commit ce020ea53264f1460ae619cfc12f968dbd0b8974 upstream.
The field obejct_idr of struct drm_via_private was introduced with the
commit http://git.kernel.org/?p=linux/kernel/git/torvalds/linux.git;a=commitdiff;h=77ee8f3825054f23b17e9c8f728f061defd86cdc .
In that patch idr_init(&dev->object_name_idr) was called instead of
idr_init(&dev_priv->object_idr) by mistake, leaving the dev_priv->object_idr
uninitialized. To be more exact, the object_idr buffer is filled with zeros
because of kzalloc(), but the dev_priv->object_idr.lock spinlock can cause
system freeze at lib/idr.c:move_to_free_list() when spin_lock_irqsave()
is called on this spinlock.
The patch was tested on Clevo D4J, model D410J laptop, on the following
hardware, without AGP kernel module loaded:
# lspci -s 01:00.0 -n
01:00.0 0300: 1106:3108 (rev 01)
# lspci -s 01:00.0 -v
01:00.0 VGA compatible controller: VIA Technologies, Inc. K8M800/K8N800/K8N800A [S3 UniChrome Pro] (rev 01) (prog-if 00 [VGA controller])
Subsystem: CLEVO/KAPOK Computer Device 4702
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 16
Memory at f0000000 (32-bit, prefetchable) [size=64M]
Memory at d1000000 (32-bit, non-prefetchable) [size=16M]
Expansion ROM at <unassigned> [disabled]
Capabilities: [60] Power Management version 2
Capabilities: [70] AGP version 3.0
Signed-off-by: Márton Németh <nm127@freemail.hu>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
The current enabling of bus mastering in the drm midlayer allows a large
race condition under kexec. When a kexec'ed kernel re-enables bus mastering
for the GPU, previously setup dma blocks may cause writes to random pieces
of memory. On radeon the writeback mechanism can cause these sorts of issues.
This patch doesn't fix the problem, but it moves the bus master enable under
the individual drivers control so they can move enabling it until later in
their load cycle and close the race.
Fix for radeon kms driver will be in a follow-up patch.
Fallout from my "kill drm_sman" refactor. Unfortunately gcc seems to
have failed me and not warned about this.
Tested-by: Jakob Bornecrantz <wallbraker@gmail.com> (on via)
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
To make the transition in a piece-wise and bisectable way possible,
I've hijacked the ->owner_list from drm_sman. While transitioning, the
list_add was done by the driver, while the list_del was still done by
the dying sman code.
Now that we are in full control of ->owner_list, do the list_del
ourselves.
v2: Better explain the list_del trickery as suggested by Chris Wilson.
Massive indirection through a hashtable for a simple key->pointer
look-up actually just adds bloat.
v2: Drop the misleading comment noted by Chris Wilson.
In contrast to kms drivers, sis/via _always_ associated a buffer with
a drm fd. So by the time we reach lastclose, all open drm fds are gone
and with them their associated objects.
So when sis/via call drm_sman_cleanup in their lastclose funcs, that
will free 0 objects.
The owner tracking now serves no purpose at all, hence rip it ou. We
can't kill the corresponding fields in struct drm_memblock_item yet
because we hijack these in the new driver private owner tracking. But
now that drm_sman.c doesn't touch ->owner_list anymore, we need to
kill the list_move hack and properly add the item to the file_priv
list.
Also leave the list_del(&obj->owner_list) in drm_sman_free for the
moment, it will move to the drivers when sman disappears completely.
v2: Remove the redundant INIT_LIST_HEAD as noted by Chris Wilson
Exactly like the previous patch for sis.
From fdf1fdebaa00f81de18c227f32f8074c8b352d50 Mon Sep 17 00:00:00 2001
Date: Sun, 30 Oct 2011 19:06:07 -0700
Subject: [PATCH] drm: Make the per-driver file_operations struct const
The DRM layer keeps a copy of struct file_operations inside its
big driver struct... which prevents it from being consistent and static.
For consistency (and the general security objective of having such things
static), it's desirable to get this fixed.
This patch splits out the file_operations field to its own struct,
which is then "static const", and just stick a pointer to this into
the driver struct, making it more consistent with how the rest of the
kernel does this.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
So that we don't get build failures once the implicit module.h
presence is removed.
This abstracts the pci/platform interface out a step further,
we can go further but this is far enough for now to allow USB
to be plugged in.
The drivers now just call the init code directly for their
device type.
Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (476 commits)
vmwgfx: Implement a proper GMR eviction mechanism
drm/radeon/kms: fix r6xx/7xx 1D tiling CS checker v2
drm/radeon/kms: properly compute group_size on 6xx/7xx
drm/radeon/kms: fix 2D tile height alignment in the r600 CS checker
drm/radeon/kms/evergreen: set the clear state to the blit state
drm/radeon/kms: don't poll dac load detect.
gpu: Add Intel GMA500(Poulsbo) Stub Driver
drm/radeon/kms: MC vram map needs to be >= pci aperture size
drm/radeon/kms: implement display watermark support for evergreen
drm/radeon/kms/evergreen: add some additional safe regs v2
drm/radeon/r600: fix tiling issues in CS checker.
drm/i915: Move gpu_write_list to per-ring
drm/i915: Invalidate the to-ring, flush the old-ring when updating domains
drm/i915/ringbuffer: Write the value passed in to the tail register
agp/intel: Restore valid PTE bit for Sandybridge after bdd3072
drm/i915: Fix flushing regression from 9af90d19f
drm/i915/sdvo: Remove unused encoding member
i915: enable AVI infoframe for intel_hdmi.c [v4]
drm/i915: Fix current fb blocking for page flip
drm/i915: IS_IRONLAKE is synonymous with gen == 5
Fix up conflicts in
- drivers/gpu/drm/i915/{i915_gem.c, i915/intel_overlay.c}: due to the
new simplified stack-based kmap_atomic() interface
- drivers/gpu/drm/vmwgfx/vmwgfx_drv.c: added .llseek entry due to BKL
removal cleanups.
The drm device drivers currently allow seeking on the
character device but never care about the actual
file position.
When we change the default llseek operation to be
no_llseek, calling llseek on a drm device would
return an error condition, which is an API change.
Explicitly setting noop_llseek lets us keep the
current API.
Cc: David Airlie <airlied@linux.ie>
Cc: dri-devel@lists.freedesktop.org
Every driver used the default implementation. Fold that one into
the only callsite and drop the callback.
All drivers happily copy&pasted the default implementation without
checking whether this callback is used at all. It's not. Sigh.
Kill it.
(v2)
With the current screwed but its ABI, ioctls for the drm, Linus pointed out that we could allow userspace to specify the allocation size, but we pass it to the driver which then uses it blindly to store a struct. Now if userspace specifies the allocation size as smaller than the driver needs, the driver can possibly overwrite memory.
This patch restructures the driver ioctls so we store the structure size we are expecting, and make sure we allocate at least that size. The copy from/to userspace are still restricted to the size the user specifies, this allows ioctl structs to grow on both sides of the equation.
Up until now we didn't really use the DRM_IOCTL defines in the kernel, so this cleans them up and adds them for nouveau.
v2:
fix nouveau pushbuf arg (thanks to Ben for pointing it out)
Reported-by: Linus Torvalds <torvalds@linuxfoundation.org>
Fixed brace, macro and spacing coding style issues.
Simplified
-if (ret) return ret;
-return 0;
+return ret;
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
* 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/radeon/kms/legacy: only enable load detection property on DVI-I
drm/radeon/kms: fix panel scaling adjusted mode setup
drivers/gpu/drm/drm_sysfs.c: sysfs files error handling
drivers/gpu/drm/radeon/radeon_atombios.c: range check issues
gpu: vga_switcheroo, fix lock imbalance
drivers/gpu/drm/drm_memory.c: fix check for end of loop
drivers/gpu/drm/via/via_video.c: fix off by one issue
drm/radeon/kms/agp The wrong AGP chipset can cause a NULL pointer dereference
drm/radeon/kms: r300 fix CS checker to allow zbuffer-only fastfill
"fx->lock" is used as the index in "dev_priv->decoder_queue[fx->lock]"
which is an array of "VIA_NR_XVMC_LOCKS" elements.
Acked-by: Thomas Hellstrom <thellstrom@vmware.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
In particular, several occurances of funny versions of 'success',
'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address',
'beginning', 'desirable', 'separate' and 'necessary' are fixed.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Joe Perches <joe@perches.com>
Cc: Junio C Hamano <gitster@pobox.com>
drm_ioctl is called with the Big Kernel Lock held,
which shows up very high in statistics on vfs_ioctl.
Moving the lock into the drm_ioctl function itself
makes sure we blame the right subsystem and it gets
us one step closer to eliminating the locked version
of fops->ioctl.
Since drm_ioctl does not require the lock itself,
we only need to hold it while calling the specific
handler. The 32 bit conversion handlers do not
interact with any other code, so they don't need
the BKL here either and can just call drm_ioctl.
As a bonus, this cleans up all the other users
of drm_ioctl which now no longer have to find
the inode or call lock_kernel.
[airlied: squashed the non-driver bits
of the second patch in here, this provides
the flag for drivers to use to select unlocked
ioctls - but doesn't modify any drivers].
Cc: dri-devel@lists.sourceforge.net
via_enable_vblank wasn't setting the VBlank enable bit - instead, it
was masking out the rest of the register.
At the same time, fix via_disable_vblank to clear the VBlank enable
bit.
Signed-off-by: Dave Airlie <airlied@linux.ie>
It hasn't been used in ages, and having the user tell your how much
memory is being freed at free time is a recipe for disaster even if it
was ever used.
Signed-off-by: Eric Anholt <eric@anholt.net>
vfree() does it's own NULL checking, no need for explicit check before
calling it.
Signed-off-by: Figo.zhang <figo1802@gmail.com>
With a postfix decrement in the test count will reach -1 rather than 0,
subsequent tests fail.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
The kernel shouldn't be in the business of telling user space which
driver to load. The kernel defers mapping PCI IDs to module names
to user space and we should do the same for DRI drivers.
And in fact, that's how it does work today. Nothing uses the
dri_library_name attribute, and the attribute is in fact broken.
For intel devices, it falls back to the default behaviour of returning
the kernel module name as the DRI driver name, which doesn't work for
i965 devices. Nobody has ever hit this problem or filed a bug about this.
Signed-off-by: Kristian Høgsberg <krh@redhat.com>
drm vblank initialization keeps track of the changes in driver-supplied
frame counts across vt switch and mode setting, but only if you let it by
not tearing down the drm vblank structure.
Signed-off-by: Keith Packard <keithp@keithp.com>
Like the last patch but adds a macro to get at the irq value instead of
dereferencing pdev directly. Should make things easier for the BSD guys and
if we ever support non-PCI devices.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Previously, drivers supporting vblank interrupt waits would run the interrupt
all the time, or all the time that any 3d client was running, preventing the
CPU from sleeping for long when the system was otherwise idle. Now, interrupts
are disabled any time that no client is waiting on a vblank event. The new
method uses vblank counters on the chipsets when the interrupts are turned
off, rather than counting interrupts, so that we can continue to present
accurate vblank numbers.
Co-author: Michel Dänzer <michel@tungstengraphics.com>
With the coming of kernel based modesetting and the memory manager stuff,
the everything in one directory approach was getting very ugly and
starting to be unmanageable.
This restructures the drm along the lines of other kernel components.
It creates a drivers/gpu/drm directory and moves the hw drivers into
subdirectores. It moves the includes into an include/drm, and
sets up the unifdef for the userspace headers we should be exporting.
