The encoder .mode_fixup() operation is legacy, atomic updates uses the
new .atomic_check() operation. Convert the encoders drivers.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
The atomic connector DPMS helper implements the connector DPMS operation
using atomic commit, removing the need for DPMS helper operations on
CRTCs and encoders.
This removes the legacy mode config code. The CRTC and encoder prepare
and commit operations are not used anymore, remove them.
When using atomic updates the encoder .enable() and .disable() helper
operations are preferred over the (then legacy) .prepare() and .commit()
operations. Implement .enable() and .disable() and rework .prepare(),
.commit() and .dpms() as wrappers around .enable() and .disable(),
easing their future removal.
The LVDS encoder doesn't support DPMS states, replace the DPMS operation
by enable/disable to avoid propagating DPMS states down to the encoder
code.
The intermediate DPMS standby and suspend states are a thing from the
past. They only matter in practice for VGA CRT monitors, and are just a
power saving vs. resume time optimization. Given that they have never
been implemented properly in the rcar-du driver and that the Intel
driver has dropped them on the vga port years ago, it's safe to only
care about the on and off states.
The rcar-du driver refuses connecting an LVDS output to an HDMI encoder.
There is not technical reason for that restriction, remove it.
If an encoder fails to initialize the device can still be used without
the failed encoder. Don't propagate the error out of the probe function
but just skip the failed encoder.
As a special case a deferred probe request from the encoder is still
propagated out of the probe function in order not to break the deferred
probing mechanism.
SoCs that integrate the DU have no internal HDMI encoder, support
external encoders only.
Add a new macro to downcast an rcar_du_encoder pointer to a drm_encoder
pointer and use it. This prepares for the replacement of the
rcar_drm_encoder encoder field with a drm_slave_encoder.
The encoder DT node will be needed to register an external HDMI encoder.
Pass it to the rcar_du_encoder_init() function to prepare for HDMI
support.
All platforms now instantiate the DU through DT, platform data support
isn't needed anymore.
Implement support for the R-Car DU DT bindings in the rcar-du DRM
driver.
The "Renesas Corporation" listed in the copyright notice doesn't exist.
Replace it with "Renesas Electronics Corporation" and update the
copyright years.
The R8A7790 includes two internal LVDS encoders. Support them in the DU
driver.
Split the output routing specification between SoC-internal data,
specified in the rcar_du_device_info structure, and board data, passed
through platform data.
The DU has 5 possible outputs (DPAD0/1, LVDS0/1, TCON). SoC-internal
output routing data specify which output are valid, which CRTCs can be
connected to the valid outputs, and the type of in-SoC encoder for the
output.
Platform data then specifies external encoders and the output they are
connected to.
The struct rcar_du_encoder_data encoder::field describes the encoder
type, and the rcar_du_encoder_lvds_data and rcar_du_encoder_vga_data
structures describe connector properties. Rename them accordingly.
Create a single rcar_du_encoder structure that implements a KMS encoder.
The current implementation is straightforward and only configures CRTC
output routing.
