path: root/drivers/gpu/drm/vmwgfx/svga3d_reg.h
2014-03-02drm/vmwgfx: Remove some unused surface formatsThomas Hellstrom
These formats are deprecated. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Brian Paul <brianp@vmware.com>
2014-02-12drm/vmwgfx: Fix command defines and checksThomas Hellstrom
Make sure all guest-backed object commands are properly packed. Have the command verifier treat uninitialized command entries as invalid rather than dereferencing NULL pointers. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
2014-02-05drm/vmwgfx: Detect old user-space drivers and set up legacy emulation v2Thomas Hellstrom
GB aware mesa userspace drivers are detected by the fact that they are calling the vmw getparam ioctl querying DRM_VMW_PARAM_HW_CAPS to detect whether the device is Guest-backed object capable. For other drivers, lie about hardware version and send the 3D capabilities in a format they expect. v2: Use DRM_VMW_PARAM_MAX_MOB_MEMORY to detect gb awareness, Make sure we don't ovwerwrite bounce buffer or write past user-space buffer indicated size. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
2014-01-17drm/vmwgfx: Silence the device command verifierThomas Hellstrom
The device and kernel module disagrees about the command length of some commands. More pack attributes might be needed. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
2014-01-17drm/vmwgfx: Implement 64-bit Otable- and MOB binding v2Thomas Hellstrom
Adds the relevant commands to the device interface header and implements 64-bit binding for 64 bit VMs. v2: Uppercase command IDs, Correctly use also 64 bit page tables. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
2014-01-17drm/vmwgfx: Update otable definitionsThomas Hellstrom
Update otable definitions and modify the otable setup code accordingly. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
2014-01-17drm/vmwgfx: Update the svga3d register header file for new device versionThomas Hellstrom
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Brian Paul <brianp@vmware.com> Reviewed-by: Zack Rusin <zackr@vmware.com>
2011-10-05vmwgfx: Update register files to latest from vmware-sdkJakob Bornecrantz
Signed-off-by: Jakob Bornecrantz <jakob@vmware.com> Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-15drm/vmwgfx: Add svga headers for vmwgfx driverJakob Bornecrantz
These headers are shared between multiple place where different coding standards apply. They will be fixed up at a later time. Signed-off-by: Thomas Hellström <thellstrom@vmware.com> Signed-off-by: Jakob Bornecrantz <jakob@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
