Registers that can be fetched from the info ioctl.
Tested-by: Marek Olšák <marek.olsak@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Split DCE6 and DCE8 programming of DCCG_AUDIO_DTO1
registers to properly enable DP audio for both DCE
revisions.
Signed-off-by: Slava Grigorev <slava.grigorev@amd.com>
Signed-off-by: Christian König <christian.koenig@amd.com>
Reviewed-by: Christian König <christian.koenig@amd.com>
We need to wait for the GPUVM flush to complete. There
was some confusion as to how this mechanism was supposed
to work. The operation is not atomic. For GPU initiated
invalidations you need to read back a VM register to
introduce enough latency for the update to complete.
v2: drop gart changes
v3: just read back rather than polling
Cc: stable@vger.kernel.org
Enable smc fan control for SI boards. Should
reduce the fan noise on systems with a higher
default fan profile.
v2: disable by default, add rpm controls
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=73338
no functional change.
Merge drm-fixes into drm-next.
Both i915 and radeon need this done for later patches.
drivers/gpu/drm/drm_crtc_helper.c
drivers/gpu/drm/i915/i915_drv.h
drivers/gpu/drm/i915/i915_gem.c
drivers/gpu/drm/i915/i915_gem_execbuffer.c
drivers/gpu/drm/i915/i915_gem_gtt.c
This patch makes it possible to decide how many address
bits are spend on the page directory vs the page tables.
v2: remove unintended change
Probably a copy paste typo.
Only VCE 2.0 support so far.
v2: squashing multiple patches into this one
v3: add IRQ support for CIK, major cleanups,
basic code documentation
v4: remove HAINAN from chipset list
DCE5 and newer hardware only has 1 DAC. Use the correct
offset. This may fix display problems on certain board
configurations.
pci config reset is a low level reset that resets
the entire chip from the bus interface. It can
be more reliable if soft reset fails.
v2: hide behind module parameter
git://people.freedesktop.org/~danvet/drm-intel into drm-next
Bit a bit -fixes pull request in the merge window than usual dua to two
feauture-y things:
- Display CRCs are now enabled on all platforms, including the odd DP case
on gm45/vlv. Since this is a testing-only feature it should ever hurt,
but I figured it'll help with regression-testing -fixes. So I left it
in and didn't postpone it to 3.14.
- Display power well refactoring from Imre. Would have caused major pain
conflict with the bdw stage 1 patches if I'd postpone this to -next.
It's only an relatively small interface rework, so shouldn't cause pain.
It's also been in my tree since almost 3 weeks already.
That accounts for about two thirds of the pull, otherwise just bugfixes:
- vlv backlight fix from Jesse/Jani
- vlv vblank timestamp fix from Jesse
- improved edp detection through vbt from Ville (fixes a vlv issue)
- eDP vdd fix from Paulo
- fixes for dvo lvds on i830M
- a few smaller things all over
Note: This contains a backmerge of v3.12. Since the -internal branch
always applied on top of -nightly I need that unified base to merge bdw
patches. So you'll get a conflict with radeon connector props when pulling
this (and nouveau/master will also conflict a bit when Ben doesn't
rebase). The backmerge itself only had conflicts in drm/i915.
There's also a tiny conflict between Jani's backlight fix and your sysfs
lifetime fix in drm-next.
* tag 'drm-intel-fixes-2013-11-07' of git://people.freedesktop.org/~danvet/drm-intel: (940 commits)
drm/i915/vlv: use per-pipe backlight controls v2
drm/i915: make backlight functions take a connector
drm/i915: move opregion asle request handling to a work queue
drm/i915/vlv: use PIPE_START_VBLANK interrupts on VLV
drm/i915: Make intel_dp_is_edp() less specific
drm/i915: Give names to the VBT child device type bits
drm/i915/vlv: enable HDA display audio for Valleyview2
drm/i915/dvo: call ->mode_set callback only when the port is running
drm/i915: avoid unclaimed registers when capturing the error state
drm/i915: Enable DP port CRC for the "auto" source on g4x/vlv
drm/i915: scramble reset support for DP port CRC on vlv
drm/i915: scramble reset support for DP port CRC on g4x
drm/i916: add "auto" pipe CRC source
MAINTAINERS
drivers/gpu/drm/i915/intel_panel.c
drivers/gpu/drm/nouveau/core/subdev/mc/base.c
drivers/gpu/drm/radeon/atombios_encoders.c
drivers/gpu/drm/radeon/radeon_connectors.c
Typo in the register offset.
Noticed-by: Sylvain BERTRAND <sylware@legeek.net>
Needed by the hda driver to properly set up synchronization
on the audio side.
Wrong bit offset for SRC endian swapping.
We need to allocate line buffer to each display when
setting up the watermarks. Failure to do so can lead
to a blank screen. This fixes blank screen problems
on dce6 asics.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=64850
Based on an initial fix from:
Jay Cornwall <jay.cornwall@amd.com>
Resturcture clockgating code so that it can be
enabled/disabled from other components such as
dpm.
v2: make function static
v3: add fine grained cg controls
Similar to DCE4/5, but supports multiple audio pins
which can be assigned per afmt block.
v2: rework the driver to handle more than one audio
pin.
v3: try different dto reg
v4: properly program dto
v5 (ck): change dto programming order
v6: program speaker allocation block
v7: rebase
v8: rebase on Rafał's changes
v9: integrated Rafał's comments, update to latest
drm_edid_to_speaker_allocation API
v10: add missing line break in error message
v11: add back audio enabled messages
v12: fix copy paste typo in r600_audio_enable
Acked-by: Rafał Miłecki <zajec5@gmail.com>
Helpful for debugging GPUVM errors as we can see what
hw block and page generated the fault in the log.
v2: simplify fault decoding
This allows you to look at the current DPM state via
debugfs.
This adds dpm support for SI asics. This includes:
- dynamic engine clock scaling
- dynamic memory clock scaling
- dynamic voltage scaling
- dynamic pcie gen1/gen2/gen3 switching
- power containment
- shader power scaling
Set radeon.dpm=1 to enable.
v2: enable hainan support, rebase
v3: guard acpi stuff
v4: fix 64 bit math
v5: fix 64 bit div harder
v6: fix thermal interrupt check noticed by Jerome
v7: attempt fix state enable
Consolidate the non-register defines.
Only Cape Verde supports power gating.
This is required for certain power management features.
Enables PCIE ASPM (Active State Power Management) on
SI asics.
v2: fix typo
If both the motherboard and GPU support pcie gen2 or 3,
enable it. PCIE gen2 and 3 offer more bandwidth than
pcie gen1.
v2: fix gb_addr_config value
Stupid copy & paste error over all generations.
v2: set UVD tiling config for rv730
Reviewed-by: Jerome Glisse <jglisse@redhat.com>
Just everything needed to decode videos using UVD.
v6: just all the bugfixes and support for R7xx-SI merged in one patch
v7: UVD_CGC_GATE is a write only register, lockup detection fix
v8: split out VRAM fallback changes, remove support for RV770,
add support for HEMLOCK, add buffer sizes checks
A new tiling config register for the display blocks was
added on DCE6.
May fix:
https://bugs.freedesktop.org/show_bug.cgi?id=62889
https://bugs.freedesktop.org/show_bug.cgi?id=57919
This is required to get the reference clock used
by the gfx engine for things like timestamps. Fixes
support for GL extensions the use timestamps on
certain boards.
When we attempt the reset the GPU, look at the status registers
to determine what blocks need to be reset.
After refactoring the _cs logic, we ended up with many
macros and constants that #define the same thing.
Clean'em up.
Signed-off-by: Ilija Hadzic <ihadzic@research.bell-labs.com>
Reviewed-by: Marek Olšák <maraeo@gmail.com>
This try to reset the dma engine when performing gpu reset. Hopefully
bringing back the gpu dma engine in sane state.
v2: agd5f: fix dma reset on cayman/TN, add support for SI
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
To help debug dma related lockup.
v2: agd5f: update SI as well
Async DMA has a special packet for contiguous pt updates
which saves overhead.
v2: rebase
Pretty much the same as cayman. Some changes to the copy
packets.
Redirect invalid memory accesses to the default page
instead of locking up the memory controller. Also
enable the invalid memory access interrupts and
start spamming system log with it.
v2 (agd5f): fix up against 2 level PT changes
Signed-off-by: Christian König <deathsimple@vodafone.de>
This register is needed for streamout to work properly.
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
This is the preferred packet for writing data to memory
or registers on SI.
Returns a snapshot of the GPU clock counter. Needed
for certain OpenGL extensions.
v2: agd5f
- address Jerome's comments
- add function documentation
Signed-off-by: Marek Olšák <maraeo@gmail.com>
When submitting a CONST_IB, emit a SWITCH_BUFFER
packet before the CONST_IB. This isn't strictly necessary
(the driver will work fine without it), but is good practice
and allows for more flexible DE/CE sychronization options
in the future. Current userspace drivers do not take
advantage of the CE yet.
v2: - clean up code flow a bit
- no need to flush caches for CONST IB
- Properly set up the RBs
- Properly set up the SPI
- Properly set up gb_addr_config
This should fix rendering issues on certain cards.
This is mostly identical to evergreen/ni, however
there are some additional fields in the IV vector
for RINGID and VMID.
