When tracking down a customer issue, it is useful to know exactly
which version of the vmwgfx they are using. Since vmware.log is
often the only available debug log, report vmwgfx version in there.
Signed-off-by: Sinclair Yeh <syeh@vmware.com>
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Initial DX support.
Co-authored with Sinclair Yeh, Charmaine Lee and Jakob Bornecrantz.
Signed-off-by: Charmaine Lee <charmainel@vmware.com>
Add support for the screen target device interface.
Add a getparam parameter and bump minor to signal availability.
Add command buffer support.
Currently we don't implement preemption or fancy error handling.
Tested with a couple of mesa-demos, compiz/unity and viewperf maya-03.
v2:
- Synchronize with pending work at command buffer manager takedown.
- Add an interface to flush the current command buffer for latency-critical
command batches and apply it to framebuffer dirtying.
v3:
- Minor fixes of definitions and typos to address reviews.
- Removed new or moved branch predictor hints.
Reviewed-by: Sinclair Yeh <syeh@vmware.com>
Contrary to the host-backed shader interface that has a per-context
name-space for shaders, the compat shader namespace was per client
(or rather, per file). Fix this so that the compat shader namespace is per
context, and at the same time, make command buffer managed context resource
management generic.
Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
Reviewed-by: Brian Paul <brianp@vmware.com>
Reviewed-by: Zack Rusin <zackr@vmware.com>
Implement MOB setup, binding and unbinding, but don't hook up to
TTM yet.
Also provide a completely dumb dma-buf ops implementation.
Once we have other virtual dma-buf aware devices, we need to provide
something better.
Add a resource-private header for common resource definitions
Reviewed-by: Dmitry Torokhov <dtor@vmware.com>
Signed-off-by: Jakob Bornecrantz <jakob@vmware.com>
Will be needed for queries and drm event-driven throttling.
As a benefit, they help avoid stale user-space fence handles.
This is needed before we introduce the fence objects.
Otherwise this will be even more confusing. The plan is to use the following:
seqno: A 32-bit sequence number that may be passed in the fifo.
marker: Objects, carrying a seqno, that track fifo submission time. They
are used for fifo lag based throttling.
fence objects: Kernel space objects, possibly accessible from user-space and
carrying a 32-bit seqno together with signaled status.
Use Ben's new range manager hooks to implement a manager for
GMRs that manages ids rather than ranges.
This means we can use the standard TTM code for binding, unbinding and
eviction.
The throttle_us member in the execbuf argument is now honored.
If the member is 0, no waiting for lag will occur, which
guarantees backwards compatibility with well-behaved clients.
This commit adds the vmwgfx driver for the VWware Virtual GPU aka SVGA.
The driver is under staging the same as Nouveau and Radeon KMS. Hopefully
the 2D ioctls are bug free and don't need changing, so that part of the
API should be stable. But there there is a pretty big chance that the 3D API
will change in the future.
Signed-off-by: Thomas Hellström <thellstrom@vmware.com>
