path: root/drivers/gpu/drm/ttm
2012-06-12drm/ttm: Fix buffer object metadata accounting regression v2Thomas Hellstrom
A regression was introduced in the 3.3 rc series, commit "drm/ttm: simplify memory accounting for ttm user v2", causing the metadata of buffer objects created using the ttm_bo_create() function to be accounted twice. That causes massive leaks with the vmwgfx driver running for example SpecViewperf Catia-03 test 2, eventually killing the app. Furthermore, the same commit introduces a regression where metadata accounting is leaked if a buffer object is initialized with an illegal size. This is also fixed with this commit. v2: Fixed an error path and removed an unused variable. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Jerome Glisse <jglisse@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-06-01drm/ttm: Fix spinlock imbalanceThomas Hellstrom
This imbalance may cause hangs when TTM is trying to swap out a buffer that is already on the delayed delete list. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Jakob Bornecrantz <jakob@vmware.com> Cc: stable@vger.kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-05-23ttm: add prime sharing support to TTM (v2)Dave Airlie
This adds the ability for ttm common code to take an SG table and use it as the backing for a slave TTM object. The drivers can then populate their GTT tables using the SG object. v2: make sure to setup VM for sg bos as well. Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-22Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm main changes from Dave Airlie: "This is the main drm pull request, I'm probably going to send two more smaller ones, will explain below. This contains a patch that is also in the fbdev tree, but it should be the same patch, it added an API for hot unplugging framebuffer devices, and I need that API for a new driver. It also contains some changes to the i2c tree which Jean has acked, and one change to moorestown platform stuff in x86. Highlights: - new drivers: UDL driver for USB displaylink devices, kms only, should support correct hotplug operations. - core: i2c speedups + better hotplug support, EDID overriding via firmware interface - allows user to load a firmware for a broken monitor/kvm from userspace, it even has documentation for it. - exynos: new HDMI audio + hdmi 1.4 + virtual output driver - gma500: code cleanup - radeon: cleanups, CS optimisations, streamout support and pageflip fix - nouveau: NVD9 displayport support + more reclocking work - i915: re-enabling GMBUS, finish gpu patch (might help hibernation who knows), missed irq fixes, stencil tiling fixes, interlaced support, aliasesd PPGTT support for SNB/IVB, swizzling for SNB/IVB, semaphore fixes As well as the usual bunch of cleanups and fixes all over the place. I've got two things I'd like to merge a bit later: a) AMD support for all their new radeonhd 7000 series GPU and APUs. AMD dropped this a bit late due to insane internal review processes, (please AMD just follow Intel and let open source guys ship stuff early) however I don't want to penalise people who own this hardware (since its been on sale for 3-4 months and GPU hw doesn't exactly have a lifetime in years) and consign them to using closed drivers for longer than necessary. The changes are well contained and just plug into the driver new gpu functionality so they should be fairly regression proof. I just want to give them a bit of a run on the hw AMD kindly sent me. b) drm prime/dma-buf interface code. This is just infrastructure code to expose the dma-buf stuff to drm drivers and to userspace. I'm not planning on pushing any driver support in this cycle (except maybe exynos), but I'd like to get the infrastructure code in so for the next cycle I can start getting the driver support into the individual drivers. We have started driver support for i915, nouveau and udl along with I think exynos and omap in staging. However this code relies on the dma-buf tree being pulled into your tree first since it needs the latest interfaces from that tree. I'll push to get that tree sent asap. (oh and any warnings you see in i915 are gcc's fault from what anyone can see)." Fix up trivial conflicts in arch/x86/platform/mrst/mrst.c due to the new msic_thermal_platform_data() thermal function being added next to the tc35876x_platform_data() i2c device function.. * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (326 commits) drm/i915: use DDC_ADDR instead of hard-coding it drm/radeon: use DDC_ADDR instead of hard-coding it drm: remove unneeded redefinition of DDC_ADDR drm/exynos: added virtual display driver. drm: allow loading an EDID as firmware to override broken monitor drm/exynos: enable hdmi audio feature drm/exynos: add default pixel format for plane drm/exynos: cleanup exynos_hdmi.h drm/exynos: add is_local member in exynos_drm_subdrv struct drm/exynos: add subdrv open/close functions drm/exynos: remove module of exynos drm subdrv drm/exynos: release pending pageflip events when closed drm/exynos: added new funtion to get/put dma address. drm/exynos: update gem and buffer framework. drm/exynos: added mode_fixup feature and code clean. drm/exynos: add HDMI version 1.4 support drm/exynos: remove exynos_mixer.h gma500: Fix mmap frambuffer drm/radeon: Drop radeon_gem_object_(un)pin. drm/radeon: Restrict offset for legacy display engine. ...
2012-03-20drm: remove the second argument of k[un]map_atomic()Cong Wang
Signed-off-by: Cong Wang <amwang@redhat.com>
2012-03-20drm/ttm: Use pr_fmt and pr_<level>Joe Perches
Use the more current logging style. Add pr_fmt and remove the TTM_PFX uses. Coalesce formats and align arguments. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-01-25drm/ttm: fix two regressions since move_notify changesBen Skeggs
Both changes in dc97b3409a790d2a21aac6e5cdb99558b5944119 cause serious regressions in the nouveau driver. move_notify() was originally able to presume that bo->mem is the old node, and new_mem is the new node. The above commit moves the call to move_notify() to after move() has been done, which means that now, sometimes, new_mem isn't the new node at all, bo->mem is, and new_mem points at a stale, possibly-just-been-killed-by-move node. This is clearly not a good situation. This patch reverts this change, and replaces it with a cleanup in the move() failure path instead. The second issue is that the call to move_notify() from cleanup_memtype_use() causes the TTM ghost objects to get passed into the driver. This is clearly bad as the driver knows nothing about these "fake" TTM BOs, and ends up accessing uninitialised memory. I worked around this in nouveau's move_notify() hook by ensuring the BO destructor was nouveau's. I don't particularly like this solution, and would rather TTM never pass the driver these objects. However, I don't clearly understand the reason why we're calling move_notify() here anyway and am happy to work around the problem in nouveau instead of breaking the behaviour expected by other drivers. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com> Cc: Jerome Glisse <j.glisse@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-01-13ttm/dma: Remove the WARN() which is not useful.Konrad Rzeszutek Wilk
. It was useful during development, but now on a production system we can get this (if the user forgot to upload the firmware): [drm] radeon: irq initialized. [drm] GART: num cpu pages 131072, num gpu pages 131072 [drm] radeon: ib pool ready. [drm] Loading SUMO Microcode r600_cp: Failed to load firmware "radeon/SUMO_pfp.bin" atl1c 0000:03:00.0: version 1.0.1.0-NAPI.213057] [drm:evergreen_startup] *ERROR* Failed to load firmware! radeon 0000:00:01.0: disabling GPU acceleration 88] radeon 0000:00:01.0: ffff8801bb782400 unpin not necessary ------------[ cut here ]------------ WARNING: at /home/konrad/linux-linus/drivers/gpu/drm/ttm/ttm_page_alloc_dma.c:956 ttm_dma_unpopulate+0x79/0x300 [ttm]() Hardware name: System Product Name Modules linked in: e1000e atl1c radeon(+) ahci libahci libata scsi_mod fbcon tileblit font ttm bitblit softcursor drm_kms_helper wmi xen_blkfront xen_netfront fb_sys_fops sysimgblt sysfillrect syscopyarea xenfs xen_privcmd Pid: 1600, comm: modprobe Not tainted 3.2.0-06100-ge343a89 #1 Call Trace: [<ffffffff8108973a>] warn_slowpath_common+0x7a/0xb0 [<ffffffff81089785>] warn_slowpath_null+0x15/0x20 [<ffffffffa0060309>] ttm_dma_unpopulate+0x79/0x300 [ttm] [<ffffffffa01341c0>] radeon_ttm_tt_unpopulate+0x120/0x130 [radeon] [<ffffffffa0056e0c>] ttm_tt_destroy+0x2c/0x70 [ttm] [<ffffffffa0057a4e>] ttm_bo_cleanup_memtype_use+0x3e/0x80 [ttm] [<ffffffffa00595a1>] ttm_bo_release+0x251/0x280 [ttm] [<ffffffffa0059610>] ttm_bo_unref+0x40/0x60 [ttm] [<ffffffffa0134d02>] radeon_bo_unref+0x42/0x80 [radeon] [<ffffffffa0186dfb>] radeon_sa_bo_manager_fini+0x6b/0x80 [radeon] [<ffffffffa0146b8f>] radeon_ib_pool_fini+0x6f/0x90 [radeon] [<ffffffffa014be49>] r100_ib_fini+0x19/0x20 [radeon] [<ffffffffa017b47e>] evergreen_init+0x1ee/0x2d0 [radeon] The big WARN() has nothing to do with the culprit - which is that the firmware was not loaded. So lets remove the WARN() from the TTM DMA code. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-01-10drm/ttm: fix condition (and vs or)Dan Carpenter
The "if (!p && !p->dev)" condition isn't right because || was intended instead of &&. But actually, "p" is the list cursor and so it's always non-NULL and we can just remove that bit. We can remove the another similar check as well. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-01-06ttm: fix agp since ttm tt reworkJerome Glisse
ttm tt rework modified the way we allocate and populate the ttm_tt structure, the AGP side was missing some bit to properly work. Fix those and fix radeon and nouveau AGP support. Tested on radeon only so far. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-01-06drm/ttm/dma: Fix accounting error when calling ttm_mem_global_free_page and ↵Konrad Rzeszutek Wilk
don't try to free freed pages. The code to figure out how many pages to shrink the pool ends up capping the 'count' at _manager->options.max_size - which is OK. Except that the 'count' is also used when accounting for how many pages are recycled - which we end up with the invalid values. This fixes it by using a different value for the amount of pages to shrink. On top of that we would free the cached page pool - which is nonsense as they are deleted from the pool - so there are no free pages in that pool.. Also we also missed the opportunity to batch the amount of pages to free (similar to how ttm_page_alloc.c does it). This reintroduces the code that was lost during rebasing. Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-01-06drm/ttm/dma: Only call set_pages_array_wb when the page is not in WB pool.Konrad Rzeszutek Wilk
Otherwise we are doing redundant work. Especially since the 'unbind' and 'unpopulate' have been merged and nouveau driver ends up calling it quite excessivly. On a GeForce 8600 GT with Gnome Shell (GNOME 3) we end up spending about 54% CPU time in __change_page_attr_set_clr checking the page flags. The callgraph (annotated) looks as so before this patch: 53.29% gnome-shell [kernel.kallsyms] [k] static_protections | --- static_protections | |--91.80%-- __change_page_attr_set_clr | change_page_attr_set_clr | set_pages_array_wb | | | |--96.55%-- ttm_dma_unpopulate | | nouveau_ttm_tt_unpopulate | | ttm_tt_destroy | | ttm_bo_cleanup_memtype_use | | ttm_bo_release | | kref_put | | ttm_bo_unref | | nouveau_gem_object_del | | drm_gem_object_free | | kref_put | | drm_gem_object_unreference_unlocked | | drm_gem_object_handle_unreference_unlocked.part.1 | | drm_gem_handle_delete | | drm_gem_close_ioctl | | drm_ioctl | | do_vfs_ioctl | | sys_ioctl | | system_call_fastpath | | __GI___ioctl | | | --3.45%-- ttm_dma_pages_put | ttm_dma_page_pool_free | ttm_dma_unpopulate | nouveau_ttm_tt_unpopulate | ttm_tt_destroy | ttm_bo_cleanup_memtype_use | ttm_bo_release | kref_put | ttm_bo_unref | nouveau_gem_object_del | drm_gem_object_free | kref_put | drm_gem_object_unreference_unlocked | drm_gem_object_handle_unreference_unlocked.part.1 | drm_gem_handle_delete | drm_gem_close_ioctl | drm_ioctl | do_vfs_ioctl | sys_ioctl | system_call_fastpath | __GI___ioctl | --8.20%-- change_page_attr_set_clr set_pages_array_wb | |--93.76%-- ttm_dma_unpopulate | nouveau_ttm_tt_unpopulate | ttm_tt_destroy | ttm_bo_cleanup_memtype_use | ttm_bo_release | kref_put | ttm_bo_unref | nouveau_gem_object_del | drm_gem_object_free | kref_put | drm_gem_object_unreference_unlocked | drm_gem_object_handle_unreference_unlocked.part.1 | drm_gem_handle_delete | drm_gem_close_ioctl | drm_ioctl | do_vfs_ioctl | sys_ioctl | system_call_fastpath | __GI___ioctl | --6.24%-- ttm_dma_pages_put ttm_dma_page_pool_free ttm_dma_unpopulate nouveau_ttm_tt_unpopulate ttm_tt_destroy ttm_bo_cleanup_memtype_use ttm_bo_release kref_put ttm_bo_unref nouveau_gem_object_del drm_gem_object_free kref_put drm_gem_object_unreference_unlocked drm_gem_object_handle_unreference_unlocked.part.1 drm_gem_handle_delete drm_gem_close_ioctl drm_ioctl do_vfs_ioctl sys_ioctl system_call_fastpath __GI___ioctl and after this patch all of that disappears. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-12-20Merge tag 'v3.2-rc6' of /home/airlied/devel/kernel/linux-2.6 into drm-core-nextDave Airlie
Merge in the upstream tree to bring in the mainline fixes. Conflicts: drivers/gpu/drm/exynos/exynos_drm_fbdev.c drivers/gpu/drm/nouveau/nouveau_sgdma.c
2011-12-06drm/ttm: callback move_notify any time bo placement change v4Jerome Glisse
Previously we were calling back move_notify in error path when the bo is returned to it's original position or when destroy the bo. When destroying the bo set the new mem placement as NULL when calling back in the driver. Updating nouveau to deal with NULL placement properly. v2: reserve the object before calling move_notify in bo destroy path at that point ttm should be the only piece of code interacting with the object so atomic_set is safe here. v3: callback move notify only once the bo is in its new position call move notify want swaping out the buffer v4:- don't call move_notify when swapin out bo, assume driver should do what is appropriate in swap notify - move move_notify call back to ttm_bo_cleanup_memtype_use for destroy path Reviewed-by: Jerome Glisse <jglisse@redhat.com> Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
2011-12-06drm/ttm: simplify memory accounting for ttm user v2Jerome Glisse
Provide helper function to compute the kernel memory size needed for each buffer object. Move all the accounting inside ttm, simplifying driver and avoiding code duplication accross them. v2 fix accounting of ghost object, one would have thought that i would have run into the issue since a longtime but it seems ghost object are rare when you have plenty of vram ;) Signed-off-by: Jerome Glisse <jglisse@redhat.com> Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
2011-12-06drm/ttm: isolate dma data from ttm_tt V4Jerome Glisse
Move dma data to a superset ttm_dma_tt structure which herit from ttm_tt. This allow driver that don't use dma functionalities to not have to waste memory for it. V2 Rebase on top of no memory account changes (where/when is my delorean when i need it ?) V3 Make sure page list is initialized empty V4 typo/syntax fixes Signed-off-by: Jerome Glisse <jglisse@redhat.com> Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
2011-12-06drm/ttm: provide dma aware ttm page pool code V9Konrad Rzeszutek Wilk
In TTM world the pages for the graphic drivers are kept in three different pools: write combined, uncached, and cached (write-back). When the pages are used by the graphic driver the graphic adapter via its built in MMU (or AGP) programs these pages in. The programming requires the virtual address (from the graphic adapter perspective) and the physical address (either System RAM or the memory on the card) which is obtained using the pci_map_* calls (which does the virtual to physical - or bus address translation). During the graphic application's "life" those pages can be shuffled around, swapped out to disk, moved from the VRAM to System RAM or vice-versa. This all works with the existing TTM pool code - except when we want to use the software IOTLB (SWIOTLB) code to "map" the physical addresses to the graphic adapter MMU. We end up programming the bounce buffer's physical address instead of the TTM pool memory's and get a non-worky driver. There are two solutions: 1) using the DMA API to allocate pages that are screened by the DMA API, or 2) using the pci_sync_* calls to copy the pages from the bounce-buffer and back. This patch fixes the issue by allocating pages using the DMA API. The second is a viable option - but it has performance drawbacks and potential correctness issues - think of the write cache page being bounced (SWIOTLB->TTM), the WC is set on the TTM page and the copy from SWIOTLB not making it to the TTM page until the page has been recycled in the pool (and used by another application). The bounce buffer does not get activated often - only in cases where we have a 32-bit capable card and we want to use a page that is allocated above the 4GB limit. The bounce buffer offers the solution of copying the contents of that 4GB page to an location below 4GB and then back when the operation has been completed (or vice-versa). This is done by using the 'pci_sync_*' calls. Note: If you look carefully enough in the existing TTM page pool code you will notice the GFP_DMA32 flag is used - which should guarantee that the provided page is under 4GB. It certainly is the case, except this gets ignored in two cases: - If user specifies 'swiotlb=force' which bounces _every_ page. - If user is using a Xen's PV Linux guest (which uses the SWIOTLB and the underlaying PFN's aren't necessarily under 4GB). To not have this extra copying done the other option is to allocate the pages using the DMA API so that there is not need to map the page and perform the expensive 'pci_sync_*' calls. This DMA API capable TTM pool requires for this the 'struct device' to properly call the DMA API. It also has to track the virtual and bus address of the page being handed out in case it ends up being swapped out or de-allocated - to make sure it is de-allocated using the proper's 'struct device'. Implementation wise the code keeps two lists: one that is attached to the 'struct device' (via the dev->dma_pools list) and a global one to be used when the 'struct device' is unavailable (think shrinker code). The global list can iterate over all of the 'struct device' and its associated dma_pool. The list in dev->dma_pools can only iterate the device's dma_pool. /[struct device_pool]\ /---------------------------------------------------| dev | / +-------| dma_pool | /-----+------\ / \--------------------/ |struct device| /-->[struct dma_pool for WC]</ /[struct device_pool]\ | dma_pools +----+ /-| dev | | ... | \--->[struct dma_pool for uncached]<-/--| dma_pool | \-----+------/ / \--------------------/ \----------------------------------------------/ [Two pools associated with the device (WC and UC), and the parallel list containing the 'struct dev' and 'struct dma_pool' entries] The maximum amount of dma pools a device can have is six: write-combined, uncached, and cached; then there are the DMA32 variants which are: write-combined dma32, uncached dma32, and cached dma32. Currently this code only gets activated when any variant of the SWIOTLB IOMMU code is running (Intel without VT-d, AMD without GART, IBM Calgary and Xen PV with PCI devices). Tested-by: Michel Dänzer <michel@daenzer.net> [v1: Using swiotlb_nr_tbl instead of swiotlb_enabled] [v2: Major overhaul - added 'inuse_list' to seperate used from inuse and reorder the order of lists to get better performance.] [v3: Added comments/and some logic based on review, Added Jerome tag] [v4: rebase on top of ttm_tt & ttm_backend merge] [v5: rebase on top of ttm memory accounting overhaul] [v6: New rebase on top of more memory accouting changes] [v7: well rebase on top of no memory accounting changes] [v8: make sure pages list is initialized empty] [v9: calll ttm_mem_global_free_page in unpopulate for accurate accountg] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Acked-by: Thomas Hellstrom <thellstrom@vmware.com>
2011-12-06drm/ttm: introduce callback for ttm_tt populate & unpopulate V4Jerome Glisse
Move the page allocation and freeing to driver callback and provide ttm code helper function for those. Most intrusive change, is the fact that we now only fully populate an object this simplify some of code designed around the page fault design. V2 Rebase on top of memory accounting overhaul V3 New rebase on top of more memory accouting changes V4 Rebase on top of no memory account changes (where/when is my delorean when i need it ?) Signed-off-by: Jerome Glisse <jglisse@redhat.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
2011-12-06drm/ttm: merge ttm_backend and ttm_tt V5Jerome Glisse
ttm_backend will only exist with a ttm_tt, and ttm_tt will only be of interest when bound to a backend. Merge them to avoid code and data duplication. V2 Rebase on top of memory accounting overhaul V3 Rebase on top of more memory accounting changes V4 Rebase on top of no memory account changes (where/when is my delorean when i need it ?) V5 make sure ttm is unbound before destroying, change commit message on suggestion from Tormod Volden Signed-off-by: Jerome Glisse <jglisse@redhat.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
2011-12-06drm/ttm: page allocation use page array instead of listJerome Glisse
Use the ttm_tt pages array for pages allocations, move the list unwinding into the page allocation functions. Signed-off-by: Jerome Glisse <jglisse@redhat.com>
2011-12-06drm/ttm: test for dma_address array allocation failureJerome Glisse
2011-12-06drm/ttm: use ttm put pages function to properly restore cache attributeJerome Glisse
On failure we need to make sure the page we free has wb cache attribute. Do this pas call the proper ttm page helper function. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
2011-12-06drm/ttm: remove split btw highmen and lowmem pageJerome Glisse
Split btw highmem and lowmem page was rendered useless by the pool code. Remove it. Note further cleanup would change the ttm page allocation helper to actualy take an array instead of relying on list this could drasticly reduce the number of function call in the common case of allocation whole buffer. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
2011-12-06drm/ttm: remove userspace backed ttm object supportJerome Glisse
This was never use in none of the driver, properly using userspace page for bo would need more code (vma interaction mostly). Removing this dead code in preparation of ttm_tt & backend merge. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
2011-11-22ttm: Don't return the bo reserved on error pathThomas Hellstrom
An unlikely race could case a bo to be returned reserved on an error path. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-10-31gpu: Add export.h as required to drivers/gpu files.Paul Gortmaker
They need this to get all the EXPORT_SYMBOL variants and THIS_MODULE Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-28Merge branch 'drm-core-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
* 'drm-core-next' of git://people.freedesktop.org/~airlied/linux: (290 commits) Revert "drm/ttm: add a way to bo_wait for either the last read or last write" Revert "drm/radeon/kms: add a new gem_wait ioctl with read/write flags" vmwgfx: Don't pass unused arguments to do_dirty functions vmwgfx: Emulate depth 32 framebuffers drm/radeon: Lower the severity of the radeon lockup messages. drm/i915/dp: Fix eDP on PCH DP on CPT/PPT drm/i915/dp: Introduce is_cpu_edp() drm/i915: use correct SPD type value drm/i915: fix ILK+ infoframe support drm/i915: add DP test request handling drm/i915: read full receiver capability field during DP hot plug drm/i915/dp: Remove eDP special cases from bandwidth checks drm/i915/dp: Fix the math in intel_dp_link_required drm/i915/panel: Always record the backlight level again (but cleverly) i915: Move i915_read/write out of line drm/i915: remove transcoder PLL mashing from mode_set per specs drm/i915: if transcoder disable fails, say which drm/i915: set watermarks for third pipe on IVB drm/i915: export a CPT mode set verification function drm/i915: fix transcoder PLL select masking ...
2011-10-27Revert "drm/ttm: add a way to bo_wait for either the last read or last write"Dave Airlie
This reverts commit dfadbbdb57b3f2bb33e14f129a43047c6f0caefa. Further upstream discussion between Marek and Thomas decided this wasn't fully baked and needed further work, so revert it before it hits mainline. Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-10-18Merge tag 'v3.1-rc10' into drm-core-nextDave Airlie
There are a number of fixes in mainline required for code in -next, also there was a few conflicts I'd rather resolve myself. Signed-off-by: Dave Airlie <airlied@redhat.com> Conflicts: drivers/gpu/drm/radeon/evergreen.c drivers/gpu/drm/radeon/r600.c drivers/gpu/drm/radeon/radeon_asic.h
2011-10-18ttm: Fix error-path using an uninitialized valueThomas Hellstrom
Pointed out by Michel Daenzer. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-10-05ttm: export ttm_bo_createThomas Hellstrom
Used by the vmwgfx driver. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-09-14drm/ttm: request zeroed system memory pages for new TT buffer objectsBen Skeggs
Fixes an information leak to userspace, we were handing out un-zeroed pages for any newly created TTM_PL_TT buffer. Reported-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Tested-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-08-31drm/ttm: add a way to bo_wait for either the last read or last writeMarek Olšák
Sometimes we want to know whether a buffer is busy and wait for it (bo_wait). However, sometimes it would be more useful to be able to query whether a buffer is busy and being either read or written, and wait until it's stopped being either read or written. The point of this is to be able to avoid unnecessary waiting, e.g. if a GPU has written something to a buffer and is now reading that buffer, and a CPU wants to map that buffer for read, it needs to only wait for the last write. If there were no write, there wouldn't be any waiting needed. This, or course, requires user space drivers to send read/write flags with each relocation (like we have read/write domains in radeon, so we can actually use those for something useful now). Now how this patch works: The read/write flags should passed to ttm_validate_buffer. TTM maintains separate sync objects of the last read and write for each buffer, in addition to the sync object of the last use of a buffer. ttm_bo_wait then operates with one the sync objects. Signed-off-by: Marek Olšák <maraeo@gmail.com> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-08-23drm/ttm: ensure ttm for new node is bound before calling move_notify()Ben Skeggs
This was true for new TTM_PL_SYSTEM and new TTM_PL_TT cases, but wasn't the case on TTM_PL_SYSTEM<->TTM_PL_TT moves, which causes trouble on some paths as nouveau's move_notify() hook requires that the dma addresses be valid at this point. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-08-23drm/ttm: unbind ttm before destroying node in accel move cleanupBen Skeggs
Nouveau makes the assumption that if a TTM is bound there will be a mm_node around for it and the backwards ordering here resulted in a use-after-free on some eviction paths. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-08-23drm/ttm: fix ttm_bo_add_ttm(user) failure pathMarcin Slusarz
ttm_tt_destroy kfrees passed object, so we need to nullify a reference to it. Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: stable@kernel.org Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-13Merge 3.0-rc7 into drm-core-nextDave Airlie
This pulls in all the drm fixes up to this point which are needed for some -next patches to work.
2011-06-27drm/ttm: use shmem_read_mapping_pageHugh Dickins
Soon tmpfs will stop supporting ->readpage and read_mapping_page(): once "tmpfs: add shmem_read_mapping_page_gfp" has been applied, this patch can be applied to ease the transition. ttm_tt_swapin() and ttm_tt_swapout() use shmem_read_mapping_page() in place of read_mapping_page(), since their swap_space has been created with shmem_file_setup(). Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Thomas Hellstrom <thellstrom@vmware.com> Cc: Dave Airlie <airlied@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-21ttm: Fix spelling mistakes and remove unused #ifdefKonrad Rzeszutek Wilk
. and some comments to make it easier to understand. Ackedby: Randy Dunlap <randy.dunlap@oracle.com> [v2: Added some more updates from Randy Dunlap] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-05-25vmscan: change shrinker API by passing shrink_control structYing Han
Change each shrinker's API by consolidating the existing parameters into shrink_control struct. This will simplify any further features added w/o touching each file of shrinker. [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: fix warning] [kosaki.motohiro@jp.fujitsu.com: fix up new shrinker API] [akpm@linux-foundation.org: fix xfs warning] [akpm@linux-foundation.org: update gfs2] Signed-off-by: Ying Han <yinghan@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-04-13Revert "ttm: Utilize the DMA API for pages that have TTM_PAGE_FLAG_DMA32 set."Dave Airlie
This reverts commit 69a07f0b117a40fcc1a479358d8e1f41793617f2. We've tracked a number of problems back to this, and Thomas thinks we should redesign this for .40/41 anyways so I'm happy to revert it. Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-10drm: minor kref_put() nitsPaul Bolle
There's no need to pass kref_put() the address of a function (just the function will do just fine) nor to cast its unused return to void. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-05drm: fix "persistant" typoJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-02-23Revert "ttm: Include the 'struct dev' when using the DMA API."Dave Airlie
This reverts commit 5a893fc28f0393adb7c885a871b8c59e623fd528. This causes a use after free in the ttm free alloc pages path, when it tries to get the be after the be has been destroyed. Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-02-23Merge branch 'stable/ttm.pci-api.v5' of ↵Dave Airlie
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen into drm-next * 'stable/ttm.pci-api.v5' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: ttm: Include the 'struct dev' when using the DMA API. nouveau/ttm/PCIe: Use dma_addr if TTM has set it. radeon/ttm/PCIe: Use dma_addr if TTM has set it. ttm: Expand (*populate) to support an array of DMA addresses. ttm: Utilize the DMA API for pages that have TTM_PAGE_FLAG_DMA32 set. ttm: Introduce a placeholder for DMA (bus) addresses.
2011-02-23drm/ttm: call driver move_notify() when doing system->tt bo movesBen Skeggs
Nouveau doesn't have enough information at ttm_backend_func.bind() time to implement things like tiled GART, or to keep a buffer at a constant address in the GPU virtual address space no matter where in physical memory it's placed. To resolve this, nouveau will handle binding of all buffers to the GPU itself from the move_notify() hook. This commit ensures it's called for all buffer moves. Talked to Dave about the impact on radeon, which uses move_notify, it doesn't look like anything should break there. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Reviewed-by: Thomas Hellstrom <thomas@shipmail.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-02-22ttm: Include the 'struct dev' when using the DMA API.Konrad Rzeszutek Wilk
This makes the accounting when using 'debug_dma_dump_mappings()' and CONFIG_DMA_API_DEBUG=y be assigned to the correct device instead of 'fallback'. No functional change - just cosmetic. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-01-27ttm: Expand (*populate) to support an array of DMA addresses.Konrad Rzeszutek Wilk
We pass in the array of ttm pages to be populated in the GART/MM of the card (or AGP). Patch titled: "ttm: Utilize the DMA API for pages that have TTM_PAGE_FLAG_DMA32 set." uses the DMA API to make those pages have a proper DMA addresses (in the situation where page_to_phys or virt_to_phys do not give use the DMA (bus) address). Since we are using the DMA API on those pages, we should pass in the DMA address to this function so it can save it in its proper fields (later patches use it). [v2: Added reviewed-by tag] Reviewed-by: Thomas Hellstrom <thellstrom@shipmail.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Tested-by: Ian Campbell <ian.campbell@citrix.com>
