path: root/drivers/gpu/drm/savage
2011-11-11drm: Make the per-driver file_operations struct constArjan van de Ven
From fdf1fdebaa00f81de18c227f32f8074c8b352d50 Mon Sep 17 00:00:00 2001 From: Arjan van de Ven <arjan@linux.intel.com> Date: Sun, 30 Oct 2011 19:06:07 -0700 Subject: [PATCH] drm: Make the per-driver file_operations struct const The DRM layer keeps a copy of struct file_operations inside its big driver struct... which prevents it from being consistent and static. For consistency (and the general security objective of having such things static), it's desirable to get this fixed. This patch splits out the file_operations field to its own struct, which is then "static const", and just stick a pointer to this into the driver struct, making it more consistent with how the rest of the kernel does this. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-10-31gpu: add module.h to drivers/gpu files as required.Paul Gortmaker
So that we don't get build failures once the implicit module.h presence is removed. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-06-14savage: remove unnecessary if statementGreg Dietsche
the code always returns ret regardless, so if(ret) check is unnecessary. v2: fixed up the spelling. Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu> Reviewed-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-02-07drm: rework PCI/platform driver interface.Dave Airlie
This abstracts the pci/platform interface out a step further, we can go further but this is far enough for now to allow USB to be plugged in. The drivers now just call the init code directly for their device type. Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-10-26Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (476 commits) vmwgfx: Implement a proper GMR eviction mechanism drm/radeon/kms: fix r6xx/7xx 1D tiling CS checker v2 drm/radeon/kms: properly compute group_size on 6xx/7xx drm/radeon/kms: fix 2D tile height alignment in the r600 CS checker drm/radeon/kms/evergreen: set the clear state to the blit state drm/radeon/kms: don't poll dac load detect. gpu: Add Intel GMA500(Poulsbo) Stub Driver drm/radeon/kms: MC vram map needs to be >= pci aperture size drm/radeon/kms: implement display watermark support for evergreen drm/radeon/kms/evergreen: add some additional safe regs v2 drm/radeon/r600: fix tiling issues in CS checker. drm/i915: Move gpu_write_list to per-ring drm/i915: Invalidate the to-ring, flush the old-ring when updating domains drm/i915/ringbuffer: Write the value passed in to the tail register agp/intel: Restore valid PTE bit for Sandybridge after bdd3072 drm/i915: Fix flushing regression from 9af90d19f drm/i915/sdvo: Remove unused encoding member i915: enable AVI infoframe for intel_hdmi.c [v4] drm/i915: Fix current fb blocking for page flip drm/i915: IS_IRONLAKE is synonymous with gen == 5 ... Fix up conflicts in - drivers/gpu/drm/i915/{i915_gem.c, i915/intel_overlay.c}: due to the new simplified stack-based kmap_atomic() interface - drivers/gpu/drm/vmwgfx/vmwgfx_drv.c: added .llseek entry due to BKL removal cleanups.
2010-09-16drm: use noop_llseekArnd Bergmann
The drm device drivers currently allow seeking on the character device but never care about the actual file position. When we change the default llseek operation to be no_llseek, calling llseek on a drm device would return an error condition, which is an API change. Explicitly setting noop_llseek lets us keep the current API. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: David Airlie <airlied@linux.ie> Cc: dri-devel@lists.freedesktop.org
2010-08-30drm: kill get_reg_ofs callbackDaniel Vetter
Every driver used the default implementation. Fold that one into the only callsite and drop the callback. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-30drm: kill drm_map_ofs callbacksDaniel Vetter
All drivers happily copy&pasted the default implementation without checking whether this callback is used at all. It's not. Sigh. Kill it. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-23Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (33 commits) drm/radeon/kms: fix typo in radeon_compute_pll_gain drm/radeon/kms: try to detect tv vs monitor for underscan drm/radeon/kms: fix sideport detection on newer rs880 boards drm/radeon: fix passing wrong type to gem object create. drm/radeon/kms: set encoder type to DVI for HDMI on evergreen drm/radeon/kms: add back missing break in info ioctl drm/radeon/kms: don't enable MSIs on AGP boards drm/radeon/kms: fix agp mode setup on cards that use pcie bridges drm: move dereference below check drm: fix end of loop test drm/radeon/kms: rework radeon_dp_detect() logic drm/radeon/kms: add missing asic callback assignment for evergreen drm/radeon/kms/DCE3+: switch pads to ddc mode when going i2c drm/radeon/kms/pm: bail early if nothing's changing drm/radeon/kms/atom: clean up dig atom handling drm/radeon/kms: DCE3/4 transmitter fixes drm/radeon/kms: rework encoder handling drm/radeon/kms: DCE3/4 AdjustPixelPll updates drm/radeon: Fix stack data leak drm/radeon/kms: fix GTT/VRAM overlapping test ...
2010-08-17drm: block userspace under allocating buffer and having drivers overwrite it ↵Dave Airlie
(v2) With the current screwed but its ABI, ioctls for the drm, Linus pointed out that we could allow userspace to specify the allocation size, but we pass it to the driver which then uses it blindly to store a struct. Now if userspace specifies the allocation size as smaller than the driver needs, the driver can possibly overwrite memory. This patch restructures the driver ioctls so we store the structure size we are expecting, and make sure we allocate at least that size. The copy from/to userspace are still restricted to the size the user specifies, this allows ioctl structs to grow on both sides of the equation. Up until now we didn't really use the DRM_IOCTL defines in the kernel, so this cleans them up and adds them for nouveau. v2: fix nouveau pushbuf arg (thanks to Ben for pointing it out) Reported-by: Linus Torvalds <torvalds@linuxfoundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-08-05Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (204 commits) agp: intel-agp: do not use PCI resources before pci_enable_device() agp: efficeon-agp: do not use PCI resources before pci_enable_device() drm: kill BKL from common code drm/kms: Simplify setup of the initial I2C encoder config. drm,io-mapping: Specify slot to use for atomic mappings drm/radeon/kms: only expose underscan on avivo chips drm/radeon: add new pci ids drm: Cleanup after failing to create master->unique and dev->name drm/radeon: tone down overchatty acpi debug messages. drm/radeon/kms: enable underscan option for digital connectors drm/radeon/kms: fix calculation of h/v scaling factors drm/radeon/kms/igp: sideport is AMD only drm/radeon/kms: handle the case of no active displays properly in the bandwidth code drm: move ttm global code to core drm drm/i915: Clear the Ironlake dithering flags when the pipe doesn't want it. drm/radeon/kms: make sure HPD is set to NONE on analog-only connectors drm/radeon/kms: make sure rio_mem is valid before unmapping it drm/agp/i915: trim stolen space to 32M drm/i915: Unset cursor if out-of-bounds upon mode change (v4) drm/i915: Unreference object not handle on creation ...
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-06-01drm: Remove drm_resource wrappersJordan Crouse
Remove the drm_resource wrappers and directly use the actual PCI and/or platform functions in their place. [airlied: fixup nouveau properly to build] Signed-off-by: Jordan Crouse <jcrouse@codeaurora.org> Reviewed-by: Matt Turner <mattst88@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-05-18drivers/gpu/drm: Use kzallocJulia Lawall
Use kzalloc rather than the combination of kmalloc and memset. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression x,size,flags; statement S; @@ -x = kmalloc(size,flags); +x = kzalloc(size,flags); if (x == NULL) S -memset(x, 0, size); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Reviewed-by: Corbin Simpson <MostAwesomeDude@gmail.com> Reviewed-by: Matt Turner <mattst88@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-18drm: convert drm_ioctl to unlocked_ioctlArnd Bergmann
drm_ioctl is called with the Big Kernel Lock held, which shows up very high in statistics on vfs_ioctl. Moving the lock into the drm_ioctl function itself makes sure we blame the right subsystem and it gets us one step closer to eliminating the locked version of fops->ioctl. Since drm_ioctl does not require the lock itself, we only need to hold it while calling the specific handler. The 32 bit conversion handlers do not interact with any other code, so they don't need the BKL here either and can just call drm_ioctl. As a bonus, this cleans up all the other users of drm_ioctl which now no longer have to find the inode or call lock_kernel. [airlied: squashed the non-driver bits of the second patch in here, this provides the flag for drivers to use to select unlocked ioctls - but doesn't modify any drivers]. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: David Airlie <airlied@linux.ie> Cc: dri-devel@lists.sourceforge.net Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-06-18drm: Remove memory debugging infrastructure.Eric Anholt
It hasn't been used in ages, and having the user tell your how much memory is being freed at free time is a recipe for disaster even if it was ever used. Signed-off-by: Eric Anholt <eric@anholt.net>
2009-03-13drm: Use resource_size_t for drm_get_resource_{start, len}Benjamin Herrenschmidt
The DRM uses its own wrappers to obtain resources from PCI devices, which currently convert the resource_size_t into an unsigned long. This is broken on 32-bit platforms with >32-bit physical address space. This fixes them, along with a few occurences of unsigned long used to store such a resource in drivers. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2008-07-14drm: reorganise drm tree to be more future proof.Dave Airlie
With the coming of kernel based modesetting and the memory manager stuff, the everything in one directory approach was getting very ugly and starting to be unmanageable. This restructures the drm along the lines of other kernel components. It creates a drivers/gpu/drm directory and moves the hw drivers into subdirectores. It moves the includes into an include/drm, and sets up the unifdef for the userspace headers we should be exporting. Signed-off-by: Dave Airlie <airlied@redhat.com>
