now selectable via sysfs.
