path: root/drivers/gpu/drm/radeon/rs600d.h
2010-05-18drm/radeon/kms: enable misc pm power state features on r5xx, rs6xxAlex Deucher
voltage drop, dynamic voltage, dynamic sclk, pcie lane adjust, etc, Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-05-18drm/radeon/kms/pm: add additional asic callbacksAlex Deucher
- pm_misc() - handles voltage, pcie lanes, and other non clock related power mode settings. Currently disabled. Needs further debugging - pm_prepare() - disables crtc mem requests right now. All memory clients need to be disabled when changing memory clocks. This function can be expanded to include disabling fb access as well. - pm_finish() - enable active memory clients. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-04-06drm/radeon/kms: simplify & improve GPU reset V2Jerome Glisse
This simplify and improve GPU reset for R1XX-R6XX hw, it's not 100% reliable here are result: - R1XX/R2XX works bunch of time in a row, sometimes it seems it can work indifinitly - R3XX/R3XX the most unreliable one, sometimes you will be able to reset few times, sometimes not even once - R5XX more reliable than previous hw, seems to work most of the times but once in a while it fails for no obvious reasons (same status than previous reset just no same happy ending) - R6XX/R7XX are lot more reliable with this patch, still it seems that it can fail after a bunch (reset every 2sec for 3hour bring down the GPU & computer) This have been tested on various hw, for some odd reasons i wasn't able to lockup RS480/RS690 (while they use to love locking up). Note that on R1XX-R5XX the cursor will disapear after lockup haven't checked why, switch to console and back to X will restore cursor. Next step is to record the bogus command that leaded to the lockup. V2 Fix r6xx resume path to avoid reinitializing blit module, use the gpu_lockup boolean to avoid entering inifinite waiting loop on fence while reiniting the GPU Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-03-31drm/radeon/kms: display watermark updates (v2)Alex Deucher
- Add module option to force the display priority 0 = auto, 1 = normal, 2 = high - Default to high on r3xx/r4xx/rv515 chips Fixes flickering problems during heavy acceleration due to underflow to the display controllers - Fill in minimal support for RS600 v2 - update display priority when bandwidth is updated so the user can change the parameter at runtime and it will take affect on the next modeset. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-08drm/radeon/kms: add regs and irq tracking bits for hpdAlex Deucher
2009-10-08drm/radeon/kms: Fix RS600/RV515/R520/RS690 IRQJerome Glisse
Bad generated header file leaded to use wrong register to check IRQ status and acknowledge them. Fix the header and use proper registers. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-10-02drm/radeon/kms: Convert RS600 to new init pathJerome Glisse
New init path allow to simply asic initialization and make easier to trace what happen on each different asic. We are removing most callback. Do a massive RS600 register cleanup to clarify RS600 register, we are still bit fuzy on some register and waiting for more informations. I don't have hw to test, so this patch is a best effort to not break anythings and to try to improve things. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
