Selecting ATOM_PPLL_INVALID should be equivalent as the
DCPLL or PPLL0 are already programmed for the DISPCLK, but
the preferred method is to always specify the PLL selected.
SetPixelClock will check the parameters and skip the
programming if the PLL is already set up.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Reviewed-by: Christian König <christian.koenig@amd.com>
Still a lot to do.
Still a lot more to do.
Document the VM functions in radeon_gart.c
v2: adjust per Christian's suggestions
v3: adjust to Christians's latest changes
Document the non-VM functions in radeon_gart.c
Adds documentation to most of the functions in
radeon_ring.c
v3: adjust per Christian's latest patches
v4: adjust per my latest changes
radeon_fence.c
v2: address Christian's comments:
- split common concept description into it's own comment
- fix description of intr parameter
- Improve description of -EDEADLK error
radeon_asic.c
radeon_irq_kms.c
radeon_kms.c
radeon_device.c
v2: split out general descriptions as per Christian's
comments.
Add support for using memory buffers rather than
scratch registers. Some rings may not be able to
write to scratch registers.
Just store the index in the ring structure.
Idea taken from one of Jerome's wip rptr patches.
When submitting a CONST_IB, emit a SWITCH_BUFFER
packet before the CONST_IB. This isn't strictly necessary
(the driver will work fine without it), but is good practice
and allows for more flexible DE/CE sychronization options
in the future. Current userspace drivers do not take
advantage of the CE yet.
v2: - clean up code flow a bit
- no need to flush caches for CONST IB
Const IBs are executed on the CE not the CP, so we can't
fence them in the normal way.
So submit them directly before the IB instead, just as
the documentation says.
v2: keep the extra documentation
Signed-off-by: Christian König <deathsimple@vodafone.de>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Otherwise we can encounter out of memory situations under extreme load.
v2: add documentation for the new function
Otherwise the sa managers out of memory
handling doesn't work.
Try to save whatever is on the rings when
we encounter an lockup.
v2: Fix spelling error. Free saved ring data if reset fails.
Add documentation for the new functions.
v3: Some more spelling fixes
v4: It doesn't make sense to save anything if all fences
are signaled
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
Before emitting any indirect buffer, emit the offset of the next
valid ring content if any. This allow code that want to resume
ring to resume ring right after ib that caused GPU lockup.
v2: use scratch registers instead of storing it into memory
v3: skip over the surface sync for ni and si as well
v4: use SET_CONFIG_REG instead of PACKET0
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
Making it easier to control when it is executed.
Just restore the page table instead. Addressing three
problem with this change:
1. Calling vm_manager_suspend in the suspend path is
problematic cause it wants to wait for the VM use
to end, which in case of a lockup never happens.
2. In case of a locked up memory controller
unbinding the VM seems to make it even more
unstable, creating an unrecoverable lockup
in the end.
3. If we want to backup/restore the leftover ring
content we must not unbind VMs in between.
Just reinitialize the shader content on resume instead.
The IB pool is in gart memory, so it is completely
superfluous to unpin / repin it on suspend / resume.
It's not critical, but the current code isn't
100% correct.
Reviewed-by: Jerome Glisse <jglisse@redhat.com>
For a normal suspend/resume we allready wait for
the rings to be empty, and for a suspend/reasume
in case of a lockup we REALLY don't want to wait
for anything.
Start with last signaled fence number instead
of last emitted one.
It is possible that radeon_fence_process is called
after writeback is disabled for suspend, leading
to an invalid read of register 0x0.
This fixes a problem for me where the fence value
is temporary incremented by 0x100000000 on
suspend/resume.
We don't need to pad anything if the number of dwords
written to the ring already matches the requirements.
Fixes some "writting more dword to ring than expected"
warnings.
GPU reset need to be exclusive, one happening at a time. For this
add a rw semaphore so that any path that trigger GPU activities
have to take the semaphore as a reader thus allowing concurency.
The GPU reset path take the semaphore as a writer ensuring that
no concurrent reset take place.
v2: init rw semaphore
Don't return success if scheduling the IB fails, otherwise
we end up with an oops in ttm_eu_fence_buffer_objects.
Cc: stable@vger.kernel.org
Waiting for a fence can fail for different reasons,
the most common is a deadlock.
Instead of returning the error handle it directly
and while at it fix the comments about the ring lock.
In gem idle/busy ioctl the radeon object was derefenced after
drm_gem_object_unreference_unlocked which in case the object
have been destroyed lead to use of a possibly free pointer with
possibly wrong data.
It was stuck right in the middle of the gart functions.
Move next to the bm_disable function and where it is used.
Consolidate the CS functions to one section of the file.
Previously they were spread all around.
Cayman and trinity allow for variable sized VM page
tables, but SI requires that all page tables be the
same size. The current code assumes variablely sized
VM page tables so SI may end up with part of each page
table overlapping with other memory which could end
up being interpreted by the VM hw as garbage.
Change the code to better accomodate SI. Allocate enough
space for at least 2 full page tables and always set
last_pfn to max_pfn on SI so each VM is backed by a full
page table. This limits us to only 2 VMs active at any
given time on SI. This will be rectified and the code can
be reunified once we move to two level page tables.
git://people.freedesktop.org/~danvet/drm-intel into drm-core-next
Daniel writes:
New -next pull request. Highlights:
- Remaining vlv patches from Jesse et al.
- Some hw workarounds from Jesse
- hw context support from Ben
- full uncore sharing on ivb
- prep work to move the gtt code from intel-gtt.c to drm/i915 for gen6+
- some backlight code improvements
- leftovers for the timeout ioctl (we've forgotten the getparam)
- ibx transcoder workarounds
- some smaller fixlets and improvements
- the new version of the "dont rely on HPD exclusively for VGA" patch
Wrt regressions QA reported quite a few this time around.
- The piglit/kernel-test fallout all has patches that are just awaiting
review and merging into the next -next cycle.
- Which just leaves a bunch of bugs about new modelines that don't work.
It looks like these are all due to the new 16:9/16:10 modes in 3.5
(yeah, only in this manual testing cycle did the git branch used by QA
contain a backmerge of mainline with these patches). Although I haven't
yet confirmed this by letting our QA test the revert of that series.
- Wrt bugs in general I'm trying to fight down some of our long-standing
backlight issues (not regressions), but this seems to be a game of
"you move, you lose" ... :("
Dropped merge bits since this had an -rc4 merge in it to fix some ugly
conflicts.
Try to remove or replace the cs_mutex with a
vm_mutex where it is still needed.
v2: fix locking order
v3: rebased on drm-next
So we can skip the locking. Also renames sw_int to
ring_int, cause that better matches its purpose.
Signed-off-by: Christian Koenig <christian.koenig@amd.com>
1. It is really dangerous to have more than one
spinlock protecting the same information.
2. radeon_irq_set sometimes wasn't called with lock
protection, so it can happen that more than one
CPU would tamper with the irq regs at the same
time.
3. The pm.gui_idle variable was assuming that the 3D
engine wasn't becoming idle between testing the
register and setting the variable. So just remove
it and test the register directly.
v2: Also handle the hpd irq code the same way.
v3: Rename hpd parameter for clarification.
The spinlock was actually there to protect the
rptr, but rptr was read outside of the locked area.
Also we don't really need a spinlock here, an
atomic should to quite fine since we only need to
prevent it from being reentrant.
v2: Keep the spinlock....
v3: Back to an atomic again after finding & fixing the real bug.
It is a rw_semaphore now and only write locked
while changing the clock. Also the lock is renamed
to better reflect what it is protecting.
v2: Keep the ttm_vm_ops on IGPs
Move inter ring syncing with semaphores into the
existing ring allocations, with that we need to
lock the ring mutex only once.
v2: BUG_ON not matching rings.
It is completely unnecessary to create fences
before they are emitted, so remove it and a bunch
of checks if fences are emitted or not.
- Use the correct union for getting the tiling info
- Properly init the PIPE_CONFIG field for SI
Required for streamout. Bump drm minor.
Marek v2: fix pkt->count check
Signed-off-by: Marek Olšák <maraeo@gmail.com>
- SMX_SAR_CTL0 needs to be programmed correctly to prevent
problems with memory exports in certain cases.
- VC_ENHANCE needs to be initialized on 6xx/7xx.
