path: root/drivers/gpu/drm/radeon/trinity_dpm.h
2013-09-11drm/radeon/dpm: add bapm callback for trinityAlex Deucher
This adds the enable_bapm callback for trinity. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-09-11drm/radeon/dpm: handle bapm on trinityAlex Deucher
bapm is a power management feature for handling the power budget between the CPU and GPU on APUs. This patch adds support for enabling or disabling it. For now disable it by default. Enabling it properly requires quite a bit more work and will be addressed in a separate patch. This patch fixes hangs on boot on certain trinity laptops when the system is on battery power. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2013-07-05drm/radeon/dpm: implement force performance level for TNAlex Deucher
Allows you to force the selected performance level via sysfs. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-06-27drm/radeon/dpm: add pre/post_set_power_state callback (TN)Alex Deucher
This properly implemented dynamic state adjustment by using a working copy of the requested and current power states. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-06-27drm/radeon/dpm: fixup dynamic state adjust for TNAlex Deucher
Use a dedicated copy of the current power state since we may have to adjust it on the fly. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-06-27drm/radeon: add dpm UVD handling for TN asics (v2)Alex Deucher
v2: fix typo noticed by Dan Carpenter Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-06-27drm/radeon/kms: add dpm support for trinity asicsAlex Deucher
This adds dpm support for trinity asics. This includes: - clockgating - powergating - dynamic engine clock scaling - dynamic voltage scaling set radeon.dpm=1 to enable it. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
