This check the root ports supported link speeds and enables
GEN2 mode if the 5.0 GT link speed is available.
The first 3.0 cards are SI so they will probably need more investigation.
Before emitting any indirect buffer, emit the offset of the next
valid ring content if any. This allow code that want to resume
ring to resume ring right after ib that caused GPU lockup.
v2: use scratch registers instead of storing it into memory
v3: skip over the surface sync for ni and si as well
v4: use SET_CONFIG_REG instead of PACKET0
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
Signed-off-by: Christian König <deathsimple@vodafone.de>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Making it easier to control when it is executed.
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
Just reinitialize the shader content on resume instead.
The IB pool is in gart memory, so it is completely
superfluous to unpin / repin it on suspend / resume.
For a normal suspend/resume we allready wait for
the rings to be empty, and for a suspend/reasume
in case of a lockup we REALLY don't want to wait
for anything.
Reviewed-by: Jerome Glisse <jglisse@redhat.com>
- SMX_SAR_CTL0 needs to be programmed correctly to prevent
problems with memory exports in certain cases.
- VC_ENHANCE needs to be initialized on 6xx/7xx.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Cc: stable@vger.kernel.org
Call it in the asic startup callback on all asics.
Previously r600 and rv770 called it in the startup
and resume callbacks while all the other asics called
it in the startup callback.
Reviewed-by: Rafał Miłecki <zajec5@gmail.com>
Tiling group size is always 256bits on r6xx/r7xx/r8xx/9xx. Also fix and
simplify render backend map. This now properly sets up the backend map
on r6xx-9xx which should improve 3D performance.
Vadim benchmarked also:
Some benchmarks on juniper (5750), fullscreen 1920x1080,
first result - kernel 3.4.0+ (fb21affa), second - with these patches:
Lightsmark: 91 fps => 123 fps +35%
Doom3: 74 fps => 101 fps +36%
Need to program an additional VM register. This doesn't not currently
cause any problems, but allows us to program the proper backend
map in a subsequent patch which should improve performance on these
asics.
While there are cards with more than 8 mem banks, the max
number of banks from a tiling perspective is 8, so cap
the tiling config at 8 banks.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=43448
All radeon_gem_init() does is initialize the gem objects
list. radeon_device.c does this explicitly. r600+ calls
radeon_gem_init() so the list gets initialized twice. Older
asics don't call it at all and rely on the the init in
radeon_device.c. Just call radeon_gem_init() in radeon_device.c
and remove the explicit calls from all the newer asics.
All asics call radeon_gem_fini() in their fini pathes. That
could possibly be cleaned up too.
Directly use the suballocator to get small chunks of memory.
It's equally fast and doesn't crash when we encounter a GPU reset.
v2: rebased on new SA interface.
into drm-core-next
Daniel prepared this branch with a back-merge as git was getting
very confused about changes in intel_display.c
Removing all the different error messages and
having just one standard behaviour over all
chipset generations.
If AGP is placed in the middle, the size_af is off-by-one, it results
in VRAM being placed at 0x7fffffff instead of 0x8000000.
v2: fix the vram_start setup.
v3: also fix r7xx & newer ASIC
Reported-by: russiane39 on #radeon
Merge the fixes so far into core-next, needed to test
intel driver.
drivers/gpu/drm/i915/intel_ringbuffer.c
Each ring type may need a different variant.
Reviewed-by: Christian König<christian.koenig@amd.com>
tidy up the radeon_asic struct, handle multiple
rings better.
If accel is not working many subsystem such as the ib pool might not be
initialized properly that can lead to segfault inside kernel when cs
ioctl is call with non working acceleration. To avoid this make sure
the accel working flag is false when an error in GPU startup happen and
return EBUSY from cs ioctl if accel is not working.
Somewhat specializaed sub-allocator designed to perform sub-allocation
for command buffer not only for current cs ioctl but for future command
submission ioctl as well. Patch also convert current ib pool to use
the sub allocator. Idea is that ib poll buffer can be share with other
command buffer submission not having 64K granularity.
v2 Harmonize pool handling and add suspend/resume callback to pin/unpin
sa bo (tested on rv280, rv370, r420, rv515, rv610, rv710, redwood, cayman,
rs480, rs690, rs880)
v3 Simplify allocator
v4 Fix radeon_ib_get error path to properly free fence
Some rptr/wptrs fields have different offsets and not all rings are pm4
so add a new nop field.
Add a start fence driver helper function which will be call
once for each ring and will compute cpu/gpu addr for fence
depending on wether to use wb buffer or scratch reg.
This patch replace initialize fence driver separately which
was broken in regard of GPU lockup. The fence list for created,
emited, signaled must be initialize once and only from the
asic init callback not from the startup call back which is
call from the gpu reset.
v2: With this in place we no longer need to know the number of
rings in fence_driver_init, also writing to the scratch reg
before knowing its offset is a bad idea.
v3: rebase on top of change to previous patch in the serie
That naming seems to make more sense, since we not
only want to run PM4 rings with it.
Replace cp, cp1 and cp2 members with just an array
of radeon_cp structs.
Every ring seems to have the concept of read and
write pointers. Make the register offset variable
so we can use the functions for different types of rings.
Give all asic and radeon_ring_* functions a
radeon_cp parameter, so they know the ring to work with.
They are used to sync between rings, while fences
sync between a ring and the cpu.
v2 Fix radeon_semaphore_driver_fini when no semaphore were
allocated.
v3 Initialize list early on to avoid issue in case or early
error
For supporting multiple CP ring buffers, async DMA
engines and UVD. We still need a way to synchronize
between engines.
v2 initialize unused fence driver ring to avoid issue in
suspend/unload
Avoid infinite loops waiting for surface updates if a GPU
reset happens while waiting for a page flip.
See:
https://bugs.freedesktop.org/show_bug.cgi?id=43191
Cc: stable@kernel.org
Reviewed-by: Mario Kleiner <mario.kleiner@tuebingen.mpg.de>
Tested-by: Simon Farnsworth <simon.farnsworth@onelan.co.uk>
After GPU lockup VRAM gart table is unpinned and thus its pointer
becomes unvalid. This patch move the unpin code to a common helper
function and set pointer to NULL so that page update code can check
if it should update GPU page table or not. That way bo still bound
to GART can be unbound (pci_unmap_page for all there page) properly
while there is no need to update the GPU page table.
V2 move the test for null gart out of the loop, small optimization
The vram scratch was originally only used on some 7xx asics
to work around a hw bug. Allocate the scratch page on all 6xx+
radeons and set the MC_VM_SYSTEM_APERTURE_DEFAULT_ADDR to point
to it. We shouldn't ever hit it since we limit the system
aperture to vram or vram and AGP, but better safe than sorry.
There are a number of fixes in mainline required for code in -next,
also there was a few conflicts I'd rather resolve myself.
drivers/gpu/drm/radeon/evergreen.c
drivers/gpu/drm/radeon/r600.c
drivers/gpu/drm/radeon/radeon_asic.h
r600-NI shared the same blit suspend code. Clean it up
and make it a shared function.
Reviewed-by: Ilija Hadzic <ihadzic@research.bell-labs.com>
Most asics just use the hw default value which requires
no explicit programming. For those that need a different
value, the vbios will program it properly. As such,
there's no need to program these registers explicitly
in the driver. Changing MC_SHARED_CHREMAP requires a reload
of all data in vram otherwise its contents will be scambled.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=40103
v2: drop now unused channel_remap functions.
This was previously done for r300 only. Use %016llX instead of %08X for
printing the table address.
Also fix typos in gart warning messages.
Signed-off-by: Tormod Volden <debian.tormod@gmail.com>
Reviewed-by: Michel Dänzer <michel@daenzer.net>
The 3D driver need to get the pipe to backend
map to certain things. Add a query to get the
info.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
ib pool weren't free for various newer asic on module unload.
This doesn't cause much arm but still could be candidate for
stable.
cc: stable@kernel.org
Reviewed-by: Alex Deucher <alexdeucher@gmail.com>
CE variant requires a different chremap setup.
Fixes:
https://bugzilla.kernel.org/show_bug.cgi?id=35472
0xff01 is not an actual voltage value, but a flag
for the driver. If the power state as that value,
skip setting the voltage.
This is needed for setting voltages other than vddc.
As per Konrad's original patch, the dummy page used
by the gart code and allocated in radeon_gart_init()
was not freed properly in radeon_gart_fini().
At the same time r6xx and newer allocated and freed the
dummy page on their own. So to do Konrad's patch one
better, just remove the allocation and freeing of the
dummy page in the r6xx, 7xx, evergreen, and ni code and
allocate and free in the gart_init/fini() functions for
all asics.
Cc: Jerome Glisse <jglisse@redhat.com>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits)
doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore
Update cpuset info & webiste for cgroups
dcdbas: force SMI to happen when expected
arch/arm/Kconfig: remove one to many l's in the word.
asm-generic/user.h: Fix spelling in comment
drm: fix printk typo 'sracth'
Remove one to many n's in a word
Documentation/filesystems/romfs.txt: fixing link to genromfs
drivers:scsi Change printk typo initate -> initiate
serial, pch uart: Remove duplicate inclusion of linux/pci.h header
fs/eventpoll.c: fix spelling
mm: Fix out-of-date comments which refers non-existent functions
drm: Fix printk typo 'failled'
coh901318.c: Change initate to initiate.
mbox-db5500.c Change initate to initiate.
edac: correct i82975x error-info reported
edac: correct i82975x mci initialisation
edac: correct commented info
fs: update comments to point correct document
target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c
Trivial conflict in fs/eventpoll.c (spelling vs addition)
This commit changed an internal radeon structure, that meant a new driver
in -next had to be fixed up, merge in the commit and fix up the driver.
Also fixes a trivial nouveau merge.
drivers/gpu/drm/nouveau/nouveau_mem.c
* 'intel/drm-intel-next' of ../drm-next: (755 commits)
drm/i915: Only wait on a pending flip if we intend to write to the buffer
drm/i915/dp: Sanity check eDP existence
drm/i915: Rebind the buffer if its alignment constraints changes with tiling
drm/i915: Disable GPU semaphores by default
drm/i915: Do not overflow the MMADDR write FIFO
Revert "drm/i915: fix corruptions on i8xx due to relaxed fencing"
drm/i915: Don't save/restore hardware status page address register
drm/i915: don't store the reg value for HWS_PGA
drm/i915: fix memory corruption with GM965 and >4GB RAM
Linux 2.6.38-rc7
Revert "TPM: Long default timeout fix"
drm/i915: Re-enable GPU semaphores for SandyBridge mobile
drm/i915: Replace vblank PM QoS with "Interrupt-Based AGPBUSY#"
Revert "drm/i915: Use PM QoS to prevent C-State starvation of gen3 GPU"
drm/i915: Allow relocation deltas outside of target bo
drm/i915: Silence an innocuous compiler warning for an unused variable
fs/block_dev.c: fix new kernel-doc warning
ACPI: Fix build for CONFIG_NET unset
mm: <asm-generic/pgtable.h> must include <linux/mm_types.h>
x86: Use u32 instead of long to set reset vector back to 0
drivers/gpu/drm/i915/i915_gem.c
So we used to use lpfn directly to restrict VRAM when we couldn't
access the unmappable area, however this was removed in
93225b0d7bc030f4a93165347a65893685822d70 as it also restricted
the gtt placements. However it was only later noticed that this
broke on some hw.
This removes the active_vram_size, and just explicitly sets it
when it changes, TTM/drm_mm will always use the real_vram_size,
and the active vram size will change the TTM size used for lpfn
setting.
We should re-work the fpfn/lpfn to per-placement at some point
I suspect, but that is too late for this kernel.
Hopefully this addresses:
https://bugs.freedesktop.org/show_bug.cgi?id=35254
v2: fix reported useful VRAM size to userspace to be correct.
Unconditionally initialize the drm gem object - it's not
worth the trouble not to for the few kernel objects.
This patch only changes the place of the drm gem object,
access is still done via pointers.
v2: Uncoditionally align the size in radeon_bo_create. At
least the r600/evergreen blit code didn't to this, angering
the paranoid gem code.
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
agd5f: minor cleanups
Signed-off-by: Cédric Cano <ccano@interfaceconcept.com>
Some fixes to the thermal sensor code:
- handle negative numbers
- properly handle temp calculation on different asics
